Nvidia hdmi monitor wont turn back on after turn off, only unplug and plug HDMI cable back work
When I use a remote to turn off the tv, then turn it on, my pc just show blank screen, only unplug then plug the HDMI cabble work. While windows doesnt have this problem.
What I tried:
_nvidia 470/nvidia 470 open source
_manjaro kde
_manjara gnome barely work, sometime the screen res is return to 1024x768, sometime black screen, sometime display and function correctly
_ubuntu/kubuntu
Which is work:
_Unplug HDMI cable then plug black
_ctrl+alt+f2 then ctrl+alt+f1
inxi --admin --verbosity=7 --filter --width        ξ‚² βœ”
  Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
    root=UUID=f9f51562-4733-4eee-98e8-35260ba81546 rw rootflags=subvol=@ quiet
    apparmor=1 security=apparmor
    resume=UUID=e0e07350-b201-4396-a488-6f81b5315f33 udev.log_priority=3
  Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Mobo: ASUSTeK model: PRIME B560M-K v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 0820
    date: 04/27/2021
  Device-1: hidpp_battery_0 model: Logitech G604 Wireless Gaming Mouse
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: Discharging
  RAM: total: 15.47 GiB used: 4.69 GiB (30.3%)
  RAM Report:
  Info: model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP
    arch: Rocket Lake family: 6 model-id: 0xA7 (167) stepping: 1 microcode: 0x40
    L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 2020 high: 4224 min/max: 800/4400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 3136 7: 4213 8: 4200 9: 2877 10: 4224 11: 801 12: 800
    bogomips: 62232
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
    avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
    est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed
    rdtscp rep_good sdbg sep sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: Micro-Star MSI
    driver: nvidia v: 470.86 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
    chip-ID: 10de:1f08 class-ID: 0300
  Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
    loaded: nvidia resolution: <missing: xdpyinfo>
  Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:43c8 class-ID: 0403
  Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
    class-ID: 0403
  Device-3: Razer USA Razer BlackShark V2 Pro type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:3 chip-ID: 1532:0528
    class-ID: 0300
  Device-4: Thesycon System & Consulting D10 type: USB driver: snd-usb-audio
    bus-ID: 1-4:5 chip-ID: 152a:8750 class-ID: fe01
  Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 1-3.3:9 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
  Local Storage: total: 8.77 TiB used: 5.34 TiB (60.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: S5Z44101 temp: 38.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 type: SSD serial: <filter> rev: 2B2QGXA7 temp: 36.9 C scheme: MBR
  ID-3: /dev/sda maj-min: 8:0 vendor: Mushkin model: MKNSSDCR120GB-7
    size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: BBF0 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD60EFRX-68L0BN1 size: 5.46 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5700 serial: <filter>
    rev: 0A82 scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01 scheme: MBR
  ID-6: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST1000LM010-9YH146
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 5400 serial: <filter> rev: CC9F scheme: MBR
  ID-7: /dev/sde maj-min: 8:64 type: USB vendor: KingMAX
    model: USB2.0 FlashDisk size: 14.75 GiB block-size: physical: 512 B
    logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
  ID-1: / raw-size: 95.5 GiB size: 95.5 GiB (100.00%) used: 13.09 GiB (13.7%)
    fs: btrfs dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: f9f51562-4733-4eee-98e8-35260ba81546
    used: 568 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 64FD-E0A8
  ID-3: /home raw-size: 95.5 GiB size: 95.5 GiB (100.00%)
    used: 13.09 GiB (13.7%) fs: btrfs dev: /dev/sda3 maj-min: 8:3 label: N/A
  ID-4: /run/media/forted/Data0 raw-size: 5.46 TiB size: 5.46 TiB (100.00%)
    used: 5.33 TiB (97.6%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: Data0
    uuid: F4301DE6301DB09A
  ID-5: /var/cache raw-size: 95.5 GiB size: 95.5 GiB (100.00%)
  ID-6: /var/log raw-size: 95.5 GiB size: 95.5 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: e0e07350-b201-4396-a488-6f81b5315f33
  ID-1: /dev/nvme0n1p1 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
    uuid: BA54-4846
  ID-2: /dev/nvme0n1p2 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:5 size: 465.16 GiB fs: ntfs
    label: Windows11 uuid: 8EF668AFF66898EB
  ID-4: /dev/nvme0n1p4 maj-min: 259:6 size: 501 MiB fs: ntfs label: N/A
    uuid: 9ACC8874CC884C87
  ID-5: /dev/nvme1n1p1 maj-min: 259:4 size: 931.51 GiB fs: ntfs
    label: FastData0 uuid: 5A1EE3AD1EE37FFD
  ID-6: /dev/sdb2 maj-min: 8:18 size: 1.6 MiB fs: <superuser required>
  ID-7: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: ntfs label: Data1
    uuid: 66A29864A2983B0F
  ID-8: /dev/sdd1 maj-min: 8:49 size: 931.51 GiB fs: ntfs label: Data2
    uuid: 5EC48684C4865DE1
  ID-9: /dev/sde1 maj-min: 8:65 size: 3.56 GiB fs: iso9660
  ID-10: /dev/sde2 maj-min: 8:66 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 8D59-F16D
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-1:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c539 class-ID: 0300
  Device-2: 1-2:3 info: Razer USA Razer BlackShark V2 Pro type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 1532:0528 class-ID: 0300
  Hub-2: 1-3:4 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 2109:2817 class-ID: 0900
  Device-1: 1-3.1:7 info: Kingmax Digital USB2.0 FlashDisk
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
    speed: 480 Mb/s power: 200mA chip-ID: 1687:3257 class-ID: 0806
    serial: <filter>
  Device-2: 1-3.3:9 info: Realtek Bluetooth Radio type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
  Hub-3: 1-3.4:10 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s chip-ID: 2109:2817 class-ID: 0900
  Device-1: 1-4:5 info: Thesycon System & Consulting D10 type: Audio
    driver: snd-usb-audio interfaces: 3 rev: 2.0 speed: 480 Mb/s
  Device-2: 1-7:6 info: Apple Aluminium Keyboard (ANSI) type: Keyboard,Mouse
    driver: apple,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
    chip-ID: 05ac:024f class-ID: 0301
  Device-3: 1-8:8 info: American Power Conversion UPS type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 2mA
    chip-ID: 051d:0003 class-ID: 0300 serial: <filter>
  Hub-4: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 20 Gb/s
  Hub-5: 2-3:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
    chip-ID: 2109:0817 class-ID: 0900
  Hub-6: 2-3.4:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
  Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 31 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
  Processes: 357 Uptime: 7h 22m wakeups: 13 Init: systemd v: 249
  tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1264 lib: 341
  flatpak: 0 Shell: Zsh v: 5.8 running-in: kitty inxi: 3.3.11
xrandr        ξ‚² βœ”
Screen 0: minimum 8 x 8, current 3840 x 2160, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 1872mm x 1053mm
   3840x2160     60.00*+  59.94    50.00    29.97    25.00    23.98
   4096x2160     59.94    50.00    29.97    25.00    24.00    23.98
   1920x1080     60.00    59.94    50.00    29.97    25.00    23.98
