Hi. I have been using manjaro for a year. Usually when I run into any issues I chroot and run an fsck or restore from timeshift. This time, manjaro was working fine, but the graphics started being laggy. Videos played were being choppy. I did a forced restart, and I cannot boot into manjaro after that.
I tried booting from a live usb and running fsck. It could not access the home directory in the beginning. After the fsck, it shows the home directory but on entering it does not show any folders. I then tried to restore from timeshift. However timeshift gets stuck and shows “updating bootloader configuration”.
Is there any thing I can do get back my old installation or is a new installation the only method.
Thanks in advance. I am really new and any leads would be appreciated.
Hello @titir24! Please provide some information on your system, since you cannot access your previous installation, boot to a live env and run inxi -Fazy
command. How to provide good information
Hi. Sorry for the delay.
This is the output from the inxi -Fazy command
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2021 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: VivoBook S14 X430UN v: 1.0
serial: <filter>
Mobo: ASUSTeK model: X430UN v: 1.0 serial: <filter>
UEFI: American Megatrends v: X430UN.304 date: 05/22/2019
ID-1: BAT0 charge: 17.6 Wh condition: 18.7/42.2 Wh (44%) volts: 11.6/11.6
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Charging
cycles: 568
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 L2 cache: 8 MiB
bogomips: 32012
Speed: 900 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 900 8: 900
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5917
Device-2: NVIDIA GP108M [GeForce MX150] vendor: ASUSTeK driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:1d10
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-6:5 chip ID: 13d3:56c1 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Device-2: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:3 chip ID: 0d8c:0014
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: AzureWave
driver: rtw_8822be v: N/A modules: rtw88_8822be port: d000 bus ID: 02:00.0
chip ID: 10ec:b822
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus ID: 00:17.0 chip ID: 8086.282a rev: 21
Local Storage: total: 1.15 TiB used: 164.6 MiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: SDM4
ID-2: /dev/sdb maj-min: 8:16 vendor: Micron model: 1100 MTFDDAV256TBN
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: A031
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Blade
size: 7.45 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.27
ID-1: / raw size: N/A size: 11.64 GiB used: 164.6 MiB (1.4%) fs: overlay
source: ERR-102
System Temperatures: cpu: 60.0 C mobo: N/A gpu: nouveau temp: 48.0 C
Fan Speeds (RPM): cpu: 3600
Processes: 260 Uptime: 3m wakeups: 1 Memory: 15.52 GiB
used: 1.97 GiB (12.7%) Init: systemd v: 247 Compilers: gcc: N/A Packages:
pacman: 1264 lib: 375 flatpak: 0 Shell: Bash v: 5.1.0 running in: yakuake
inxi: 3.2.01
What should I do now?
You shouldn’t have done that, you should have just restarted manually
Never mind, inxi -Fazy
doesn’t give much info I guess, try this :- inxi --admin --verbosity=7 --filter --no-host --width
By forced restart, I meant I switched it off and then restarted normally. Sorry for the miscommunication.
Yeah, I actually also meant that
This is the output
radeon.modeset=1
serial: <filter>
ID-1: BAT0 charge: 16.9 Wh condition: 18.7/42.2 Wh (44%) volts: 11.6/11.6
cycles: 569
RAM: total: 15.52 GiB used: 1.82 GiB (11.7%)
microcode: E0 L2 cache: 8 MiB bogomips: 32012
Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
diag: 354mm (13.9")
direct render: Yes
chip ID: 8086:9d71
chip ID: 10ec:b822
Local Storage: total: 1.15 TiB used: 145.9 MiB (0.0%)
rev: 1.27
ID-1: / raw size: N/A size: 11.64 GiB used: 145.9 MiB (1.2%) fs: overlay
source: ERR-102 label: N/A uuid: N/A
ID-1: /dev/sda1 maj-min: 8:1 size: 252.88 GiB fs: <superuser required>
ID-2: /dev/sda2 maj-min: 8:2 size: 513 MiB fs: vfat label: N/A
uuid: A7EB-784A
ID-3: /dev/sda3 maj-min: 8:3 size: 1024 KiB fs: <superuser required>
ID-4: /dev/sda4 maj-min: 8:4 size: 127 MiB fs: <superuser required>
ID-5: /dev/sda5 maj-min: 8:5 size: 662.13 GiB fs: ext4 label: N/A
uuid: c332107e-3f34-4ed1-bd49-2242e65db4d5
ID-6: /dev/sda6 maj-min: 8:6 size: 15.88 GiB fs: swap label: N/A
uuid: d2966272-21ce-4318-b9d5-2253c91ec749
ID-7: /dev/sdb1 maj-min: 8:17 size: 260 MiB fs: vfat label: SYSTEM
uuid: 324C-0759
ID-8: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
ID-9: /dev/sdb3 maj-min: 8:19 size: 237.42 GiB fs: ntfs label: OS
uuid: 9ACC5029CC4FFDC7
ID-10: /dev/sdb4 maj-min: 8:20 size: 800 MiB fs: ntfs label: RECOVERY
uuid: AE96D11A96D0E3BD
ID-11: /dev/sdc1 maj-min: 8:33 size: 3 GiB fs: iso9660
label: MANJARO_KDE_2021 uuid: 2021-01-03-09-07-36-00
ID-12: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 7B2D-7571
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-1:2 info: Dell Dell Universal Receiver type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 413c:8505
Device-2: 1-3:3 info: C-Media Audio Adapter (Unitek Y-247A) type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s chip ID: 0d8c:0014
Device-3: 1-4:4 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 0781:5567 serial: <filter>
Device-4: 1-6:5 info: IMC Networks USB2.0 HD UVC WebCam type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 13d3:56c1
serial: <filter>
Device-5: 1-8:6 info: IMC Networks Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 13d3:3526
serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nouveau temp: 47.0 C
Fan Speeds (RPM): cpu: 3200
Processes: 249 Uptime: 3m wakeups: 1 Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1264 lib: 375 flatpak: 0 Shell: Bash v: 5.1.0
running in: yakuake inxi: 3.2.01
Can anyone help me out?
