Nvidia drivers don't work
I have tried both the Open Source and proprietary drivers in my HP Laptop and neither make use of the GPU. (Steam survey either shows only the Intel integrated graphics or a unusable GPU with inaccesible VRAM)
However, Linux Mint installed in the same hardware does work and provides all the hardware functionality.
I also have the same (unsolved) problem as in this thread
Nvidia Settings is missing most if not all the important options.
Therefore, following this tutorial is basically impossible:
Now that I can post links I will add images to this post showing the exact problem
EDIT
My hardware
  Kernel: 5.10.63-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=fed2816e-5f83-42bb-b6c6-8e1af0a5da9e rw quiet apparmor=1
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: cairo-dock wm: kwin_x11 vt: 1
  Type: Laptop System: Hewlett-Packard product: HP ENVY 15 Notebook PC
  v: 0980110000405F10000310100 serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: Hewlett-Packard model: 22A0 v: KBC Version 83.0B serial: <filter>
  UEFI: Insyde v: F.13 date: 05/27/2014
  ID-1: BAT0 charge: 43.5 Wh (100.0%) condition: 43.5/43.5 Wh (100.0%)
  volts: 12.5 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
  serial: <filter> status: Full
  RAM: total: 11.62 GiB used: 2.01 GiB (17.3%)
  Info: Quad Core model: Intel Core i7-4712HQ bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
  L2: 6 MiB bogomips: 36731
  Speed: 2295 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 2295 2: 2295
  3: 2295 4: 2300 5: 2295 6: 2301 7: 2296 8: 2298
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
  clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
  dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
  fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
  monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
  pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
  sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
  xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: Intel 4th Gen Core Processor Integrated Graphics
  vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
  chip-ID: 8086:0416 class-ID: 0300
  Device-2: NVIDIA GM107M [GeForce GTX 850M] vendor: Hewlett-Packard
  driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1391 class-ID: 0302
  Device-3: Chicony HP Truevision HD type: USB driver: uvcvideo bus-ID: 3-7:3
  chip-ID: 04f2:b40d class-ID: 0e02
  loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :0
  screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
  v: 4.5 Mesa 21.2.1 compat-v: 3.0 direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  chip-ID: 8086:0c0c class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  chip-ID: 8086:8c20 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.63-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.35 running: no
  Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel port: 5000
  bus-ID: 07:00.0 chip-ID: 8086:08b1 class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 0f:00.0
  bus-ID: 1-1.1:3 chip-ID: 8087:07dc class-ID: e001
  Local Storage: total: 931.51 GiB used: 218.43 GiB (23.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-60JC3T0
  type: HDD rpm: 5400 serial: <filter> rev: 1A01 scheme: GPT
  ID-1: / raw-size: 62.82 GiB size: 61.53 GiB (97.95%) used: 47.82 GiB (77.7%)
  fs: ext4 dev: /dev/sda8 maj-min: 8:8 label: N/A
  uuid: fed2816e-5f83-42bb-b6c6-8e1af0a5da9e
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 105.4 MiB (41.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 5C64-5466
  ID-3: /mnt/Datos raw-size: 474.37 GiB size: 474.37 GiB (100.00%)
  used: 170.51 GiB (35.9%) fs: ntfs dev: /dev/sda6 maj-min: 8:6 label: Datos
  uuid: 054D211F78D82F2C
  ID-1: swap-1 type: partition size: 11.44 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda5 maj-min: 8:5 label: N/A
  uuid: 2bae34ba-de00-4b89-8cdc-69465e42d6b6
  ID-1: /dev/sda1 maj-min: 8:1 size: 650 MiB fs: ntfs label: WINRE
  uuid: DA76BADB76BAB819
  ID-2: /dev/sda3 maj-min: 8:3 size: 128 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-3: /dev/sda4 maj-min: 8:4 size: 78.06 GiB fs: ntfs label: N/A
  uuid: A8285A2E2859FBAE
  ID-4: /dev/sda7 maj-min: 8:7 size: 140.62 GiB fs: ext4 label: N/A
  uuid: cec19290-a9fd-45d5-9729-aedc96f7de2e
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Device-1: 1-1.1:3 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
  Hub-6: 3-4:2 info: Genesys Logic USB2.0 Hub ports: 4 rev: 2.0
  speed: 480 Mb/s power: 100mA chip-ID: 05e3:0618 class-ID: 0900
  Device-1: 3-4.1:4 info: Genesys Logic USB Storage type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 98mA
  chip-ID: 05e3:0752 class-ID: 0806
  Device-2: 3-4.4:5 info: [Maxxter] USB GAMING MOUSE type: Mouse,Keyboard
  power: 100mA chip-ID: 18f8:1286 class-ID: 0300
  Device-3: 3-7:3 info: Chicony HP Truevision HD type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b40d
  class-ID: 0e02
  Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 58.0 C mobo: 58.0 C
  Processes: 265 Uptime: 3m wakeups: 1 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: 1488 pacman: 1474 lib: 430 flatpak: 14
  Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Yes, they do. Please edit your topic to reflect the issue
Please see: Forum Rules - Manjaro
Help us help you. You never did post what was asked of you.
Done. Sorry, I have to reboot between Mint and Manjaro so I forgot this.
Not for me. At least not out of the box. And I am worried about the future. I can’t buy new hardware:
Hello @Josue :wink:
Nvidia does work, but look here:
Since the Nvidia card is not configured for xorg, there will be no other option. Intel is auto configured as main and nvidia is just there for offloading by default.
So can you post the linux mint xorg configuration file?
Strange. In Mint it shows exactly the same thing in that screen:
it says “Display Devices: None” in both Manjaro and Mint.
@Josue
This information is needed:
export configs=( "/etc/X11/xorg.conf" "/etc/X11/xorg.conf.d/*.conf" "/etc/modprobe.d/*.conf" "/etc/modules-load.d/*.conf" )
for x in ${configs[@]}; do echo -e "\n---$x---\n$(cat $x)"; done
export logs=( "/var/log/Xorg*.log" "$HOME/.local/share/xorg/Xorg*.log" )
for x in ${logs[@]}; do echo -e "\n---$x---\n$(cat $x)"; done
You mean this from Linux Mint, right?
Result is this
---/etc/X11/xorg.conf---
Section "ServerLayout"
    Identifier "layout"
    Screen 0 "nvidia"
    Inactive "intel"
EndSection
Section "Device"
    Identifier "intel"
    Driver "modesetting"
    BusID "PCI:0@0:2:0"
    Option "AccelMethod" "None"
EndSection
Section "Screen"
    Identifier "intel"
    Device "intel"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:1@0:0:0"
    Option "ConstrainCursor" "off"
EndSection
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
    Option "AllowEmptyInitialConfiguration" "on"
    Option "IgnoreDisplayDevices" "CRT"
EndSection
cat: '/etc/X11/xorg.conf.d/*.conf': No existe el archivo o el directorio
---/etc/X11/xorg.conf.d/*.conf---
---/etc/modprobe.d/alsa-base.conf---
# autoloader aliases
install sound-slot-0 /sbin/modprobe snd-card-0
install sound-slot-1 /sbin/modprobe snd-card-1
install sound-slot-2 /sbin/modprobe snd-card-2
install sound-slot-3 /sbin/modprobe snd-card-3
install sound-slot-4 /sbin/modprobe snd-card-4
install sound-slot-5 /sbin/modprobe snd-card-5
install sound-slot-6 /sbin/modprobe snd-card-6
install sound-slot-7 /sbin/modprobe snd-card-7
# Cause optional modules to be loaded above generic modules
install snd /sbin/modprobe --ignore-install snd $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-ioctl32 ; /sbin/modprobe --quiet --use-blacklist snd-seq ; }
# Workaround at bug #499695 (reverted in Ubuntu see LP #319505)
install snd-pcm /sbin/modprobe --ignore-install snd-pcm $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-pcm-oss ; : ; }
install snd-mixer /sbin/modprobe --ignore-install snd-mixer $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-mixer-oss ; : ; }
install snd-seq /sbin/modprobe --ignore-install snd-seq $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq-midi ; /sbin/modprobe --quiet --use-blacklist snd-seq-oss ; : ; }
install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq-midi ; : ; }
# Cause optional modules to be loaded above sound card driver modules
install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-emu10k1-synth ; }
install snd-via82xx /sbin/modprobe --ignore-install snd-via82xx $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq ; }
# Load saa7134-alsa instead of saa7134 (which gets dragged in by it anyway)
install saa7134 /sbin/modprobe --ignore-install saa7134 $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist saa7134-alsa ; : ; }
