"Normal" Text in every Window
After the newest update, i have a text that says Normal in the top right corner on every application window. How can i remove this?
Something like that? We need more information, see:
exactly like this
Is a nvidia config the reason for this?
You have the G-Sync indicator enabled? That’s what causes it for me.
yes it was activated
deactivate and reboot solved it, thx
You just need to relaunch affected applications after toggling it.
