Thanks for answering, @Mirdarthos @Nachlese !
I’m using Linux 5.15.32-1-MANJARO. I’ve read that it has ntfs support maybe I’ll try removing the ntfs-3g first.
0 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'i', '@supabase/supabase-js' ]
1 info using npm@8.5.5
2 info using node@v17.8.0
3 timing npm:load:whichnode Completed in 1ms
4 timing config:load:defaults Completed in 9ms
5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 9ms
6 timing config:load:builtin Completed in 11ms
7 timing config:load:cli Completed in 11ms
8 timing config:load:env Completed in 2ms
9 timing config:load:file:/run/media/user/Personal/Projects/react/my-app/.npmrc Completed in 2ms
10 timing config:load:project Completed in 22ms
11 timing config:load:file:/home/user/.npmrc Completed in 8ms
12 timing config:load:user Completed in 10ms
13 timing config:load:file:/home/user/.npm-global/etc/npmrc Completed in 1ms
14 timing config:load:global Completed in 2ms
15 timing config:load:validate Completed in 4ms
16 timing config:load:credentials Completed in 4ms
17 timing config:load:setEnvs Completed in 4ms
18 timing config:load Completed in 85ms
19 timing npm:load:configload Completed in 86ms
20 timing npm:load:setTitle Completed in 3ms
21 timing config:load:flatten Completed in 14ms
22 timing npm:load:display Completed in 24ms
23 verbose logfile /home/user/.npm/_logs/2022-05-03T11_22_18_326Z-debug-0.log
24 timing npm:load:logFile Completed in 38ms
25 timing npm:load:timers Completed in 1ms
26 timing npm:load:configScope Completed in 0ms
27 timing npm:load Completed in 157ms
28 timing arborist:ctor Completed in 4ms
29 silly logfile start cleaning logs, removing 1 files
30 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
31 timing idealTree:init Completed in 5953ms
32 timing idealTree:userRequests Completed in 13ms
33 silly idealTree buildDeps
34 silly fetch manifest @supabase/supabase-js@*
35 http fetch GET 200 https://registry.npmjs.org/@supabase%2fsupabase-js 28760ms (cache hit)
36 silly placeDep ROOT @supabase/supabase-js@1.35.2 OK for: my-app@0.1.0 want: *
37 silly fetch manifest @supabase/functions-js@^1.3.3
38 silly fetch manifest @supabase/gotrue-js@^1.22.13
39 silly fetch manifest @supabase/postgrest-js@^0.37.2
40 silly fetch manifest @supabase/realtime-js@^1.7.2
41 silly fetch manifest @supabase/storage-js@^1.7.0
42 http fetch GET 200 https://registry.npmjs.org/@supabase%2ffunctions-js 396ms (cache hit)
43 http fetch GET 200 https://registry.npmjs.org/@supabase%2fgotrue-js 401ms (cache hit)
44 http fetch GET 200 https://registry.npmjs.org/@supabase%2fpostgrest-js 407ms (cache hit)
45 http fetch GET 200 https://registry.npmjs.org/@supabase%2frealtime-js 413ms (cache hit)
46 http fetch GET 200 https://registry.npmjs.org/@supabase%2fstorage-js 419ms (cache hit)
47 timing idealTree:#root Completed in 29279ms
48 silly placeDep ROOT @supabase/functions-js@1.3.3 OK for: @supabase/supabase-js@1.35.2 want: ^1.3.3
49 silly placeDep ROOT @supabase/gotrue-js@1.22.13 OK for: @supabase/supabase-js@1.35.2 want: ^1.22.13
50 silly placeDep ROOT @supabase/postgrest-js@0.37.2 OK for: @supabase/supabase-js@1.35.2 want: ^0.37.2
51 silly placeDep ROOT @supabase/realtime-js@1.7.2 OK for: @supabase/supabase-js@1.35.2 want: ^1.7.2
52 silly placeDep ROOT @supabase/storage-js@1.7.0 OK for: @supabase/supabase-js@1.35.2 want: ^1.7.0
53 silly fetch manifest cross-fetch@^3.1.5
54 silly fetch manifest cross-fetch@^3.0.6
55 silly fetch manifest @types/phoenix@^1.5.4
56 silly fetch manifest websocket@^1.0.34
57 silly fetch manifest cross-fetch@^3.1.0
58 http fetch GET 200 https://registry.npmjs.org/cross-fetch 62ms (cache hit)
59 http fetch GET 200 https://registry.npmjs.org/@types%2fphoenix 68ms (cache hit)
60 http fetch GET 200 https://registry.npmjs.org/websocket 68ms (cache hit)
61 timing idealTree:node_modules/@supabase/supabase-js Completed in 143ms
62 silly placeDep ROOT cross-fetch@3.1.5 OK for: @supabase/functions-js@1.3.3 want: ^3.1.5
63 silly fetch manifest node-fetch@2.6.7
64 http fetch GET 200 https://registry.npmjs.org/node-fetch 17ms (cache hit)
65 timing idealTree:node_modules/@supabase/functions-js Completed in 44ms
66 timing idealTree:node_modules/@supabase/gotrue-js Completed in 0ms
67 timing idealTree:node_modules/@supabase/postgrest-js Completed in 0ms
68 silly placeDep ROOT @types/phoenix@1.5.4 OK for: @supabase/realtime-js@1.7.2 want: ^1.5.4
69 silly placeDep ROOT websocket@1.0.34 OK for: @supabase/realtime-js@1.7.2 want: ^1.0.34
70 silly fetch manifest bufferutil@^4.0.1
71 silly fetch manifest debug@^2.2.0
72 silly fetch manifest es5-ext@^0.10.50
73 silly fetch manifest utf-8-validate@^5.0.2
74 silly fetch manifest yaeti@^0.0.6
75 http fetch GET 200 https://registry.npmjs.org/bufferutil 61ms (cache hit)
76 http fetch GET 200 https://registry.npmjs.org/debug 62ms (cache hit)
77 http fetch GET 200 https://registry.npmjs.org/es5-ext 76ms (cache hit)
78 http fetch GET 200 https://registry.npmjs.org/utf-8-validate 79ms (cache hit)
79 http fetch GET 200 https://registry.npmjs.org/yaeti 80ms (cache hit)
80 timing idealTree:node_modules/@supabase/realtime-js Completed in 120ms
81 timing idealTree:node_modules/@supabase/storage-js Completed in 0ms
82 timing idealTree:node_modules/@types/phoenix Completed in 0ms
83 silly fetch manifest encoding@^0.1.0
84 http fetch GET 200 https://registry.npmjs.org/encoding 19ms (cache hit)
85 silly placeDep ROOT node-fetch@2.6.7 OK for: cross-fetch@3.1.5 want: 2.6.7
86 silly fetch manifest whatwg-url@^5.0.0
87 http fetch GET 200 https://registry.npmjs.org/whatwg-url 16ms (cache hit)
88 timing idealTree:node_modules/cross-fetch Completed in 67ms
89 silly placeDep node_modules/node-fetch whatwg-url@5.0.0 OK for: node-fetch@2.6.7 want: ^5.0.0
90 silly fetch manifest tr46@~0.0.3
91 silly fetch manifest webidl-conversions@^3.0.0
92 http fetch GET 200 https://registry.npmjs.org/tr46 28ms (cache hit)
93 http fetch GET 200 https://registry.npmjs.org/webidl-conversions 35ms (cache hit)
94 timing idealTree:node_modules/node-fetch Completed in 65ms
95 silly placeDep ROOT bufferutil@4.0.6 OK for: websocket@1.0.34 want: ^4.0.1
96 silly placeDep node_modules/websocket debug@2.6.9 OK for: websocket@1.0.34 want: ^2.2.0
97 silly placeDep ROOT es5-ext@0.10.61 OK for: websocket@1.0.34 want: ^0.10.50
98 silly placeDep ROOT utf-8-validate@5.0.9 OK for: websocket@1.0.34 want: ^5.0.2
99 silly placeDep ROOT yaeti@0.0.6 OK for: websocket@1.0.34 want: ^0.0.6
100 silly fetch manifest node-gyp-build@^4.3.0
101 silly fetch manifest ms@2.0.0
102 silly fetch manifest es6-iterator@^2.0.3
103 silly fetch manifest es6-symbol@^3.1.3
104 silly fetch manifest next-tick@^1.1.0
105 http fetch GET 200 https://registry.npmjs.org/node-gyp-build 87ms (cache hit)
106 http fetch GET 200 https://registry.npmjs.org/ms 90ms (cache hit)
107 http fetch GET 200 https://registry.npmjs.org/es6-iterator 99ms (cache hit)
108 http fetch GET 200 https://registry.npmjs.org/es6-symbol 104ms (cache hit)
109 http fetch GET 200 https://registry.npmjs.org/next-tick 104ms (cache hit)
110 timing idealTree:node_modules/websocket Completed in 178ms
111 silly placeDep ROOT node-gyp-build@4.4.0 OK for: bufferutil@4.0.6 want: ^4.3.0
112 timing idealTree:node_modules/bufferutil Completed in 10ms
113 silly placeDep ROOT es6-iterator@2.0.3 OK for: es5-ext@0.10.61 want: ^2.0.3
114 silly placeDep ROOT es6-symbol@3.1.3 OK for: es5-ext@0.10.61 want: ^3.1.3
115 silly placeDep ROOT next-tick@1.1.0 OK for: es5-ext@0.10.61 want: ^1.1.0
116 silly fetch manifest d@1
117 silly fetch manifest d@^1.0.1
118 silly fetch manifest ext@^1.1.2
119 http fetch GET 200 https://registry.npmjs.org/d 45ms (cache hit)
120 http fetch GET 200 https://registry.npmjs.org/ext 44ms (cache hit)
121 timing idealTree:node_modules/es5-ext Completed in 80ms
122 silly placeDep ROOT d@1.0.1 OK for: es6-iterator@2.0.3 want: 1
123 silly fetch manifest type@^1.0.1
124 http fetch GET 200 https://registry.npmjs.org/type 22ms (cache hit)
125 timing idealTree:node_modules/es6-iterator Completed in 36ms
126 silly placeDep ROOT type@1.2.0 OK for: d@1.0.1 want: ^1.0.1
127 timing idealTree:node_modules/d Completed in 8ms
128 silly placeDep ROOT ext@1.6.0 OK for: es6-symbol@3.1.3 want: ^1.1.2
129 silly fetch manifest type@^2.5.0
130 timing idealTree:node_modules/es6-symbol Completed in 11ms
131 silly placeDep node_modules/ext type@2.6.0 OK for: ext@1.6.0 want: ^2.5.0
132 timing idealTree:node_modules/ext Completed in 5ms
133 timing idealTree:node_modules/next-tick Completed in 0ms
134 timing idealTree:node_modules/node-gyp-build Completed in 0ms
135 timing idealTree:node_modules/type Completed in 0ms
136 timing idealTree:node_modules/utf-8-validate Completed in 0ms
137 timing idealTree:node_modules/yaeti Completed in 0ms
138 timing idealTree:node_modules/ext/node_modules/type Completed in 1ms
139 silly placeDep node_modules/node-fetch tr46@0.0.3 OK for: whatwg-url@5.0.0 want: ~0.0.3
140 silly placeDep node_modules/node-fetch webidl-conversions@3.0.1 OK for: whatwg-url@5.0.0 want: ^3.0.0
