Nvidia blackscreen when plugged into HDMI
I’m runnin my notebook (Gell G15 5515) with a external HDMI display. About 2 days ago when i turned on the pc it wouldn’t boot screen. When i unplug the HDMI everything works just fine. If i plug the HDMI after logon both the internal and the external monitor goes black… I can still see the cursor and move it. With the alt+shift+f# key i can access other ttys but the screen won’t go back to normal untill i reboot.
My inxi -Fza is:
  Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64
    root=UUID=ea5f2afa-a2dc-453a-b284-0ee423e70cd5 rw quiet splash udev.log_priority=3
  Console: pty pts/4 DM: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: Dell product: Dell G15 5515 v: 1.22.0 serial: <filter> Chassis: type: 10
  Mobo: Dell model: 0C57DP v: A00 serial: <filter> part-nu: 0A6E
    uuid: 4c4c4544-0037-5710-8044-b2c04f565133 UEFI: Dell v: 1.22.0 date: 09/04/2024
  ID-1: BAT1 charge: 47.2 Wh (100.0%) condition: 47.2/86.0 Wh (54.9%) volts: 12.0 min: 11.4
    model: BYD 0x48,0x31,0x43,0x35,0x69,0x03,0x06 type: Li-ion serial: <filter> status: full
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280 serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  Info: model: AMD Ryzen 7 5800H with Radeon Graphics socket: FP6 bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
    model-id: 0x50 (80) stepping: 0 microcode: 0xA500011
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 threads: 16 tpc: 2 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1100 min/max: 400/4463 boost: enabled base/boost: 3200/4450 scaling:
    driver: amd-pstate-epp governor: performance volts: 1.2 V ext-clock: 100 MHz cores: 1: 1100
    2: 1100 3: 1100 4: 1100 5: 1100 6: 1100 7: 1100 8: 1100 9: 1100 10: 1100 11: 1100 12: 1100
    13: 1100 14: 1100 15: 1100 16: 1100 bogomips: 102244
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW; STIBP: always-on; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell driver: nvidia
    v: 570.133.07 alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as of
    2025-01; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023
    pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: none off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2560 class-ID: 0300
  Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 0c45:6720 class-ID: 0e02
  Display: unspecified server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_x11
    driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch tty: 202x55
  Monitor-1: eDP-1 model: LG Display 0x067e built: 2020 res: 1920x1080 dpi: 142 gamma: 1.2
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm: drv: nvidia surfaceless:
    drv: nvidia inactive: wayland,x11
  API: OpenGL v: 4.6.0 vendor: nvidia v: 570.133.07 note: console (EGL sourced) renderer: NVIDIA
    GeForce RTX 3060 Laptop GPU/PCIe/SSE2
  API: Vulkan v: 1.4.304 layers: 2 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 3060
    Laptop GPU driver: N/A device-ID: 10de:2560 surfaces: N/A
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor
    gpu: nvidia-settings,nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
  Device-1: NVIDIA GA106 High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:228e class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio vendor: Dell
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss type: oss-emulator
  Server-2: PipeWire v: 1.4.1 status: n/a (root, process) with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8125 class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer driver: iwlwifi v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  IF-ID-2: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
  Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-3:2 chip-ID: 8087:0029 class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter> status: discoverable: yes
    active: no pairing: yes class-ID: 6c010c
  Local Storage: total: 1.38 TiB used: 545.75 GiB (38.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: KIOXIA model: CL4-3D512-Q11 NVMe SSSTC 512GB
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD
    serial: <filter> fw-rev: 25301114 temp: 35.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: WD Green SN350 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD
    serial: <filter> fw-rev: 33006000 temp: 36.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Generic model: N/A size: 7.44 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A
    serial: <filter> fw-rev: 1.11 scheme: MBR
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 388.74 GiB (42.5%) fs: ext4
    block-size: 4096 B dev: /dev/nvme1n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 308 KiB (0.1%) fs: vfat
    block-size: 512 B dev: /dev/nvme1n1p1 maj-min: 259:1
  ID-1: swap-1 type: file size: 10 GiB used: 0 KiB (0.0%) priority: -2
    file: /etc/shared/swapfile
  System Temperatures: cpu: 68.0 C mobo: 61.0 C sodimm: SODIMM C gpu: nvidia temp: 58 C
  Fan Speeds (rpm): cpu: 2800 mobo: 2500
  Memory: total: 32 GiB available: 31.19 GiB used: 3.32 GiB (10.6%)
  Processes: 417 Power: uptime: 4m states: freeze,mem,disk suspend: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.45 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 257
  Packages: 1470 pm: pacman pkgs: 1446 libs: 379 tools: pamac pm: flatpak pkgs: 24 Compilers:
    clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: Bash (su) v: 5.2.37 running-in: pty pts/4 inxi: 3.3.37
I’ve tryed to downgrade nvidea, tryed installing video-linux and uninstall nvidea … Didn’t had much succes…
My hmwd is:
> 0000:01:00.0 (0300:10de:2560) Display controller nVidia Corporation:
          video-nvidia            2025.01.13               false            PCI
    video-nvidia-470xx            2023.03.23               false            PCI
           video-linux            2024.05.06                true            PCI
Turning on the dell OPTIMUS on system bios the system stays on black screen even without the HMDI display
can you try on boot , press Esc to get Grub ,
go in advanced section , (e)dit ans suppress “quiet splash”
This might be related;
Relevance: Testing and Stable branches.
Please see the Stable Update 2025-03-24 announcement, under Known Issues and Solutions; specifically, the item System may hang during splash screen when Nvidia 570 drivers are used:
See the linked item for a workaround.