# Prevent abnormal drivers from grabbing index 0
options bt87x index=-2
options cx88_alsa index=-2
options saa7134-alsa index=-2
options snd-atiixp-modem index=-2
options snd-intel8x0m index=-2
options snd-via82xx-modem index=-2
options snd-usb-audio index=-2
options snd-usb-caiaq index=-2
options snd-usb-ua101 index=-2
options snd-usb-us122l index=-2
options snd-usb-usx2y index=-2
# Ubuntu #62691, enable MPU for snd-cmipci
options snd-cmipci mpu_port=0x330 fm_port=0x388
# Keep snd-pcsp from being loaded as first soundcard
options snd-pcsp index=-2
# Keep snd-usb-audio from beeing loaded as first soundcard
---/etc/modprobe.d/blacklist-ath_pci.conf---
# For some Atheros 5K RF MACs, the madwifi driver loads buts fails to
# correctly initialize the hardware, leaving it in a state from
# which ath5k cannot recover. To prevent this condition, stop
# madwifi from loading by default. Use Jockey to select one driver
# or the other. (Ubuntu: #315056, #323830)
blacklist ath_pci
---/etc/modprobe.d/blacklist.conf---
# This file lists those modules which we don't want to be loaded by
# alias expansion, usually so some other driver will be loaded for the
# device instead.
# evbug is a debug tool that should be loaded explicitly
blacklist evbug
# these drivers are very simple, the HID drivers are usually preferred
blacklist usbmouse
blacklist usbkbd
# replaced by e100
blacklist eepro100
# replaced by tulip
blacklist de4x5
# causes no end of confusion by creating unexpected network interfaces
blacklist eth1394
# snd_intel8x0m can interfere with snd_intel8x0, doesn't seem to support much
# hardware on its own (Ubuntu bug #2011, #6810)
blacklist snd_intel8x0m
# Conflicts with dvb driver (which is better for handling this device)
blacklist snd_aw2
# Causes trackpads to stop working on Lenovo 11e 2nd gen (Ubuntu: #1802135)
# and Lenovo x240 to hang on boot (Ubuntu: #1802689)
blacklist i2c_i801
# replaced by p54pci
blacklist prism54
# replaced by b43 and ssb.
blacklist bcm43xx
# most apps now use garmin usb driver directly (Ubuntu: #114565)
blacklist garmin_gps
# replaced by asus-laptop (Ubuntu: #184721)
blacklist asus_acpi
# low-quality, just noise when being used for sound playback, causes
# hangs at desktop session start (Ubuntu: #246969)
blacklist snd_pcsp
# ugly and loud noise, getting on everyone's nerves; this should be done by a
# nice pulseaudio bing (Ubuntu: #77010)
blacklist pcspkr
# EDAC driver for amd76x clashes with the agp driver preventing the aperture
# from being initialised (Ubuntu: #297750). Blacklist so that the driver
# continues to build and is installable for the few cases where its
# really needed.
blacklist amd76x_edac
---/etc/modprobe.d/blacklist-firewire.conf---
# Select the legacy firewire stack over the new CONFIG_FIREWIRE one.
blacklist ohci1394
blacklist sbp2
blacklist dv1394
blacklist raw1394
blacklist video1394
#blacklist firewire-ohci
#blacklist firewire-sbp2
---/etc/modprobe.d/blacklist-framebuffer.conf---
# Framebuffer drivers are generally buggy and poorly-supported, and cause
# suspend failures, kernel panics and general mayhem.  For this reason we
# never load them automatically.
blacklist aty128fb
blacklist atyfb
blacklist bochs-drm
blacklist radeonfb
blacklist cirrusfb
blacklist cyber2000fb
blacklist cyblafb
blacklist gx1fb
blacklist hgafb
blacklist i810fb
blacklist intelfb
blacklist kyrofb
blacklist lxfb
blacklist matroxfb_base
blacklist neofb
blacklist nvidiafb
blacklist pm2fb
blacklist rivafb
blacklist s1d13xxxfb
blacklist savagefb
blacklist sisfb
blacklist sstfb
blacklist tdfxfb
blacklist tridentfb
#blacklist vesafb
blacklist vfb
blacklist viafb
blacklist vt8623fb
blacklist udlfb
---/etc/modprobe.d/blacklist-modem.conf---
# Uncomment these entries in order to blacklist unwanted modem drivers
# blacklist snd-atiixp-modem
# blacklist snd-intel8x0m
# blacklist snd-via82xx-modem
---/etc/modprobe.d/blacklist-oss.conf---
blacklist ac97
blacklist ac97_codec
blacklist ac97_plugin_ad1980
blacklist ad1848
blacklist ad1889
blacklist adlib_card
blacklist aedsp16
blacklist ali5455
blacklist btaudio
blacklist cmpci
blacklist cs4232
blacklist cs4281
blacklist cs461x
blacklist cs46xx
blacklist emu10k1
blacklist es1370
blacklist es1371
blacklist esssolo1
blacklist forte
blacklist gus
blacklist i810_audio
blacklist kahlua
blacklist mad16
blacklist maestro
blacklist maestro3
blacklist maui
blacklist mpu401
blacklist nm256_audio
blacklist opl3
blacklist opl3sa
blacklist opl3sa2
blacklist pas2
blacklist pss
blacklist rme96xx
blacklist sb
blacklist sb_lib
blacklist sgalaxy
blacklist sonicvibes
blacklist sound
blacklist sscape
blacklist trident
blacklist trix
blacklist uart401
blacklist uart6850
blacklist via82cxxx_audio
blacklist v_midi
blacklist wavefront
blacklist ymfpci
blacklist ac97_plugin_wm97xx
blacklist ad1816
blacklist audio
blacklist awe_wave
blacklist dmasound_core
blacklist dmasound_pmac
blacklist harmony
blacklist sequencer
blacklist soundcard
blacklist usb-midi
---/etc/modprobe.d/blacklist-rare-network.conf---
# Many less commonly used network protocols have recently had various
# security flaws discovered. In an effort to reduce the scope of future
# vulnerability exploitations, they are being blacklisted here so that
# unprivileged users cannot use them by default. System owners can still
# either modify this file, or specifically modprobe any needed protocols.
# ax25
alias net-pf-3 off
# netrom
alias net-pf-6 off
# x25
alias net-pf-9 off
# rose
alias net-pf-11 off
# decnet
alias net-pf-12 off
# econet
alias net-pf-19 off
# rds
alias net-pf-21 off
# af_802154
alias net-pf-36 off
---/etc/modprobe.d/blacklist-watchdog.conf---
# Watchdog drivers should not be loaded automatically, but only if a
# watchdog daemon is installed.
blacklist acquirewdt
blacklist advantechwdt
blacklist alim1535_wdt
blacklist alim7101_wdt
blacklist booke_wdt
blacklist cpu5wdt
blacklist eurotechwdt
blacklist i6300esb
blacklist i8xx_tco
blacklist ib700wdt
blacklist ibmasr
blacklist indydog
blacklist iTCO_wdt
blacklist it8712f_wdt
blacklist it87_wdt
blacklist ixp2000_wdt
blacklist ixp4xx_wdt
blacklist machzwd
blacklist mixcomwd
blacklist mpc8xx_wdt
blacklist mpcore_wdt
blacklist mv64x60_wdt
blacklist pc87413_wdt
blacklist pcwd
blacklist pcwd_pci
blacklist pcwd_usb
blacklist s3c2410_wdt
blacklist sa1100_wdt
blacklist sbc60xxwdt
blacklist sbc7240_wdt
blacklist sb8360
blacklist sc1200wdt
blacklist sc520_wdt
blacklist sch311_wdt
blacklist scx200_wdt
blacklist shwdt
blacklist smsc37b787_wdt
blacklist softdog
blacklist twl4030_wdt
blacklist w83627hf_wdt
blacklist w83697hf_wdt
blacklist w83697ug_wdt
blacklist w83877f_wdt
blacklist w83977f_wdt
blacklist wafer5823wdt
blacklist wdt
blacklist wdt_pci
blacklist wm8350_wdt
---/etc/modprobe.d/dkms.conf---
# modprobe information used for DKMS modules
# This is a stub file, should be edited when needed,
# used by default by DKMS.
---/etc/modprobe.d/fbdev-blacklist.conf---
# This file blacklists most old-style PCI framebuffer drivers.
blacklist arkfb
blacklist aty128fb
blacklist atyfb
blacklist radeonfb
blacklist cirrusfb
blacklist kyrofb
blacklist mb862xxfb
blacklist neofb
blacklist pm2fb
blacklist pm3fb
blacklist s3fb
blacklist savagefb
blacklist sisfb
blacklist tdfxfb
blacklist tridentfb
blacklist vt8623fb
---/etc/modprobe.d/hda-jack-retask.conf---
# This file was added by the program 'hda-jack-retask'.
# If you want to revert the changes made by this program, you can simply erase this file and reboot your computer.
options snd-hda-intel patch=hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retask.fw