141 timing idealTree:node_modules/node-fetch/node_modules/whatwg-url Completed in 9ms
142 timing idealTree:node_modules/node-fetch/node_modules/tr46 Completed in 0ms
143 timing idealTree:node_modules/node-fetch/node_modules/webidl-conversions Completed in 0ms
144 silly placeDep node_modules/websocket ms@2.0.0 OK for: debug@2.6.9 want: 2.0.0
145 timing idealTree:node_modules/websocket/node_modules/debug Completed in 5ms
146 timing idealTree:node_modules/websocket/node_modules/ms Completed in 0ms
147 timing idealTree:buildDeps Completed in 30080ms
148 timing idealTree:fixDepFlags Completed in 108ms
149 timing idealTree Completed in 36279ms
150 timing reify:loadTrees Completed in 36286ms
151 timing reify:diffTrees Completed in 285ms
152 silly reify moves {}
153 timing reify:retireShallow Completed in 5ms
154 timing reify:createSparse Completed in 84ms
155 timing reify:loadBundles Completed in 0ms
156 silly audit bulk request {
156 silly audit '@ampproject/remapping': [ '2.2.0' ],
156 silly audit '@babel/code-frame': [ '7.16.7' ],
156 silly audit '@babel/compat-data': [ '7.17.10' ],
156 silly audit '@babel/core': [ '7.17.10' ],
156 silly audit semver: [ '6.3.0', '7.0.0', '7.3.7' ],
156 silly audit '@babel/eslint-parser': [ '7.17.0' ],
156 silly audit 'eslint-scope': [ '5.1.1', '7.1.1' ],
156 silly audit 'eslint-visitor-keys': [ '2.1.0', '3.3.0' ],
156 silly audit estraverse: [ '4.3.0', '5.3.0' ],
156 silly audit '@babel/generator': [ '7.17.10' ],
156 silly audit '@babel/helper-annotate-as-pure': [ '7.16.7' ],
156 silly audit '@babel/helper-builder-binary-assignment-operator-visitor': [ '7.16.7' ],
156 silly audit '@babel/helper-compilation-targets': [ '7.17.10' ],
156 silly audit '@babel/helper-create-class-features-plugin': [ '7.17.9' ],
156 silly audit '@babel/helper-create-regexp-features-plugin': [ '7.17.0' ],
156 silly audit '@babel/helper-define-polyfill-provider': [ '0.3.1' ],
156 silly audit '@babel/helper-environment-visitor': [ '7.16.7' ],
156 silly audit '@babel/helper-explode-assignable-expression': [ '7.16.7' ],
156 silly audit '@babel/helper-function-name': [ '7.17.9' ],
156 silly audit '@babel/helper-hoist-variables': [ '7.16.7' ],
156 silly audit '@babel/helper-member-expression-to-functions': [ '7.17.7' ],
156 silly audit '@babel/helper-module-imports': [ '7.16.7' ],
156 silly audit '@babel/helper-module-transforms': [ '7.17.7' ],
156 silly audit '@babel/helper-optimise-call-expression': [ '7.16.7' ],
156 silly audit '@babel/helper-plugin-utils': [ '7.16.7' ],
156 silly audit '@babel/helper-remap-async-to-generator': [ '7.16.8' ],
156 silly audit '@babel/helper-replace-supers': [ '7.16.7' ],
156 silly audit '@babel/helper-simple-access': [ '7.17.7' ],
156 silly audit '@babel/helper-skip-transparent-expression-wrappers': [ '7.16.0' ],
156 silly audit '@babel/helper-split-export-declaration': [ '7.16.7' ],
156 silly audit '@babel/helper-validator-identifier': [ '7.16.7' ],
156 silly audit '@babel/helper-validator-option': [ '7.16.7' ],
156 silly audit '@babel/helper-wrap-function': [ '7.16.8' ],
156 silly audit '@babel/helpers': [ '7.17.9' ],
156 silly audit '@babel/highlight': [ '7.17.9' ],
156 silly audit '@babel/parser': [ '7.17.10' ],
156 silly audit '@babel/plugin-bugfix-safari-id-destructuring-collision-in-function-expression': [ '7.16.7' ],
156 silly audit '@babel/plugin-bugfix-v8-spread-parameters-in-optional-chaining': [ '7.16.7' ],
156 silly audit '@babel/plugin-proposal-async-generator-functions': [ '7.16.8' ],
156 silly audit '@babel/plugin-proposal-class-properties': [ '7.16.7' ],
156 silly audit '@babel/plugin-proposal-class-static-block': [ '7.17.6' ],
156 silly audit '@babel/plugin-proposal-decorators': [ '7.17.9' ],
156 silly audit '@babel/plugin-proposal-dynamic-import': [ '7.16.7' ],
156 silly audit '@babel/plugin-proposal-export-namespace-from': [ '7.16.7' ],
156 silly audit '@babel/plugin-proposal-json-strings': [ '7.16.7' ],
156 silly audit '@babel/plugin-proposal-logical-assignment-operators': [ '7.16.7' ],
156 silly audit '@babel/plugin-proposal-nullish-coalescing-operator': [ '7.16.7' ],
156 silly audit '@babel/plugin-proposal-numeric-separator': [ '7.16.7' ],
156 silly audit '@babel/plugin-proposal-object-rest-spread': [ '7.17.3' ],
156 silly audit '@babel/plugin-proposal-optional-catch-binding': [ '7.16.7' ],
156 silly audit '@babel/plugin-proposal-optional-chaining': [ '7.16.7' ],
156 silly audit '@babel/plugin-proposal-private-methods': [ '7.16.11' ],
156 silly audit '@babel/plugin-proposal-private-property-in-object': [ '7.16.7' ],
156 silly audit '@babel/plugin-proposal-unicode-property-regex': [ '7.16.7' ],
156 silly audit '@babel/plugin-syntax-async-generators': [ '7.8.4' ],
156 silly audit '@babel/plugin-syntax-bigint': [ '7.8.3' ],
156 silly audit '@babel/plugin-syntax-class-properties': [ '7.12.13' ],
156 silly audit '@babel/plugin-syntax-class-static-block': [ '7.14.5' ],
156 silly audit '@babel/plugin-syntax-decorators': [ '7.17.0' ],
156 silly audit '@babel/plugin-syntax-dynamic-import': [ '7.8.3' ],
156 silly audit '@babel/plugin-syntax-export-namespace-from': [ '7.8.3' ],
156 silly audit '@babel/plugin-syntax-flow': [ '7.16.7' ],
156 silly audit '@babel/plugin-syntax-import-meta': [ '7.10.4' ],
156 silly audit '@babel/plugin-syntax-json-strings': [ '7.8.3' ],
156 silly audit '@babel/plugin-syntax-jsx': [ '7.16.7' ],
156 silly audit '@babel/plugin-syntax-logical-assignment-operators': [ '7.10.4' ],
156 silly audit '@babel/plugin-syntax-nullish-coalescing-operator': [ '7.8.3' ],
156 silly audit '@babel/plugin-syntax-numeric-separator': [ '7.10.4' ],
156 silly audit '@babel/plugin-syntax-object-rest-spread': [ '7.8.3' ],
156 silly audit '@babel/plugin-syntax-optional-catch-binding': [ '7.8.3' ],
156 silly audit '@babel/plugin-syntax-optional-chaining': [ '7.8.3' ],
156 silly audit '@babel/plugin-syntax-private-property-in-object': [ '7.14.5' ],
156 silly audit '@babel/plugin-syntax-top-level-await': [ '7.14.5' ],
156 silly audit '@babel/plugin-syntax-typescript': [ '7.17.10' ],
156 silly audit '@babel/plugin-transform-arrow-functions': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-async-to-generator': [ '7.16.8' ],
156 silly audit '@babel/plugin-transform-block-scoped-functions': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-block-scoping': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-classes': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-computed-properties': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-destructuring': [ '7.17.7' ],
156 silly audit '@babel/plugin-transform-dotall-regex': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-duplicate-keys': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-exponentiation-operator': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-flow-strip-types': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-for-of': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-function-name': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-literals': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-member-expression-literals': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-modules-amd': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-modules-commonjs': [ '7.17.9' ],
156 silly audit '@babel/plugin-transform-modules-systemjs': [ '7.17.8' ],
156 silly audit '@babel/plugin-transform-modules-umd': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-named-capturing-groups-regex': [ '7.17.10' ],
156 silly audit '@babel/plugin-transform-new-target': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-object-super': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-parameters': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-property-literals': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-react-constant-elements': [ '7.17.6' ],
156 silly audit '@babel/plugin-transform-react-display-name': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-react-jsx': [ '7.17.3' ],
156 silly audit '@babel/plugin-transform-react-jsx-development': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-react-pure-annotations': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-regenerator': [ '7.17.9' ],
156 silly audit '@babel/plugin-transform-reserved-words': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-runtime': [ '7.17.10' ],
156 silly audit '@babel/plugin-transform-shorthand-properties': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-spread': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-sticky-regex': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-template-literals': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-typeof-symbol': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-typescript': [ '7.16.8' ],
156 silly audit '@babel/plugin-transform-unicode-escapes': [ '7.16.7' ],
156 silly audit '@babel/plugin-transform-unicode-regex': [ '7.16.7' ],
156 silly audit '@babel/preset-env': [ '7.17.10' ],
156 silly audit '@babel/preset-modules': [ '0.1.5' ],
156 silly audit '@babel/preset-react': [ '7.16.7' ],
156 silly audit '@babel/preset-typescript': [ '7.16.7' ],