   1680x1050     59.95
   1600x900      60.00
   1440x900      59.89
   1366x768      59.79
   1280x1024     75.02    60.02
   1280x800      59.81
   1280x720      60.00    59.94    50.00
   1152x864      75.00
   1024x768      75.03    70.07    60.00
   800x600       75.00    72.19    60.32
   720x576       50.00
   720x480       59.94
   640x480       75.00    72.81    59.94
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
[     4.385] (--) Log file renamed from "/var/log/Xorg.pid-683.log" to "/var/log/Xorg.0.log"
[     4.386]
X.Org X Server 1.21.1.2
[     4.386] Current Operating System: Linux ForteD-PCLi 5.15.7-1-MANJARO #1 SMP PREEMPT Wed Dec 8 10:09:19 UTC 2021 x86_64
[     4.386] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64 root=UUID=f9f51562-4733-4eee-98e8-35260ba81546 rw rootflags=subvol=@ quiet apparmor=1 security=apparmor resume=UUID=e0e07350-b201-4396-a488-6f81b5315f33 udev.log_priority=3
[     4.386]
[     4.386] Current version of pixman: 0.40.0
[     4.386] 	Before reporting problems, check http://wiki.x.org
[     4.386] Markers: (--) probed, (**) from config file, (==) default setting,
[     4.386] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Dec 27 11:59:14 2021
[     4.388] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     4.388] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     4.388] (==) ServerLayout "layout"
[     4.388] (**) |-->Screen "Screen0" (0)
[     4.388] (**) |   |-->Monitor "Monitor0"
[     4.388] (**) |   |-->Device "Device0"
[     4.388] (==) Automatically adding devices
[     4.388] (==) Automatically enabling devices
[     4.388] (==) Automatically adding GPU devices
[     4.388] (==) Automatically binding GPU devices
[     4.388] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     4.390] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     4.390] 	Entry deleted from font path.
[     4.390] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     4.390] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     4.390] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     4.390] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     4.390] (==) ModulePath set to "/usr/lib/xorg/modules"
[     4.390] (**) Extension "COMPOSITE" is enabled
[     4.390] (II) The server relies on udev to provide the list of input devices.
[     4.390] (II) Module ABI versions:
[     4.390] 	X.Org ANSI C Emulation: 0.4
[     4.390] 	X.Org Video Driver: 25.2
[     4.390] 	X.Org XInput driver : 24.4
[     4.390] 	X.Org Server Extension : 10.0
[     4.390] (++) using VT number 1
[     4.390] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     4.391] (II) xfree86: Adding drm device (/dev/dri/card0)
[     4.391] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[     4.391] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     4.391] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     4.392] (--) PCI:*(1@0:0:0) 10de:1f08:1462:3755 rev 161, Mem @ 0xa0000000/16777216, 0x4000000000/268435456, 0x4010000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[     4.392] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     4.392] (II) LoadModule: "glx"
[     4.393] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     4.400] (II) Module glx: vendor="X.Org Foundation"
[     4.400] 	compiled for 1.21.1.2, module version = 1.0.0
[     4.400] 	ABI class: X.Org Server Extension, version 10.0
[     4.400] (II) LoadModule: "nvidia"
[     4.400] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     4.410] (II) Module nvidia: vendor="NVIDIA Corporation"
[     4.410] 	compiled for 1.6.99.901, module version = 1.0.0
[     4.410] 	Module class: X.Org Video Driver
[     4.410] (II) NVIDIA dlloader X Driver  470.86  Tue Oct 26 21:53:29 UTC 2021
[     4.410] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     4.410] (II) Loading sub module "fb"
[     4.410] (II) LoadModule: "fb"
[     4.410] (II) Module "fb" already built-in
[     4.410] (II) Loading sub module "wfb"
[     4.410] (II) LoadModule: "wfb"
[     4.411] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     4.413] (II) Module wfb: vendor="X.Org Foundation"
[     4.413] 	compiled for 1.21.1.2, module version = 1.0.0
[     4.413] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     4.413] (II) Loading sub module "ramdac"
[     4.413] (II) LoadModule: "ramdac"
[     4.413] (II) Module "ramdac" already built-in
[     4.465] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[     4.465] (==) NVIDIA(0): RGB weight 888
[     4.465] (==) NVIDIA(0): Default visual is TrueColor
[     4.465] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[     4.465] (**) Option "AllowNVIDIAGpuScreens"
[     4.465] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[     4.465] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[     4.465] (**) NVIDIA(0): Enabling 2D acceleration
[     4.465] (II) Loading sub module "glxserver_nvidia"
[     4.465] (II) LoadModule: "glxserver_nvidia"
[     4.465] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[     4.520] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[     4.520] 	compiled for 1.6.99.901, module version = 1.0.0
[     4.520] 	Module class: X.Org Server Extension
[     4.520] (II) NVIDIA GLX Module  470.86  Tue Oct 26 21:51:04 UTC 2021
[     4.520] (II) NVIDIA: The X server supports PRIME Render Offload.
[     5.199] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[     5.199] (--) NVIDIA(0):     DFP-0
[     5.199] (--) NVIDIA(0):     DFP-1
[     5.199] (--) NVIDIA(0):     DFP-2
[     5.199] (--) NVIDIA(0):     DFP-3
[     5.199] (--) NVIDIA(0):     DFP-4 (boot)
[     5.199] (--) NVIDIA(0):     DFP-5
[     5.199] (--) NVIDIA(0):     DFP-6
[     5.200] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce RTX 2060 (TU106-A) at PCI:1:0:0
[     5.200] (II) NVIDIA(0):     (GPU-0)
[     5.200] (--) NVIDIA(0): Memory: 6291456 kBytes
[     5.200] (--) NVIDIA(0): VideoBIOS: 90.06.30.00.aa
[     5.200] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[     5.200] (--) NVIDIA(GPU-0): DFP-0: disconnected
[     5.200] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[     5.200] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[     5.200] (--) NVIDIA(GPU-0): DFP-1: disconnected
[     5.200] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[     5.200] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[     5.200] (--) NVIDIA(GPU-0): DFP-2: disconnected
[     5.200] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[     5.200] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[     5.200] (--) NVIDIA(GPU-0): DFP-3: disconnected
[     5.200] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[     5.200] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[     5.245] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[     5.245] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[     5.245] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[     5.245] (--) NVIDIA(GPU-0): DFP-5: disconnected
[     5.245] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[     5.245] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[     5.245] (--) NVIDIA(GPU-0): DFP-6: disconnected
[     5.245] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[     5.245] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[     5.316] (==) NVIDIA(0):
[     5.316] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[     5.316] (==) NVIDIA(0):     will be used as the requested mode.