---/etc/modprobe.d/intel-microcode-blacklist.conf---
# The microcode module attempts to apply a microcode update when
# it autoloads.  This is not always safe, so we block it by default.
blacklist microcode
---/etc/modprobe.d/iwlwifi.conf---
# /etc/modprobe.d/iwlwifi.conf
# iwlwifi will dyamically load either iwldvm or iwlmvm depending on the
# microcode file installed on the system.  When removing iwlwifi, first
# remove the iwl?vm module and then iwlwifi.
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
---/etc/modprobe.d/mlx4.conf---
# mlx4_core gets automatically loaded, load mlx4_en also (LP: #1115710)
softdep mlx4_core post: mlx4_en
---/etc/modprobe.d/nvidia-375_hybrid.conf---
# This file was installed by nvidia-375
# Do not edit this file manually
blacklist nouveau
blacklist lbm-nouveau
alias nouveau off
alias lbm-nouveau off
---/etc/modprobe.d/nvidia-384_hybrid.conf---
# This file was installed by nvidia-384
blacklist nouveau
alias nouveau off
---/etc/modprobe.d/nvidia-graphics-drivers.conf---
blacklist nouveau
blacklist nvidia-current
blacklist nvidia-173
blacklist nvidia-96
blacklist nvidia-current-updates
blacklist nvidia-173-updates
blacklist nvidia-96-updates
blacklist nvidia-384-updates
alias nvidia nvidia_384
alias nvidia-uvm nvidia_384_uvm
alias nvidia-modeset nvidia_384_modeset
alias nvidia-drm nvidia_384_drm
alias nouveau off
options nvidia_384_drm modeset=0
---/etc/modprobe.d/vmware-fuse.conf---
# Added by VMware.
alias char-major-10-229 fuse
---/etc/modprobe.d/vmwgfx-fbdev.conf---
options vmwgfx enable_fbdev=1
---/etc/modules-load.d/cups-filters.conf---
# Parallel printer driver modules loading for cups
# LOAD_LP_MODULE was 'yes' in /etc/default/cups
lp
ppdev
parport_pc
---/etc/modules-load.d/modules.conf---
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
# Generated by sensors-detect on Mon Aug 12 21:29:50 2019
# Chip drivers
coretemp
---/etc/modules-load.d/vhba.conf---
vhba
and for this:
The result is this:
---/var/log/Xorg.0.log---
[    31.100] (--) Log file renamed from "/var/log/Xorg.pid-1406.log" to "/var/log/Xorg.0.log"
[    31.101]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[    31.101] X Protocol Version 11, Revision 0
[    31.101] Build Operating System: Linux 4.15.0-140-generic x86_64 Ubuntu
[    31.101] Current Operating System: Linux josue-HP-ENVY-15-Notebook-PC 4.13.0-32-generic #35~16.04.1-Ubuntu SMP Thu Jan 25 10:13:43 UTC 2018 x86_64
[    31.101] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.13.0-32-generic root=UUID=cec19290-a9fd-45d5-9729-aedc96f7de2e ro quiet splash vt.handoff=7
[    31.101] Build Date: 08 April 2021  01:52:21PM
[    31.101] xorg-server 2:1.18.4-0ubuntu0.12 (For technical support please see http://www.ubuntu.com/support)
[    31.101] Current version of pixman: 0.33.6
[    31.101]    Before reporting problems, check http://wiki.x.org
[    31.101] Markers: (--) probed, (**) from config file, (==) default setting,
[    31.101] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Sep 19 18:57:19 2021
[    31.113] (==) Using config file: "/etc/X11/xorg.conf"
[    31.113] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    31.165] (==) ServerLayout "layout"
[    31.165] (**) |-->Screen "nvidia" (0)
[    31.165] (**) |   |-->Monitor "<default monitor>"
[    31.165] (**) |   |-->Device "nvidia"
[    31.165] (**) |   |-->GPUDevice "nvidia"
[    31.165] (==) No monitor specified for screen "nvidia".
[    31.165] (**) |-->Inactive Device "intel"
[    31.165] (==) Automatically adding devices
[    31.165] (==) Automatically enabling devices
[    31.166] (==) Automatically adding GPU devices
[    31.166] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    31.166] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    31.166]    Entry deleted from font path.
[    31.166] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    31.166] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    31.166] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    31.166] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    31.166] (==) FontPath set to:
        /usr/share/fonts/X11/misc,
        /usr/share/fonts/X11/Type1,
        built-ins
[    31.166] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    31.166] (II) The server relies on udev to provide the list of input devices.
[    31.166] (II) Loader magic: 0x5618ba546dc0
[    31.166] (II) Module ABI versions:
[    31.166]    X.Org ANSI C Emulation: 0.4
[    31.166]    X.Org Video Driver: 20.0
[    31.166]    X.Org XInput driver : 22.1
[    31.166]    X.Org Server Extension : 9.0
[    31.166] (++) using VT number 7
[    31.166] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    31.167] (II) xfree86: Adding drm device (/dev/dri/card1)
[    31.167] (II) xfree86: Adding drm device (/dev/dri/card0)
[    31.167] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
[    31.167] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
[    31.169] (--) PCI:*(0:0:2:0) 8086:0416:103c:22a0 rev 6, Mem @ 0xd3000000/4194304, 0xc0000000/268435456, I/O @ 0x00006000/64, BIOS @ 0x????????/131072
[    31.169] (--) PCI: (0:1:0:0) 10de:1391:103c:22a0 rev 162, Mem @ 0xd2000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x????????/524288
[    31.170] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[    31.170] (II) "glx" will be loaded by default.
[    31.170] (II) LoadModule: "glx"
[    31.170] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[    32.064] (II) Module glx: vendor="NVIDIA Corporation"
[    32.064]    compiled for 4.0.2, module version = 1.0.0
[    32.064]    Module class: X.Org Server Extension
[    32.064] (II) NVIDIA GLX Module  384.130  Wed Mar 21 02:54:48 PDT 2018
[    32.064] (II) LoadModule: "nvidia"
[    32.064] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[    32.065] (II) Module nvidia: vendor="NVIDIA Corporation"
[    32.065]    compiled for 4.0.2, module version = 1.0.0
[    32.065]    Module class: X.Org Video Driver
[    32.065] (II) LoadModule: "modesetting"
[    32.065] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    32.065] (II) Module modesetting: vendor="X.Org Foundation"
[    32.065]    compiled for 1.18.4, module version = 1.18.4
[    32.065]    ABI class: X.Org Video Driver, version 20.0
[    32.065] (II) NVIDIA dlloader X Driver  384.130  Wed Mar 21 02:29:29 PDT 2018
[    32.065] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    32.065] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    32.094] (II) Loading sub module "fb"
[    32.094] (II) LoadModule: "fb"
[    32.094] (II) Loading /usr/lib/xorg/modules/libfb.so
[    32.094] (II) Module fb: vendor="X.Org Foundation"
[    32.094]    compiled for 1.18.4, module version = 1.0.0
[    32.094]    ABI class: X.Org ANSI C Emulation, version 0.4
[    32.094] (II) Loading sub module "wfb"
[    32.094] (II) LoadModule: "wfb"
[    32.095] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    32.095] (II) Module wfb: vendor="X.Org Foundation"
[    32.095]    compiled for 1.18.4, module version = 1.0.0
[    32.095]    ABI class: X.Org ANSI C Emulation, version 0.4
[    32.095] (II) Loading sub module "ramdac"
[    32.095] (II) LoadModule: "ramdac"
[    32.095] (II) Module "ramdac" already built-in
[    32.095] (WW) Falling back to old probe method for modesetting
[    32.095] (II) NVIDIA(0): Creating default Display subsection in Screen section
        "nvidia" for depth/fbbpp 24/32
[    32.095] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    32.095] (==) NVIDIA(0): RGB weight 888
[    32.095] (==) NVIDIA(0): Default visual is TrueColor
[    32.095] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    32.095] (**) NVIDIA(0): Option "ConstrainCursor" "off"
[    32.095] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "on"
[    32.096] (**) NVIDIA(0): Option "IgnoreDisplayDevices" "CRT"
[    32.096] (**) NVIDIA(0): Enabling 2D acceleration
[    32.405] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 850M (GM107-A) at PCI:1:0:0 (GPU-0)
[    32.405] (--) NVIDIA(0): Memory: 4194304 kBytes
[    32.405] (--) NVIDIA(0): VideoBIOS: 82.07.29.00.45
[    32.405] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    32.405] (II) NVIDIA(0): Validated MetaModes:
[    32.405] (II) NVIDIA(0):     "NULL"
[    32.405] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[    32.405] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[    32.405] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[    32.405] (--) Depth 24 pixmap format is 32 bpp
[    32.406] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[    32.406] (II) NVIDIA:     access.
[    32.434] (II) NVIDIA(0): Setting mode "NULL"
[    32.473] (==) NVIDIA(0): Disabling shared memory pixmaps
[    32.473] (==) NVIDIA(0): Backing store enabled
[    32.473] (==) NVIDIA(0): Silken mouse enabled
[    32.474] (==) NVIDIA(0): DPMS enabled
[    32.474] (II) Loading sub module "dri2"
[    32.474] (II) LoadModule: "dri2"
[    32.474] (II) Module "dri2" already built-in
[    32.474] (II) NVIDIA(0): [DRI2] Setup complete
[    32.474] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    32.474] (--) RandR disabled
[    32.507] (II) SELinux: Disabled on system
[    32.508] (II) Initializing extension GLX
[    32.508] (II) Indirect GLX disabled.
[    32.784] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    32.784] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    32.784] (II) LoadModule: "evdev"
[    32.784] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    32.785] (II) Module evdev: vendor="X.Org Foundation"
[    32.785]    compiled for 1.18.1, module version = 2.10.1
[    32.785]    Module class: X.Org XInput Driver
[    32.785]    ABI class: X.Org XInput driver, version 22.1
[    32.785] (II) Using input driver 'evdev' for 'Power Button'
[    32.785] (**) Power Button: always reports core events
[    32.785] (**) evdev: Power Button: Device: "/dev/input/event2"
[    32.785] (--) evdev: Power Button: Vendor 0 Product 0x1
[    32.785] (--) evdev: Power Button: Found keys
[    32.785] (II) evdev: Power Button: Configuring as keyboard
[    32.785] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[    32.785] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    32.785] (**) Option "xkb_rules" "evdev"
[    32.785] (**) Option "xkb_model" "pc105"
[    32.785] (**) Option "xkb_layout" "latam"
[    32.798] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[    32.798] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    32.798] (II) Using input driver 'evdev' for 'Video Bus'
[    32.799] (**) Video Bus: always reports core events
[    32.799] (**) evdev: Video Bus: Device: "/dev/input/event5"
[    32.799] (--) evdev: Video Bus: Vendor 0 Product 0x6
[    32.799] (--) evdev: Video Bus: Found keys
[    32.799] (II) evdev: Video Bus: Configuring as keyboard
[    32.799] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input7/event5"
[    32.799] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    32.799] (**) Option "xkb_rules" "evdev"
[    32.799] (**) Option "xkb_model" "pc105"
[    32.799] (**) Option "xkb_layout" "latam"
[    32.801] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[    32.801] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    32.801] (II) Using input driver 'evdev' for 'Video Bus'
[    32.801] (**) Video Bus: always reports core events
[    32.801] (**) evdev: Video Bus: Device: "/dev/input/event4"
[    32.801] (--) evdev: Video Bus: Vendor 0 Product 0x6
[    32.801] (--) evdev: Video Bus: Found keys
[    32.801] (II) evdev: Video Bus: Configuring as keyboard
[    32.801] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:4a/LNXVIDEO:00/input/input6/event4"
[    32.801] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    32.801] (**) Option "xkb_rules" "evdev"
[    32.801] (**) Option "xkb_model" "pc105"
[    32.801] (**) Option "xkb_layout" "latam"
[    32.802] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    32.802] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    32.802] (II) Using input driver 'evdev' for 'Power Button'
[    32.802] (**) Power Button: always reports core events
[    32.803] (**) evdev: Power Button: Device: "/dev/input/event1"
[    32.803] (--) evdev: Power Button: Vendor 0 Product 0x1
[    32.803] (--) evdev: Power Button: Found keys
[    32.803] (II) evdev: Power Button: Configuring as keyboard
[    32.803] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[    32.803] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[    32.803] (**) Option "xkb_rules" "evdev"
[    32.803] (**) Option "xkb_model" "pc105"
[    32.803] (**) Option "xkb_layout" "latam"
[    32.804] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    32.804] (II) No input driver specified, ignoring this device.
[    32.804] (II) This device may have been added with another device file.
[    32.805] (II) config/udev: Adding drm device (/dev/dri/card0)
[    32.805] (II) xfree86: Adding drm device (/dev/dri/card0)
[    32.805] (II) LoadModule: "modesetting"
[    32.805] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    32.805] (II) Module modesetting: vendor="X.Org Foundation"
[    32.805]    compiled for 1.18.4, module version = 1.18.4
[    32.805]    Module class: X.Org Video Driver
[    32.805]    ABI class: X.Org Video Driver, version 20.0
[    32.805] (II) UnloadModule: "modesetting"
[    32.805] (II) Unloading modesetting
[    32.805] (II) Failed to load module "modesetting" (already loaded, 22040)
[    32.805] (II) modeset(G0): using drv /dev/dri/card0
[    32.805] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    32.805] (==) modeset(G0): RGB weight 888
[    32.805] (==) modeset(G0): Default visual is TrueColor
[    32.805] (II) Loading sub module "glamoregl"
[    32.805] (II) LoadModule: "glamoregl"
[    32.806] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    32.950] (II) Module glamoregl: vendor="X.Org Foundation"
[    32.950]    compiled for 1.18.4, module version = 1.0.0
[    32.950]    ABI class: X.Org ANSI C Emulation, version 0.4
[    32.950] (II) glamor: OpenGL accelerated X.org driver based.
[    33.094] (EE) modeset(G0): eglInitialize() failed
[    33.094] (EE) modeset(G0): glamor initialization failed
[    33.094] (II) modeset(G0): ShadowFB: preferred YES, enabled YES
[    33.097] (II) modeset(G0): Output eDP-1-1 has no monitor section
[    33.105] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[    33.116] (II) modeset(G0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[    33.116] (==) modeset(G0): DPI set to (96, 96)
[    33.116] (II) Loading sub module "fb"
[    33.116] (II) LoadModule: "fb"
[    33.116] (II) Loading /usr/lib/xorg/modules/libfb.so
[    33.116] (II) Module fb: vendor="X.Org Foundation"
[    33.116]    compiled for 1.18.4, module version = 1.0.0
[    33.116]    ABI class: X.Org ANSI C Emulation, version 0.4
[    33.116] (II) Loading sub module "shadow"
[    33.116] (II) LoadModule: "shadow"
[    33.116] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    33.116] (II) Module shadow: vendor="X.Org Foundation"
[    33.116]    compiled for 1.18.4, module version = 1.1.0
[    33.116] (==) modeset(G0): Backing store enabled
[    33.116] (==) modeset(G0): Silken mouse enabled
[    33.116] (II) modeset(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    33.173] (==) modeset(G0): DPMS enabled
[    33.173] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[    33.173] (WW) modeset(G0): Option "IgnoreDisplayDevices" is not used
[    33.442] (II) modeset(G0): Damage tracking initialized
[    33.442] xf86: found device 2
[    33.443] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event11)
[    33.443] (II) No input driver specified, ignoring this device.
[    33.443] (II) This device may have been added with another device file.
[    33.443] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event12)
[    33.444] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event13)
[    33.444] (II) No input driver specified, ignoring this device.
[    33.444] (II) This device may have been added with another device file.
[    33.444] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event14)
[    33.444] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event15)
[    33.445] (II) config/udev: Adding input device USB GAMING MOUSE  (/dev/input/event7)
[    33.445] (**) USB GAMING MOUSE : Applying InputClass "evdev pointer catchall"
[    33.445] (II) Using input driver 'evdev' for 'USB GAMING MOUSE '
[    33.445] (**) USB GAMING MOUSE : always reports core events
[    33.445] (**) evdev: USB GAMING MOUSE : Device: "/dev/input/event7"
[    33.504] (--) evdev: USB GAMING MOUSE : Vendor 0x18f8 Product 0x1286
[    33.504] (--) evdev: USB GAMING MOUSE : Found 9 mouse buttons
[    33.504] (--) evdev: USB GAMING MOUSE : Found scroll wheel(s)
[    33.504] (--) evdev: USB GAMING MOUSE : Found relative axes
[    33.504] (--) evdev: USB GAMING MOUSE : Found x and y relative axes
[    33.504] (II) evdev: USB GAMING MOUSE : Configuring as mouse
[    33.504] (II) evdev: USB GAMING MOUSE : Adding scrollwheel support
[    33.504] (**) evdev: USB GAMING MOUSE : YAxisMapping: buttons 4 and 5
[    33.504] (**) evdev: USB GAMING MOUSE : EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    33.504] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.4/3-4.4:1.0/0003:18F8:1286.0001/input/input8/event7"
[    33.504] (II) XINPUT: Adding extended input device "USB GAMING MOUSE " (type: MOUSE, id 10)
[    33.504] (II) evdev: USB GAMING MOUSE : initialized for relative axes.
[    33.504] (**) USB GAMING MOUSE : (accel) keeping acceleration scheme 1
[    33.504] (**) USB GAMING MOUSE : (accel) acceleration profile 0
[    33.504] (**) USB GAMING MOUSE : (accel) acceleration factor: 2.000
[    33.504] (**) USB GAMING MOUSE : (accel) acceleration threshold: 4
[    33.505] (II) config/udev: Adding input device USB GAMING MOUSE  (/dev/input/mouse1)
[    33.505] (II) No input driver specified, ignoring this device.
[    33.505] (II) This device may have been added with another device file.
[    33.506] (II) config/udev: Adding input device USB GAMING MOUSE  (/dev/input/event8)
[    33.506] (**) USB GAMING MOUSE : Applying InputClass "evdev keyboard catchall"
[    33.506] (II) Using input driver 'evdev' for 'USB GAMING MOUSE '
[    33.506] (**) USB GAMING MOUSE : always reports core events
[    33.506] (**) evdev: USB GAMING MOUSE : Device: "/dev/input/event8"
[    33.506] (--) evdev: USB GAMING MOUSE : Vendor 0x18f8 Product 0x1286
[    33.506] (--) evdev: USB GAMING MOUSE : Found 1 mouse buttons
[    33.506] (--) evdev: USB GAMING MOUSE : Found scroll wheel(s)
[    33.506] (--) evdev: USB GAMING MOUSE : Found relative axes
[    33.506] (II) evdev: USB GAMING MOUSE : Forcing relative x/y axes to exist.
[    33.506] (--) evdev: USB GAMING MOUSE : Found absolute axes
[    33.506] (II) evdev: USB GAMING MOUSE : Forcing absolute x/y axes to exist.
[    33.506] (--) evdev: USB GAMING MOUSE : Found keys
[    33.506] (II) evdev: USB GAMING MOUSE : Configuring as mouse
[    33.506] (II) evdev: USB GAMING MOUSE : Configuring as keyboard
[    33.506] (II) evdev: USB GAMING MOUSE : Adding scrollwheel support
[    33.506] (**) evdev: USB GAMING MOUSE : YAxisMapping: buttons 4 and 5
[    33.506] (**) evdev: USB GAMING MOUSE : EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    33.506] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.4/3-4.4:1.1/0003:18F8:1286.0002/input/input9/event8"
[    33.506] (II) XINPUT: Adding extended input device "USB GAMING MOUSE " (type: KEYBOARD, id 11)
[    33.506] (**) Option "xkb_rules" "evdev"
[    33.506] (**) Option "xkb_model" "pc105"
[    33.506] (**) Option "xkb_layout" "latam"
[    33.506] (II) evdev: USB GAMING MOUSE : initialized for relative axes.
[    33.506] (WW) evdev: USB GAMING MOUSE : ignoring absolute axes.
[    33.506] (**) USB GAMING MOUSE : (accel) keeping acceleration scheme 1
[    33.506] (**) USB GAMING MOUSE : (accel) acceleration profile 0
[    33.506] (**) USB GAMING MOUSE : (accel) acceleration factor: 2.000
[    33.506] (**) USB GAMING MOUSE : (accel) acceleration threshold: 4
[    33.507] (II) config/udev: Adding input device HP Truevision HD: HP Truevision (/dev/input/event19)
[    33.507] (**) HP Truevision HD: HP Truevision: Applying InputClass "evdev keyboard catchall"
[    33.507] (II) Using input driver 'evdev' for 'HP Truevision HD: HP Truevision'
[    33.507] (**) HP Truevision HD: HP Truevision: always reports core events
[    33.507] (**) evdev: HP Truevision HD: HP Truevision: Device: "/dev/input/event19"
[    33.507] (--) evdev: HP Truevision HD: HP Truevision: Vendor 0x4f2 Product 0xb40d
[    33.507] (--) evdev: HP Truevision HD: HP Truevision: Found keys
[    33.507] (II) evdev: HP Truevision HD: HP Truevision: Configuring as keyboard
[    33.507] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-7/3-7:1.0/input/input20/event19"
[    33.507] (II) XINPUT: Adding extended input device "HP Truevision HD: HP Truevision" (type: KEYBOARD, id 12)
[    33.507] (**) Option "xkb_rules" "evdev"
[    33.507] (**) Option "xkb_model" "pc105"
[    33.507] (**) Option "xkb_layout" "latam"
[    33.508] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event16)
[    33.508] (II) No input driver specified, ignoring this device.
[    33.508] (II) This device may have been added with another device file.
