hello
I got the hardware in the screenshot below, I’m not sure it’s well configured (new to Manjaro)
Wifi working but not seen. It’s a mediatek 7921e with mt61 driver, which I got working thankfully to some friends here.
I thought it should be part of firmware from kernel 5.16, which I’m using
GPU is fine too, using wayland on KDE but I’m confused if it’s using the right driver. which one should be ticked?
Your amdgpu is opensource and supported by the kernel … no need to mess with the driver unless you want to do advanced configuration ala something like here:
