As you are on stable … it should be there …
though all other branches it no longer exists.
(and will shortly be the same for you and stable) Manjaro - Branch Compare
That usually means you should be using some sort of setup for that … in the case of this EOL card … it would probably be bumblebee … but I am not even sure that is available.
Nvidia dropped support for your card years ago.
Very soon you will be forced into the open drivers anyways (video-linux) where the drivers are in the kernel.
I did old tutorial, so only nvidia is recognized, with prime off load. Its from the old forum.
So you are saying that no matter my setup you will ( as distro ) change it, meaning uninstall the drivers and install video-linux ??
I didnt mean it as a distro … its up to nvidia.
The only thing manjaro has ever done is keep things around for much longer, as a niceness.
(and I may have spoke too quickly … after some digging your card is still supported by 340 … but only on older kernels, with a year old driver, that isnt expected to be updated … and 340 series may be dead itself very soon)
(I guess some of them are still in the AUR … not sure how those will turn out either… but our upstream [Arch Linux] has never hosted multiple or older nvidia-xx packages … simply ‘nvidia’ … we had added the extras, as a niceness)
I am not that verse in programming, but why do you have to remove them if say there is no security issue or at least till Xorg drops support. ? I get that the kernel is changing bits and pieces with each update, but nvidia is just used for dispaly and limited range of games in may case, or shall I say in case of old laptops in general. Just saying…
PS. I’ve checked the extra repository and the file( module ) is realy missing
Lots to unpack there as to ‘why’ and ‘how’
For one thing … its extra resources to build modules … for another sources and builds may not be reliable, etc.
You may have also just stumbled on a low-priority bug with the current package.
(as it is likely to disappear anyways)
I am not sure.
In any case I am relatively sure this isnt related to your original thread so I am going to split it.