[    33.508] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event17)
[    33.509] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[    33.509] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    33.509] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[    33.509] (**) AT Translated Set 2 keyboard: always reports core events
[    33.509] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event3"
[    33.509] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[    33.509] (--) evdev: AT Translated Set 2 keyboard: Found keys
[    33.509] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[    33.509] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[    33.509] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[    33.509] (**) Option "xkb_rules" "evdev"
[    33.509] (**) Option "xkb_model" "pc105"
[    33.509] (**) Option "xkb_layout" "latam"
[    33.509] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event6)
[    33.509] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[    33.509] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchscreen catchall"
[    33.509] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[    33.509] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Default clickpad buttons"
[    33.509] (II) LoadModule: "synaptics"
[    33.510] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[    33.510] (II) Module synaptics: vendor="X.Org Foundation"
[    33.510]    compiled for 1.18.1, module version = 1.8.2
[    33.510]    Module class: X.Org XInput Driver
[    33.510]    ABI class: X.Org XInput driver, version 22.1
[    33.510] (II) Using input driver 'synaptics' for 'SynPS/2 Synaptics TouchPad'
[    33.510] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    33.510] (**) Option "Device" "/dev/input/event6"
[    33.592] (II) synaptics: SynPS/2 Synaptics TouchPad: found clickpad property
[    33.592] (--) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1362 - 5610 (res 31)
[    33.592] (--) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1238 - 4700 (res 56)
[    33.592] (--) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[    33.592] (--) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[    33.592] (--) synaptics: SynPS/2 Synaptics TouchPad: buttons: left double triple
[    33.592] (--) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[    33.592] (**) Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
[    33.592] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[    33.592] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    33.632] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input5/event6"
[    33.632] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 14)
[    33.632] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[    33.632] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MaxSpeed is now 1.75
[    33.632] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) AccelFactor is now 0.036
[    33.632] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[    33.632] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[    33.632] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    33.632] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    33.632] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[    33.633] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[    33.633] (**) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
[    33.633] (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/event10)
[    33.633] (II) No input driver specified, ignoring this device.
[    33.633] (II) This device may have been added with another device file.
[    33.633] (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/js0)
[    33.636] (II) config/udev: Adding input device HP Wireless hotkeys (/dev/input/event9)
[    33.636] (**) HP Wireless hotkeys: Applying InputClass "evdev keyboard catchall"
[    33.636] (II) Using input driver 'evdev' for 'HP Wireless hotkeys'
[    33.636] (**) HP Wireless hotkeys: always reports core events
[    33.636] (**) evdev: HP Wireless hotkeys: Device: "/dev/input/event9"
[    33.636] (--) evdev: HP Wireless hotkeys: Vendor 0 Product 0
[    33.636] (--) evdev: HP Wireless hotkeys: Found keys
[    33.636] (II) evdev: HP Wireless hotkeys: Configuring as keyboard
[    33.636] (**) Option "config_info" "udev:/sys/devices/virtual/input/input10/event9"
[    33.636] (II) XINPUT: Adding extended input device "HP Wireless hotkeys" (type: KEYBOARD, id 15)
[    33.636] (**) Option "xkb_rules" "evdev"
[    33.636] (**) Option "xkb_model" "pc105"
[    33.636] (**) Option "xkb_layout" "latam"
[    33.636] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event18)
[    33.636] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    33.636] (II) Using input driver 'evdev' for 'HP WMI hotkeys'
[    33.636] (**) HP WMI hotkeys: always reports core events
[    33.636] (**) evdev: HP WMI hotkeys: Device: "/dev/input/event18"
[    33.636] (--) evdev: HP WMI hotkeys: Vendor 0 Product 0
[    33.636] (--) evdev: HP WMI hotkeys: Found keys
[    33.636] (II) evdev: HP WMI hotkeys: Configuring as keyboard
[    33.636] (**) Option "config_info" "udev:/sys/devices/virtual/input/input17/event18"
[    33.636] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 16)
---/var/log/Xorg.1.log---
[ 42697.664] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[ 42697.664] _XSERVTransMakeAllCOTSServerListeners: server already running
[ 42697.715] (--) Log file renamed from "/var/log/Xorg.pid-1680.log" to "/var/log/Xorg.1.log"
[ 42697.968]
[ 42698.141] X Protocol Version 11, Revision 0
[ 42698.141] Build Operating System: Linux 4.4.0-97-generic x86_64 Ubuntu
[ 42698.141] Current Operating System: Linux josue-HP-ENVY-15-Notebook-PC 4.13.0-32-generic #35~16.04.1-Ubuntu SMP Thu Jan 25 10:13:43 UTC 2018 x86_64
[ 42698.141] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.13.0-32-generic root=UUID=cec19290-a9fd-45d5-9729-aedc96f7de2e ro quiet splash vt.handoff=7
[ 42698.141] Build Date: 13 October 2017  01:57:05PM
[ 42698.141] xorg-server 2:1.18.4-0ubuntu0.7 (For technical support please see http://www.ubuntu.com/support)
[ 42698.141] Current version of pixman: 0.33.6
[ 42698.141]    Before reporting problems, check http://wiki.x.org
[ 42698.141] Markers: (--) probed, (**) from config file, (==) default setting,
[ 42698.141] (==) Log file: "/var/log/Xorg.1.log", Time: Thu Sep  3 02:02:53 2020
[ 42698.172] (==) Using config file: "/etc/X11/xorg.conf"
[ 42698.172] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 42698.488] (==) ServerLayout "layout"
[ 42698.488] (**) |-->Screen "nvidia" (0)
[ 42698.488] (**) |   |-->Monitor "<default monitor>"
[ 42698.488] (**) |   |-->Device "nvidia"
[ 42698.488] (**) |   |-->GPUDevice "nvidia"
[ 42698.488] (==) No monitor specified for screen "nvidia".
[ 42698.488] (**) |-->Inactive Device "intel"
[ 42698.488] (==) Automatically adding devices
[ 42698.488] (==) Automatically enabling devices
[ 42698.488] (==) Automatically adding GPU devices
[ 42698.488] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 42698.488] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 42698.488]    Entry deleted from font path.
[ 42698.488] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 42698.488] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 42698.488] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 42698.488] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 42698.488] (==) FontPath set to:
        built-ins
[ 42698.488] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 42698.488] (II) The server relies on udev to provide the list of input devices.
[ 42698.488] (II) Loader magic: 0x562152cf3dc0
[ 42698.488] (II) Module ABI versions:
[ 42698.488]    X.Org ANSI C Emulation: 0.4
[ 42698.488]    X.Org Video Driver: 20.0
[ 42698.488]    X.Org XInput driver : 22.1
[ 42698.488]    X.Org Server Extension : 9.0
[ 42698.489] (++) using VT number 7
[ 42698.489] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 42698.489] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 42698.490] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 42698.498] (--) PCI:*(0:0:2:0) 8086:0416:103c:22a0 rev 6, Mem @ 0xd3000000/4194304, 0xc0000000/268435456, I/O @ 0x00006000/64, BIOS @ 0x????????/131072
[ 42698.498] (--) PCI: (0:1:0:0) 10de:1391:103c:22a0 rev 162, Mem @ 0xd2000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x????????/524288
[ 42698.498] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[ 42698.498] (II) "glx" will be loaded by default.
[ 42698.498] (II) LoadModule: "glx"
[ 42698.628] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 42700.953] (II) Module glx: vendor="NVIDIA Corporation"
[ 42700.953]    compiled for 4.0.2, module version = 1.0.0
[ 42700.953]    Module class: X.Org Server Extension
[ 42701.092] (II) NVIDIA GLX Module  384.130  Wed Mar 21 02:54:48 PDT 2018
[ 42701.092] (II) LoadModule: "nvidia"
[ 42701.092] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 42701.479] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 42701.479]    compiled for 4.0.2, module version = 1.0.0
[ 42701.479]    Module class: X.Org Video Driver
[ 42701.479] (II) LoadModule: "modesetting"
[ 42701.525] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 42701.525] (II) Module modesetting: vendor="X.Org Foundation"
[ 42701.525]    compiled for 1.18.4, module version = 1.18.4
[ 42701.525]    Module class: X.Org Video Driver
[ 42701.525]    ABI class: X.Org Video Driver, version 20.0
[ 42701.525] (II) NVIDIA dlloader X Driver  384.130  Wed Mar 21 02:29:29 PDT 2018
[ 42701.525] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 42701.525] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 42701.525] (II) Loading sub module "fb"
[ 42701.525] (II) LoadModule: "fb"
[ 42701.525] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 42701.525] (II) Module fb: vendor="X.Org Foundation"
[ 42701.525]    compiled for 1.18.4, module version = 1.0.0
[ 42701.525]    ABI class: X.Org ANSI C Emulation, version 0.4
[ 42701.525] (II) Loading sub module "wfb"
[ 42701.525] (II) LoadModule: "wfb"
[ 42701.557] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 42701.603] (II) Module wfb: vendor="X.Org Foundation"
[ 42701.603]    compiled for 1.18.4, module version = 1.0.0
[ 42701.603]    ABI class: X.Org ANSI C Emulation, version 0.4
[ 42701.603] (II) Loading sub module "ramdac"
[ 42701.603] (II) LoadModule: "ramdac"
[ 42701.603] (II) Module "ramdac" already built-in
[ 42701.610] (II) modeset(G0): using drv /dev/dri/card0
[ 42701.610] (II) NVIDIA(0): Creating default Display subsection in Screen section
[ 42701.610] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 42701.610] (==) NVIDIA(0): RGB weight 888
[ 42701.610] (==) NVIDIA(0): Default visual is TrueColor
[ 42701.610] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 42701.610] (**) NVIDIA(0): Option "ConstrainCursor" "off"
[ 42701.610] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "on"
[ 42701.635] (**) NVIDIA(0): Option "IgnoreDisplayDevices" "CRT"
[ 42701.635] (**) NVIDIA(0): Enabling 2D acceleration
[ 42701.642] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 850M (GM107-A) at PCI:1:0:0 (GPU-0)
[ 42701.642] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 42701.642] (--) NVIDIA(0): VideoBIOS: 82.07.29.00.45
[ 42701.642] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 42701.642] (II) NVIDIA(0): Validated MetaModes:
[ 42701.642] (II) NVIDIA(0):     "NULL"
[ 42701.642] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 42701.642] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 42701.642] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 42701.642] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 42701.642] (**) modeset(G0): Option "AccelMethod" "None"
[ 42701.642] (==) modeset(G0): RGB weight 888
[ 42701.642] (==) modeset(G0): Default visual is TrueColor
[ 42701.642] (**) modeset(G0): glamor disabled
[ 42701.642] (II) modeset(G0): ShadowFB: preferred YES, enabled YES
[ 42701.645] (II) modeset(G0): Output eDP-1-1 has no monitor section
[ 42701.653] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 42701.656] (II) modeset(G0): EDID for output eDP-1-1
[ 42701.656] (II) modeset(G0): Manufacturer: AUO  Model: 32ed  Serial#: 0
[ 42701.656] (II) modeset(G0): Year: 2012  Week: 0
[ 42701.656] (II) modeset(G0): EDID Version: 1.4
[ 42701.656] (II) modeset(G0): Digital Display Input
[ 42701.656] (II) modeset(G0): 6 bits per channel
[ 42701.656] (II) modeset(G0): Digital interface is undefined
[ 42701.656] (II) modeset(G0): Max Image Size [cm]: horiz.: 34  vert.: 19
[ 42701.656] (II) modeset(G0): Gamma: 2.20
[ 42701.656] (II) modeset(G0): No DPMS capabilities specified
[ 42701.656] (II) modeset(G0): Supported color encodings: RGB 4:4:4
[ 42701.656] (II) modeset(G0): First detailed timing is preferred mode
[ 42701.656] (II) modeset(G0): Preferred mode is native pixel format and refresh rate
[ 42701.656] (II) modeset(G0): redX: 0.620 redY: 0.349   greenX: 0.324 greenY: 0.606
[ 42701.656] (II) modeset(G0): blueX: 0.152 blueY: 0.118   whiteX: 0.313 whiteY: 0.329
[ 42701.656] (II) modeset(G0): Manufacturer's mask: 0
[ 42701.656] (II) modeset(G0): Supported detailed timing:
[ 42701.656] (II) modeset(G0): clock: 140.0 MHz   Image Size:  344 x 193 mm
[ 42701.656] (II) modeset(G0): h_active: 1920  h_sync: 1968  h_sync_end 2068 h_blank_end 2100 h_border: 0
[ 42701.656] (II) modeset(G0): v_active: 1080  v_sync: 1083  v_sync_end 1084 v_blanking: 1110 v_border: 0
[ 42701.656] (II) modeset(G0): clock: 93.3 MHz   Image Size:  344 x 193 mm
[ 42701.656] (II) modeset(G0): Unknown vendor-specific block 2
[ 42701.656] (II) modeset(G0): EDID (in hex):
[ 42701.656] (II) modeset(G0):  00ffffffffffff0006afed3200000000
[ 42701.656] (II) modeset(G0):  001601049022137802d1159e59539b27
[ 42701.656] (II) modeset(G0):  1e505400000001010101010101010101
[ 42701.656] (II) modeset(G0):  010101010101b03680b470381e403064
[ 42701.656] (II) modeset(G0):  310058c110000018752480b470381e40
[ 42701.656] (II) modeset(G0):  3064310058c110000018000000000000
[ 42701.656] (II) modeset(G0):  00000000000000000000000000000002
[ 42701.656] (II) modeset(G0):  000c3dff0c3c7d1b0d1c7d20202000e5
[ 42701.656] (II) modeset(G0): Printing probed modes for output eDP-1-1
[ 42701.656] (II) modeset(G0): Modeline "1920x1080"x60.1  140.00  1920 1968 2068 2100  1080 1083 1084 1110 -hsync -vsync (66.7 kHz eP)
[ 42701.656] (II) modeset(G0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 42701.656] (II) modeset(G0): Modeline "1920x1080"x40.0   93.33  1920 1968 2068 2100  1080 1083 1084 1110 -hsync -vsync (44.4 kHz e)
[ 42701.656] (II) modeset(G0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 42701.656] (II) modeset(G0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "1600x1024"x60.2  103.12  1600 1600 1656 1664  1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "1360x768"x59.8   84.75  1360 1432 1568 1776  768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "1360x768"x60.0   72.00  1360 1408 1440 1520  768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "800x512"x120.3   51.56  800 800 828 832  512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "720x450"x119.8   53.25  720 760 836 952  450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "680x384"x119.6   42.38  680 716 784 888  384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "680x384"x119.9   36.00  680 704 720 760  384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "576x432"x120.1   40.81  576 608 668 760  432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 42701.657] (II) modeset(G0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 42701.665] (II) modeset(G0): EDID for output HDMI-1-1
[ 42701.665] (II) modeset(G0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 42701.665] (==) modeset(G0): DPI set to (96, 96)
[ 42701.665] (II) Loading sub module "fb"
[ 42701.665] (II) LoadModule: "fb"
[ 42701.665] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 42701.665] (II) Module fb: vendor="X.Org Foundation"
[ 42701.665]    compiled for 1.18.4, module version = 1.0.0
[ 42701.665]    ABI class: X.Org ANSI C Emulation, version 0.4
[ 42701.665] (II) Loading sub module "shadow"
[ 42701.666] (II) LoadModule: "shadow"
[ 42701.666] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 42701.723] (II) Module shadow: vendor="X.Org Foundation"
[ 42701.723]    compiled for 1.18.4, module version = 1.1.0
[ 42701.723]    ABI class: X.Org ANSI C Emulation, version 0.4
[ 42701.723] (--) Depth 24 pixmap format is 32 bpp
[ 42701.761] (==) modeset(G0): Backing store enabled
[ 42701.761] (==) modeset(G0): Silken mouse enabled
[ 42701.761] (II) modeset(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 42701.826] (==) modeset(G0): DPMS enabled
[ 42701.826] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[ 42701.826] (WW) modeset(G0): Option "IgnoreDisplayDevices" is not used
[ 42702.096] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 42702.096] (II) NVIDIA:     access.
[ 42702.205] (II) NVIDIA(0): Setting mode "NULL"
[ 42702.212] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 42702.212] (==) NVIDIA(0): Backing store enabled
[ 42702.212] (==) NVIDIA(0): Silken mouse enabled
[ 42702.212] (==) NVIDIA(0): DPMS enabled
[ 42702.212] (II) Loading sub module "dri2"
[ 42702.212] (II) LoadModule: "dri2"
[ 42702.212] (II) Module "dri2" already built-in
[ 42702.212] (II) NVIDIA(0): [DRI2] Setup complete
[ 42702.212] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[ 42702.212] (--) RandR disabled
[ 42702.215] (II) SELinux: Disabled on system
[ 42702.215] (II) Initializing extension GLX
[ 42702.215] (II) Indirect GLX disabled.
[ 42702.216] (II) modeset(G0): Damage tracking initialized
[ 42702.900] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 42702.900] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 42702.900] (II) LoadModule: "evdev"
[ 42702.901] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 42702.901] (II) Module evdev: vendor="X.Org Foundation"
[ 42702.901]    compiled for 1.18.1, module version = 2.10.1
[ 42702.901]    Module class: X.Org XInput Driver
[ 42702.901]    ABI class: X.Org XInput driver, version 22.1
[ 42702.901] (II) Using input driver 'evdev' for 'Power Button'
[ 42702.901] (**) Power Button: always reports core events
[ 42702.901] (**) evdev: Power Button: Device: "/dev/input/event2"
[ 42702.901] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 42702.901] (--) evdev: Power Button: Found keys
[ 42702.901] (II) evdev: Power Button: Configuring as keyboard
[ 42702.901] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 42702.901] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 42702.901] (**) Option "xkb_rules" "evdev"
[ 42702.901] (**) Option "xkb_model" "pc105"
[ 42702.901] (**) Option "xkb_layout" "latam"
[ 42703.047] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[ 42703.047] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 42703.047] (II) Using input driver 'evdev' for 'Video Bus'
[ 42703.047] (**) Video Bus: always reports core events
[ 42703.047] (**) evdev: Video Bus: Device: "/dev/input/event5"
[ 42703.047] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 42703.047] (--) evdev: Video Bus: Found keys
[ 42703.047] (II) evdev: Video Bus: Configuring as keyboard
[ 42703.047] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input7/event5"
[ 42703.047] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 42703.047] (**) Option "xkb_rules" "evdev"
[ 42703.047] (**) Option "xkb_model" "pc105"
[ 42703.047] (**) Option "xkb_layout" "latam"
[ 42703.048] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[ 42703.048] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 42703.048] (II) Using input driver 'evdev' for 'Video Bus'
[ 42703.048] (**) Video Bus: always reports core events
[ 42703.048] (**) evdev: Video Bus: Device: "/dev/input/event4"
[ 42703.048] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 42703.048] (--) evdev: Video Bus: Found keys
[ 42703.048] (II) evdev: Video Bus: Configuring as keyboard
[ 42703.048] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:4a/LNXVIDEO:00/input/input6/event4"
[ 42703.048] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 42703.048] (**) Option "xkb_rules" "evdev"
[ 42703.048] (**) Option "xkb_model" "pc105"
[ 42703.048] (**) Option "xkb_layout" "latam"
[ 42703.049] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 42703.049] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 42703.049] (II) Using input driver 'evdev' for 'Power Button'
[ 42703.049] (**) Power Button: always reports core events
[ 42703.049] (**) evdev: Power Button: Device: "/dev/input/event1"
[ 42703.049] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 42703.049] (--) evdev: Power Button: Found keys
[ 42703.049] (II) evdev: Power Button: Configuring as keyboard
[ 42703.049] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 42703.049] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 42703.049] (**) Option "xkb_rules" "evdev"
[ 42703.049] (**) Option "xkb_model" "pc105"
[ 42703.049] (**) Option "xkb_layout" "latam"
[ 42703.049] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 42703.049] (II) No input driver specified, ignoring this device.
