After my previous victory of installing the correct drivers and being able to boot, it’s time to tackle number 2.
I have an Asus vivobook pro, with intel 11370 cpu and a Nvidia geforce 3050 and onboard intel gpu. The display is a 2.5K @ 120hz.
I bought this laptop recently, believing that Nvidia and Linux had becom good friends. Well, I have tried about 15 distros. With each and every one of them I had GPU problems. Eventually I tracked those down to the kernel version. I tried Linux mint, fedora, Parrot, Pop os, nobara, kubuntu, ubuntu, solus, neon kde and all with different DEs: kde plasma, mate, cinnamon, xfce, gnome. Sometimes you have the option to load open or proprietary drivers. Even that made no difference.
- Kernel 5.15 and below: horrible flickering, like here. Little did I know you could have a workaround (add
i915.enable_psr=0
as kernel parameter in grub) - from 5.16 things got better. Flickering is gone, but every thing that gets drawn, seems to be really slow. Mouse cursor follows the mouse very late, the cursor freezes. Especially when I get to the top of a window, where the titlebar and close/maximize/minimize buttons are, it seems like a lot of effort for my notebook. It does not feel snappy at all! If I move the mouse a bit fast, it is not a smooth movement (same with trackpad).
- From the 6.0 kernel it gets acceptable if I lower the refresh rate from 120hz to 60hz.
A lower resolution does not help, and it also makes no difference if I force the Nvidia card or Intel GPU. Changing Vsync settings: no difference.
Anyone knows what I could investigate or try?
xrandr:
Screen 0: minimum 320 x 200, current 2560 x 1600, maximum 16384 x 16384
eDP-1 connected primary 2560x1600+0+0 (0x48) normal (normal left inverted right x axis y axis) 344mm x 215mm
Identifier: 0x42
Timestamp: 31619
Subpixel: unknown
Gamma: 1.0:1.2:1.4
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0006af95e400000000
231f0104b5221678037e85ad5142b126
0e505400000001010101010101010101
01010101010104d800a0a0405e603020
aa0058d7100000180c6c00a0a0405e60
3020aa0058d710000018000000fd0030
78cccc37010a202020202020000000fe
004231363051414e30322e4c200a01de
02031d00e3058000e60607016b6b476d
1a00000203307800046b476b47000000
00000000000000000000000000000000
000000000000000000000000000000c9
vrr_capable: 1
range: (0, 1)
scaling mode: Full aspect
supported: Full, Center, Full aspect
Colorspace: Default
supported: Default, RGB_Wide_Gamut_Fixed_Point, RGB_Wide_Gamut_Floating_Point, opRGB, DCI-P3_RGB_D65, BT2020_RGB, BT601_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, BT2020_CYCC, BT2020_YCC
max bpc: 12
range: (6, 12)
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
panel orientation: Normal
supported: Normal, Upside Down, Left Side Up, Right Side Up
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 308
supported: 308
non-desktop: 0
range: (0, 1)
2560x1600 (0x47) 553.000MHz -HSync -VSync +preferred
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 203.31KHz
v: height 1600 start 1610 end 1620 total 1694 clock 120.02Hz
2560x1600 (0x48) 348.500MHz -HSync +VSync *current
h: width 2560 start 2760 end 3032 total 3504 skew 0 clock 99.46KHz
v: height 1600 start 1603 end 1609 total 1658 clock 59.99Hz
2560x1600 (0x49) 276.600MHz -HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 101.69KHz
v: height 1600 start 1610 end 1620 total 1694 clock 60.03Hz
