Nvidia GTX 1650 and Ryzen 5 processor
Guys any solution to this proble my GPU is nvidia GTX 1650 and Ryzen 5 processor, Manjaro automatically installed video-hybrid-amd-nvidia-driver-450x-prime during installation process. When i installed latest nvidia driver and rebooted it is stuck in black screen I can use tty but No gui, Should i remove the latest driver?
Hello and welcome,
Moved to a proper help request topic, so you get dedicated assistance for your issue.
If you have a Desktop PC, disable the integrated GPU from BIOS and install the video-nvidia-450xx
Remove any other drivers before that.
Thanks for providing dedicated thread, i have UEFI system. Model:Asus TUF 505DT,Ryzen 5 Nvidia gtx 1650. How i will disable Integrated GPU?
So is a Laptop then. Please provide:
inxi -Fxza --no-host
and
mhwd -li
Use ``` above and bellow the text you paste here, from your terminal, for proper formatting.
If is with a Ryzen CPU and an Nvidia GPU, it can’t have an intel integrated GPU, so the
are totally off. Most likely it would require to see this:
hence install the video-hybrid-amd-nvidia-450xx-prime drivers.
sorry it was a typing mistake it was video-hybrid-amd-nvidia-450xx-prime drivers installed at beginning and i installed nvidia 450, which was successfully installed and after reboot i see black screen, no GUI.
please returns theses info
inxi -Fza
mhwd -li
how i am going to add link or image to post it is not accepting. I am in tty i can’t copy
For inxi always use text. Copy it from terminal and paste it here.
I am in dual boot now i am posting from windows, in linux it is with no gui so how will copy and paste. I can upload pictures but it is saying you cannot post with links
problems-with-amd-cpu-integrated-graphics-and-nvidia-gpu
ok so if found this thread while searching both of us use same Asus TUF 505dt model let me see his solution work or not
if nothing else works post photos of the screen :smiley:
that’s the problem, i am not able to post image directly or share imagur link it is saying links not allowed but my laptop is exactly same configuration posted in thread “problems-with-amd-cpu-integrated-graphics-and-nvidia-gpu”. I will do a fresh installation tomorrow and post relevant data
Put a spaces into the link until it’s no longer colored in the preview.
ok then
inxi -Fza:
https: // imgur . com/jU4cHVn
mhwd -li:
https: // imgur . com/bjUWtr5
You need to remove the video-nvidia-450xx configuration, and install the video-hybrid-amd-nvidia-450xx-prime configuration, since that is the correct one for your device.
sudo mhwd -r pci video-nvidia-450xx
sudo mhwd -i pci video-hybrid-amd-nvidia-450xx-prime
and then just reboot.
it is telling me to install dependencies video-linux when i type yes nothing happen should i i install it manually?
Yes, install it manually.
inxi -Fza
System:    Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
           parameters: ro root=/dev/nvme0n1p5   initrd=boot\initramfs-5.8-x86_64.img
           Desktop: i3 4.18.2 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0 serial: <filter>
           Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <filter> UEFI: American Megatrends
           v: FX505DT.310 date: 12/24/2019
Battery:   ID-1: BAT0 charge: 40.8 Wh condition: 40.8/48.2 Wh (85%) volts: 12.7/11.9 model: FX50442
           type: Li-ion serial: N/A status: Full
CPU:       Topology: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
           type: MT MCP arch: Zen+ family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108102
           L2 cache: 2048 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33551
           Speed: 1296 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1289 2: 1310
           3: 1224 4: 1226 5: 1224 6: 1226 7: 1224 8: 1226
           Type: spectre_v2
           mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics:  Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
           driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:1f91
           Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 05:00.0
           chip ID: 1002:15d8
           Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 3-1:2
           chip ID: 13d3:56a2 serial: <filter>
           Display: x11 server: X.Org 1.20.8 driver: modesetting
           alternate: ati,fbdev,nouveau,nv,vesa display ID: :0 screens: 1
           s-diag: 582mm (22.9")
           Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142 size: 344x194mm (13.5x7.6")
           diag: 395mm (15.5")
           OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.3-2-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.6
           direct render: Yes
Audio:     Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1
           chip ID: 10de:10fa
           Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 05:00.6 chip ID: 1022:15e3
           Sound Server: ALSA v: k5.8.3-2-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
           driver: r8169 v: kernel port: e000 bus ID: 02:00.0 chip ID: 10ec:8168
           Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: AzureWave
           driver: rtw_8822be v: N/A modules: rtw88_8822be port: d000 bus ID: 04:00.0
           chip ID: 10ec:b822
           IF: wlp4s0 state: up mac: <filter>
Drives:    Local Storage: total: 1.38 TiB used: 5.47 GiB (0.4%)
           ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB block size:
           physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 002C
           scheme: GPT
           ID-2: /dev/sda vendor: Toshiba model: HDWL110 size: 931.51 GiB block size:
           physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
           rev: 0A scheme: GPT
Partition: ID-1: / raw size: 142.00 GiB size: 138.77 GiB (97.73%) used: 5.46 GiB (3.9%) fs: ext4
           dev: /dev/nvme0n1p5
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 4.00 GiB used: 0 KiB (0.0%) priority: -2
           dev: /dev/nvme0n1p4
Sensors:   System Temperatures: cpu: 56.2 C mobo: N/A
           Fan Speeds (RPM): cpu: 2700
           GPU: device: amdgpu temp: 56 C device: nouveau temp: 42 C
Info:      Processes: 234 Uptime: 4m Memory: 7.28 GiB used: 1.12 GiB (15.4%) Init: systemd v: 246
           Compilers: gcc: 10.2.0 Packages: pacman: 961 lib: 216 Shell: Zsh v: 5.8
           running in: urxvtd inxi: 3.1.05 '''
 mhwd -li
Warning: No installed PCI configs!
mhwd -l
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:01:00.0 (0300:10de:1f91) Display controller nVidia Corporation:
video-hybrid-amd-nvidia-450xx-prime            2019.10.25               false            PCI
video-hybrid-amd-nvidia-440xx-prime            2019.10.25               false            PCI
video-hybrid-amd-nvidia-435xx-prime            2019.10.25               false            PCI
    video-nvidia-450xx            2019.10.25               false            PCI
    video-nvidia-440xx            2019.10.25               false            PCI
    video-nvidia-435xx            2019.10.25               false            PCI
    video-nvidia-430xx            2019.10.25               false            PCI
    video-nvidia-418xx            2019.10.25               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:05:00.0 (0300:1002:15d8) Display controller ATI Technologies Inc:
Please can anyone tell me which driver should i install? this is after fresh reinstall
redo this
sudo mhwd  -f -i pci video-hybrid-amd-nvidia-450xx-prime
then reboot
the last suppression from video-nvidia-450xx has deleted config nvidia for nouveau