[ 42703.049] (II) This device may have been added with another device file.
[ 42703.050] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event11)
[ 42703.050] (II) No input driver specified, ignoring this device.
[ 42703.050] (II) This device may have been added with another device file.
[ 42703.050] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event12)
[ 42703.051] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event13)
[ 42703.051] (II) No input driver specified, ignoring this device.
[ 42703.051] (II) This device may have been added with another device file.
[ 42703.051] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event14)
[ 42703.051] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event15)
[ 42703.052] (II) config/udev: Adding input device USB GAMING MOUSE  (/dev/input/event7)
[ 42703.052] (**) USB GAMING MOUSE : Applying InputClass "evdev pointer catchall"
[ 42703.052] (II) Using input driver 'evdev' for 'USB GAMING MOUSE '
[ 42703.052] (**) USB GAMING MOUSE : always reports core events
[ 42703.052] (**) evdev: USB GAMING MOUSE : Device: "/dev/input/event7"
[ 42703.112] (--) evdev: USB GAMING MOUSE : Vendor 0x18f8 Product 0x1286
[ 42703.112] (--) evdev: USB GAMING MOUSE : Found 9 mouse buttons
[ 42703.112] (--) evdev: USB GAMING MOUSE : Found scroll wheel(s)
[ 42703.112] (--) evdev: USB GAMING MOUSE : Found relative axes
[ 42703.112] (--) evdev: USB GAMING MOUSE : Found x and y relative axes
[ 42703.112] (II) evdev: USB GAMING MOUSE : Configuring as mouse
[ 42703.112] (II) evdev: USB GAMING MOUSE : Adding scrollwheel support
[ 42703.112] (**) evdev: USB GAMING MOUSE : YAxisMapping: buttons 4 and 5
[ 42703.112] (**) evdev: USB GAMING MOUSE : EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 42703.112] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.4/3-4.4:1.0/0003:18F8:1286.0001/input/input8/event7"
[ 42703.112] (II) XINPUT: Adding extended input device "USB GAMING MOUSE " (type: MOUSE, id 10)
[ 42703.112] (II) evdev: USB GAMING MOUSE : initialized for relative axes.
[ 42703.112] (**) USB GAMING MOUSE : (accel) keeping acceleration scheme 1
[ 42703.112] (**) USB GAMING MOUSE : (accel) acceleration profile 0
[ 42703.112] (**) USB GAMING MOUSE : (accel) acceleration factor: 2.000
[ 42703.112] (**) USB GAMING MOUSE : (accel) acceleration threshold: 4
[ 42703.113] (II) config/udev: Adding input device USB GAMING MOUSE  (/dev/input/mouse1)
[ 42703.113] (II) No input driver specified, ignoring this device.
[ 42703.113] (II) This device may have been added with another device file.
[ 42703.114] (II) config/udev: Adding input device USB GAMING MOUSE  (/dev/input/event8)
[ 42703.114] (**) USB GAMING MOUSE : Applying InputClass "evdev keyboard catchall"
[ 42703.114] (II) Using input driver 'evdev' for 'USB GAMING MOUSE '
[ 42703.114] (**) USB GAMING MOUSE : always reports core events
[ 42703.114] (**) evdev: USB GAMING MOUSE : Device: "/dev/input/event8"
[ 42703.114] (--) evdev: USB GAMING MOUSE : Vendor 0x18f8 Product 0x1286
[ 42703.114] (--) evdev: USB GAMING MOUSE : Found 1 mouse buttons
[ 42703.114] (--) evdev: USB GAMING MOUSE : Found scroll wheel(s)
[ 42703.114] (--) evdev: USB GAMING MOUSE : Found relative axes
[ 42703.114] (II) evdev: USB GAMING MOUSE : Forcing relative x/y axes to exist.
[ 42703.114] (--) evdev: USB GAMING MOUSE : Found absolute axes
[ 42703.114] (II) evdev: USB GAMING MOUSE : Forcing absolute x/y axes to exist.
[ 42703.114] (--) evdev: USB GAMING MOUSE : Found keys
[ 42703.114] (II) evdev: USB GAMING MOUSE : Configuring as mouse
[ 42703.114] (II) evdev: USB GAMING MOUSE : Configuring as keyboard
[ 42703.114] (II) evdev: USB GAMING MOUSE : Adding scrollwheel support
[ 42703.114] (**) evdev: USB GAMING MOUSE : YAxisMapping: buttons 4 and 5
[ 42703.114] (**) evdev: USB GAMING MOUSE : EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 42703.114] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4.4/3-4.4:1.1/0003:18F8:1286.0002/input/input9/event8"
[ 42703.114] (II) XINPUT: Adding extended input device "USB GAMING MOUSE " (type: KEYBOARD, id 11)
[ 42703.114] (**) Option "xkb_rules" "evdev"
[ 42703.114] (**) Option "xkb_model" "pc105"
[ 42703.114] (**) Option "xkb_layout" "latam"
[ 42703.114] (II) evdev: USB GAMING MOUSE : initialized for relative axes.
[ 42703.114] (WW) evdev: USB GAMING MOUSE : ignoring absolute axes.
[ 42703.114] (**) USB GAMING MOUSE : (accel) keeping acceleration scheme 1
[ 42703.114] (**) USB GAMING MOUSE : (accel) acceleration profile 0
[ 42703.114] (**) USB GAMING MOUSE : (accel) acceleration factor: 2.000
[ 42703.114] (**) USB GAMING MOUSE : (accel) acceleration threshold: 4
[ 42703.115] (II) config/udev: Adding input device HP Truevision HD: HP Truevision (/dev/input/event19)
[ 42703.115] (**) HP Truevision HD: HP Truevision: Applying InputClass "evdev keyboard catchall"
[ 42703.115] (II) Using input driver 'evdev' for 'HP Truevision HD: HP Truevision'
[ 42703.115] (**) HP Truevision HD: HP Truevision: always reports core events
[ 42703.115] (**) evdev: HP Truevision HD: HP Truevision: Device: "/dev/input/event19"
[ 42703.115] (--) evdev: HP Truevision HD: HP Truevision: Vendor 0x4f2 Product 0xb40d
[ 42703.115] (--) evdev: HP Truevision HD: HP Truevision: Found keys
[ 42703.115] (II) evdev: HP Truevision HD: HP Truevision: Configuring as keyboard
[ 42703.115] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-7/3-7:1.0/input/input20/event19"
[ 42703.115] (II) XINPUT: Adding extended input device "HP Truevision HD: HP Truevision" (type: KEYBOARD, id 12)
[ 42703.115] (**) Option "xkb_rules" "evdev"
[ 42703.115] (**) Option "xkb_model" "pc105"
[ 42703.115] (**) Option "xkb_layout" "latam"
[ 42703.115] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event16)
[ 42703.115] (II) No input driver specified, ignoring this device.
[ 42703.116] (II) This device may have been added with another device file.
[ 42703.116] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event17)
[ 42703.116] (II) No input driver specified, ignoring this device.
[ 42703.116] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 42703.116] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 42703.116] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 42703.116] (**) AT Translated Set 2 keyboard: always reports core events
[ 42703.116] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event3"
[ 42703.116] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 42703.116] (--) evdev: AT Translated Set 2 keyboard: Found keys
[ 42703.116] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 42703.116] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 42703.116] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[ 42703.116] (**) Option "xkb_rules" "evdev"
[ 42703.116] (**) Option "xkb_model" "pc105"
[ 42703.116] (**) Option "xkb_layout" "latam"
[ 42703.117] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event6)
[ 42703.117] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 42703.117] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchscreen catchall"
[ 42703.117] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[ 42703.117] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Default clickpad buttons"
[ 42703.117] (II) LoadModule: "synaptics"
[ 42703.117] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 42703.117] (II) Module synaptics: vendor="X.Org Foundation"
[ 42703.117]    compiled for 1.18.1, module version = 1.8.2
[ 42703.117]    Module class: X.Org XInput Driver
[ 42703.117]    ABI class: X.Org XInput driver, version 22.1
[ 42703.118] (II) Using input driver 'synaptics' for 'SynPS/2 Synaptics TouchPad'
[ 42703.118] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 42703.118] (**) Option "Device" "/dev/input/event6"
[ 42703.192] (II) synaptics: SynPS/2 Synaptics TouchPad: found clickpad property
[ 42703.192] (--) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1362 - 5610 (res 31)
[ 42703.192] (--) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1238 - 4700 (res 56)
[ 42703.192] (--) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[ 42703.192] (--) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[ 42703.192] (--) synaptics: SynPS/2 Synaptics TouchPad: buttons: left double triple
[ 42703.192] (--) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[ 42703.192] (**) Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
[ 42703.192] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 42703.192] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 42703.224] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input5/event6"
[ 42703.224] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 14)
[ 42703.224] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[ 42703.224] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MaxSpeed is now 1.75
[ 42703.224] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) AccelFactor is now 0.036
[ 42703.224] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 42703.224] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[ 42703.224] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 42703.224] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 42703.224] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 42703.224] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 42703.224] (**) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass "touchpad ignore duplicates"
[ 42703.225] (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/event10)
[ 42703.225] (II) No input driver specified, ignoring this device.
[ 42703.225] (II) This device may have been added with another device file.