2560x1600 (0x4a) 268.500MHz +HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 98.71KHz
v: height 1600 start 1603 end 1609 total 1646 clock 59.97Hz
2560x1440 (0x4b) 469.125MHz +HSync -VSync DoubleScan
h: width 2560 start 2584 end 2600 total 2640 skew 0 clock 177.70KHz
v: height 1440 start 1441 end 1444 total 1481 clock 59.99Hz
2560x1440 (0x4c) 312.250MHz -HSync +VSync
h: width 2560 start 2752 end 3024 total 3488 skew 0 clock 89.52KHz
v: height 1440 start 1443 end 1448 total 1493 clock 59.96Hz
2560x1440 (0x4d) 241.500MHz +HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 1440 start 1443 end 1448 total 1481 clock 59.95Hz
2048x1536 (0x4e) 388.040MHz -HSync +VSync
h: width 2048 start 2216 end 2440 total 2832 skew 0 clock 137.02KHz
v: height 1536 start 1537 end 1540 total 1612 clock 85.00Hz
2048x1536 (0x4f) 340.480MHz -HSync +VSync
h: width 2048 start 2216 end 2440 total 2832 skew 0 clock 120.23KHz
v: height 1536 start 1537 end 1540 total 1603 clock 75.00Hz
2048x1536 (0x50) 266.950MHz -HSync +VSync
h: width 2048 start 2200 end 2424 total 2800 skew 0 clock 95.34KHz
v: height 1536 start 1537 end 1540 total 1589 clock 60.00Hz
1920x1440 (0x51) 341.350MHz -HSync +VSync
h: width 1920 start 2072 end 2288 total 2656 skew 0 clock 128.52KHz
v: height 1440 start 1441 end 1444 total 1512 clock 85.00Hz
1920x1440 (0x52) 297.000MHz -HSync +VSync
h: width 1920 start 2064 end 2288 total 2640 skew 0 clock 112.50KHz
v: height 1440 start 1441 end 1444 total 1500 clock 75.00Hz
1920x1440 (0x53) 234.000MHz -HSync +VSync
h: width 1920 start 2048 end 2256 total 2600 skew 0 clock 90.00KHz
v: height 1440 start 1441 end 1444 total 1500 clock 60.00Hz
1856x1392 (0x54) 288.000MHz -HSync +VSync
h: width 1856 start 1984 end 2208 total 2560 skew 0 clock 112.50KHz
v: height 1392 start 1393 end 1396 total 1500 clock 75.00Hz
1856x1392 (0x55) 218.300MHz -HSync +VSync
h: width 1856 start 1952 end 2176 total 2528 skew 0 clock 86.35KHz
v: height 1392 start 1393 end 1396 total 1439 clock 60.01Hz
1792x1344 (0x56) 261.000MHz -HSync +VSync
h: width 1792 start 1888 end 2104 total 2456 skew 0 clock 106.27KHz
v: height 1344 start 1345 end 1348 total 1417 clock 75.00Hz
1792x1344 (0x57) 204.800MHz -HSync +VSync
h: width 1792 start 1920 end 2120 total 2448 skew 0 clock 83.66KHz
v: height 1344 start 1345 end 1348 total 1394 clock 60.01Hz
2048x1152 (0x58) 406.500MHz -HSync +VSync DoubleScan
h: width 2048 start 2220 end 2444 total 2840 skew 0 clock 143.13KHz
v: height 1152 start 1153 end 1156 total 1193 clock 59.99Hz
2048x1152 (0x59) 302.500MHz +HSync -VSync DoubleScan
h: width 2048 start 2072 end 2088 total 2128 skew 0 clock 142.15KHz
v: height 1152 start 1153 end 1156 total 1185 clock 59.98Hz
2048x1152 (0x5a) 197.000MHz -HSync +VSync
h: width 2048 start 2184 end 2400 total 2752 skew 0 clock 71.58KHz
v: height 1152 start 1155 end 1160 total 1195 clock 59.90Hz
2048x1152 (0x5b) 156.750MHz +HSync -VSync
h: width 2048 start 2096 end 2128 total 2208 skew 0 clock 70.99KHz
v: height 1152 start 1155 end 1160 total 1185 clock 59.91Hz
1920x1200 (0x5c) 193.250MHz -HSync +VSync
h: width 1920 start 2056 end 2256 total 2592 skew 0 clock 74.56KHz
v: height 1200 start 1203 end 1209 total 1245 clock 59.88Hz
1920x1200 (0x5d) 154.000MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 74.04KHz
v: height 1200 start 1203 end 1209 total 1235 clock 59.95Hz
1920x1080 (0x5e) 356.375MHz -HSync +VSync DoubleScan
h: width 1920 start 2080 end 2288 total 2656 skew 0 clock 134.18KHz