[     5.316] (II) NVIDIA(0): Validated MetaModes:
[     5.316] (II) NVIDIA(0):     "DFP-4:nvidia-auto-select"
[     5.316] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 2160
[     5.387] (++) NVIDIA(0): DPI set to (144, 144); computed from -dpi X commandline option
[     5.388] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[     5.388] (II) NVIDIA:     access.
[     5.390] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[     5.390] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[     5.390] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[     5.390] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[     5.390] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[     5.390] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[     5.390] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[     5.390] (II) NVIDIA(0):     Config Options in the README.
[     5.402] (II) NVIDIA(0): Setting mode "DFP-4:nvidia-auto-select"
[     5.492] (==) NVIDIA(0): Disabling shared memory pixmaps
[     5.492] (==) NVIDIA(0): Backing store enabled
[     5.492] (==) NVIDIA(0): Silken mouse enabled
[     5.492] (**) NVIDIA(0): DPMS enabled
[     5.492] (WW) NVIDIA(0): Option "NoLogo" is not used
[     5.492] (II) Loading sub module "dri2"
[     5.492] (II) LoadModule: "dri2"
[     5.492] (II) Module "dri2" already built-in
[     5.492] (II) NVIDIA(0): [DRI2] Setup complete
[     5.492] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[     5.492] (II) Initializing extension Generic Event Extension
[     5.492] (II) Initializing extension SHAPE
[     5.492] (II) Initializing extension MIT-SHM
[     5.492] (II) Initializing extension XInputExtension
[     5.492] (II) Initializing extension XTEST
[     5.492] (II) Initializing extension BIG-REQUESTS
[     5.493] (II) Initializing extension SYNC
[     5.493] (II) Initializing extension XKEYBOARD
[     5.493] (II) Initializing extension XC-MISC
[     5.493] (II) Initializing extension SECURITY
[     5.493] (II) Initializing extension XFIXES
[     5.493] (II) Initializing extension RENDER
[     5.493] (II) Initializing extension RANDR
[     5.493] (II) Initializing extension COMPOSITE
[     5.493] (II) Initializing extension DAMAGE
[     5.493] (II) Initializing extension MIT-SCREEN-SAVER
[     5.493] (II) Initializing extension DOUBLE-BUFFER
[     5.493] (II) Initializing extension RECORD
[     5.493] (II) Initializing extension DPMS
[     5.493] (II) Initializing extension Present
[     5.493] (II) Initializing extension DRI3
[     5.493] (II) Initializing extension X-Resource
[     5.493] (II) Initializing extension XVideo
[     5.493] (II) Initializing extension XVideo-MotionCompensation
[     5.493] (II) Initializing extension GLX
[     5.493] (II) Indirect GLX disabled.
[     5.493] (II) GLX: Another vendor is already registered for screen 0
[     5.493] (II) Initializing extension XFree86-VidModeExtension
[     5.493] (II) Initializing extension XFree86-DGA
[     5.494] (II) Initializing extension XFree86-DRI
[     5.494] (II) Initializing extension DRI2
[     5.494] (II) Initializing extension NV-GLX
[     5.494] (II) Initializing extension NV-CONTROL
[     5.494] (II) Initializing extension XINERAMA
[     5.630] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[     5.630] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     5.630] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     5.630] (**) Power Button: Applying InputClass "system-keyboard"
[     5.630] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     5.630] (II) LoadModule: "libinput"
[     5.630] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     5.636] (II) Module libinput: vendor="X.Org Foundation"
[     5.636] 	compiled for 1.21.1, module version = 1.2.0
[     5.636] 	Module class: X.Org XInput Driver
[     5.636] 	ABI class: X.Org XInput driver, version 24.4
[     5.636] (II) Using input driver 'libinput' for 'Power Button'
[     5.636] (**) Power Button: always reports core events
[     5.636] (**) Option "Device" "/dev/input/event2"
[     5.636] (**) Option "_source" "server/udev"
[     5.641] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     5.641] (II) event2  - Power Button: device is a keyboard
[     5.642] (II) event2  - Power Button: device removed
[     5.678] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[     5.678] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     5.678] (**) Option "xkb_layout" "us"
[     5.678] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.697] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     5.697] (II) event2  - Power Button: device is a keyboard
[     5.698] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     5.698] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     5.698] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     5.698] (**) Power Button: Applying InputClass "system-keyboard"
[     5.698] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     5.698] (II) Using input driver 'libinput' for 'Power Button'
[     5.698] (**) Power Button: always reports core events
[     5.698] (**) Option "Device" "/dev/input/event1"
[     5.698] (**) Option "_source" "server/udev"
[     5.698] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     5.698] (II) event1  - Power Button: device is a keyboard
[     5.698] (II) event1  - Power Button: device removed
[     5.744] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[     5.744] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     5.744] (**) Option "xkb_layout" "us"
[     5.744] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.746] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     5.747] (II) event1  - Power Button: device is a keyboard
[     5.748] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[     5.748] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[     5.748] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[     5.748] (**) Sleep Button: Applying InputClass "system-keyboard"
[     5.748] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[     5.748] (II) Using input driver 'libinput' for 'Sleep Button'
[     5.748] (**) Sleep Button: always reports core events
[     5.748] (**) Option "Device" "/dev/input/event0"
[     5.748] (**) Option "_source" "server/udev"
[     5.750] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     5.750] (II) event0  - Sleep Button: device is a keyboard
[     5.750] (II) event0  - Sleep Button: device removed
[     5.771] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[     5.771] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[     5.771] (**) Option "xkb_layout" "us"
[     5.771] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.774] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     5.774] (II) event0  - Sleep Button: device is a keyboard
[     5.775] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
[     5.775] (II) No input driver specified, ignoring this device.
[     5.775] (II) This device may have been added with another device file.
[     5.776] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
[     5.776] (II) No input driver specified, ignoring this device.
[     5.776] (II) This device may have been added with another device file.
[     5.777] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
[     5.777] (II) No input driver specified, ignoring this device.
[     5.777] (II) This device may have been added with another device file.
[     5.778] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event11)
[     5.778] (II) No input driver specified, ignoring this device.
[     5.778] (II) This device may have been added with another device file.
[     5.778] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event12)
[     5.779] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event13)
[     5.779] (II) No input driver specified, ignoring this device.
[     5.779] (II) This device may have been added with another device file.
[     5.780] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event14)
[     5.780] (II) No input driver specified, ignoring this device.