156 silly audit '@babel/runtime': [ '7.17.9' ],
156 silly audit '@babel/runtime-corejs3': [ '7.17.9' ],
156 silly audit '@babel/template': [ '7.16.7' ],
156 silly audit '@babel/traverse': [ '7.17.10' ],
156 silly audit '@babel/types': [ '7.17.10' ],
156 silly audit '@bcoe/v8-coverage': [ '0.2.3' ],
156 silly audit '@csstools/normalize.css': [ '12.0.0' ],
156 silly audit '@csstools/postcss-color-function': [ '1.1.0' ],
156 silly audit '@csstools/postcss-font-format-keywords': [ '1.0.0' ],
156 silly audit '@csstools/postcss-hwb-function': [ '1.0.0' ],
156 silly audit '@csstools/postcss-ic-unit': [ '1.0.0' ],
156 silly audit '@csstools/postcss-is-pseudo-class': [ '2.0.2' ],
156 silly audit '@csstools/postcss-normalize-display-values': [ '1.0.0' ],
156 silly audit '@csstools/postcss-oklab-function': [ '1.1.0' ],
156 silly audit '@csstools/postcss-progressive-custom-properties': [ '1.3.0' ],
156 silly audit '@csstools/postcss-stepped-value-functions': [ '1.0.0' ],
156 silly audit '@csstools/postcss-unset-value': [ '1.0.0' ],
156 silly audit '@eslint/eslintrc': [ '1.2.2' ],
156 silly audit argparse: [ '2.0.1', '1.0.10' ],
156 silly audit globals: [ '13.13.0', '11.12.0' ],
156 silly audit 'js-yaml': [ '4.1.0', '3.14.1' ],
156 silly audit 'type-fest': [ '0.20.2', '0.16.0', '0.21.3' ],
156 silly audit '@humanwhocodes/config-array': [ '0.9.5' ],
156 silly audit '@humanwhocodes/object-schema': [ '1.2.1' ],
156 silly audit '@istanbuljs/load-nyc-config': [ '1.1.0' ],
156 silly audit camelcase: [ '5.3.1', '6.3.0' ],
156 silly audit 'find-up': [ '4.1.0', '2.1.0', '5.0.0', '3.0.0' ],
156 silly audit 'locate-path': [ '5.0.0', '2.0.0', '6.0.0', '3.0.0' ],
156 silly audit 'p-limit': [ '2.3.0', '1.3.0', '3.1.0' ],
156 silly audit 'p-locate': [ '4.1.0', '2.0.0', '5.0.0', '3.0.0' ],
156 silly audit '@istanbuljs/schema': [ '0.1.3' ],
156 silly audit '@jest/console': [ '27.5.1', '28.0.2' ],
156 silly audit 'ansi-styles': [ '4.3.0', '3.2.1', '5.2.0' ],
156 silly audit chalk: [ '4.1.2', '3.0.0', '2.4.2' ],
156 silly audit 'color-convert': [ '2.0.1', '1.9.3' ],
156 silly audit 'color-name': [ '1.1.4', '1.1.3' ],
156 silly audit 'has-flag': [ '4.0.0', '3.0.0' ],
156 silly audit 'supports-color': [ '7.2.0', '8.1.1', '5.5.0' ],
156 silly audit '@jest/core': [ '27.5.1' ],
156 silly audit '@jest/environment': [ '27.5.1' ],
156 silly audit '@jest/fake-timers': [ '27.5.1' ],
156 silly audit '@jest/globals': [ '27.5.1' ],
156 silly audit '@jest/reporters': [ '27.5.1' ],
156 silly audit 'source-map': [ '0.6.1', '0.7.3', '0.8.0-beta.0' ],
156 silly audit '@jest/schemas': [ '28.0.2' ],
156 silly audit '@jest/source-map': [ '27.5.1' ],
156 silly audit '@jest/test-result': [ '27.5.1', '28.0.2' ],
156 silly audit '@jest/test-sequencer': [ '27.5.1' ],
156 silly audit '@jest/transform': [ '27.5.1' ],
156 silly audit '@jest/types': [ '27.5.1', '28.0.2' ],
156 silly audit '@jridgewell/gen-mapping': [ '0.1.1' ],
156 silly audit '@jridgewell/resolve-uri': [ '3.0.6' ],
156 silly audit '@jridgewell/set-array': [ '1.1.0' ],
156 silly audit '@jridgewell/sourcemap-codec': [ '1.4.12' ],
156 silly audit '@jridgewell/trace-mapping': [ '0.3.9' ],
156 silly audit '@leichtgewicht/ip-codec': [ '2.0.3' ],
156 silly audit '@nodelib/fs.scandir': [ '2.1.5' ],
156 silly audit '@nodelib/fs.stat': [ '2.0.5' ],
156 silly audit '@nodelib/fs.walk': [ '1.2.8' ],
156 silly audit '@pmmmwh/react-refresh-webpack-plugin': [ '0.5.5' ],
156 silly audit '@rollup/plugin-babel': [ '5.3.1' ],
156 silly audit '@rollup/plugin-node-resolve': [ '11.2.1' ],
156 silly audit '@rollup/plugin-replace': [ '2.4.2' ],
156 silly audit '@rollup/pluginutils': [ '3.1.0' ],
156 silly audit '@types/estree': [ '0.0.39', '0.0.51' ],
156 silly audit '@rushstack/eslint-patch': [ '1.1.3' ],
156 silly audit '@sinclair/typebox': [ '0.23.5' ],
156 silly audit '@sinonjs/commons': [ '1.8.3' ],
156 silly audit '@sinonjs/fake-timers': [ '8.1.0' ],
156 silly audit '@surma/rollup-plugin-off-main-thread': [ '2.2.3' ],
156 silly audit '@svgr/babel-plugin-add-jsx-attribute': [ '5.4.0' ],
156 silly audit '@svgr/babel-plugin-remove-jsx-attribute': [ '5.4.0' ],
156 silly audit '@svgr/babel-plugin-remove-jsx-empty-expression': [ '5.0.1' ],
156 silly audit '@svgr/babel-plugin-replace-jsx-attribute-value': [ '5.0.1' ],
156 silly audit '@svgr/babel-plugin-svg-dynamic-title': [ '5.4.0' ],
156 silly audit '@svgr/babel-plugin-svg-em-dimensions': [ '5.4.0' ],
156 silly audit '@svgr/babel-plugin-transform-react-native-svg': [ '5.4.0' ],
156 silly audit '@svgr/babel-plugin-transform-svg-component': [ '5.5.0' ],
156 silly audit '@svgr/babel-preset': [ '5.5.0' ],
156 silly audit '@svgr/core': [ '5.5.0' ],
156 silly audit '@svgr/hast-util-to-babel-ast': [ '5.5.0' ],
156 silly audit '@svgr/plugin-jsx': [ '5.5.0' ],
156 silly audit '@svgr/plugin-svgo': [ '5.5.0' ],
156 silly audit '@svgr/webpack': [ '5.5.0' ],
156 silly audit '@testing-library/dom': [ '8.13.0' ],
156 silly audit 'aria-query': [ '5.0.0', '4.2.2' ],
156 silly audit '@testing-library/jest-dom': [ '5.16.4' ],
156 silly audit '@testing-library/react': [ '13.1.1' ],
156 silly audit '@testing-library/user-event': [ '13.5.0' ],
156 silly audit '@tootallnate/once': [ '1.1.2' ],
156 silly audit '@trysound/sax': [ '0.2.0' ],
156 silly audit '@types/aria-query': [ '4.2.2' ],
156 silly audit '@types/babel__core': [ '7.1.19' ],
156 silly audit '@types/babel__generator': [ '7.6.4' ],
156 silly audit '@types/babel__template': [ '7.4.1' ],
156 silly audit '@types/babel__traverse': [ '7.17.1' ],
156 silly audit '@types/body-parser': [ '1.19.2' ],
156 silly audit '@types/bonjour': [ '3.5.10' ],
156 silly audit '@types/connect': [ '3.4.35' ],
156 silly audit '@types/connect-history-api-fallback': [ '1.3.5' ],
156 silly audit '@types/eslint': [ '7.29.0' ],
156 silly audit '@types/eslint-scope': [ '3.7.3' ],
156 silly audit '@types/express': [ '4.17.13' ],
156 silly audit '@types/express-serve-static-core': [ '4.17.28' ],
156 silly audit '@types/graceful-fs': [ '4.1.5' ],
156 silly audit '@types/html-minifier-terser': [ '6.1.0' ],
156 silly audit '@types/http-proxy': [ '1.17.8' ],
156 silly audit '@types/istanbul-lib-coverage': [ '2.0.4' ],
156 silly audit '@types/istanbul-lib-report': [ '3.0.0' ],
156 silly audit '@types/istanbul-reports': [ '3.0.1' ],
156 silly audit '@types/jest': [ '27.5.0' ],
156 silly audit '@types/json-schema': [ '7.0.11' ],
156 silly audit '@types/json5': [ '0.0.29' ],
156 silly audit '@types/mime': [ '1.3.2' ],
156 silly audit '@types/node': [ '17.0.31' ],
156 silly audit '@types/parse-json': [ '4.0.0' ],
156 silly audit '@types/prettier': [ '2.6.0' ],
156 silly audit '@types/prop-types': [ '15.7.5' ],
156 silly audit '@types/q': [ '1.5.5' ],
156 silly audit '@types/qs': [ '6.9.7' ],
156 silly audit '@types/range-parser': [ '1.2.4' ],
156 silly audit '@types/react': [ '18.0.8' ],
156 silly audit '@types/react-dom': [ '18.0.3' ],
156 silly audit '@types/resolve': [ '1.17.1' ],
156 silly audit '@types/retry': [ '0.12.0' ],
156 silly audit '@types/scheduler': [ '0.16.2' ],
156 silly audit '@types/serve-index': [ '1.9.1' ],
156 silly audit '@types/serve-static': [ '1.13.10' ],
156 silly audit '@types/sockjs': [ '0.3.33' ],
156 silly audit '@types/stack-utils': [ '2.0.1' ],
156 silly audit '@types/testing-library__jest-dom': [ '5.14.3' ],
156 silly audit '@types/trusted-types': [ '2.0.2' ],
156 silly audit '@types/ws': [ '8.5.3' ],
156 silly audit '@types/yargs': [ '16.0.4', '17.0.10' ],
156 silly audit '@types/yargs-parser': [ '21.0.0' ],
156 silly audit '@typescript-eslint/eslint-plugin': [ '5.22.0' ],
156 silly audit '@typescript-eslint/experimental-utils': [ '5.22.0' ],
156 silly audit '@typescript-eslint/parser': [ '5.22.0' ],
156 silly audit '@typescript-eslint/scope-manager': [ '5.22.0' ],
156 silly audit '@typescript-eslint/type-utils': [ '5.22.0' ],
156 silly audit '@typescript-eslint/types': [ '5.22.0' ],
156 silly audit '@typescript-eslint/typescript-estree': [ '5.22.0' ],
156 silly audit '@typescript-eslint/utils': [ '5.22.0' ],
156 silly audit '@typescript-eslint/visitor-keys': [ '5.22.0' ],
156 silly audit '@webassemblyjs/ast': [ '1.11.1' ],
156 silly audit '@webassemblyjs/floating-point-hex-parser': [ '1.11.1' ],
156 silly audit '@webassemblyjs/helper-api-error': [ '1.11.1' ],
156 silly audit '@webassemblyjs/helper-buffer': [ '1.11.1' ],
156 silly audit '@webassemblyjs/helper-numbers': [ '1.11.1' ],
156 silly audit '@webassemblyjs/helper-wasm-bytecode': [ '1.11.1' ],
156 silly audit '@webassemblyjs/helper-wasm-section': [ '1.11.1' ],
156 silly audit '@webassemblyjs/ieee754': [ '1.11.1' ],
156 silly audit '@webassemblyjs/leb128': [ '1.11.1' ],
156 silly audit '@webassemblyjs/utf8': [ '1.11.1' ],
156 silly audit '@webassemblyjs/wasm-edit': [ '1.11.1' ],
156 silly audit '@webassemblyjs/wasm-gen': [ '1.11.1' ],
156 silly audit '@webassemblyjs/wasm-opt': [ '1.11.1' ],
156 silly audit '@webassemblyjs/wasm-parser': [ '1.11.1' ],
156 silly audit '@webassemblyjs/wast-printer': [ '1.11.1' ],
156 silly audit '@xtuc/ieee754': [ '1.2.0' ],
156 silly audit '@xtuc/long': [ '4.2.2' ],