v: height 1080 start 1081 end 1084 total 1118 clock 60.01Hz
1920x1080 (0x5f) 266.500MHz +HSync -VSync DoubleScan
h: width 1920 start 1944 end 1960 total 2000 skew 0 clock 133.25KHz
v: height 1080 start 1081 end 1084 total 1111 clock 59.97Hz
1920x1080 (0x60) 173.000MHz -HSync +VSync
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.16KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.96Hz
1920x1080 (0x61) 138.500MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 66.59KHz
v: height 1080 start 1083 end 1088 total 1111 clock 59.93Hz
1600x1200 (0x62) 229.500MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 106.25KHz
v: height 1200 start 1201 end 1204 total 1250 clock 85.00Hz
1600x1200 (0x63) 202.500MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 93.75KHz
v: height 1200 start 1201 end 1204 total 1250 clock 75.00Hz
1600x1200 (0x64) 189.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 87.50KHz
v: height 1200 start 1201 end 1204 total 1250 clock 70.00Hz
1600x1200 (0x65) 175.500MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 81.25KHz
v: height 1200 start 1201 end 1204 total 1250 clock 65.00Hz
1600x1200 (0x66) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1680x1050 (0x67) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1680x1050 (0x68) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1400x1050 (0x69) 155.800MHz +HSync +VSync
h: width 1400 start 1464 end 1784 total 1912 skew 0 clock 81.49KHz
v: height 1050 start 1052 end 1064 total 1090 clock 74.76Hz
1400x1050 (0x6a) 122.000MHz +HSync +VSync
h: width 1400 start 1488 end 1640 total 1880 skew 0 clock 64.89KHz
v: height 1050 start 1052 end 1064 total 1082 clock 59.98Hz
1600x900 (0x6b) 246.000MHz -HSync +VSync DoubleScan
h: width 1600 start 1728 end 1900 total 2200 skew 0 clock 111.82KHz
v: height 900 start 901 end 904 total 932 clock 59.99Hz
1600x900 (0x6c) 186.500MHz +HSync -VSync DoubleScan
h: width 1600 start 1624 end 1640 total 1680 skew 0 clock 111.01KHz
v: height 900 start 901 end 904 total 926 clock 59.94Hz
1600x900 (0x6d) 118.250MHz -HSync +VSync
h: width 1600 start 1696 end 1856 total 2112 skew 0 clock 55.99KHz
v: height 900 start 903 end 908 total 934 clock 59.95Hz
1600x900 (0x6e) 97.500MHz +HSync -VSync
h: width 1600 start 1648 end 1680 total 1760 skew 0 clock 55.40KHz
v: height 900 start 903 end 908 total 926 clock 59.82Hz
1280x1024 (0x6f) 157.500MHz +HSync +VSync
h: width 1280 start 1344 end 1504 total 1728 skew 0 clock 91.15KHz
v: height 1024 start 1025 end 1028 total 1072 clock 85.02Hz
1280x1024 (0x70) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x71) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1400x900 (0x72) 103.500MHz -HSync +VSync
h: width 1400 start 1480 end 1624 total 1848 skew 0 clock 56.01KHz
v: height 900 start 903 end 913 total 934 clock 59.96Hz
1400x900 (0x73) 86.500MHz +HSync -VSync
h: width 1400 start 1448 end 1480 total 1560 skew 0 clock 55.45KHz
v: height 900 start 903 end 913 total 926 clock 59.88Hz
1280x960 (0x74) 148.500MHz +HSync +VSync
h: width 1280 start 1344 end 1504 total 1728 skew 0 clock 85.94KHz
v: height 960 start 961 end 964 total 1011 clock 85.00Hz
1280x960 (0x75) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1440x810 (0x76) 198.125MHz -HSync +VSync DoubleScan
h: width 1440 start 1548 end 1704 total 1968 skew 0 clock 100.67KHz
v: height 810 start 811 end 814 total 839 clock 60.00Hz
1440x810 (0x77) 151.875MHz +HSync -VSync DoubleScan
