Hi everybody. I’ve been using Manjaro for almost 1 year but I am facing a problem for a month - after started using Optimus Manager.
I tried to enable force full composition pipeline option in nvidia-settings but there is no advanced option for that. Actually, there are no advanced options at all.
Also, I tried to add option force full composition pipeline to my conf files (/etc/X11/xorg.conf.d/10-optimus-manager.conf and /etc/optimus-manager/xorg/nvidia-mode/nvidia-gpu.conf) but nothing changed.
And I tried to change using drivers in manjaro-settings-manager but nothing changed again.
What should I do? Is there any way to use Nvidia as primary GPU without any tearing or other problems? I even thought to switch to Windows because of this problem.
Please let me keep using Manjaro.
Best wishes.
My system information is like this:
Kernel: 5.18.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=3e96a7f7-9525-4c97-9b6e-f4d975a8f54a rw udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX505DT.316 date: 01/28/2021
ID-1: BAT0 charge: 39.9 Wh (100.0%) condition: 39.9/48.1 Wh (83.0%)
volts: 12.6 min: 11.7 model: FX50442 type: Li-ion serial: N/A status: full
RAM: total: 5.73 GiB used: 2.7 GiB (47.2%)
RAM Report:
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 built: 2019 process: GF 12nm
family: 0x17 (23) model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1254 high: 1342 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1342 2: 1232
3: 1224 4: 1221 5: 1222 6: 1222 7: 1321 8: 1255 bogomips: 33550
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 470.129.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f91
class-ID: 0300
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN 5 process: GF 14nm
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: none bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP-1-1 model: Najing CEC Panda 0x002d
built: 2018 res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 470.129.06 direct render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.18.12-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 04:00.0
chip-ID: 10ec:c821 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 13d3:3530 class-ID: e001 serial: <filter>
Local Storage: total: 1.14 TiB used: 150.94 GiB (12.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3256GJ3 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: E8FK11.T temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: SDM4 scheme: GPT
ID-1: / raw-size: 227.47 GiB size: 222.84 GiB (97.97%)
used: 13.93 GiB (6.3%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 3e96a7f7-9525-4c97-9b6e-f4d975a8f54a
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 312 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 3B3F-1EFB
ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
used: 136.99 GiB (15.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 6eb81d20-5724-4a90-a8d3-834b566bdd3e
ID-1: swap-1 type: partition size: 10 GiB used: 22.5 MiB (0.2%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: b480c900-d377-438d-b89b-2215526ce2af
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:2 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
Device-2: 1-4:3 info: IMC Networks Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Hub-4: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A
Fan Speeds (RPM): cpu: 5700
GPU: device: nvidia screen: :0.0 temp: 46 C device: amdgpu temp: 65.0 C
Processes: 279 Uptime: 46m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: 1317 pacman: 1309 lib: 366 flatpak: 0 snap: 8 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.19