[     5.780] (II) This device may have been added with another device file.
[     5.781] (II) config/udev: Adding input device Logitech G604  (/dev/input/event6)
[     5.781] (**) Logitech G604 : Applying InputClass "evdev pointer catchall"
[     5.781] (**) Logitech G604 : Applying InputClass "evdev keyboard catchall"
[     5.781] (**) Logitech G604 : Applying InputClass "libinput pointer catchall"
[     5.781] (**) Logitech G604 : Applying InputClass "libinput keyboard catchall"
[     5.781] (**) Logitech G604 : Applying InputClass "system-keyboard"
[     5.781] (**) Logitech G604 : Applying InputClass "Keyboard Defaults"
[     5.781] (II) Using input driver 'libinput' for 'Logitech G604 '
[     5.781] (**) Logitech G604 : always reports core events
[     5.782] (**) Option "Device" "/dev/input/event6"
[     5.782] (**) Option "_source" "server/udev"
[     5.784] (II) event6  - Logitech G604 : is tagged by udev as: Keyboard Mouse
[     5.785] (II) event6  - Logitech G604 : device is a pointer
[     5.785] (II) event6  - Logitech G604 : device is a keyboard
[     5.785] (II) event6  - Logitech G604 : device removed
[     5.811] (II) libinput: Logitech G604 : needs a virtual subdevice
[     5.811] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/0003:046D:C539.0003/0003:046D:4085.0005/input/input16/event6"
[     5.811] (II) XINPUT: Adding extended input device "Logitech G604 " (type: MOUSE, id 9)
[     5.811] (**) Option "AccelerationScheme" "none"
[     5.811] (**) Logitech G604 : (accel) selected scheme none/0
[     5.811] (**) Logitech G604 : (accel) acceleration factor: 2.000
[     5.811] (**) Logitech G604 : (accel) acceleration threshold: 4
[     5.812] (II) event6  - Logitech G604 : is tagged by udev as: Keyboard Mouse
[     5.813] (II) event6  - Logitech G604 : device is a pointer
[     5.813] (II) event6  - Logitech G604 : device is a keyboard
[     5.813] (II) config/udev: Adding input device Logitech G604  (/dev/input/mouse0)
[     5.813] (**) Logitech G604 : Applying InputClass "system-keyboard"
[     5.813] (**) Logitech G604 : Applying InputClass "Keyboard Defaults"
[     5.813] (II) No input driver specified, ignoring this device.
[     5.813] (II) This device may have been added with another device file.
[     5.814] (II) config/udev: Adding input device Razer Razer BlackShark V2 Pro (/dev/input/event5)
[     5.814] (II) No input driver specified, ignoring this device.
[     5.814] (II) This device may have been added with another device file.
[     5.814] (II) config/udev: Adding input device Razer Razer BlackShark V2 Pro Consumer Control (/dev/input/event3)
[     5.814] (**) Razer Razer BlackShark V2 Pro Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.815] (**) Razer Razer BlackShark V2 Pro Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.815] (**) Razer Razer BlackShark V2 Pro Consumer Control: Applying InputClass "system-keyboard"
[     5.815] (**) Razer Razer BlackShark V2 Pro Consumer Control: Applying InputClass "Keyboard Defaults"
[     5.815] (II) Using input driver 'libinput' for 'Razer Razer BlackShark V2 Pro Consumer Control'
[     5.815] (**) Razer Razer BlackShark V2 Pro Consumer Control: always reports core events
[     5.815] (**) Option "Device" "/dev/input/event3"
[     5.815] (**) Option "_source" "server/udev"
[     5.815] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: is tagged by udev as: Keyboard
[     5.815] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: device is a keyboard
[     5.815] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: device removed
[     5.892] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.3/0003:1532:0528.0004/input/input8/event3"
[     5.892] (II) XINPUT: Adding extended input device "Razer Razer BlackShark V2 Pro Consumer Control" (type: KEYBOARD, id 10)
[     5.892] (**) Option "xkb_layout" "us"
[     5.892] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.895] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: is tagged by udev as: Keyboard
[     5.895] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: device is a keyboard
[     5.897] (II) config/udev: Adding input device Razer Razer BlackShark V2 Pro (/dev/input/event4)
[     5.897] (II) No input driver specified, ignoring this device.
[     5.897] (II) This device may have been added with another device file.
[     5.898] (II) config/udev: Adding input device Keychron Keychron K3 (/dev/input/event21)
[     5.898] (**) Keychron Keychron K3: Applying InputClass "evdev keyboard catchall"
[     5.898] (**) Keychron Keychron K3: Applying InputClass "libinput keyboard catchall"
[     5.898] (**) Keychron Keychron K3: Applying InputClass "system-keyboard"
[     5.898] (**) Keychron Keychron K3: Applying InputClass "Keyboard Defaults"
[     5.898] (II) Using input driver 'libinput' for 'Keychron Keychron K3'
[     5.898] (**) Keychron Keychron K3: always reports core events
[     5.898] (**) Option "Device" "/dev/input/event21"
[     5.898] (**) Option "_source" "server/udev"
[     5.900] (II) event21 - Keychron Keychron K3: is tagged by udev as: Keyboard
[     5.900] (II) event21 - Keychron Keychron K3: device is a keyboard
[     5.900] (II) event21 - Keychron Keychron K3: device removed
[     5.918] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:05AC:024F.0006/input/input31/event21"
[     5.918] (II) XINPUT: Adding extended input device "Keychron Keychron K3" (type: KEYBOARD, id 11)
[     5.918] (**) Option "xkb_layout" "us"
[     5.918] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.918] (II) event21 - Keychron Keychron K3: is tagged by udev as: Keyboard
[     5.918] (II) event21 - Keychron Keychron K3: device is a keyboard
[     5.919] (II) config/udev: Adding input device Keychron Keychron K3 (/dev/input/event22)
[     5.919] (**) Keychron Keychron K3: Applying InputClass "evdev keyboard catchall"
[     5.919] (**) Keychron Keychron K3: Applying InputClass "libinput keyboard catchall"
[     5.919] (**) Keychron Keychron K3: Applying InputClass "system-keyboard"
[     5.919] (**) Keychron Keychron K3: Applying InputClass "Keyboard Defaults"
[     5.919] (II) Using input driver 'libinput' for 'Keychron Keychron K3'
[     5.919] (**) Keychron Keychron K3: always reports core events
[     5.919] (**) Option "Device" "/dev/input/event22"
[     5.919] (**) Option "_source" "server/udev"
[     5.919] (II) event22 - Keychron Keychron K3: is tagged by udev as: Keyboard
[     5.919] (II) event22 - Keychron Keychron K3: device is a keyboard
[     5.919] (II) event22 - Keychron Keychron K3: device removed
[     5.971] (II) libinput: Keychron Keychron K3: needs a virtual subdevice
[     5.971] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:05AC:024F.0007/input/input32/event22"
[     5.971] (II) XINPUT: Adding extended input device "Keychron Keychron K3" (type: MOUSE, id 12)
[     5.971] (**) Option "AccelerationScheme" "none"
[     5.971] (**) Keychron Keychron K3: (accel) selected scheme none/0
[     5.971] (**) Keychron Keychron K3: (accel) acceleration factor: 2.000
[     5.971] (**) Keychron Keychron K3: (accel) acceleration threshold: 4
[     5.974] (II) event22 - Keychron Keychron K3: is tagged by udev as: Keyboard
[     5.974] (II) event22 - Keychron Keychron K3: device is a keyboard
[     5.976] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event15)
[     5.976] (II) No input driver specified, ignoring this device.
