thats what im using… i dont need to run nvidia, so this disables it, its not being detected … but switching between gpus requires a reboot… so its up to you …
I’m going to test my battery life but envycontrol is functioning fine so far. I like that it tells you to reboot instead of forcing you to logout. Often times optimus became unstable after logging out so I had to reboot anyway.
Still not sure what broke optimus but I’ll consider this problem solved. I only wish that the GTX 1050 Mobile was a turing line GPU, or Turing wasn’t required to power off nVidia graphics while in hybrid mode.
Thanks for all your help.