h: width 1440 start 1464 end 1480 total 1520 skew 0 clock 99.92KHz
v: height 810 start 811 end 814 total 833 clock 59.97Hz
1368x768 (0x78) 85.250MHz -HSync +VSync
h: width 1368 start 1440 end 1576 total 1784 skew 0 clock 47.79KHz
v: height 768 start 771 end 781 total 798 clock 59.88Hz
1368x768 (0x79) 72.250MHz +HSync -VSync
h: width 1368 start 1416 end 1448 total 1528 skew 0 clock 47.28KHz
v: height 768 start 771 end 781 total 790 clock 59.85Hz
1280x800 (0x7a) 174.250MHz -HSync +VSync DoubleScan
h: width 1280 start 1380 end 1516 total 1752 skew 0 clock 99.46KHz
v: height 800 start 801 end 804 total 829 clock 59.99Hz
1280x800 (0x7b) 134.250MHz +HSync -VSync DoubleScan
h: width 1280 start 1304 end 1320 total 1360 skew 0 clock 98.71KHz
v: height 800 start 801 end 804 total 823 clock 59.97Hz
1280x800 (0x7c) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x800 (0x7d) 71.000MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 49.31KHz
v: height 800 start 803 end 809 total 823 clock 59.91Hz
1152x864 (0x7e) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x7f) 156.125MHz -HSync +VSync DoubleScan
h: width 1280 start 1376 end 1512 total 1744 skew 0 clock 89.52KHz
v: height 720 start 721 end 724 total 746 clock 60.00Hz
1280x720 (0x80) 120.750MHz +HSync -VSync DoubleScan
h: width 1280 start 1304 end 1320 total 1360 skew 0 clock 88.79KHz
v: height 720 start 721 end 724 total 740 clock 59.99Hz
1280x720 (0x81) 74.500MHz -HSync +VSync
h: width 1280 start 1344 end 1472 total 1664 skew 0 clock 44.77KHz
v: height 720 start 723 end 728 total 748 clock 59.86Hz
1280x720 (0x82) 63.750MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 44.27KHz
v: height 720 start 723 end 728 total 741 clock 59.74Hz
1024x768 (0x83) 194.020MHz -HSync +VSync DoubleScan
h: width 1024 start 1108 end 1220 total 1416 skew 0 clock 137.02KHz
v: height 768 start 768 end 770 total 806 clock 85.00Hz
1024x768 (0x84) 170.240MHz -HSync +VSync DoubleScan
h: width 1024 start 1108 end 1220 total 1416 skew 0 clock 120.23KHz
v: height 768 start 768 end 770 total 801 clock 75.05Hz
1024x768 (0x85) 133.475MHz -HSync +VSync DoubleScan
h: width 1024 start 1100 end 1212 total 1400 skew 0 clock 95.34KHz
v: height 768 start 768 end 770 total 794 clock 60.04Hz
1024x768 (0x86) 94.500MHz +HSync +VSync
h: width 1024 start 1072 end 1168 total 1376 skew 0 clock 68.68KHz
v: height 768 start 769 end 772 total 808 clock 85.00Hz
1024x768 (0x87) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x88) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x89) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
1024x768i (0x8a) 44.900MHz +HSync +VSync Interlace
h: width 1024 start 1032 end 1208 total 1264 skew 0 clock 35.52KHz
v: height 768 start 768 end 776 total 817 clock 86.96Hz
960x720 (0x8b) 170.675MHz -HSync +VSync DoubleScan
h: width 960 start 1036 end 1144 total 1328 skew 0 clock 128.52KHz
v: height 720 start 720 end 722 total 756 clock 85.00Hz
960x720 (0x8c) 148.500MHz -HSync +VSync DoubleScan
h: width 960 start 1032 end 1144 total 1320 skew 0 clock 112.50KHz
v: height 720 start 720 end 722 total 750 clock 75.00Hz
960x720 (0x8d) 117.000MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1128 total 1300 skew 0 clock 90.00KHz
v: height 720 start 720 end 722 total 750 clock 60.00Hz
928x696 (0x8e) 144.000MHz -HSync +VSync DoubleScan
h: width 928 start 992 end 1104 total 1280 skew 0 clock 112.50KHz
v: height 696 start 696 end 698 total 750 clock 75.00Hz
928x696 (0x8f) 109.150MHz -HSync +VSync DoubleScan
h: width 928 start 976 end 1088 total 1264 skew 0 clock 86.35KHz
v: height 696 start 696 end 698 total 719 clock 60.05Hz
896x672 (0x90) 130.500MHz -HSync +VSync DoubleScan
h: width 896 start 944 end 1052 total 1228 skew 0 clock 106.27KHz
v: height 672 start 672 end 674 total 708 clock 75.05Hz
896x672 (0x91) 102.400MHz -HSync +VSync DoubleScan
h: width 896 start 960 end 1060 total 1224 skew 0 clock 83.66KHz
v: height 672 start 672 end 674 total 697 clock 60.01Hz
1024x576 (0x92) 98.500MHz -HSync +VSync DoubleScan
h: width 1024 start 1092 end 1200 total 1376 skew 0 clock 71.58KHz
v: height 576 start 577 end 580 total 597 clock 59.95Hz
1024x576 (0x93) 78.375MHz +HSync -VSync DoubleScan
h: width 1024 start 1048 end 1064 total 1104 skew 0 clock 70.99KHz
v: height 576 start 577 end 580 total 592 clock 59.96Hz
1024x576 (0x94) 46.500MHz -HSync +VSync
h: width 1024 start 1064 end 1160 total 1296 skew 0 clock 35.88KHz
v: height 576 start 579 end 584 total 599 clock 59.90Hz
1024x576 (0x95) 42.000MHz +HSync -VSync
h: width 1024 start 1072 end 1104 total 1184 skew 0 clock 35.47KHz
v: height 576 start 579 end 584 total 593 clock 59.82Hz
960x600 (0x96) 96.625MHz -HSync +VSync DoubleScan
h: width 960 start 1028 end 1128 total 1296 skew 0 clock 74.56KHz
v: height 600 start 601 end 604 total 622 clock 59.93Hz
960x600 (0x97) 77.000MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 74.04KHz
v: height 600 start 601 end 604 total 617 clock 60.00Hz
832x624 (0x98) 57.284MHz -HSync -VSync
h: width 832 start 864 end 928 total 1152 skew 0 clock 49.73KHz
v: height 624 start 625 end 628 total 667 clock 74.55Hz
960x540 (0x99) 86.500MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1124 total 1288 skew 0 clock 67.16KHz
v: height 540 start 541 end 544 total 560 clock 59.96Hz
960x540 (0x9a) 69.250MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 66.59KHz
v: height 540 start 541 end 544 total 555 clock 59.99Hz
960x540 (0x9b) 40.750MHz -HSync +VSync
h: width 960 start 992 end 1088 total 1216 skew 0 clock 33.51KHz
v: height 540 start 543 end 548 total 562 clock 59.63Hz
960x540 (0x9c) 37.250MHz +HSync -VSync
h: width 960 start 1008 end 1040 total 1120 skew 0 clock 33.26KHz
v: height 540 start 543 end 548 total 556 clock 59.82Hz
800x600 (0x9d) 114.750MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 106.25KHz
v: height 600 start 600 end 602 total 625 clock 85.00Hz
800x600 (0x9e) 101.250MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 93.75KHz
v: height 600 start 600 end 602 total 625 clock 75.00Hz
800x600 (0x9f) 94.500MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 87.50KHz
v: height 600 start 600 end 602 total 625 clock 70.00Hz
800x600 (0xa0) 87.750MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 81.25KHz
v: height 600 start 600 end 602 total 625 clock 65.00Hz
800x600 (0xa1) 81.000MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 75.00KHz
v: height 600 start 600 end 602 total 625 clock 60.00Hz
800x600 (0xa2) 56.300MHz +HSync +VSync
h: width 800 start 832 end 896 total 1048 skew 0 clock 53.72KHz
v: height 600 start 601 end 604 total 631 clock 85.14Hz
800x600 (0xa3) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0xa4) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0xa5) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0xa6) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
840x525 (0xa7) 73.125MHz -HSync +VSync DoubleScan
h: width 840 start 892 end 980 total 1120 skew 0 clock 65.29KHz
v: height 525 start 526 end 529 total 544 clock 60.01Hz
840x525 (0xa8) 59.500MHz +HSync -VSync DoubleScan
h: width 840 start 864 end 880 total 920 skew 0 clock 64.67KHz
v: height 525 start 526 end 529 total 540 clock 59.88Hz
864x486 (0xa9) 32.500MHz -HSync +VSync
h: width 864 start 888 end 968 total 1072 skew 0 clock 30.32KHz
v: height 486 start 489 end 494 total 506 clock 59.92Hz
864x486 (0xaa) 30.500MHz +HSync -VSync
h: width 864 start 912 end 944 total 1024 skew 0 clock 29.79KHz
v: height 486 start 489 end 494 total 500 clock 59.57Hz
700x525 (0xab) 77.900MHz +HSync +VSync DoubleScan
h: width 700 start 732 end 892 total 956 skew 0 clock 81.49KHz
v: height 525 start 526 end 532 total 545 clock 74.76Hz
700x525 (0xac) 61.000MHz +HSync +VSync DoubleScan
h: width 700 start 744 end 820 total 940 skew 0 clock 64.89KHz
v: height 525 start 526 end 532 total 541 clock 59.98Hz
800x450 (0xad) 59.125MHz -HSync +VSync DoubleScan
h: width 800 start 848 end 928 total 1056 skew 0 clock 55.99KHz
v: height 450 start 451 end 454 total 467 clock 59.95Hz
800x450 (0xae) 48.750MHz +HSync -VSync DoubleScan
h: width 800 start 824 end 840 total 880 skew 0 clock 55.40KHz
v: height 450 start 451 end 454 total 463 clock 59.82Hz
640x512 (0xaf) 78.750MHz +HSync +VSync DoubleScan
h: width 640 start 672 end 752 total 864 skew 0 clock 91.15KHz
v: height 512 start 512 end 514 total 536 clock 85.02Hz
640x512 (0xb0) 67.500MHz +HSync +VSync DoubleScan
h: width 640 start 648 end 720 total 844 skew 0 clock 79.98KHz
v: height 512 start 512 end 514 total 533 clock 75.02Hz
640x512 (0xb1) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 664 end 720 total 844 skew 0 clock 63.98KHz
v: height 512 start 512 end 514 total 533 clock 60.02Hz
700x450 (0xb2) 51.750MHz -HSync +VSync DoubleScan
h: width 700 start 740 end 812 total 924 skew 0 clock 56.01KHz
v: height 450 start 451 end 456 total 467 clock 59.96Hz
700x450 (0xb3) 43.250MHz +HSync -VSync DoubleScan
h: width 700 start 724 end 740 total 780 skew 0 clock 55.45KHz
v: height 450 start 451 end 456 total 463 clock 59.88Hz
640x480 (0xb4) 74.250MHz +HSync +VSync DoubleScan
h: width 640 start 672 end 752 total 864 skew 0 clock 85.94KHz
v: height 480 start 480 end 482 total 505 clock 85.09Hz
640x480 (0xb5) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 688 end 744 total 900 skew 0 clock 60.00KHz
v: height 480 start 480 end 482 total 500 clock 60.00Hz
640x480 (0xb6) 36.000MHz -HSync -VSync
h: width 640 start 696 end 752 total 832 skew 0 clock 43.27KHz
v: height 480 start 481 end 484 total 509 clock 85.01Hz
640x480 (0xb7) 31.500MHz -HSync -VSync
h: width 640 start 664 end 704 total 832 skew 0 clock 37.86KHz
v: height 480 start 489 end 492 total 520 clock 72.81Hz
640x480 (0xb8) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0xb9) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x405 (0xba) 22.500MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 25.11KHz
v: height 405 start 408 end 413 total 422 clock 59.51Hz
720x405 (0xbb) 21.750MHz +HSync -VSync
h: width 720 start 768 end 800 total 880 skew 0 clock 24.72KHz
v: height 405 start 408 end 413 total 419 clock 58.99Hz
720x400 (0xbc) 35.500MHz -HSync +VSync
h: width 720 start 756 end 828 total 936 skew 0 clock 37.93KHz
v: height 400 start 401 end 404 total 446 clock 85.04Hz