[     5.976] (II) This device may have been added with another device file.
[     5.977] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event16)
[     5.977] (II) No input driver specified, ignoring this device.
[     5.977] (II) This device may have been added with another device file.
[     5.977] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event17)
[     5.978] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event18)
[     5.978] (II) No input driver specified, ignoring this device.
[     5.978] (II) This device may have been added with another device file.
[     5.979] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event19)
[     5.979] (II) No input driver specified, ignoring this device.
[     5.979] (II) This device may have been added with another device file.
[     5.980] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event20)
[     5.980] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[     5.980] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[     5.980] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[     5.980] (**) Eee PC WMI hotkeys: Applying InputClass "Keyboard Defaults"
[     5.980] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[     5.980] (**) Eee PC WMI hotkeys: always reports core events
[     5.980] (**) Option "Device" "/dev/input/event20"
[     5.980] (**) Option "_source" "server/udev"
[     5.981] (II) event20 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     5.981] (II) event20 - Eee PC WMI hotkeys: device is a keyboard
[     5.982] (II) event20 - Eee PC WMI hotkeys: device removed
[     6.027] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input30/event20"
[     6.027] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 13)
[     6.027] (**) Option "xkb_layout" "us"
[     6.027] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.028] (II) event20 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     6.028] (II) event20 - Eee PC WMI hotkeys: device is a keyboard
[     6.028] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[     6.028] (II) No input driver specified, ignoring this device.
[     6.028] (II) This device may have been added with another device file.
[     6.031] (**) Logitech G604 : Applying InputClass "evdev pointer catchall"
[     6.032] (**) Logitech G604 : Applying InputClass "evdev keyboard catchall"
[     6.032] (**) Logitech G604 : Applying InputClass "libinput pointer catchall"
[     6.032] (**) Logitech G604 : Applying InputClass "libinput keyboard catchall"
[     6.032] (**) Logitech G604 : Applying InputClass "system-keyboard"
[     6.032] (**) Logitech G604 : Applying InputClass "Keyboard Defaults"
[     6.032] (II) Using input driver 'libinput' for 'Logitech G604 '
[     6.032] (**) Logitech G604 : always reports core events
[     6.032] (**) Option "Device" "/dev/input/event6"
[     6.032] (**) Option "_source" "_driver/libinput"
[     6.032] (II) libinput: Logitech G604 : is a virtual subdevice
[     6.032] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/0003:046D:C539.0003/0003:046D:4085.0005/input/input16/event6"
[     6.032] (II) XINPUT: Adding extended input device "Logitech G604 " (type: KEYBOARD, id 14)
[     6.032] (**) Option "xkb_layout" "us"
[     6.032] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.032] (**) Keychron Keychron K3: Applying InputClass "evdev keyboard catchall"
[     6.032] (**) Keychron Keychron K3: Applying InputClass "libinput keyboard catchall"
[     6.032] (**) Keychron Keychron K3: Applying InputClass "system-keyboard"
[     6.032] (**) Keychron Keychron K3: Applying InputClass "Keyboard Defaults"
[     6.032] (II) Using input driver 'libinput' for 'Keychron Keychron K3'
[     6.032] (**) Keychron Keychron K3: always reports core events
[     6.032] (**) Option "Device" "/dev/input/event22"
[     6.032] (II) libinput: Keychron Keychron K3: is a virtual subdevice
[     6.032] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:05AC:024F.0007/input/input32/event22"
[     6.032] (II) XINPUT: Adding extended input device "Keychron Keychron K3" (type: KEYBOARD, id 15)
[     6.032] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[     6.032] (II) No input driver specified, ignoring this device.
[     6.032] (II) This device may have been added with another device file.
[     6.033] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event13)
[     6.033] (II) No input driver specified, ignoring this device.
[     6.033] (II) This device may have been added with another device file.
[     6.033] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event14)
[     6.033] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
[     6.033] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
[     6.033] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
[     6.034] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event12)
[     6.034] (II) No input driver specified, ignoring this device.
[     6.034] (II) This device may have been added with another device file.
[     6.034] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event11)
[     6.034] (II) config/udev: removing device Eee PC WMI hotkeys
[     6.034] (II) event20 - Eee PC WMI hotkeys: device removed
[     6.104] (II) UnloadModule: "libinput"
[     6.104] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event20)
[     6.104] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[     6.104] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[     6.104] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[     6.104] (**) Eee PC WMI hotkeys: Applying InputClass "Keyboard Defaults"
[     6.104] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[     6.104] (**) Eee PC WMI hotkeys: always reports core events
[     6.104] (**) Option "Device" "/dev/input/event20"
[     6.104] (**) Option "_source" "server/udev"
[     6.105] (II) event20 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     6.105] (II) event20 - Eee PC WMI hotkeys: device is a keyboard
[     6.105] (II) event20 - Eee PC WMI hotkeys: device removed
[     6.184] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input30/event20"
[     6.184] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 13)
[     6.184] (**) Option "xkb_layout" "us"
[     6.184] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.186] (II) event20 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     6.186] (II) event20 - Eee PC WMI hotkeys: device is a keyboard
[     6.189] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event16)
[     6.189] (II) No input driver specified, ignoring this device.
[     6.189] (II) This device may have been added with another device file.
[     6.189] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event19)
[     6.190] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event18)
[     6.190] (II) No input driver specified, ignoring this device.
[     6.190] (II) This device may have been added with another device file.
[     6.190] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event15)
[     6.191] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event17)
[     6.191] (II) No input driver specified, ignoring this device.
[     6.191] (II) This device may have been added with another device file.
[     6.193] (II) config/udev: Adding input device Logitech G604  (/dev/input/mouse0)
[     6.193] (**) Logitech G604 : Applying InputClass "system-keyboard"
[     6.193] (**) Logitech G604 : Applying InputClass "Keyboard Defaults"
[     6.193] (II) No input driver specified, ignoring this device.
[     6.193] (II) This device may have been added with another device file.