156 silly audit abab: [ '2.0.6' ],
156 silly audit accepts: [ '1.3.8' ],
156 silly audit acorn: [ '8.7.1', '7.4.1' ],
156 silly audit 'acorn-globals': [ '6.0.0' ],
156 silly audit 'acorn-import-assertions': [ '1.8.0' ],
156 silly audit 'acorn-jsx': [ '5.3.2' ],
156 silly audit 'acorn-node': [ '1.8.2' ],
156 silly audit 'acorn-walk': [ '7.2.0' ],
156 silly audit address: [ '1.2.0' ],
156 silly audit 'adjust-sourcemap-loader': [ '4.0.0' ],
156 silly audit 'agent-base': [ '6.0.2' ],
156 silly audit ajv: [ '6.12.6', '8.11.0' ],
156 silly audit 'ajv-formats': [ '2.1.1' ],
156 silly audit 'json-schema-traverse': [ '1.0.0', '0.4.1' ],
156 silly audit 'ajv-keywords': [ '3.5.2', '5.1.0' ],
156 silly audit 'ansi-escapes': [ '4.3.2' ],
156 silly audit 'ansi-html-community': [ '0.0.8' ],
156 silly audit 'ansi-regex': [ '5.0.1', '6.0.1' ],
156 silly audit anymatch: [ '3.1.2' ],
156 silly audit arg: [ '5.0.1' ],
156 silly audit 'array-flatten': [ '2.1.2', '1.1.1' ],
156 silly audit 'array-includes': [ '3.1.4' ],
156 silly audit 'array-union': [ '2.1.0' ],
156 silly audit 'array.prototype.flat': [ '1.3.0' ],
156 silly audit 'array.prototype.flatmap': [ '1.3.0' ],
156 silly audit asap: [ '2.0.6' ],
156 silly audit 'ast-types-flow': [ '0.0.7' ],
156 silly audit async: [ '2.6.4', '3.2.3' ],
156 silly audit asynckit: [ '0.4.0' ],
156 silly audit 'at-least-node': [ '1.0.0' ],
156 silly audit atob: [ '2.1.2' ],
156 silly audit autoprefixer: [ '10.4.7' ],
156 silly audit 'axe-core': [ '4.4.1' ],
156 silly audit 'axobject-query': [ '2.2.0' ],
156 silly audit 'babel-jest': [ '27.5.1' ],
156 silly audit 'babel-loader': [ '8.2.5' ],
156 silly audit 'schema-utils': [ '2.7.1', '4.0.0', '2.7.0', '3.1.1' ],
156 silly audit 'babel-plugin-dynamic-import-node': [ '2.3.3' ],
156 silly audit 'babel-plugin-istanbul': [ '6.1.1' ],
156 silly audit 'babel-plugin-jest-hoist': [ '27.5.1' ],
156 silly audit 'babel-plugin-macros': [ '3.1.0' ],
156 silly audit 'babel-plugin-named-asset-import': [ '0.3.8' ],
156 silly audit 'babel-plugin-polyfill-corejs2': [ '0.3.1' ],
156 silly audit 'babel-plugin-polyfill-corejs3': [ '0.5.2' ],
156 silly audit 'babel-plugin-polyfill-regenerator': [ '0.3.1' ],
156 silly audit 'babel-plugin-transform-react-remove-prop-types': [ '0.4.24' ],
156 silly audit 'babel-preset-current-node-syntax': [ '1.0.1' ],
156 silly audit 'babel-preset-jest': [ '27.5.1' ],
156 silly audit 'babel-preset-react-app': [ '10.0.1' ],
156 silly audit 'balanced-match': [ '1.0.2' ],
156 silly audit batch: [ '0.6.1' ],
156 silly audit bfj: [ '7.0.2' ],
156 silly audit 'big.js': [ '5.2.2' ],
156 silly audit 'binary-extensions': [ '2.2.0' ],
156 silly audit bluebird: [ '3.7.2' ],
156 silly audit 'body-parser': [ '1.20.0' ],
156 silly audit bytes: [ '3.1.2', '3.0.0' ],
156 silly audit debug: [ '2.6.9', '4.3.4', '3.2.7' ],
156 silly audit 'iconv-lite': [ '0.4.24', '0.6.3' ],
156 silly audit ms: [ '2.0.0', '2.1.2', '2.1.3' ],
156 silly audit 'bonjour-service': [ '1.0.12' ],
156 silly audit boolbase: [ '1.0.0' ],
156 silly audit 'brace-expansion': [ '1.1.11', '2.0.1' ],
156 silly audit braces: [ '3.0.2' ],
156 silly audit 'browser-process-hrtime': [ '1.0.0' ],
156 silly audit browserslist: [ '4.20.3' ],
156 silly audit bser: [ '2.1.1' ],
156 silly audit 'buffer-from': [ '1.1.2' ],
156 silly audit 'builtin-modules': [ '3.2.0' ],
156 silly audit 'call-bind': [ '1.0.2' ],
156 silly audit callsites: [ '3.1.0' ],
156 silly audit 'camel-case': [ '4.1.2' ],
156 silly audit 'camelcase-css': [ '2.0.1' ],
156 silly audit 'caniuse-api': [ '3.0.0' ],
156 silly audit 'caniuse-lite': [ '1.0.30001335' ],
156 silly audit 'case-sensitive-paths-webpack-plugin': [ '2.4.0' ],
156 silly audit 'char-regex': [ '1.0.2', '2.0.1' ],
156 silly audit charcodes: [ '0.2.0' ],
156 silly audit 'check-types': [ '11.1.2' ],
156 silly audit chokidar: [ '3.5.3' ],
156 silly audit 'glob-parent': [ '5.1.2', '6.0.2' ],
156 silly audit 'chrome-trace-event': [ '1.0.3' ],
156 silly audit 'ci-info': [ '3.3.0' ],
156 silly audit 'cjs-module-lexer': [ '1.2.2' ],
156 silly audit 'clean-css': [ '5.3.0' ],
156 silly audit cliui: [ '7.0.4' ],
156 silly audit co: [ '4.6.0' ],
156 silly audit coa: [ '2.0.2' ],
156 silly audit 'collect-v8-coverage': [ '1.0.1' ],
156 silly audit colord: [ '2.9.2' ],
156 silly audit colorette: [ '2.0.16' ],
156 silly audit 'combined-stream': [ '1.0.8' ],
156 silly audit commander: [ '8.3.0', '7.2.0', '2.20.3' ],
156 silly audit 'common-path-prefix': [ '3.0.0' ],
156 silly audit 'common-tags': [ '1.8.2' ],
156 silly audit commondir: [ '1.0.1' ],
156 silly audit compressible: [ '2.0.18' ],
156 silly audit compression: [ '1.7.4' ],
156 silly audit 'concat-map': [ '0.0.1' ],
156 silly audit 'confusing-browser-globals': [ '1.0.11' ],
156 silly audit 'connect-history-api-fallback': [ '1.6.0' ],
156 silly audit 'content-disposition': [ '0.5.4' ],
156 silly audit 'safe-buffer': [ '5.2.1', '5.1.2' ],
156 silly audit 'content-type': [ '1.0.4' ],
156 silly audit 'convert-source-map': [ '1.8.0' ],
156 silly audit cookie: [ '0.5.0' ],
156 silly audit 'cookie-signature': [ '1.0.6' ],
156 silly audit 'core-js': [ '3.22.4' ],
156 silly audit 'core-js-compat': [ '3.22.4' ],
156 silly audit 'core-js-pure': [ '3.22.4' ],
156 silly audit 'core-util-is': [ '1.0.3' ],
156 silly audit cosmiconfig: [ '7.0.1', '6.0.0' ],
156 silly audit 'cross-spawn': [ '7.0.3' ],
156 silly audit 'crypto-random-string': [ '2.0.0' ],
156 silly audit css: [ '3.0.0' ],
156 silly audit 'css-blank-pseudo': [ '3.0.3' ],
156 silly audit 'css-declaration-sorter': [ '6.2.2' ],
156 silly audit 'css-has-pseudo': [ '3.0.4' ],
156 silly audit 'css-loader': [ '6.7.1' ],
156 silly audit 'css-minimizer-webpack-plugin': [ '3.4.1' ],
156 silly audit 'css-prefers-color-scheme': [ '6.0.3' ],
156 silly audit 'css-select': [ '4.3.0', '2.1.0' ],
156 silly audit 'css-select-base-adapter': [ '0.1.1' ],
156 silly audit 'css-tree': [ '1.0.0-alpha.37', '1.1.3' ],
156 silly audit 'css-what': [ '6.1.0', '3.4.2' ],
156 silly audit 'css.escape': [ '1.5.1' ],
156 silly audit cssdb: [ '6.6.1' ],
156 silly audit cssesc: [ '3.0.0' ],
156 silly audit cssnano: [ '5.1.7' ],
156 silly audit 'cssnano-preset-default': [ '5.2.7' ],
156 silly audit 'cssnano-utils': [ '3.1.0' ],
156 silly audit csso: [ '4.2.0' ],
156 silly audit 'mdn-data': [ '2.0.14', '2.0.4' ],
156 silly audit cssom: [ '0.4.4', '0.3.8' ],
156 silly audit cssstyle: [ '2.3.0' ],
156 silly audit csstype: [ '3.0.11' ],
156 silly audit 'damerau-levenshtein': [ '1.0.8' ],
156 silly audit 'data-urls': [ '2.0.0' ],
156 silly audit 'decimal.js': [ '10.3.1' ],
156 silly audit 'decode-uri-component': [ '0.2.0' ],
156 silly audit dedent: [ '0.7.0' ],
156 silly audit 'deep-is': [ '0.1.4' ],
156 silly audit deepmerge: [ '4.2.2' ],
156 silly audit 'default-gateway': [ '6.0.3' ],
156 silly audit 'define-lazy-prop': [ '2.0.0' ],
156 silly audit 'define-properties': [ '1.1.4' ],
156 silly audit defined: [ '1.0.0' ],
156 silly audit 'delayed-stream': [ '1.0.0' ],
156 silly audit depd: [ '2.0.0', '1.1.2' ],
156 silly audit destroy: [ '1.2.0' ],
156 silly audit 'detect-newline': [ '3.1.0' ],
156 silly audit 'detect-node': [ '2.1.0' ],
156 silly audit 'detect-port-alt': [ '1.1.6' ],
156 silly audit detective: [ '5.2.0' ],
156 silly audit didyoumean: [ '1.2.2' ],
156 silly audit 'diff-sequences': [ '27.5.1' ],
156 silly audit 'dir-glob': [ '3.0.1' ],
156 silly audit dlv: [ '1.1.3' ],
156 silly audit 'dns-equal': [ '1.0.0' ],
156 silly audit 'dns-packet': [ '5.3.1' ],
156 silly audit doctrine: [ '3.0.0', '2.1.0' ],
156 silly audit 'dom-accessibility-api': [ '0.5.14' ],
156 silly audit 'dom-converter': [ '0.2.0' ],
156 silly audit 'dom-serializer': [ '1.4.1', '0.2.2' ],
156 silly audit domelementtype: [ '2.3.0', '1.3.1' ],
156 silly audit domexception: [ '2.0.1' ],
156 silly audit 'webidl-conversions': [ '5.0.0', '4.0.2', '6.1.0', '3.0.1' ],
156 silly audit domhandler: [ '4.3.1' ],
156 silly audit domutils: [ '2.8.0', '1.7.0' ],
156 silly audit 'dot-case': [ '3.0.4' ],
156 silly audit dotenv: [ '10.0.0' ],
156 silly audit 'dotenv-expand': [ '5.1.0' ],
156 silly audit duplexer: [ '0.1.2' ],
156 silly audit 'ee-first': [ '1.1.1' ],
156 silly audit ejs: [ '3.1.7' ],
156 silly audit 'electron-to-chromium': [ '1.4.131' ],
156 silly audit emittery: [ '0.8.1', '0.10.2' ],
156 silly audit 'emoji-regex': [ '9.2.2', '8.0.0' ],
156 silly audit 'emojis-list': [ '3.0.0' ],
156 silly audit encodeurl: [ '1.0.2' ],
156 silly audit 'enhanced-resolve': [ '5.9.3' ],
156 silly audit entities: [ '2.2.0' ],
156 silly audit 'error-ex': [ '1.3.2' ],
156 silly audit 'error-stack-parser': [ '2.0.7' ],
156 silly audit 'es-abstract': [ '1.19.5' ],
156 silly audit 'es-module-lexer': [ '0.9.3' ],
156 silly audit 'es-shim-unscopables': [ '1.0.0' ],
156 silly audit 'es-to-primitive': [ '1.2.1' ],
156 silly audit escalade: [ '3.1.1' ],
156 silly audit 'escape-html': [ '1.0.3' ],
156 silly audit 'escape-string-regexp': [ '1.0.5', '4.0.0', '2.0.0' ],
156 silly audit escodegen: [ '2.0.0' ],
156 silly audit levn: [ '0.3.0', '0.4.1' ],
