Hello,
Here is some input about my laptop.
inxi -G
Graphics: Device-1: Intel UHD Graphics driver: i915 v: kernel
Device-2: NVIDIA TU104GLM [Quadro RTX 5000 Mobile / Max-Q] driver: N/A
Device-3: Quanta HP HD Camera type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: llvmpipe (LLVM 12.0.0 256 bits) v: 4.5 Mesa 21.1.2
mhwd --listinstalled
Warning: No installed PCI configs!
mhwd-kernel --listinstalled
Currently running: 5.11.22-2-MANJARO (linux511)
* linux511
I have been following the forum post (Nvidia Drivers Not Working) to install Nvidia drivers on Manjaro. On running the following command
sudo mhwd -f -i pci video-nvidia
I get the following error
> Installing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core is up to date
extra is up to date
community is up to date
multilib is up to date
resolving dependencies...
Packages (3) lib32-nvidia-utils-465.31-1 linux511-nvidia-465.31-3 nvidia-utils-465.31-1
Total Installed Size: 526.94 MiB
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
error: failed to commit transaction (conflicting files)
nvidia-utils: /usr/bin/nvidia-bug-report.sh exists in filesystem
nvidia-utils: /usr/bin/nvidia-cuda-mps-control exists in filesystem
nvidia-utils: /usr/bin/nvidia-cuda-mps-server exists in filesystem
nvidia-utils: /usr/bin/nvidia-debugdump exists in filesystem
nvidia-utils: /usr/bin/nvidia-modprobe exists in filesystem
nvidia-utils: /usr/bin/nvidia-persistenced exists in filesystem
nvidia-utils: /usr/bin/nvidia-settings exists in filesystem
nvidia-utils: /usr/bin/nvidia-smi exists in filesystem
nvidia-utils: /usr/bin/nvidia-xconfig exists in filesystem
nvidia-utils: /usr/lib/libEGL_nvidia.so.0 exists in filesystem
nvidia-utils: /usr/lib/libGLESv1_CM_nvidia.so.1 exists in filesystem
nvidia-utils: /usr/lib/libGLESv2_nvidia.so.2 exists in filesystem
nvidia-utils: /usr/lib/libGLX_nvidia.so.0 exists in filesystem
nvidia-utils: /usr/lib/libcuda.so exists in filesystem
nvidia-utils: /usr/lib/libcuda.so.1 exists in filesystem
nvidia-utils: /usr/lib/libnvcuvid.so exists in filesystem
nvidia-utils: /usr/lib/libnvcuvid.so.1 exists in filesystem
nvidia-utils: /usr/lib/libnvidia-cfg.so exists in filesystem
nvidia-utils: /usr/lib/libnvidia-cfg.so.1 exists in filesystem
nvidia-utils: /usr/lib/libnvidia-encode.so exists in filesystem
nvidia-utils: /usr/lib/libnvidia-encode.so.1 exists in filesystem
nvidia-utils: /usr/lib/libnvidia-fbc.so exists in filesystem
nvidia-utils: /usr/lib/libnvidia-fbc.so.1 exists in filesystem
nvidia-utils: /usr/lib/libnvidia-ifr.so exists in filesystem
nvidia-utils: /usr/lib/libnvidia-ifr.so.1 exists in filesystem
nvidia-utils: /usr/lib/libnvidia-ml.so exists in filesystem
nvidia-utils: /usr/lib/libnvidia-ml.so.1 exists in filesystem
nvidia-utils: /usr/lib/libnvidia-opticalflow.so exists in filesystem
nvidia-utils: /usr/lib/libnvidia-opticalflow.so.1 exists in filesystem
nvidia-utils: /usr/lib/libnvidia-ptxjitcompiler.so exists in filesystem
nvidia-utils: /usr/lib/libnvidia-ptxjitcompiler.so.1 exists in filesystem
nvidia-utils: /usr/lib/libnvoptix.so.1 exists in filesystem
nvidia-utils: /usr/lib/vdpau/libvdpau_nvidia.so.1 exists in filesystem
nvidia-utils: /usr/lib/xorg/modules/drivers/nvidia_drv.so exists in filesystem
nvidia-utils: /usr/share/applications/nvidia-settings.desktop exists in filesystem
nvidia-utils: /usr/share/glvnd/egl_vendor.d/10_nvidia.json exists in filesystem
nvidia-utils: /usr/share/man/man1/nvidia-cuda-mps-control.1.gz exists in filesystem
nvidia-utils: /usr/share/man/man1/nvidia-modprobe.1.gz exists in filesystem
nvidia-utils: /usr/share/man/man1/nvidia-persistenced.1.gz exists in filesystem
nvidia-utils: /usr/share/man/man1/nvidia-settings.1.gz exists in filesystem
nvidia-utils: /usr/share/man/man1/nvidia-smi.1.gz exists in filesystem
nvidia-utils: /usr/share/man/man1/nvidia-xconfig.1.gz exists in filesystem
lib32-nvidia-utils: /usr/lib32/libEGL_nvidia.so.0 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libGLESv1_CM_nvidia.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libGLESv2_nvidia.so.2 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libGLX_nvidia.so.0 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libcuda.so exists in filesystem
lib32-nvidia-utils: /usr/lib32/libcuda.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvcuvid.so exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvcuvid.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-encode.so exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-encode.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-fbc.so exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-fbc.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ifr.so exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ifr.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ml.so exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ml.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-opticalflow.so exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-opticalflow.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ptxjitcompiler.so exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ptxjitcompiler.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/vdpau/libvdpau_nvidia.so.1 exists in filesystem
Error: pacman failed!
Error: script failed!
Please help. Thank you for your support.
