Hey! So I am new to Manjaro and I am facing the issue that it is not detecting my Bluetooth and Wifi Drivers. I am connected to the internet right now through USB tethering. Is there any way anyone can help me?
i have installed realtec drivers, broadcom drivers and nothing helped. please guide me through the process.
                ben75
                    11 June 2023 04:06
              2
              inxi        INT ✘
CPU: 12-core (4-mt/8-st) 13th Gen Intel Core i5-1340P (-MST AMCP-)
speed/min/max: 1303/400/4600:3400 MHz Kernel: 6.4.0-1-MANJARO x86_64 Up: 43m
Mem: 7388.9/15621.9 MiB (47.3%) Storage: 476.94 GiB (16.3% used) Procs: 334
Shell: Zsh inxi: 3.3.2
this is the inxi output
                ben75
                    11 June 2023 04:20
              4
              Did you even read the post I linked?
It said to provide the output of:
inxi --admin --verbosity=7 --filter --width
              inxi --admin --verbosity=7 --filter --width                                                    ✔
  Kernel: 6.4.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
    root=UUID=24c286dd-fc23-45d3-a489-71ba4abe20bb rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
  Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop K3504VA_K3504VA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: K3504VA v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: K3504VA.203 date: 01/19/2023
  ID-1: BAT0 charge: 33.5 Wh (69.4%) condition: 48.3/50.0 Wh (96.6%)
    volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: discharging cycles: 6
  System RAM: available: 15.26 GiB used: 4.3 GiB (28.2%)
  Info: model: 13th Gen Intel Core i5-1340P bits: 64 type: MST AMCP
    arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xBA (186) stepping: 2 microcode: 0x4112
  Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
    cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
    desc: 4x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1143 high: 2200 min/max: 400/4600:3400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 440 2: 618 3: 400 4: 2200
    5: 827 6: 598 7: 954 8: 1127 9: 2200 10: 400 11: 2200 12: 564 13: 2200
    14: 927 15: 442 16: 2200 bogomips: 70064
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes
    vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt
    xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: ASUSTeK driver: i915
    v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
    active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:a7a0
    class-ID: 0300
  Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:5 chip-ID: 13d3:5463
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Graphics (RPL-P)
    direct-render: Yes
  Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
    alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:51ca
    class-ID: 0403
  API: ALSA v: k6.4.0-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Device-1: MEDIATEK vendor: AzureWave driver: N/A modules: wl port: N/A
    bus-ID: 0000:02:00.0 chip-ID: 14c3:7902 class-ID: 0280
  IF-ID-1: enp0s20f0u4 state: unknown speed: -1 duplex: half mac: <filter>
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:6 chip-ID: 13d3:3579
  Device-2: OPPO DN2101 driver: rndis_host v: kernel type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 22d9:276a
    class-ID: 0a00 serial: <filter>
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
    class-ID: 0104
  Local Storage: total: 476.94 GiB used: 38.97 GiB (8.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA512QFM
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA003 temp: 32.9 C
    scheme: GPT
  ID-1: / raw-size: 386.91 GiB size: 379.77 GiB (98.15%)
    used: 38.91 GiB (10.2%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    label: N/A uuid: 24c286dd-fc23-45d3-a489-71ba4abe20bb
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 64.5 MiB (25.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM uuid: 9E68-48B0
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 88.53 GiB fs: bitlocker
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs label: RECOVERY
    uuid: B0F65BD6F65B9B82
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 260 MiB fs: vfat label: MYASUS
    uuid: 7C49-7ECF
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: Logitech Unifying Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Device-2: 1-4:3 info: OPPO DN2101 type: bluetooth,CDC-data
    driver: rndis_host interfaces: 2 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 22d9:276a class-ID: 0a00
    serial: <filter>
  Device-3: 1-7:4 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 04f3:0c90 class-ID: 0000
  Device-4: 1-9:5 info: IMC Networks USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 13d3:5463 class-ID: fe01 serial: <filter>
  Device-5: 1-10:6 info: IMC Networks Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 13d3:3579 class-ID: e001 serial: <filter>
  System Temperatures: cpu: 51.0 C mobo: N/A
  Processes: 301 Uptime: 5m wakeups: 323 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: 1383 pm: pacman pkgs: 1375 libs: 378 tools: pamac,yaourt
  pm: flatpak pkgs: 8 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.27
sorry about that, I misunderstood, here’s the output.
                ben75
                    11 June 2023 04:49
              6
 VoidWalker:
chip-ID: 14c3:7902
It appears there is not a driver for that chip available for Linux. Maybe someone else can provide more info.
Also, why is this post tagged with kde, plasma, update, and boot? Drivers are totally independent of desktop environment.
 VoidWalker:
14c3:7902
No kernel support yet. No 3rd party additional package. You are out of luck. You are going to have to get some external usb wifi/bluetooth adapter (linux compatible)
              yep, that’s what I am doing. any idea when the support will be available? also thanks for your help @ben75  and @cfinnberg .
That is quite difficult to say. Maybe tomorrow someone add support in the Linux kernel or maybe a couple of years can go before someone does something (or even longer). Some hardware can be quite hard to understand (without maker’s help) and can take a long time or never have proper support in Linux.
Let’s just hope for the best and that in a short time support is added to the kernel
              Yeah, I hope the same. Thanks for the help!