156 silly audit optionator: [ '0.8.3', '0.9.1' ],
156 silly audit 'prelude-ls': [ '1.1.2', '1.2.1' ],
156 silly audit 'type-check': [ '0.3.2', '0.4.0' ],
156 silly audit eslint: [ '8.14.0' ],
156 silly audit 'eslint-config-react-app': [ '7.0.1' ],
156 silly audit 'eslint-import-resolver-node': [ '0.3.6' ],
156 silly audit 'eslint-module-utils': [ '2.7.3' ],
156 silly audit 'p-try': [ '1.0.0', '2.2.0' ],
156 silly audit 'path-exists': [ '3.0.0', '4.0.0' ],
156 silly audit 'eslint-plugin-flowtype': [ '8.0.3' ],
156 silly audit 'eslint-plugin-import': [ '2.26.0' ],
156 silly audit 'eslint-plugin-jest': [ '25.7.0' ],
156 silly audit 'eslint-plugin-jsx-a11y': [ '6.5.1' ],
156 silly audit 'eslint-plugin-react': [ '7.29.4' ],
156 silly audit 'eslint-plugin-react-hooks': [ '4.5.0' ],
156 silly audit resolve: [ '2.0.0-next.3', '1.22.0' ],
156 silly audit 'eslint-plugin-testing-library': [ '5.3.1' ],
156 silly audit 'eslint-utils': [ '3.0.0' ],
156 silly audit 'eslint-webpack-plugin': [ '3.1.1' ],
156 silly audit espree: [ '9.3.1' ],
156 silly audit esprima: [ '4.0.1' ],
156 silly audit esquery: [ '1.4.0' ],
156 silly audit esrecurse: [ '4.3.0' ],
156 silly audit 'estree-walker': [ '1.0.1' ],
156 silly audit esutils: [ '2.0.3' ],
156 silly audit etag: [ '1.8.1' ],
156 silly audit eventemitter3: [ '4.0.7' ],
156 silly audit events: [ '3.3.0' ],
156 silly audit execa: [ '5.1.1' ],
156 silly audit exit: [ '0.1.2' ],
156 silly audit expect: [ '27.5.1' ],
156 silly audit express: [ '4.18.1' ],
156 silly audit 'fast-deep-equal': [ '3.1.3' ],
156 silly audit 'fast-glob': [ '3.2.11' ],
156 silly audit 'fast-json-stable-stringify': [ '2.1.0' ],
156 silly audit 'fast-levenshtein': [ '2.0.6' ],
156 silly audit fastq: [ '1.13.0' ],
156 silly audit 'faye-websocket': [ '0.11.4' ],
156 silly audit 'fb-watchman': [ '2.0.1' ],
156 silly audit 'file-entry-cache': [ '6.0.1' ],
156 silly audit 'file-loader': [ '6.2.0' ],
156 silly audit filelist: [ '1.0.3' ],
156 silly audit minimatch: [ '5.0.1', '3.1.2', '3.0.4' ],
156 silly audit filesize: [ '8.0.7' ],
156 silly audit 'fill-range': [ '7.0.1' ],
156 silly audit finalhandler: [ '1.2.0' ],
156 silly audit 'find-cache-dir': [ '3.3.2' ],
156 silly audit 'flat-cache': [ '3.0.4' ],
156 silly audit flatted: [ '3.2.5' ],
156 silly audit 'follow-redirects': [ '1.14.9' ],
156 silly audit 'fork-ts-checker-webpack-plugin': [ '6.5.2' ],
156 silly audit 'fs-extra': [ '9.1.0', '10.1.0' ],
156 silly audit tapable: [ '1.1.3', '2.2.1' ],
156 silly audit 'form-data': [ '3.0.1' ],
156 silly audit forwarded: [ '0.2.0' ],
156 silly audit 'fraction.js': [ '4.2.0' ],
156 silly audit fresh: [ '0.5.2' ],
156 silly audit 'fs-monkey': [ '1.0.3' ],
156 silly audit 'fs.realpath': [ '1.0.0' ],
156 silly audit fsevents: [ '2.3.2' ],
156 silly audit 'function-bind': [ '1.1.1' ],
156 silly audit 'functional-red-black-tree': [ '1.0.1' ],
156 silly audit 'functions-have-names': [ '1.2.3' ],
156 silly audit gensync: [ '1.0.0-beta.2' ],
156 silly audit 'get-caller-file': [ '2.0.5' ],
156 silly audit 'get-intrinsic': [ '1.1.1' ],
156 silly audit 'get-own-enumerable-property-symbols': [ '3.0.2' ],
156 silly audit 'get-package-type': [ '0.1.0' ],
156 silly audit 'get-stream': [ '6.0.1' ],
156 silly audit 'get-symbol-description': [ '1.0.0' ],
156 silly audit glob: [ '7.2.0' ],
156 silly audit 'glob-to-regexp': [ '0.4.1' ],
156 silly audit 'global-modules': [ '2.0.0' ],
156 silly audit 'global-prefix': [ '3.0.0' ],
156 silly audit which: [ '1.3.1', '2.0.2' ],
156 silly audit globby: [ '11.1.0' ],
156 silly audit 'graceful-fs': [ '4.2.10' ],
156 silly audit 'gzip-size': [ '6.0.0' ],
156 silly audit 'handle-thing': [ '2.0.1' ],
156 silly audit 'harmony-reflect': [ '1.6.2' ],
156 silly audit has: [ '1.0.3' ],
156 silly audit 'has-bigints': [ '1.0.2' ],
156 silly audit 'has-property-descriptors': [ '1.0.0' ],
156 silly audit 'has-symbols': [ '1.0.3' ],
156 silly audit 'has-tostringtag': [ '1.0.0' ],
156 silly audit he: [ '1.2.0' ],
156 silly audit hoopy: [ '0.1.4' ],
156 silly audit 'hpack.js': [ '2.1.6' ],
156 silly audit 'readable-stream': [ '2.3.7', '3.6.0' ],
156 silly audit string_decoder: [ '1.1.1', '1.3.0' ],
156 silly audit 'html-encoding-sniffer': [ '2.0.1' ],
156 silly audit 'html-entities': [ '2.3.3' ],
156 silly audit 'html-escaper': [ '2.0.2' ],
156 silly audit 'html-minifier-terser': [ '6.1.0' ],
156 silly audit 'html-webpack-plugin': [ '5.5.0' ],
156 silly audit htmlparser2: [ '6.1.0' ],
156 silly audit 'http-deceiver': [ '1.2.7' ],
156 silly audit 'http-errors': [ '2.0.0', '1.6.3' ],
156 silly audit 'http-parser-js': [ '0.5.6' ],
156 silly audit 'http-proxy': [ '1.18.1' ],
156 silly audit 'http-proxy-agent': [ '4.0.1' ],
156 silly audit 'http-proxy-middleware': [ '2.0.6' ],
156 silly audit 'https-proxy-agent': [ '5.0.1' ],
156 silly audit 'human-signals': [ '2.1.0' ],
156 silly audit 'icss-utils': [ '5.1.0' ],
156 silly audit idb: [ '6.1.5' ],
156 silly audit 'identity-obj-proxy': [ '3.0.0' ],
156 silly audit ignore: [ '5.2.0' ],
156 silly audit immer: [ '9.0.12' ],
156 silly audit 'import-fresh': [ '3.3.0' ],
156 silly audit 'resolve-from': [ '4.0.0', '5.0.0' ],
156 silly audit 'import-local': [ '3.1.0' ],
156 silly audit imurmurhash: [ '0.1.4' ],
156 silly audit 'indent-string': [ '4.0.0' ],
156 silly audit inflight: [ '1.0.6' ],
156 silly audit inherits: [ '2.0.4', '2.0.3' ],
156 silly audit ini: [ '1.3.8' ],
156 silly audit 'internal-slot': [ '1.0.3' ],
156 silly audit 'ipaddr.js': [ '2.0.1', '1.9.1' ],
156 silly audit 'is-arrayish': [ '0.2.1' ],
156 silly audit 'is-bigint': [ '1.0.4' ],
156 silly audit 'is-binary-path': [ '2.1.0' ],
156 silly audit 'is-boolean-object': [ '1.1.2' ],
156 silly audit 'is-callable': [ '1.2.4' ],
156 silly audit 'is-core-module': [ '2.9.0' ],
156 silly audit 'is-date-object': [ '1.0.5' ],
156 silly audit 'is-docker': [ '2.2.1' ],
156 silly audit 'is-extglob': [ '2.1.1' ],
156 silly audit 'is-fullwidth-code-point': [ '3.0.0' ],
156 silly audit 'is-generator-fn': [ '2.1.0' ],
156 silly audit 'is-glob': [ '4.0.3' ],
156 silly audit 'is-module': [ '1.0.0' ],
156 silly audit 'is-negative-zero': [ '2.0.2' ],
156 silly audit 'is-number': [ '7.0.0' ],
156 silly audit 'is-number-object': [ '1.0.7' ],
156 silly audit 'is-obj': [ '1.0.1' ],
156 silly audit 'is-plain-obj': [ '3.0.0' ],
156 silly audit 'is-potential-custom-element-name': [ '1.0.1' ],
156 silly audit 'is-regex': [ '1.1.4' ],
156 silly audit 'is-regexp': [ '1.0.0' ],
156 silly audit 'is-root': [ '2.1.0' ],
156 silly audit 'is-shared-array-buffer': [ '1.0.2' ],
156 silly audit 'is-stream': [ '2.0.1' ],
156 silly audit 'is-string': [ '1.0.7' ],
156 silly audit 'is-symbol': [ '1.0.4' ],
156 silly audit 'is-typedarray': [ '1.0.0' ],
156 silly audit 'is-weakref': [ '1.0.2' ],
156 silly audit 'is-wsl': [ '2.2.0' ],
156 silly audit isarray: [ '1.0.0' ],
156 silly audit isexe: [ '2.0.0' ],
156 silly audit 'istanbul-lib-coverage': [ '3.2.0' ],
156 silly audit 'istanbul-lib-instrument': [ '5.2.0' ],
156 silly audit 'istanbul-lib-report': [ '3.0.0' ],
156 silly audit 'istanbul-lib-source-maps': [ '4.0.1' ],
156 silly audit 'istanbul-reports': [ '3.1.4' ],
156 silly audit jake: [ '10.8.5' ],
156 silly audit jest: [ '27.5.1' ],
156 silly audit 'jest-changed-files': [ '27.5.1' ],
156 silly audit 'jest-circus': [ '27.5.1' ],
156 silly audit 'jest-cli': [ '27.5.1' ],
156 silly audit 'jest-config': [ '27.5.1' ],
156 silly audit 'jest-diff': [ '27.5.1' ],
156 silly audit 'jest-docblock': [ '27.5.1' ],
156 silly audit 'jest-each': [ '27.5.1' ],
156 silly audit 'jest-environment-jsdom': [ '27.5.1' ],
156 silly audit 'jest-environment-node': [ '27.5.1' ],
156 silly audit 'jest-get-type': [ '27.5.1' ],
156 silly audit 'jest-haste-map': [ '27.5.1' ],
156 silly audit 'jest-jasmine2': [ '27.5.1' ],
156 silly audit 'jest-leak-detector': [ '27.5.1' ],
156 silly audit 'jest-matcher-utils': [ '27.5.1' ],
156 silly audit 'jest-message-util': [ '27.5.1', '28.0.2' ],
156 silly audit 'jest-mock': [ '27.5.1' ],
156 silly audit 'jest-pnp-resolver': [ '1.2.2' ],
156 silly audit 'jest-regex-util': [ '27.5.1', '28.0.2' ],
156 silly audit 'jest-resolve': [ '27.5.1' ],
156 silly audit 'jest-resolve-dependencies': [ '27.5.1' ],
156 silly audit 'jest-runner': [ '27.5.1' ],
156 silly audit 'jest-runtime': [ '27.5.1' ],
156 silly audit 'jest-serializer': [ '27.5.1' ],
156 silly audit 'jest-snapshot': [ '27.5.1' ],
156 silly audit 'jest-util': [ '27.5.1', '28.0.2' ],
156 silly audit 'jest-validate': [ '27.5.1' ],
156 silly audit 'jest-watch-typeahead': [ '1.1.0' ],
156 silly audit slash: [ '3.0.0', '4.0.0' ],
156 silly audit 'jest-watcher': [ '28.0.2', '27.5.1' ],
156 silly audit 'string-length': [ '4.0.2', '5.0.1' ],
156 silly audit 'strip-ansi': [ '6.0.1', '7.0.1' ],
156 silly audit 'pretty-format': [ '28.0.2', '27.5.1' ],
156 silly audit 'react-is': [ '18.1.0', '16.13.1', '17.0.2' ],
156 silly audit 'jest-worker': [ '27.5.1', '26.6.2' ],
156 silly audit 'js-tokens': [ '4.0.0' ],
156 silly audit jsdom: [ '16.7.0' ],
156 silly audit jsesc: [ '2.5.2', '0.5.0' ],