[ 42703.225] (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/js0)
[ 42703.227] (II) config/udev: Adding input device HP Wireless hotkeys (/dev/input/event9)
[ 42703.227] (**) HP Wireless hotkeys: Applying InputClass "evdev keyboard catchall"
[ 42703.227] (II) Using input driver 'evdev' for 'HP Wireless hotkeys'
[ 42703.227] (**) HP Wireless hotkeys: always reports core events
[ 42703.227] (**) evdev: HP Wireless hotkeys: Device: "/dev/input/event9"
[ 42703.227] (--) evdev: HP Wireless hotkeys: Vendor 0 Product 0
[ 42703.227] (--) evdev: HP Wireless hotkeys: Found keys
[ 42703.227] (II) evdev: HP Wireless hotkeys: Configuring as keyboard
[ 42703.227] (**) Option "config_info" "udev:/sys/devices/virtual/input/input10/event9"
[ 42703.227] (II) XINPUT: Adding extended input device "HP Wireless hotkeys" (type: KEYBOARD, id 15)
[ 42703.227] (**) Option "xkb_rules" "evdev"
[ 42703.227] (**) Option "xkb_model" "pc105"
[ 42703.227] (**) Option "xkb_layout" "latam"
[ 42703.228] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event18)
[ 42703.228] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 42703.228] (II) Using input driver 'evdev' for 'HP WMI hotkeys'
[ 42703.228] (**) HP WMI hotkeys: always reports core events
[ 42703.228] (**) evdev: HP WMI hotkeys: Device: "/dev/input/event18"
[ 42703.228] (--) evdev: HP WMI hotkeys: Vendor 0 Product 0
[ 42703.228] (--) evdev: HP WMI hotkeys: Found keys
[ 42703.228] (II) evdev: HP WMI hotkeys: Configuring as keyboard
[ 42703.228] (**) Option "config_info" "udev:/sys/devices/virtual/input/input12/event18"
[ 42703.228] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 16)
[ 42703.228] (**) Option "xkb_rules" "evdev"
[ 42703.228] (**) Option "xkb_model" "pc105"
[ 42703.228] (**) Option "xkb_layout" "latam"
[ 42707.210] (II) evdev: HP WMI hotkeys: Close
[ 42707.210] (II) UnloadModule: "evdev"
[ 42707.210] (II) evdev: HP Wireless hotkeys: Close
[ 42707.210] (II) UnloadModule: "synaptics"
[ 42707.210] (II) evdev: AT Translated Set 2 keyboard: Close
[ 42707.210] (II) evdev: HP Truevision HD: HP Truevision: Close
[ 42707.210] (II) evdev: USB GAMING MOUSE : Close
[ 42707.210] (II) evdev: Power Button: Close
[ 42707.210] (II) evdev: Video Bus: Close
[ 42707.246] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 42708.114] (II) Server terminated successfully (0). Closing log file.
cat: '/home/josue/.local/share/xorg/Xorg*.log': No existe el archivo o el directorio
---/home/josue/.local/share/xorg/Xorg*.log---
Modeset? Perhaps I should have changed any of those options before installing?
Good, here you have the xorg config. Just for explanation, so that you understand the reason why nvidia is not configured like that on Manjaro:
Manjaro is a Rolling Release, as you know, and therefore it is recommend to stay as default as possible by default. There is no fixed version, which will used for this release, like on linux mint. Therefore you need to set special configurations, like the one on linux mint, yourself, which could, but don’t have to, break after upgrade.
Manjaro is simple, ready to use and is on the on the surface user friendly, but not the same way like Ubuntu or Linux Mint, since it is not a fixed release and special configurations have to be done manually.
Manjaro, as it is now, is a something between beginner friendly Distro like Ubuntu and a “highlevel” Distro for experts like Gentoo. So Manjaro tries to be everything, or better: it tries to balance between these levels.
I guess you can use the same configuration of Linux Mint in Manjaro.
Also to mention. You use on Manjaro Nvidia 470.63.01:
But on Linux Mint the Nvidia Version 384.130:
So you can expect differences…
Thank you but it didn’t work.
/etc/X11/xorg.conf
I copied xorg.conf from Mint to Manjaro’s /etc/X11/ folder. Nothing happened even after rebooting the laptop. Nvidia Xserver settings still lack the important options (selecting the discrete GPU being one of them)
Sorry, no idea. I never used (or even saw it ever since now) this function. Most of the time I do it manually by editing the xorg.conf. Or maybe use the optimus-manager, which should be the default on newer versions.
Thanks but that means I’m still stuck with the Intel integrated graphics, without the option to change it in the Nvidia Settings interface. So, that means nothing is solved and my laptop is still unusable for high demanding GPU tasks.
When you installed the hybrid driver from Manjaro Settings, it should have configured the use of another xorg config file, in theory /etc/X11/mhwd.d/nvidia.conf, do you have that file on your system? Also remove the xorg.conf file you copied to avoid confusion and/or issue the day you remove the Nvidia driver.
Also as mentioned the config was for another older driver, maybe that is why it is different in Nvidia Settings?
//EDIT and on a side note, as far as I know, to offload on the Nvidia card, shouldn’t you use prime-run? For example in Steam, in a game properties, add prime-run %command% to the startup parameter? I mean on a normal Manjaro installation with hybrid driver, without modifying the xorg configs manually with configs from Mint.
I think it works as intended on your system currently, but it doesn’t work like on Mint.
It is fully normal to use prime-run <your command> to offload demanding GPU tasks to nvidia card, but what you actually do is switching the GPU completely. This can only be done by switching the xorg config and restart the xserver (relogin).
So prime-run is just an easier name for __NV_PRIME_RENDER_OFFLOAD=1, have look here: Chapter 34. PRIME Render Offload
Nope. It doesn’t. Just as a test I tried a Linux native game (American Truck Simulator on Steam, it has native Linux runtimes) it runs as slow as garbage in Manjaro. It works like a charm on Mint.
/etc/X11/
The folder is almost empty compared to all the things I see on Mint.
And in /etc/X11/mhwd.d/ the nvidia.conf file is empty. All it has is this:
## Generated by mhwd - Manjaro Hardware Detection
What if you try what I said for your Steam games then?
//EDIT: right click your game in Steam, click Properties, add it to the Launch Options.
I will have to add that command to every single thing I want to run with the GPU? That doesn’t sound like normal usage for me and more like a huge bothersome that I didn’t have with Mint. But I can’t use Mint anymore, it’s going into End of Life support and newer versions don’t ship with KDE Plasma.
Anyways, I want to use Blender and run Windows games with Wine or Lutirs as well, why should this be so cluncky and overcomplicated? And I decided to go for Manjaro because those become outdated and stop working when updates come and the available tools remain outdated…
It’s late, I will have to try this tomorrow.
We could discuss that later, first try, then give result. Then we can see how to improve things but first things first, do the driver work?
ok… I read the README:
On version 384.130, the only way to switch the GPU was with randr.
Now on version 470.63.01, there is also primerenderoffload, but the old behavior is still there with randr.
So you have to configure it like described on the README. I am sorry, but Manjaro does not everything like you used to have on Linux Mint. Primerenderoffload is the default here, if your need the other way, go for it.
Otherwise stay on Linux Mint where everything works like a charm. No one is forcing you to use Manjaro in any way. :wink:
It was causing issues already, some KDE desktop effects such as the cube desktop were not working at all. After removing it, they work again.
Anyways, I just tried adding the prime-run %command% to American Truck Simulator on Steam. It seems to be working. it seems playable. But now how do I get other things to work? And all I get in the Nvidia XServer Settings is a percentage of usage, nothing else.
That’s quite strange, the Nvidia driver provided a way much simpler and more practical way of doing it with a switch in the Nvidia Xserver Settings interface. Why is that missing here? So maybe this machine could actually be working with the Nouveau Open Source drivers but I have to do all that? Oh but now that I remember it, the Nouveau drivers didn’t even recognize the VRAM.
I guess I don’t have much other choice. Other distros don’t come with all the capabilites I need. Then again, wasn’t Manjaro about making Arch usable for everyone just like Ubuntu and Mint make Linux usable for everyone?
Sorry but I can’t do that. The situation is forcing me. I am cornered with an old laptop, that’s all I have, my PC is much older and it’s starting to fail. Mint doesn’t ship with KDE anymore and I got tired of asking them for similar features for Mate and Cinnamon (that used to exist there as well) and they would simply say won’t fix.
If they don’t want to keep the quality and maintain functionalities that existed before, then I can’t do much. If functions (even if some aesthetically pleasing capabilities) in Linux don’t remain consistent how can anyone expect Linux on the desktop to be considered anything else than a joke? Windows users laugh at me on Facebook when I say I Linux can be used as an alternative!
When you were on Linux Mint,you were on NVIDIA mode,meaning everything you do (Firefox,Discord,Steam Games etc) was rendering on your NVIDIA gpu,while this can be great,it also increase the heat of the laptop that some people can concerned and the battery life of the laptop will not be great because the NVIDIA gpu is ON all the time (thats what the iGPU is for,but you are not using it at all).
This was the only way to have a proper NVIDIA functionality back in the day (384.130 drivers),now (470 drivers) things are little different and much like Windows.
Everything is rendering your iGPU,and you do a prime-run when you want some application to use the NVIDIA gpu.
Now this process is automatic with application that uses Vulkan or with CUDA applications,but OpenGL still needs prime-run,so when you said
Sounds like American Truck Simulator uses OpenGL,hence the slowness and why you needed the prime-run in the launch options,but normally all the games with Proton and new natives (like Splitgate) uses Vulkan,so the NVIDIA gpu is detected automatically,you can test it by yourself if you run the Windows version with Proton,now you will be using Vulkan (maybe this can increase the performance of the game as well).
Of course if you don’t like this and want everything to render with the NVIDIA gpu just like you were on Linux Mint you can still do it,just install optimus-manager and change from hybrid mode (the mode you are right now on Manjaro) to NVIDIA mode.