[     6.193] (II) config/udev: removing device Razer Razer BlackShark V2 Pro Consumer Control
[     6.193] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: device removed
[     6.261] (II) UnloadModule: "libinput"
[     6.262] (II) config/udev: Adding input device Razer Razer BlackShark V2 Pro Consumer Control (/dev/input/event3)
[     6.262] (**) Razer Razer BlackShark V2 Pro Consumer Control: Applying InputClass "evdev keyboard catchall"
[     6.262] (**) Razer Razer BlackShark V2 Pro Consumer Control: Applying InputClass "libinput keyboard catchall"
[     6.262] (**) Razer Razer BlackShark V2 Pro Consumer Control: Applying InputClass "system-keyboard"
[     6.262] (**) Razer Razer BlackShark V2 Pro Consumer Control: Applying InputClass "Keyboard Defaults"
[     6.262] (II) Using input driver 'libinput' for 'Razer Razer BlackShark V2 Pro Consumer Control'
[     6.262] (**) Razer Razer BlackShark V2 Pro Consumer Control: always reports core events
[     6.262] (**) Option "Device" "/dev/input/event3"
[     6.262] (**) Option "_source" "server/udev"
[     6.264] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: is tagged by udev as: Keyboard
[     6.264] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: device is a keyboard
[     6.265] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: device removed
[     6.384] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.3/0003:1532:0528.0004/input/input8/event3"
[     6.384] (II) XINPUT: Adding extended input device "Razer Razer BlackShark V2 Pro Consumer Control" (type: KEYBOARD, id 10)
[     6.384] (**) Option "xkb_layout" "us"
[     6.384] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.387] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: is tagged by udev as: Keyboard
[     6.388] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: device is a keyboard
[     6.388] (II) config/udev: removing device Logitech G604
[     6.388] (II) UnloadModule: "libinput"
[     6.389] (II) event6  - Logitech G604 : device removed
[     6.411] (II) UnloadModule: "libinput"
[     6.412] (II) config/udev: Adding input device Logitech G604  (/dev/input/event6)
[     6.412] (**) Logitech G604 : Applying InputClass "evdev pointer catchall"
[     6.412] (**) Logitech G604 : Applying InputClass "evdev keyboard catchall"
[     6.412] (**) Logitech G604 : Applying InputClass "libinput pointer catchall"
[     6.412] (**) Logitech G604 : Applying InputClass "libinput keyboard catchall"
[     6.412] (**) Logitech G604 : Applying InputClass "system-keyboard"
[     6.412] (**) Logitech G604 : Applying InputClass "Keyboard Defaults"
[     6.412] (II) Using input driver 'libinput' for 'Logitech G604 '
[     6.412] (**) Logitech G604 : always reports core events
[     6.412] (**) Option "Device" "/dev/input/event6"
[     6.413] (**) Option "_source" "server/udev"
[     6.415] (II) event6  - Logitech G604 : is tagged by udev as: Keyboard Mouse
[     6.416] (II) event6  - Logitech G604 : device is a pointer
[     6.416] (II) event6  - Logitech G604 : device is a keyboard
[     6.416] (II) event6  - Logitech G604 : device removed
[     6.464] (II) libinput: Logitech G604 : needs a virtual subdevice
[     6.464] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/0003:046D:C539.0003/0003:046D:4085.0005/input/input16/event6"
[     6.464] (II) XINPUT: Adding extended input device "Logitech G604 " (type: MOUSE, id 9)
[     6.465] (**) Option "AccelerationScheme" "none"
[     6.465] (**) Logitech G604 : (accel) selected scheme none/0
[     6.465] (**) Logitech G604 : (accel) acceleration factor: 2.000
[     6.465] (**) Logitech G604 : (accel) acceleration threshold: 4
[     6.468] (II) event6  - Logitech G604 : is tagged by udev as: Keyboard Mouse
[     6.468] (II) event6  - Logitech G604 : device is a pointer
[     6.468] (II) event6  - Logitech G604 : device is a keyboard
[     6.469] (**) Logitech G604 : Applying InputClass "evdev pointer catchall"
[     6.469] (**) Logitech G604 : Applying InputClass "evdev keyboard catchall"
[     6.469] (**) Logitech G604 : Applying InputClass "libinput pointer catchall"
[     6.469] (**) Logitech G604 : Applying InputClass "libinput keyboard catchall"
[     6.469] (**) Logitech G604 : Applying InputClass "system-keyboard"
[     6.469] (**) Logitech G604 : Applying InputClass "Keyboard Defaults"
[     6.469] (II) Using input driver 'libinput' for 'Logitech G604 '
[     6.469] (**) Logitech G604 : always reports core events
[     6.469] (**) Option "Device" "/dev/input/event6"
[     6.469] (**) Option "_source" "_driver/libinput"
[     6.469] (II) libinput: Logitech G604 : is a virtual subdevice
[     6.469] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.2/0003:046D:C539.0003/0003:046D:4085.0005/input/input16/event6"
[     6.469] (II) XINPUT: Adding extended input device "Logitech G604 " (type: KEYBOARD, id 14)
[     6.469] (**) Option "xkb_layout" "us"
[     6.469] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.471] (II) config/udev: Adding input device Razer Razer BlackShark V2 Pro (/dev/input/event4)
[     6.471] (II) No input driver specified, ignoring this device.
[     6.471] (II) This device may have been added with another device file.
[     6.472] (II) config/udev: Adding input device Razer Razer BlackShark V2 Pro (/dev/input/event5)
[     6.472] (II) No input driver specified, ignoring this device.
[     6.472] (II) This device may have been added with another device file.