156 silly audit 'json-parse-better-errors': [ '1.0.2' ],
156 silly audit 'json-parse-even-better-errors': [ '2.3.1' ],
156 silly audit 'json-schema': [ '0.4.0' ],
156 silly audit 'json-stable-stringify-without-jsonify': [ '1.0.1' ],
156 silly audit json5: [ '2.2.1', '1.0.1' ],
156 silly audit jsonfile: [ '6.1.0' ],
156 silly audit jsonpointer: [ '5.0.0' ],
156 silly audit 'jsx-ast-utils': [ '3.3.0' ],
156 silly audit 'kind-of': [ '6.0.3' ],
156 silly audit kleur: [ '3.0.3' ],
156 silly audit klona: [ '2.0.5' ],
156 silly audit 'language-subtag-registry': [ '0.3.21' ],
156 silly audit 'language-tags': [ '1.0.5' ],
156 silly audit leven: [ '3.1.0' ],
156 silly audit lilconfig: [ '2.0.5' ],
156 silly audit 'lines-and-columns': [ '1.2.4' ],
156 silly audit 'loader-runner': [ '4.3.0' ],
156 silly audit 'loader-utils': [ '2.0.2', '3.2.0' ],
156 silly audit lodash: [ '4.17.21' ],
156 silly audit 'lodash.debounce': [ '4.0.8' ],
156 silly audit 'lodash.memoize': [ '4.1.2' ],
156 silly audit 'lodash.merge': [ '4.6.2' ],
156 silly audit 'lodash.sortby': [ '4.7.0' ],
156 silly audit 'lodash.uniq': [ '4.5.0' ],
156 silly audit 'loose-envify': [ '1.4.0' ],
156 silly audit 'lower-case': [ '2.0.2' ],
156 silly audit 'lru-cache': [ '6.0.0' ],
156 silly audit 'lz-string': [ '1.4.4' ],
156 silly audit 'magic-string': [ '0.25.9' ],
156 silly audit 'make-dir': [ '3.1.0' ],
156 silly audit makeerror: [ '1.0.12' ],
156 silly audit 'media-typer': [ '0.3.0' ],
156 silly audit memfs: [ '3.4.1' ],
156 silly audit 'merge-descriptors': [ '1.0.1' ],
156 silly audit 'merge-stream': [ '2.0.0' ],
156 silly audit merge2: [ '1.4.1' ],
156 silly audit methods: [ '1.1.2' ],
156 silly audit micromatch: [ '4.0.5' ],
156 silly audit mime: [ '1.6.0' ],
156 silly audit 'mime-db': [ '1.52.0' ],
156 silly audit 'mime-types': [ '2.1.35' ],
156 silly audit 'mimic-fn': [ '2.1.0' ],
156 silly audit 'min-indent': [ '1.0.1' ],
156 silly audit 'mini-css-extract-plugin': [ '2.6.0' ],
156 silly audit 'minimalistic-assert': [ '1.0.1' ],
156 silly audit minimist: [ '1.2.6' ],
156 silly audit mkdirp: [ '0.5.6' ],
156 silly audit 'multicast-dns': [ '7.2.4' ],
156 silly audit nanoid: [ '3.3.3' ],
156 silly audit 'natural-compare': [ '1.4.0' ],
156 silly audit negotiator: [ '0.6.3' ],
156 silly audit 'neo-async': [ '2.6.2' ],
156 silly audit 'no-case': [ '3.0.4' ],
156 silly audit 'node-forge': [ '1.3.1' ],
156 silly audit 'node-int64': [ '0.4.0' ],
156 silly audit 'node-releases': [ '2.0.4' ],
156 silly audit 'normalize-path': [ '3.0.0' ],
156 silly audit 'normalize-range': [ '0.1.2' ],
156 silly audit 'normalize-url': [ '6.1.0' ],
156 silly audit 'npm-run-path': [ '4.0.1' ],
156 silly audit 'nth-check': [ '2.0.1', '1.0.2' ],
156 silly audit nwsapi: [ '2.2.0' ],
156 silly audit 'object-assign': [ '4.1.1' ],
156 silly audit 'object-hash': [ '3.0.0' ],
156 silly audit 'object-inspect': [ '1.12.0' ],
156 silly audit 'object-keys': [ '1.1.1' ],
156 silly audit 'object.assign': [ '4.1.2' ],
156 silly audit 'object.entries': [ '1.1.5' ],
156 silly audit 'object.fromentries': [ '2.0.5' ],
156 silly audit 'object.getownpropertydescriptors': [ '2.1.3' ],
156 silly audit 'object.hasown': [ '1.1.0' ],
156 silly audit 'object.values': [ '1.1.5' ],
156 silly audit obuf: [ '1.1.2' ],
156 silly audit 'on-finished': [ '2.4.1' ],
156 silly audit 'on-headers': [ '1.0.2' ],
156 silly audit once: [ '1.4.0' ],
156 silly audit onetime: [ '5.1.2' ],
156 silly audit open: [ '8.4.0' ],
156 silly audit 'p-retry': [ '4.6.2' ],
156 silly audit 'param-case': [ '3.0.4' ],
156 silly audit 'parent-module': [ '1.0.1' ],
156 silly audit 'parse-json': [ '5.2.0' ],
156 silly audit parse5: [ '6.0.1' ],
156 silly audit parseurl: [ '1.3.3' ],
156 silly audit 'pascal-case': [ '3.1.2' ],
156 silly audit 'path-is-absolute': [ '1.0.1' ],
156 silly audit 'path-key': [ '3.1.1' ],
156 silly audit 'path-parse': [ '1.0.7' ],
156 silly audit 'path-to-regexp': [ '0.1.7' ],
156 silly audit 'path-type': [ '4.0.0' ],
156 silly audit 'performance-now': [ '2.1.0' ],
156 silly audit picocolors: [ '1.0.0', '0.2.1' ],
156 silly audit picomatch: [ '2.3.1' ],
156 silly audit pirates: [ '4.0.5' ],
156 silly audit 'pkg-dir': [ '4.2.0' ],
156 silly audit 'pkg-up': [ '3.1.0' ],
156 silly audit portfinder: [ '1.0.28' ],
156 silly audit postcss: [ '8.4.13', '7.0.39' ],
156 silly audit 'postcss-attribute-case-insensitive': [ '5.0.0' ],
156 silly audit 'postcss-browser-comments': [ '4.0.0' ],
156 silly audit 'postcss-calc': [ '8.2.4' ],
156 silly audit 'postcss-clamp': [ '4.1.0' ],
156 silly audit 'postcss-color-functional-notation': [ '4.2.2' ],
156 silly audit 'postcss-color-hex-alpha': [ '8.0.3' ],
156 silly audit 'postcss-color-rebeccapurple': [ '7.0.2' ],
156 silly audit 'postcss-colormin': [ '5.3.0' ],
156 silly audit 'postcss-convert-values': [ '5.1.0' ],
156 silly audit 'postcss-custom-media': [ '8.0.0' ],
156 silly audit 'postcss-custom-properties': [ '12.1.7' ],
156 silly audit 'postcss-custom-selectors': [ '6.0.0' ],
156 silly audit 'postcss-dir-pseudo-class': [ '6.0.4' ],
156 silly audit 'postcss-discard-comments': [ '5.1.1' ],
156 silly audit 'postcss-discard-duplicates': [ '5.1.0' ],
156 silly audit 'postcss-discard-empty': [ '5.1.1' ],
156 silly audit 'postcss-discard-overridden': [ '5.1.0' ],
156 silly audit 'postcss-double-position-gradients': [ '3.1.1' ],
156 silly audit 'postcss-env-function': [ '4.0.6' ],
156 silly audit 'postcss-flexbugs-fixes': [ '5.0.2' ],
156 silly audit 'postcss-focus-visible': [ '6.0.4' ],
156 silly audit 'postcss-focus-within': [ '5.0.4' ],
156 silly audit 'postcss-font-variant': [ '5.0.0' ],
156 silly audit 'postcss-gap-properties': [ '3.0.3' ],
156 silly audit 'postcss-image-set-function': [ '4.0.6' ],
156 silly audit 'postcss-initial': [ '4.0.1' ],
156 silly audit 'postcss-js': [ '4.0.0' ],
156 silly audit 'postcss-lab-function': [ '4.2.0' ],
156 silly audit 'postcss-load-config': [ '3.1.4' ],
156 silly audit 'postcss-loader': [ '6.2.1' ],
156 silly audit 'postcss-logical': [ '5.0.4' ],
156 silly audit 'postcss-media-minmax': [ '5.0.0' ],
156 silly audit 'postcss-merge-longhand': [ '5.1.4' ],
156 silly audit 'postcss-merge-rules': [ '5.1.1' ],
156 silly audit 'postcss-minify-font-values': [ '5.1.0' ],
156 silly audit 'postcss-minify-gradients': [ '5.1.1' ],
156 silly audit 'postcss-minify-params': [ '5.1.2' ],
156 silly audit 'postcss-minify-selectors': [ '5.2.0' ],
156 silly audit 'postcss-modules-extract-imports': [ '3.0.0' ],
156 silly audit 'postcss-modules-local-by-default': [ '4.0.0' ],
156 silly audit 'postcss-modules-scope': [ '3.0.0' ],
156 silly audit 'postcss-modules-values': [ '4.0.0' ],
156 silly audit 'postcss-nested': [ '5.0.6' ],
156 silly audit 'postcss-nesting': [ '10.1.4' ],
156 silly audit 'postcss-normalize': [ '10.0.1' ],
156 silly audit 'postcss-normalize-charset': [ '5.1.0' ],
156 silly audit 'postcss-normalize-display-values': [ '5.1.0' ],
156 silly audit 'postcss-normalize-positions': [ '5.1.0' ],
156 silly audit 'postcss-normalize-repeat-style': [ '5.1.0' ],
156 silly audit 'postcss-normalize-string': [ '5.1.0' ],
156 silly audit 'postcss-normalize-timing-functions': [ '5.1.0' ],
156 silly audit 'postcss-normalize-unicode': [ '5.1.0' ],
156 silly audit 'postcss-normalize-url': [ '5.1.0' ],
156 silly audit 'postcss-normalize-whitespace': [ '5.1.1' ],
156 silly audit 'postcss-opacity-percentage': [ '1.1.2' ],
156 silly audit 'postcss-ordered-values': [ '5.1.1' ],
156 silly audit 'postcss-overflow-shorthand': [ '3.0.3' ],
156 silly audit 'postcss-page-break': [ '3.0.4' ],
156 silly audit 'postcss-place': [ '7.0.4' ],
156 silly audit 'postcss-preset-env': [ '7.5.0' ],
156 silly audit 'postcss-pseudo-class-any-link': [ '7.1.2' ],
156 silly audit 'postcss-reduce-initial': [ '5.1.0' ],
156 silly audit 'postcss-reduce-transforms': [ '5.1.0' ],
156 silly audit 'postcss-replace-overflow-wrap': [ '4.0.0' ],
156 silly audit 'postcss-selector-not': [ '5.0.0' ],
156 silly audit 'postcss-selector-parser': [ '6.0.10' ],
156 silly audit 'postcss-svgo': [ '5.1.0' ],
156 silly audit svgo: [ '2.8.0', '1.3.2' ],
156 silly audit 'postcss-unique-selectors': [ '5.1.1' ],
156 silly audit 'postcss-value-parser': [ '4.2.0' ],
156 silly audit 'pretty-bytes': [ '5.6.0' ],
156 silly audit 'pretty-error': [ '4.0.0' ],
156 silly audit 'process-nextick-args': [ '2.0.1' ],
156 silly audit promise: [ '8.1.0' ],
156 silly audit prompts: [ '2.4.2' ],
156 silly audit 'prop-types': [ '15.8.1' ],
156 silly audit 'proxy-addr': [ '2.0.7' ],
156 silly audit psl: [ '1.8.0' ],
156 silly audit punycode: [ '2.1.1' ],
156 silly audit q: [ '1.5.1' ],
156 silly audit qs: [ '6.10.3' ],
156 silly audit 'queue-microtask': [ '1.2.3' ],
156 silly audit 'quick-lru': [ '5.1.1' ],
156 silly audit raf: [ '3.4.1' ],
156 silly audit randombytes: [ '2.1.0' ],
156 silly audit 'range-parser': [ '1.2.1' ],
156 silly audit 'raw-body': [ '2.5.1' ],
156 silly audit react: [ '18.1.0' ],
156 silly audit 'react-app-polyfill': [ '3.0.0' ],
156 silly audit 'react-dev-utils': [ '12.0.1' ],
156 silly audit 'react-dom': [ '18.1.0' ],
