Hi there.
I switched from Kubuntu to Manjaro KDE a couple months ago and have enjoyed the experience until now. Suddenly my GTX 1050 is not detected. Not sure if this was caused by an update. Maybe when I installed an intel vulkan package, which let Yuzu run on my iGPU. But when I tried switching to nVidia using prime-plasma it didn’t work. I played around a bit and only got nVidia to show up in Settings Manager once. I thought it was a hardware issue, but…
Using a bootable PopOS image I have been able to detect the nvidia card
01:00.0 3D controller: NVIDIA Corporation GP107M [GeForce GTX 1050 Mobile] (rev a1)
mhwd -l -d INT ✘
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:3e9b)
Display controller Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630]
> INSTALLED:
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> AVAILABLE:
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
Warning: no configs for USB devices found!
sudo inxi -v7azy ![]()
Kernel: 5.15.72-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=8f780df1-123c-4f36-ba64-2245427b9396 rw quiet
udev.log_priority=3
Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Dell product: XPS 15 9570 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0JVFJ2 v: A00 serial: <filter> UEFI: Dell v: 1.18.1
date: 12/14/2020
ID-1: BAT0 charge: 41.5 Wh (58.2%) condition: 71.3/97.0 Wh (73.5%)
volts: 11.3 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
status: discharging
RAM: total: 30.98 GiB used: 1.4 GiB (4.5%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM A type: DDR4 detail: synchronous size: 16 GiB
speed: 2667 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
total: 64 manufacturer: 04CD000080AD part-no: F4-2666C18-16GRS serial: N/A
Device-2: DIMM B type: DDR4 detail: synchronous size: 16 GiB
Info: model: Intel Core i5-8300H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 921 high: 970 min/max: 800/4000 base/boost: 3366/4000
scaling: driver: intel_pstate governor: powersave volts: 1.0 V
ext-clock: 100 MHz cores: 1: 900 2: 900 3: 970 4: 952 5: 908 6: 900 7: 900
8: 940 bogomips: 36812
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
ports: active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:4 chip-ID: 0c45:671d class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: Sharp 0x148d built: 2018 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 3840x2160
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Sound API: ALSA v: k5.15.72-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks Killer Wireless-n/a/ac 1535 driver: ath10k_pci
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3b:00.0
chip-ID: 168c:003e class-ID: 0280 temp: 39.0 C
IF: wlp59s0 state: up mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
chip-ID: 0cf3:e301 class-ID: e001
Local Storage: total: 1.82 TiB used: 1.15 TiB (63.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P2SSD8
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P2CR031 temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 100d 20h cycles: 297 read-units: 8,969,000
[4.59 TB] written-units: 11,619,988 [5.94 TB]
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 23.84 GiB (24.9%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 8f780df1-123c-4f36-ba64-2245427b9396
ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%) used: 298 KiB
(0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 5E7B-D3D8
ID-3: /home raw-size: 1.53 TiB size: 1.51 TiB (98.36%) used: 1.13 TiB
(74.7%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3 maj-min: 259:3
label: home uuid: ec46ced5-45b4-4d90-bedb-d5aa1de43f23
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 195.31 GiB fs: N/A label: N/A
uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-4:2 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e301
class-ID: e001
Device-2: 1-7:3 info: Shenzhen Goodix Fingerprint Reader
type: Abstract (modem),CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5395 class-ID: 0a00
serial: <filter>
Device-3: 1-12:4 info: Microdia Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 46.0 C pch: 48.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2510 fan-2: 2483
Processes: 241 Uptime: 1m wakeups: 231 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1500 pm: dpkg pkgs: 0 pm: pacman pkgs: 1489 libs: 385 tools: pamac
pm: flatpak pkgs: 11 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.22