[     6.473] (II) config/udev: removing device Keychron Keychron K3
[     6.473] (II) event21 - Keychron Keychron K3: device removed
[     6.504] (II) UnloadModule: "libinput"
[     6.506] (II) config/udev: Adding input device Keychron Keychron K3 (/dev/input/event21)
[     6.506] (**) Keychron Keychron K3: Applying InputClass "evdev keyboard catchall"
[     6.506] (**) Keychron Keychron K3: Applying InputClass "libinput keyboard catchall"
[     6.506] (**) Keychron Keychron K3: Applying InputClass "system-keyboard"
[     6.506] (**) Keychron Keychron K3: Applying InputClass "Keyboard Defaults"
[     6.506] (II) Using input driver 'libinput' for 'Keychron Keychron K3'
[     6.506] (**) Keychron Keychron K3: always reports core events
[     6.506] (**) Option "Device" "/dev/input/event21"
[     6.506] (**) Option "_source" "server/udev"
[     6.510] (II) event21 - Keychron Keychron K3: is tagged by udev as: Keyboard
[     6.511] (II) event21 - Keychron Keychron K3: device is a keyboard
[     6.512] (II) event21 - Keychron Keychron K3: device removed
[     6.558] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:05AC:024F.0006/input/input31/event21"
[     6.558] (II) XINPUT: Adding extended input device "Keychron Keychron K3" (type: KEYBOARD, id 11)
[     6.558] (**) Option "xkb_layout" "us"
[     6.558] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     6.561] (II) event21 - Keychron Keychron K3: is tagged by udev as: Keyboard
[     6.561] (II) event21 - Keychron Keychron K3: device is a keyboard
[     6.562] (II) config/udev: removing device Keychron Keychron K3
[     6.562] (II) UnloadModule: "libinput"
[     6.562] (II) event22 - Keychron Keychron K3: device removed
[     6.584] (II) UnloadModule: "libinput"
[     6.585] (II) config/udev: Adding input device Keychron Keychron K3 (/dev/input/event22)
[     6.586] (**) Keychron Keychron K3: Applying InputClass "evdev keyboard catchall"
[     6.586] (**) Keychron Keychron K3: Applying InputClass "libinput keyboard catchall"
[     6.586] (**) Keychron Keychron K3: Applying InputClass "system-keyboard"
[     6.586] (**) Keychron Keychron K3: Applying InputClass "Keyboard Defaults"
[     6.586] (II) Using input driver 'libinput' for 'Keychron Keychron K3'
[     6.586] (**) Keychron Keychron K3: always reports core events
[     6.586] (**) Option "Device" "/dev/input/event22"
[     6.586] (**) Option "_source" "server/udev"
[     6.588] (II) event22 - Keychron Keychron K3: is tagged by udev as: Keyboard
[     6.589] (II) event22 - Keychron Keychron K3: device is a keyboard
[     6.589] (II) event22 - Keychron Keychron K3: device removed
[     6.624] (II) libinput: Keychron Keychron K3: needs a virtual subdevice
[     6.624] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:05AC:024F.0007/input/input32/event22"
[     6.624] (II) XINPUT: Adding extended input device "Keychron Keychron K3" (type: MOUSE, id 12)
[     6.625] (**) Option "AccelerationScheme" "none"
[     6.625] (**) Keychron Keychron K3: (accel) selected scheme none/0
[     6.625] (**) Keychron Keychron K3: (accel) acceleration factor: 2.000
[     6.625] (**) Keychron Keychron K3: (accel) acceleration threshold: 4
[     6.627] (II) event22 - Keychron Keychron K3: is tagged by udev as: Keyboard
[     6.627] (II) event22 - Keychron Keychron K3: device is a keyboard
[     6.628] (**) Keychron Keychron K3: Applying InputClass "evdev keyboard catchall"
[     6.628] (**) Keychron Keychron K3: Applying InputClass "libinput keyboard catchall"
[     6.628] (**) Keychron Keychron K3: Applying InputClass "system-keyboard"
[     6.628] (**) Keychron Keychron K3: Applying InputClass "Keyboard Defaults"
[     6.628] (II) Using input driver 'libinput' for 'Keychron Keychron K3'
[     6.628] (**) Keychron Keychron K3: always reports core events
[     6.628] (**) Option "Device" "/dev/input/event22"
[     6.628] (**) Option "_source" "_driver/libinput"
[     6.629] (II) libinput: Keychron Keychron K3: is a virtual subdevice
[     6.629] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:05AC:024F.0007/input/input32/event22"
[     6.629] (II) XINPUT: Adding extended input device "Keychron Keychron K3" (type: KEYBOARD, id 15)
[     6.629] (**) Option "xkb_layout" "us"
[     6.629] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    14.063] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    14.063] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[    14.063] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[    14.063] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    14.063] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    14.063] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    14.063] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    14.063] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    14.063] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[    14.063] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    14.063] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    14.063] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    14.108] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[    14.108] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[    14.108] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[    14.108] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    14.108] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[    14.108] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[    14.108] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    14.108] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[    14.108] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[    14.656] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    14.656] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[    14.656] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[    14.657] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    14.657] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    14.657] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    14.657] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    14.657] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    14.657] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[    14.657] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    14.657] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    14.657] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    14.701] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[    14.701] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[    14.701] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[    14.701] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    14.701] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[    14.701] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[    14.702] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    14.702] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[    14.702] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[   920.237] (EE) event21 - Keychron Keychron K3: client bug: event processing lagging behind by 35ms, your system is too slow
[   938.079] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-7ms), your system is too slow
[   938.079] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-20ms), your system is too slow
[   960.776] (EE) event21 - Keychron Keychron K3: client bug: event processing lagging behind by 18ms, your system is too slow
[  1277.963] (EE) event21 - Keychron Keychron K3: client bug: event processing lagging behind by 22ms, your system is too slow
[  1282.778] (EE) event21 - Keychron Keychron K3: client bug: event processing lagging behind by 33ms, your system is too slow
[  1553.089] (EE) event6  - Logitech G604 : client bug: event processing lagging behind by 25ms, your system is too slow
[  1873.728] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-5ms), your system is too slow
[  1873.728] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-18ms), your system is too slow
[  1968.790] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-7ms), your system is too slow
[  2166.425] (EE) event21 - Keychron Keychron K3: client bug: event processing lagging behind by 14ms, your system is too slow
[  2166.425] (EE) event21 - Keychron Keychron K3: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[  2247.998] (EE) event6  - Logitech G604 : client bug: event processing lagging behind by 14ms, your system is too slow
[  2250.962] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-12ms), your system is too slow
[  2255.128] (EE) event6  - Logitech G604 : client bug: event processing lagging behind by 23ms, your system is too slow
[  2257.445] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
[  2308.319] (EE) event6  - Logitech G604 : client bug: event processing lagging behind by 34ms, your system is too slow
[  2311.458] (EE) event6  - Logitech G604 : client bug: event processing lagging behind by 20ms, your system is too slow
[  2311.458] (EE) event6  - Logitech G604 : WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[  2447.320] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[  2537.710] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[  2889.729] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-10ms), your system is too slow
[  2889.730] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-23ms), your system is too slow
[  3571.149] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-9ms), your system is too slow
[  3593.435] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-10ms), your system is too slow
[  3593.436] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-23ms), your system is too slow
[  3682.350] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-8ms), your system is too slow
[  3682.350] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-21ms), your system is too slow
[  3694.692] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-10ms), your system is too slow
[  3694.692] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-23ms), your system is too slow
[  3820.988] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
[  3987.103] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-1ms), your system is too slow
[  3987.104] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-14ms), your system is too slow
[  4081.776] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-6ms), your system is too slow
[  4081.776] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-19ms), your system is too slow
[ 19207.689] (--) NVIDIA(GPU-0): DFP-4: connected
[ 19207.689] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 19207.689] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 19207.849] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 19207.849] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 19207.849] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 19208.459] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 19208.459] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 19208.459] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 19208.503] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 19208.503] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 19208.503] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 19271.607] (II) event6  - Logitech G604 : SYN_DROPPED event - some input events have been lost.
