I change my GPU power settings to maximum performance and enable freesync. When I log out or reboot, the settings revert back to auto and disabled.
How can I save these settings so that they persists across sessions?
Not sure about freesync, I thought that was enabled in the kernel by default but I could be way wrong on that. For performance mode I use this little script
#!/bin/bash
nvidia-settings -a “[gpu:0]/GpuPowerMizerMode=1”
I make it executable and add it to my start up programs to run at boot
I suggest you try this to save changes for nVidia GPU
(adjust performance and freesync settings rather than refresh rate in 2nd part)
save the settings you need in your home - then use nvidia-settings -l
at login
“nvidia-settings --load-config-only” is I think the correct string.
