Resolved HDMI video with these helpful steps: No HDMI output on either free or non-free
Found today however that no audio is available out through HDMI, it doesn’t appear to be a device option in settings.
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=403f112b-1702-45ed-a929-c45d3823ec77 rw quiet
cryptdevice=UUID=2ee7a1ba-8adb-4f6f-a13d-e555ed19d9bd:luks-2ee7a1ba-8adb-4f6f-a13d-e555ed19d9bd
root=/dev/mapper/luks-2ee7a1ba-8adb-4f6f-a13d-e555ed19d9bd apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: OMEN Laptop 15-en0xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8786 v: 22.54 serial: <filter> UEFI: AMI v: F.07
date: 09/16/2020
ID-1: BAT0 charge: 68.7 Wh (100.0%) condition: 68.7/68.7 Wh (100.0%)
volts: 12.9 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: Full cycles: 618
RAM: total: 15 GiB used: 5.83 GiB (38.9%)
Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600103 cache: L2: 4 MiB bogomips: 92661
Speed: 2755 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
1: 2755 2: 3084 3: 1694 4: 1741 5: 1539 6: 1793 7: 1491 8: 1397 9: 2718
10: 1904 11: 1542 12: 1587 13: 1500 14: 1907 15: 1490 16: 4066
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:2191 class-ID: 0300
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: Luxvisions Innotech Limited HP Wide Vision HD Camera type: USB
driver: uvcvideo bus-ID: 3-3:3 chip-ID: 30c9:000e class-ID: 0e02
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: HDMI-0 res: 2560x1440 hz: 75 dpi: 93 size: 697x393mm (27.4x15.5")
diag: 800mm (31.5")
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 06:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000
bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:4
Device-1: luks-2ee7a1ba-8adb-4f6f-a13d-e555ed19d9bd maj-min: 254:0
type: LUKS dm: dm-0 size: 790.16 GiB
Components:
p-1: nvme0n1p5 maj-min: 259:5 size: 790.16 GiB
Local Storage: total: 953.87 GiB used: 23.41 GiB (2.5%)
model: PC SN730 SDBPNTY-1T00-1006 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: HPS2 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 790.16 GiB size: 776.68 GiB (98.29%)
used: 23.36 GiB (3.0%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-2ee7a1ba-8adb-4f6f-a13d-e555ed19d9bd label: N/A
uuid: 403f112b-1702-45ed-a929-c45d3823ec77
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 60 MiB (23.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 18B8-834A
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 162.93 GiB fs: ntfs label: Windows
uuid: 9C34BA6134BA3DD8
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 511 MiB fs: ntfs
label: Windows RE tools uuid: 747E102D7E0FE6A8
Hub-1: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-2:5
info: Microsoft 2.4GHz Transceiver v8.0 used by mouse Wireless Desktop 900
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 045e:07b2 class-ID: 0300
Device-2: 3-3:3 info: Luxvisions Innotech Limited HP Wide Vision HD Camera
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 30c9:000e class-ID: 0e02
Device-3: 3-4:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 59.0 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 43 C device: amdgpu temp: 42.0 C
Processes: 401 Uptime: 20h 9m wakeups: 3 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1325 pacman: 1318 lib: 369
flatpak: 0 snap: 7 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.06
saw in some other threads modification to pulse rules, this is the current rule state… not clear to me if any of this is problematic.
# Remove NVIDIA USB xHCI Host Controller devices, if present
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c0330", ATTR{remove}="1"
# Remove NVIDIA USB Type-C UCSI devices, if present
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c8000", ATTR{remove}="1"
# Remove NVIDIA Audio devices, if present (enable it for kernels lower than 5.5)
#ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x040300", ATTR{remove}="1"
# Enable runtime PM for NVIDIA VGA/3D controller devices on driver bind
ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030000", TEST=="power/control", ATTR{power/control}="auto"
ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030200", TEST=="power/control", ATTR{power/control}="auto"
# Disable runtime PM for NVIDIA VGA/3D controller devices on driver unbind
ACTION=="unbind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030000", TEST=="power/control", ATTR{power/control}="on"
ACTION=="unbind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x030200", TEST=="power/control", ATTR{power/control}="on"
Welcome to Manjaro!
to give us more information so we can see what’s really going on.
this message and I’ll come back and have another look.