[ 19271.607] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-24ms), your system is too slow
[ 19296.382] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 19296.382] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 19296.382] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 19296.425] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 19296.425] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 19296.425] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 19297.239] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 19297.239] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 19297.239] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 19297.282] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 19297.282] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 19297.282] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 19362.171] (--) NVIDIA(GPU-0): DFP-4: connected
[ 19362.171] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 19362.171] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 19362.293] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 19362.293] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 19362.293] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 19362.912] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 19362.912] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 19362.912] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 19362.956] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 19362.956] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 19362.956] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 25976.303] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 25976.303] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 25976.303] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 25976.350] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 25976.350] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 25976.350] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 25977.158] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 25977.158] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 25977.158] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 25977.203] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 25977.203] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 25977.203] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 26028.136] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 26028.136] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 26028.136] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 26028.828] (II) NVIDIA(0): Setting mode "NULL"
[ 26041.844] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 26041.844] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 26041.844] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 26042.678] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[ 26071.252] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
[ 26082.609] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-5ms), your system is too slow
[ 26082.609] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-18ms), your system is too slow
[ 26085.332] (EE) event6  - Logitech G604 : client bug: event processing lagging behind by 20ms, your system is too slow
[ 26085.332] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-8ms), your system is too slow
[ 26583.418] (EE) event6  - Logitech G604 : client bug: event processing lagging behind by 26ms, your system is too slow
[ 26604.075] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-2ms), your system is too slow
[ 26604.076] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-15ms), your system is too slow
[ 26687.824] (EE) event6  - Logitech G604 : client bug: event processing lagging behind by 12ms, your system is too slow
[ 26688.337] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 26712.356] (EE) event6  - Logitech G604 : client bug: event processing lagging behind by 27ms, your system is too slow
[ 26729.431] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-8ms), your system is too slow
[ 26729.432] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-21ms), your system is too slow
[ 26785.491] (EE) event6  - Logitech G604 : client bug: event processing lagging behind by 35ms, your system is too slow
[ 26785.491] (EE) event6  - Logitech G604 : WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 26785.934] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-10ms), your system is too slow
[ 26785.934] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-23ms), your system is too slow
[ 26792.326] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 26792.326] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 26792.326] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 26792.326] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 26792.326] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 26792.326] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 26792.326] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 26792.326] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 26792.326] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 26792.326] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 26792.326] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 26792.326] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 26792.370] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 26792.370] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 26792.370] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 26792.370] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 26792.370] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 26792.370] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 26792.370] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 26792.370] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 26792.370] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 26798.993] (EE) client bug: timer event6 debounce: scheduled expiry is in the past (-6ms), your system is too slow
[ 26798.993] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-20ms), your system is too slow
[ 26933.381] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[ 27460.426] (EE) client bug: timer event6 debounce short: scheduled expiry is in the past (-8ms), your system is too slow
[ 27501.102] (EE) event21 - Keychron Keychron K3: client bug: event processing lagging behind by 17ms, your system is too slow
[ 27520.238] (EE) event21 - Keychron Keychron K3: client bug: event processing lagging behind by 19ms, your system is too slow
[ 27574.465] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 27574.465] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 27574.465] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 27574.508] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 27574.508] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 27574.508] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 27575.301] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 27575.301] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 27575.301] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 27575.344] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 27575.344] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 27575.344] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 27617.199] (II) event2  - Power Button: device removed
[ 27617.248] (II) event1  - Power Button: device removed
[ 27617.273] (II) event0  - Sleep Button: device removed
[ 27617.315] (II) event20 - Eee PC WMI hotkeys: device removed
[ 27617.395] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: device removed
[ 27617.452] (II) event6  - Logitech G604 : device removed
[ 27617.488] (II) event21 - Keychron Keychron K3: device removed
[ 27617.528] (II) event22 - Keychron Keychron K3: device removed
[ 27623.020] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 27623.020] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 27623.020] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 27623.020] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 27623.020] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 27623.020] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 27623.020] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 27623.020] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 27623.020] (--) NVIDIA(GPU-0): DFP-2: 2660.0 MHz maximum pixel clock
[ 27623.020] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 27623.020] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[ 27623.020] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[ 27623.064] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): connected
[ 27623.064] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): Internal TMDS
[ 27623.064] (--) NVIDIA(GPU-0): SAMSUNG (DFP-4): 600.0 MHz maximum pixel clock
[ 27623.064] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 27623.064] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 27623.064] (--) NVIDIA(GPU-0): DFP-5: 2660.0 MHz maximum pixel clock
[ 27623.064] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 27623.064] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 27623.064] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 27623.122] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @3840x2160 +0+0 {ViewPortIn=3840x2160, ViewPortOut=3840x2160+0+0}"
[ 27623.149] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 27623.149] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[ 27623.149] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[ 27623.149] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[ 27623.149] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[ 27623.149] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[ 27623.149] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[ 27623.149] (II) NVIDIA(0):     Config Options in the README.
[ 27623.167] (II) event2  - Power Button: is tagged by udev as: Keyboard
[ 27623.167] (II) event2  - Power Button: device is a keyboard
[ 27623.167] (II) event1  - Power Button: is tagged by udev as: Keyboard
[ 27623.167] (II) event1  - Power Button: device is a keyboard
[ 27623.168] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[ 27623.168] (II) event0  - Sleep Button: device is a keyboard
[ 27623.168] (II) event20 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 27623.168] (II) event20 - Eee PC WMI hotkeys: device is a keyboard
[ 27623.169] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: is tagged by udev as: Keyboard
[ 27623.169] (II) event3  - Razer Razer BlackShark V2 Pro Consumer Control: device is a keyboard
[ 27623.170] (II) event6  - Logitech G604 : is tagged by udev as: Keyboard Mouse
[ 27623.170] (II) event6  - Logitech G604 : device is a pointer
[ 27623.170] (II) event6  - Logitech G604 : device is a keyboard
[ 27623.171] (II) event21 - Keychron Keychron K3: is tagged by udev as: Keyboard
[ 27623.171] (II) event21 - Keychron Keychron K3: device is a keyboard
[ 27623.172] (II) event22 - Keychron Keychron K3: is tagged by udev as: Keyboard
[ 27623.172] (II) event22 - Keychron Keychron K3: device is a keyboard
[ 28533.820] (EE) event6  - Logitech G604 : client bug: event processing lagging behind by 11ms, your system is too slow
[ 28534.707] (EE) event6  - Logitech G604 : client bug: event processing lagging behind by 12ms, your system is too slow
Not enough details. Neofech only has base info.
Thanks you, I missed that info