684x384 (0xbd) 42.625MHz -HSync +VSync DoubleScan
h: width 684 start 720 end 788 total 892 skew 0 clock 47.79KHz
v: height 384 start 385 end 390 total 399 clock 59.88Hz
684x384 (0xbe) 36.125MHz +HSync -VSync DoubleScan
h: width 684 start 708 end 724 total 764 skew 0 clock 47.28KHz
v: height 384 start 385 end 390 total 395 clock 59.85Hz
640x400 (0xbf) 41.750MHz -HSync +VSync DoubleScan
h: width 640 start 676 end 740 total 840 skew 0 clock 49.70KHz
v: height 400 start 401 end 404 total 415 clock 59.88Hz
640x400 (0xc0) 35.500MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 49.31KHz
v: height 400 start 401 end 404 total 411 clock 59.98Hz
640x400 (0xc1) 31.500MHz -HSync +VSync
h: width 640 start 672 end 736 total 832 skew 0 clock 37.86KHz
v: height 400 start 401 end 404 total 445 clock 85.08Hz
576x432 (0xc2) 54.000MHz +HSync +VSync DoubleScan
h: width 576 start 608 end 672 total 800 skew 0 clock 67.50KHz
v: height 432 start 432 end 434 total 450 clock 75.00Hz
640x360 (0xc3) 37.250MHz -HSync +VSync DoubleScan
h: width 640 start 672 end 736 total 832 skew 0 clock 44.77KHz
v: height 360 start 361 end 364 total 374 clock 59.86Hz
640x360 (0xc4) 31.875MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 44.27KHz
v: height 360 start 361 end 364 total 370 clock 59.83Hz
640x360 (0xc5) 18.000MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 22.50KHz
v: height 360 start 363 end 368 total 376 clock 59.84Hz
640x360 (0xc6) 17.750MHz +HSync -VSync
h: width 640 start 688 end 720 total 800 skew 0 clock 22.19KHz
v: height 360 start 363 end 368 total 374 clock 59.32Hz
640x350 (0xc7) 31.500MHz +HSync -VSync
v: height 350 start 382 end 385 total 445 clock 85.08Hz
512x384 (0xc8) 47.250MHz +HSync +VSync DoubleScan
h: width 512 start 536 end 584 total 688 skew 0 clock 68.68KHz
v: height 384 start 384 end 386 total 404 clock 85.00Hz
512x384 (0xc9) 39.375MHz +HSync +VSync DoubleScan
h: width 512 start 520 end 568 total 656 skew 0 clock 60.02KHz
v: height 384 start 384 end 386 total 400 clock 75.03Hz
512x384 (0xca) 37.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 664 skew 0 clock 56.48KHz
v: height 384 start 385 end 388 total 403 clock 70.07Hz
512x384 (0xcb) 32.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 672 skew 0 clock 48.36KHz
v: height 384 start 385 end 388 total 403 clock 60.00Hz
512x384i (0xcc) 22.450MHz +HSync +VSync Interlace DoubleScan
h: width 512 start 516 end 604 total 632 skew 0 clock 35.52KHz
v: height 384 start 384 end 388 total 408 clock 87.06Hz
512x288 (0xcd) 23.250MHz -HSync +VSync DoubleScan
h: width 512 start 532 end 580 total 648 skew 0 clock 35.88KHz
v: height 288 start 289 end 292 total 299 clock 60.00Hz
512x288 (0xce) 21.000MHz +HSync -VSync DoubleScan
h: width 512 start 536 end 552 total 592 skew 0 clock 35.47KHz
v: height 288 start 289 end 292 total 296 clock 59.92Hz
416x312 (0xcf) 28.642MHz -HSync -VSync DoubleScan
h: width 416 start 432 end 464 total 576 skew 0 clock 49.73KHz
v: height 312 start 312 end 314 total 333 clock 74.66Hz
480x270 (0xd0) 20.375MHz -HSync +VSync DoubleScan
h: width 480 start 496 end 544 total 608 skew 0 clock 33.51KHz
v: height 270 start 271 end 274 total 281 clock 59.63Hz
480x270 (0xd1) 18.625MHz +HSync -VSync DoubleScan
h: width 480 start 504 end 520 total 560 skew 0 clock 33.26KHz
v: height 270 start 271 end 274 total 278 clock 59.82Hz
400x300 (0xd2) 28.150MHz +HSync +VSync DoubleScan