156 silly audit 'react-error-overlay': [ '6.0.11' ],
156 silly audit 'react-refresh': [ '0.11.0' ],
156 silly audit 'react-scripts': [ '5.0.1' ],
156 silly audit readdirp: [ '3.6.0' ],
156 silly audit 'recursive-readdir': [ '2.2.2' ],
156 silly audit redent: [ '3.0.0' ],
156 silly audit regenerate: [ '1.4.2' ],
156 silly audit 'regenerate-unicode-properties': [ '10.0.1' ],
156 silly audit 'regenerator-runtime': [ '0.13.9' ],
156 silly audit 'regenerator-transform': [ '0.15.0' ],
156 silly audit 'regex-parser': [ '2.2.11' ],
156 silly audit 'regexp.prototype.flags': [ '1.4.3' ],
156 silly audit regexpp: [ '3.2.0' ],
156 silly audit 'regexpu-core': [ '5.0.1' ],
156 silly audit regjsgen: [ '0.6.0' ],
156 silly audit regjsparser: [ '0.8.4' ],
156 silly audit relateurl: [ '0.2.7' ],
156 silly audit renderkid: [ '3.0.0' ],
156 silly audit 'require-directory': [ '2.1.1' ],
156 silly audit 'require-from-string': [ '2.0.2' ],
156 silly audit 'requires-port': [ '1.0.0' ],
156 silly audit 'resolve-cwd': [ '3.0.0' ],
156 silly audit 'resolve-url-loader': [ '4.0.0' ],
156 silly audit 'resolve.exports': [ '1.1.0' ],
156 silly audit retry: [ '0.13.1' ],
156 silly audit reusify: [ '1.0.4' ],
156 silly audit rimraf: [ '3.0.2' ],
156 silly audit rollup: [ '2.71.1' ],
156 silly audit 'rollup-plugin-terser': [ '7.0.2' ],
156 silly audit 'serialize-javascript': [ '4.0.0', '6.0.0' ],
156 silly audit 'run-parallel': [ '1.2.0' ],
156 silly audit 'safer-buffer': [ '2.1.2' ],
156 silly audit 'sanitize.css': [ '13.0.0' ],
156 silly audit 'sass-loader': [ '12.6.0' ],
156 silly audit sax: [ '1.2.4' ],
156 silly audit saxes: [ '5.0.1' ],
156 silly audit scheduler: [ '0.22.0' ],
156 silly audit 'select-hose': [ '2.0.0' ],
156 silly audit selfsigned: [ '2.0.1' ],
156 silly audit send: [ '0.18.0' ],
156 silly audit 'serve-index': [ '1.9.1' ],
156 silly audit setprototypeof: [ '1.1.0', '1.2.0' ],
156 silly audit statuses: [ '1.5.0', '2.0.1' ],
156 silly audit 'serve-static': [ '1.15.0' ],
156 silly audit 'shebang-command': [ '2.0.0' ],
156 silly audit 'shebang-regex': [ '3.0.0' ],
156 silly audit 'shell-quote': [ '1.7.3' ],
156 silly audit 'side-channel': [ '1.0.4' ],
156 silly audit 'signal-exit': [ '3.0.7' ],
156 silly audit sisteransi: [ '1.0.5' ],
156 silly audit sockjs: [ '0.3.24' ],
156 silly audit 'source-list-map': [ '2.0.1' ],
156 silly audit 'source-map-js': [ '1.0.2' ],
156 silly audit 'source-map-loader': [ '3.0.1' ],
156 silly audit 'source-map-resolve': [ '0.6.0' ],
156 silly audit 'source-map-support': [ '0.5.21' ],
156 silly audit 'sourcemap-codec': [ '1.4.8' ],
156 silly audit spdy: [ '4.0.2' ],
156 silly audit 'spdy-transport': [ '3.0.0' ],
156 silly audit 'sprintf-js': [ '1.0.3' ],
156 silly audit stable: [ '0.1.8' ],
156 silly audit 'stack-utils': [ '2.0.5' ],
156 silly audit stackframe: [ '1.2.1' ],
156 silly audit 'string-natural-compare': [ '3.0.1' ],
156 silly audit 'string-width': [ '4.2.3' ],
156 silly audit 'string.prototype.matchall': [ '4.0.7' ],
156 silly audit 'string.prototype.trimend': [ '1.0.5' ],
156 silly audit 'string.prototype.trimstart': [ '1.0.5' ],
156 silly audit 'stringify-object': [ '3.3.0' ],
156 silly audit 'strip-bom': [ '4.0.0', '3.0.0' ],
156 silly audit 'strip-comments': [ '2.0.1' ],
156 silly audit 'strip-final-newline': [ '2.0.0' ],
156 silly audit 'strip-indent': [ '3.0.0' ],
156 silly audit 'strip-json-comments': [ '3.1.1' ],
156 silly audit 'style-loader': [ '3.3.1' ],
156 silly audit stylehacks: [ '5.1.0' ],
156 silly audit 'supports-hyperlinks': [ '2.2.0' ],
156 silly audit 'supports-preserve-symlinks-flag': [ '1.0.0' ],
156 silly audit 'svg-parser': [ '2.0.4' ],
156 silly audit 'symbol-tree': [ '3.2.4' ],
156 silly audit tailwindcss: [ '3.0.24' ],
156 silly audit 'temp-dir': [ '2.0.0' ],
156 silly audit tempy: [ '0.6.0' ],
156 silly audit 'terminal-link': [ '2.1.1' ],
156 silly audit terser: [ '5.13.1' ],
156 silly audit 'terser-webpack-plugin': [ '5.3.1' ],
156 silly audit tr46: [ '1.0.1', '2.1.0', '0.0.3' ],
156 silly audit 'whatwg-url': [ '7.1.0', '8.7.0', '5.0.0' ],
156 silly audit 'test-exclude': [ '6.0.0' ],
156 silly audit 'text-table': [ '0.2.0' ],
156 silly audit throat: [ '6.0.1' ],
156 silly audit thunky: [ '1.1.0' ],
156 silly audit tmpl: [ '1.0.5' ],
156 silly audit 'to-fast-properties': [ '2.0.0' ],
156 silly audit 'to-regex-range': [ '5.0.1' ],
156 silly audit toidentifier: [ '1.0.1' ],
156 silly audit 'tough-cookie': [ '4.0.0' ],
156 silly audit universalify: [ '0.1.2', '2.0.0' ],
156 silly audit tryer: [ '1.0.1' ],
156 silly audit 'tsconfig-paths': [ '3.14.1' ],
156 silly audit tslib: [ '2.4.0', '1.14.1' ],
156 silly audit tsutils: [ '3.21.0' ],
156 silly audit 'type-detect': [ '4.0.8' ],
156 silly audit 'type-is': [ '1.6.18' ],
156 silly audit 'typedarray-to-buffer': [ '3.1.5' ],
156 silly audit typescript: [ '4.6.4' ],
156 silly audit 'unbox-primitive': [ '1.0.2' ],
156 silly audit 'unicode-canonical-property-names-ecmascript': [ '2.0.0' ],
156 silly audit 'unicode-match-property-ecmascript': [ '2.0.0' ],
156 silly audit 'unicode-match-property-value-ecmascript': [ '2.0.0' ],
156 silly audit 'unicode-property-aliases-ecmascript': [ '2.0.0' ],
156 silly audit 'unique-string': [ '2.0.0' ],
156 silly audit unpipe: [ '1.0.0' ],
156 silly audit unquote: [ '1.1.1' ],
156 silly audit upath: [ '1.2.0' ],
156 silly audit 'uri-js': [ '4.4.1' ],
156 silly audit 'util-deprecate': [ '1.0.2' ],
156 silly audit 'util.promisify': [ '1.0.1' ],
156 silly audit utila: [ '0.4.0' ],
156 silly audit 'utils-merge': [ '1.0.1' ],
156 silly audit uuid: [ '8.3.2' ],
156 silly audit 'v8-compile-cache': [ '2.3.0' ],
156 silly audit 'v8-to-istanbul': [ '8.1.1' ],
156 silly audit vary: [ '1.1.2' ],
156 silly audit 'w3c-hr-time': [ '1.0.2' ],
156 silly audit 'w3c-xmlserializer': [ '2.0.0' ],
156 silly audit walker: [ '1.0.8' ],
156 silly audit watchpack: [ '2.3.1' ],
156 silly audit wbuf: [ '1.7.3' ],
156 silly audit 'web-vitals': [ '2.1.4' ],
156 silly audit webpack: [ '5.72.0' ],
156 silly audit 'webpack-dev-middleware': [ '5.3.1' ],
156 silly audit 'webpack-dev-server': [ '4.8.1' ],
156 silly audit ws: [ '8.6.0', '7.5.7' ],
156 silly audit 'webpack-manifest-plugin': [ '4.1.1' ],
156 silly audit 'webpack-sources': [ '2.3.1', '3.2.3', '1.4.3' ],
156 silly audit 'websocket-driver': [ '0.7.4' ],
156 silly audit 'websocket-extensions': [ '0.1.4' ],
156 silly audit 'whatwg-encoding': [ '1.0.5' ],
156 silly audit 'whatwg-fetch': [ '3.6.2' ],
156 silly audit 'whatwg-mimetype': [ '2.3.0' ],
156 silly audit 'which-boxed-primitive': [ '1.0.2' ],
156 silly audit 'word-wrap': [ '1.2.3' ],
156 silly audit 'workbox-background-sync': [ '6.5.3' ],
156 silly audit 'workbox-broadcast-update': [ '6.5.3' ],
156 silly audit 'workbox-build': [ '6.5.3' ],
156 silly audit '@apideck/better-ajv-errors': [ '0.3.3' ],
156 silly audit 'workbox-cacheable-response': [ '6.5.3' ],
156 silly audit 'workbox-core': [ '6.5.3' ],
156 silly audit 'workbox-expiration': [ '6.5.3' ],
156 silly audit 'workbox-google-analytics': [ '6.5.3' ],
156 silly audit 'workbox-navigation-preload': [ '6.5.3' ],
156 silly audit 'workbox-precaching': [ '6.5.3' ],
156 silly audit 'workbox-range-requests': [ '6.5.3' ],
156 silly audit 'workbox-recipes': [ '6.5.3' ],
156 silly audit 'workbox-routing': [ '6.5.3' ],
156 silly audit 'workbox-strategies': [ '6.5.3' ],
156 silly audit 'workbox-streams': [ '6.5.3' ],
156 silly audit 'workbox-sw': [ '6.5.3' ],
156 silly audit 'workbox-webpack-plugin': [ '6.5.3' ],
156 silly audit 'workbox-window': [ '6.5.3' ],
156 silly audit 'wrap-ansi': [ '7.0.0' ],
156 silly audit wrappy: [ '1.0.2' ],
156 silly audit 'write-file-atomic': [ '3.0.3' ],
156 silly audit 'xml-name-validator': [ '3.0.0' ],
156 silly audit xmlchars: [ '2.2.0' ],
156 silly audit xtend: [ '4.0.2' ],
156 silly audit y18n: [ '5.0.8' ],
156 silly audit yallist: [ '4.0.0' ],
156 silly audit yaml: [ '1.10.2' ],
156 silly audit yargs: [ '16.2.0' ],
156 silly audit 'yargs-parser': [ '20.2.9' ],
156 silly audit 'yocto-queue': [ '0.1.0' ],
156 silly audit '@supabase/supabase-js': [ '1.35.2' ],
156 silly audit '@supabase/functions-js': [ '1.3.3' ],
156 silly audit '@supabase/gotrue-js': [ '1.22.13' ],
156 silly audit '@supabase/postgrest-js': [ '0.37.2' ],
156 silly audit '@supabase/realtime-js': [ '1.7.2' ],
156 silly audit '@supabase/storage-js': [ '1.7.0' ],
156 silly audit 'cross-fetch': [ '3.1.5' ],
156 silly audit '@types/phoenix': [ '1.5.4' ],
156 silly audit websocket: [ '1.0.34' ],
156 silly audit 'node-fetch': [ '2.6.7' ],
156 silly audit bufferutil: [ '4.0.6' ],
156 silly audit 'es5-ext': [ '0.10.61' ],
156 silly audit 'utf-8-validate': [ '5.0.9' ],
156 silly audit yaeti: [ '0.0.6' ],
156 silly audit 'node-gyp-build': [ '4.4.0' ],
156 silly audit 'es6-iterator': [ '2.0.3' ],
156 silly audit 'es6-symbol': [ '3.1.3' ],
156 silly audit 'next-tick': [ '1.1.0' ],
156 silly audit d: [ '1.0.1' ],
156 silly audit type: [ '1.2.0', '2.6.0' ],
156 silly audit ext: [ '1.6.0' ]
156 silly audit }
157 verbose reify failed optional dependency /run/media/user/Personal/Projects/react/my-app/node_modules/fsevents
158 silly reify mark deleted [
158 silly reify '/run/media/user/Personal/Projects/react/my-app/node_modules/fsevents'
158 silly reify ]
159 timing reifyNode:node_modules/fsevents Completed in 130ms
160 timing reifyNode:node_modules/@types/phoenix Completed in 1425ms
161 timing reifyNode:node_modules/websocket/node_modules/ms Completed in 1446ms
162 timing reifyNode:node_modules/node-fetch/node_modules/webidl-conversions Completed in 1517ms
163 timing reifyNode:node_modules/node-gyp-build Completed in 1576ms
164 timing reifyNode:node_modules/next-tick Completed in 1701ms
165 timing reifyNode:node_modules/yaeti Completed in 1734ms
166 timing reifyNode:node_modules/node-fetch/node_modules/whatwg-url Completed in 1753ms
167 timing reifyNode:node_modules/d Completed in 1782ms
168 timing reifyNode:node_modules/node-fetch Completed in 1825ms
169 timing reifyNode:node_modules/node-fetch/node_modules/tr46 Completed in 1938ms
170 timing reifyNode:node_modules/websocket/node_modules/debug Completed in 1945ms
171 timing reifyNode:node_modules/cross-fetch Completed in 1977ms
172 timing reifyNode:node_modules/es6-iterator Completed in 2195ms
173 timing reifyNode:node_modules/es6-symbol Completed in 2235ms
174 http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/advisories/bulk 2270ms
175 timing auditReport:getReport Completed in 2373ms
176 silly audit report {
176 silly audit report 'nth-check': [
176 silly audit report id: 1067654,
176 silly audit report url: 'https://github.com/advisories/GHSA-rp65-9cf3-cjxr',
176 silly audit report title: 'Inefficient Regular Expression Complexity in nth-check',
176 silly audit report severity: 'moderate',
176 silly audit report vulnerable_versions: '<2.0.1',
176 silly audit report cwe: [Array],
176 silly audit report cvss: [Object]
176 silly audit report }
176 silly audit report ]
177 timing metavuln:cache:get:security-advisory:nth-check:3k06OroJLgELuM+zLlxCn28v8PFxG7M4G0FWcdepJA8uKso4q0acHHNqZia/QUgPjIAZYPDsdUpRuAKARKSiBw== Completed in 141ms
178 timing reifyNode:node_modules/websocket Completed in 2403ms
179 timing reifyNode:node_modules/bufferutil Completed in 2489ms
180 timing reifyNode:node_modules/utf-8-validate Completed in 2497ms
181 timing reifyNode:node_modules/@supabase/functions-js Completed in 2495ms
182 http fetch GET 200 https://registry.npmjs.org/nth-check 566ms (cache revalidated)
183 timing metavuln:packument:nth-check Completed in 571ms
184 timing metavuln:load:security-advisory:nth-check:1067654 Completed in 3ms
185 timing metavuln:calculate:security-advisory:nth-check:1067654 Completed in 580ms
186 timing metavuln:cache:get:security-advisory:css-select:vzizomWRd6M2v4gU0UEGoaekLHkD3hIj0mXfP3aMLDIu3MHlqGiGJvanbTgzgznDLl+JoCuOlcho9fkDwydzfg== Completed in 118ms
187 http fetch GET 200 https://registry.npmjs.org/css-select 472ms (cache revalidated)
188 timing metavuln:packument:css-select Completed in 477ms
189 timing metavuln:load:security-advisory:css-select:3k06OroJLgELuM+zLlxCn28v8PFxG7M4G0FWcdepJA8uKso4q0acHHNqZia/QUgPjIAZYPDsdUpRuAKARKSiBw== Completed in 1ms
190 timing metavuln:calculate:security-advisory:css-select:3k06OroJLgELuM+zLlxCn28v8PFxG7M4G0FWcdepJA8uKso4q0acHHNqZia/QUgPjIAZYPDsdUpRuAKARKSiBw== Completed in 479ms
191 timing metavuln:cache:get:security-advisory:svgo:0DIruXXuZ2ZyQO7GAIY8nnjPmA+VUxjHAdZNp9fNliVrYY6FdH4SRJ0/U8INfEZU3ifIvdJwOX2uFgIhtEZymQ== Completed in 103ms
192 timing reifyNode:node_modules/ext Completed in 3651ms
193 http fetch GET 200 https://registry.npmjs.org/svgo 451ms (cache revalidated)
194 timing metavuln:packument:svgo Completed in 464ms
195 timing metavuln:load:security-advisory:svgo:vzizomWRd6M2v4gU0UEGoaekLHkD3hIj0mXfP3aMLDIu3MHlqGiGJvanbTgzgznDLl+JoCuOlcho9fkDwydzfg== Completed in 4ms
196 timing metavuln:calculate:security-advisory:svgo:vzizomWRd6M2v4gU0UEGoaekLHkD3hIj0mXfP3aMLDIu3MHlqGiGJvanbTgzgznDLl+JoCuOlcho9fkDwydzfg== Completed in 469ms
197 timing reifyNode:node_modules/ext/node_modules/type Completed in 3802ms
198 timing metavuln:cache:get:security-advisory:@svgr/plugin-svgo:GlUBfYKBe//VwBUf14INrfRzokCk3zcsH+3ooIUy4CHLIhw6Fumg3BbXbawe27Myvxd+GORUQlyxrr5/yUhmxA== Completed in 69ms
199 timing reifyNode:node_modules/@supabase/postgrest-js Completed in 3848ms
200 timing reifyNode:node_modules/@supabase/supabase-js Completed in 3859ms
201 timing reifyNode:node_modules/@supabase/storage-js Completed in 3877ms
202 timing reifyNode:node_modules/@supabase/gotrue-js Completed in 3979ms
203 http fetch GET 200 https://registry.npmjs.org/@svgr%2fplugin-svgo 225ms (cache revalidated)
204 timing metavuln:packument:@svgr/plugin-svgo Completed in 230ms
205 timing metavuln:load:security-advisory:@svgr/plugin-svgo:0DIruXXuZ2ZyQO7GAIY8nnjPmA+VUxjHAdZNp9fNliVrYY6FdH4SRJ0/U8INfEZU3ifIvdJwOX2uFgIhtEZymQ== Completed in 1ms
206 timing metavuln:calculate:security-advisory:@svgr/plugin-svgo:0DIruXXuZ2ZyQO7GAIY8nnjPmA+VUxjHAdZNp9fNliVrYY6FdH4SRJ0/U8INfEZU3ifIvdJwOX2uFgIhtEZymQ== Completed in 233ms
207 timing metavuln:cache:get:security-advisory:@svgr/webpack:YCKitfWJ1nvB6TcKzmMnp67mrLHbAAAQm5kP8zN6VEZCrcgCEDndX6rN4ivSubGVoFWUJF+mveALS2U5tEFlWQ== Completed in 85ms
208 timing reifyNode:node_modules/@supabase/realtime-js Completed in 4115ms
209 http fetch GET 200 https://registry.npmjs.org/@svgr%2fwebpack 300ms (cache revalidated)
210 timing metavuln:packument:@svgr/webpack Completed in 310ms
211 timing metavuln:load:security-advisory:@svgr/webpack:GlUBfYKBe//VwBUf14INrfRzokCk3zcsH+3ooIUy4CHLIhw6Fumg3BbXbawe27Myvxd+GORUQlyxrr5/yUhmxA== Completed in 1ms
212 timing metavuln:calculate:security-advisory:@svgr/webpack:GlUBfYKBe//VwBUf14INrfRzokCk3zcsH+3ooIUy4CHLIhw6Fumg3BbXbawe27Myvxd+GORUQlyxrr5/yUhmxA== Completed in 313ms
213 timing metavuln:cache:get:security-advisory:react-scripts:TdBNC/bzy4pCMT1Mye76ROCL8weSGaq1VDvENkCWoNJDQW2J6gELIsNp1nupvqfp7BqVzBLaPUtPLtuvhUh/2g== Completed in 40ms
214 timing reifyNode:node_modules/type Completed in 4382ms
215 http fetch GET 200 https://registry.npmjs.org/react-scripts 181ms (cache revalidated)
216 timing metavuln:packument:react-scripts Completed in 213ms
217 timing metavuln:load:security-advisory:react-scripts:YCKitfWJ1nvB6TcKzmMnp67mrLHbAAAQm5kP8zN6VEZCrcgCEDndX6rN4ivSubGVoFWUJF+mveALS2U5tEFlWQ== Completed in 7ms
218 timing metavuln:calculate:security-advisory:react-scripts:YCKitfWJ1nvB6TcKzmMnp67mrLHbAAAQm5kP8zN6VEZCrcgCEDndX6rN4ivSubGVoFWUJF+mveALS2U5tEFlWQ== Completed in 223ms
219 timing auditReport:init Completed in 2540ms
220 timing reify:audit Completed in 4920ms
221 timing reifyNode:node_modules/es5-ext Completed in 6177ms
222 timing reify:unpack Completed in 6193ms
223 timing reify:unretire Completed in 1ms
224 timing build:queue Completed in 29ms
225 timing build:link:node_modules/node-gyp-build Completed in 13ms
226 timing build:link Completed in 15ms
227 info run bufferutil@4.0.6 install node_modules/bufferutil node-gyp-build
228 info run utf-8-validate@5.0.9 install node_modules/utf-8-validate node-gyp-build
229 info run bufferutil@4.0.6 install { code: 126, signal: null }
230 info run utf-8-validate@5.0.9 install { code: 126, signal: null }
231 timing reify:rollback:createSparse Completed in 2324ms
232 timing reify:rollback:retireShallow Completed in 0ms
233 timing command:i Completed in 45576ms
234 verbose stack Error: command failed
234 verbose stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/index.js:64:27)
234 verbose stack at ChildProcess.emit (node:events:527:28)
234 verbose stack at maybeClose (node:internal/child_process:1090:16)
234 verbose stack at Socket.<anonymous> (node:internal/child_process:449:11)
234 verbose stack at Socket.emit (node:events:527:28)
234 verbose stack at Pipe.<anonymous> (node:net:709:12)
235 verbose pkgid bufferutil@4.0.6
236 verbose cwd /run/media/user/Personal/Projects/react/my-app
237 verbose Linux 5.15.32-1-MANJARO
238 verbose argv "/usr/bin/node" "/usr/bin/npm" "i" "@supabase/supabase-js"
239 verbose node v17.8.0
240 verbose npm v8.5.5
241 error code 126
242 error path /run/media/user/Personal/Projects/react/my-app/node_modules/bufferutil
243 error command failed
244 error command sh -c node-gyp-build
245 error sh: line 1: /run/media/user/Personal/Projects/react/my-app/node_modules/.bin/node-gyp-build: Permission denied
246 verbose exit 126
247 timing npm Completed in 46824ms
248 verbose unfinished npm timer reify 1651576939528
249 verbose unfinished npm timer reify:build 1651576982590
250 verbose unfinished npm timer build 1651576982594
251 verbose unfinished npm timer build:deps 1651576982594
252 verbose unfinished npm timer build:run:install 1651576982639
253 verbose unfinished npm timer build:run:install:node_modules/bufferutil 1651576982643
254 verbose unfinished npm timer build:run:install:node_modules/utf-8-validate 1651576982706
255 verbose code 126
256 error A complete log of this run can be found in:
256 error /home/user/.npm/_logs/2022-05-03T11_22_18_326Z-debug-0.log
I’m only a casual linux user. That might mess up my system so I’ll prefer to do something less scary.