h: width 400 start 416 end 448 total 524 skew 0 clock 53.72KHz
v: height 300 start 300 end 302 total 315 clock 85.27Hz
400x300 (0xd3) 25.000MHz +HSync +VSync DoubleScan
h: width 400 start 428 end 488 total 520 skew 0 clock 48.08KHz
v: height 300 start 318 end 321 total 333 clock 72.19Hz
400x300 (0xd4) 24.750MHz +HSync +VSync DoubleScan
h: width 400 start 408 end 448 total 528 skew 0 clock 46.88KHz
v: height 300 start 300 end 302 total 312 clock 75.12Hz
400x300 (0xd5) 20.000MHz +HSync +VSync DoubleScan
h: width 400 start 420 end 484 total 528 skew 0 clock 37.88KHz
v: height 300 start 300 end 302 total 314 clock 60.32Hz
400x300 (0xd6) 18.000MHz +HSync +VSync DoubleScan
h: width 400 start 412 end 448 total 512 skew 0 clock 35.16KHz
v: height 300 start 300 end 301 total 312 clock 56.34Hz
432x243 (0xd7) 16.250MHz -HSync +VSync DoubleScan
h: width 432 start 444 end 484 total 536 skew 0 clock 30.32KHz
v: height 243 start 244 end 247 total 253 clock 59.92Hz
432x243 (0xd8) 15.250MHz +HSync -VSync DoubleScan
h: width 432 start 456 end 472 total 512 skew 0 clock 29.79KHz
v: height 243 start 244 end 247 total 250 clock 59.57Hz
320x240 (0xd9) 18.000MHz -HSync -VSync DoubleScan
h: width 320 start 348 end 376 total 416 skew 0 clock 43.27KHz
v: height 240 start 240 end 242 total 254 clock 85.18Hz
320x240 (0xda) 15.750MHz -HSync -VSync DoubleScan
h: width 320 start 332 end 352 total 416 skew 0 clock 37.86KHz
v: height 240 start 244 end 246 total 260 clock 72.81Hz
320x240 (0xdb) 15.750MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 360 total 420 skew 0 clock 37.50KHz
v: height 240 start 240 end 242 total 250 clock 75.00Hz
320x240 (0xdc) 12.587MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 376 total 400 skew 0 clock 31.47KHz
v: height 240 start 245 end 246 total 262 clock 60.05Hz
360x202 (0xdd) 11.250MHz -HSync +VSync DoubleScan
h: width 360 start 372 end 404 total 448 skew 0 clock 25.11KHz
v: height 202 start 204 end 206 total 211 clock 59.51Hz
360x202 (0xde) 10.875MHz +HSync -VSync DoubleScan
h: width 360 start 384 end 400 total 440 skew 0 clock 24.72KHz
v: height 202 start 204 end 206 total 209 clock 59.13Hz
360x200 (0xdf) 17.750MHz -HSync +VSync DoubleScan
h: width 360 start 378 end 414 total 468 skew 0 clock 37.93KHz
v: height 200 start 200 end 202 total 223 clock 85.04Hz
320x200 (0xe0) 15.750MHz -HSync +VSync DoubleScan
h: width 320 start 336 end 368 total 416 skew 0 clock 37.86KHz
v: height 200 start 200 end 202 total 222 clock 85.27Hz
320x180 (0xe1) 9.000MHz -HSync +VSync DoubleScan
h: width 320 start 332 end 360 total 400 skew 0 clock 22.50KHz
v: height 180 start 181 end 184 total 188 clock 59.84Hz
320x180 (0xe2) 8.875MHz +HSync -VSync DoubleScan
h: width 320 start 344 end 360 total 400 skew 0 clock 22.19KHz
v: height 180 start 181 end 184 total 187 clock 59.32Hz
320x175 (0xe3) 15.750MHz +HSync -VSync DoubleScan
v: height 175 start 191 end 192 total 222 clock 85.27Hz
inxi
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
driver: nvidia v: 525.60.11 arch: Ampere pcie: speed: 2.5 GT/s lanes: 4
bus-ID: 01:00.0 chip-ID: 10de:25a2 class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 13d3:5458 class-ID: fe01 serial: 0x0001
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model: AU Optronics 0xe495 res: 2560x1600 dpi: 189
size: 344x215mm (13.54x8.46") diag: 406mm (16") modes: 2560x1600
API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct render: Yes
