Bill
30 November 2020 10:11
1
Hi,
I’ve newly tried to install manjaro xfce 20.1.2
Installing stopped after failing starting Light Display Manager. I’ve found some explanations about nvidia driver. But I haven’t nvdia.
Then I started a new installation with architect and succeeded after installing video-vesa driver.
I believe that I’m not using my GPU… That’s why I’m asking you how to verify it. How can I find the name of my GPU, know if it’s used and know which driver I need for ?
Many thanks.
Bill
cscs
30 November 2020 10:29
2
Alot of ground to cover here … but you almost certainly shouldnt be using vesa.
Configure Graphics Cards - Manjaro
How to provide good information
Bill
30 November 2020 11:36
3
Sorry for not providing my system information first.
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=b1311b37-fe24-446f-bfad-741ffa21c0cb rw quiet udev.log_priority=3
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Packard Bell BV product: EasyNote_MX37-U-056FR
v: PC10E06402 serial: <filter> Chassis: PACKARD BELL BV type: 10
serial: <filter>
Mobo: PACKARD BELL BV model: T12C v: 1.0 serial: <filter>
BIOS: American Megatrends v: 218 date: 04/25/2008
ID-1: BAT0 charge: 17.8 Wh condition: 18.0/47.3 Wh (38%) volts: 12.3/11.1
model: PACKARD BELL T12--22 type: Li-ion serial: N/A status: Unknown
Info: Dual Core model: Intel Pentium Dual T2370 bits: 64 type: MCP
arch: Core Merom family: 6 model-id: F (15) stepping: D (13) microcode: A4
L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 6934
Speed: 1733 MHz min/max: 800/1733 MHz Core speeds (MHz): 1: 1733 2: 1733
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: Silicon Integrated Systems [SiS] 771/671 PCIE VGA Display Adapter
vendor: Packard Bell B.V. driver: N/A bus ID: 01:00.0 chip ID: 1039:6351
Display: x11 server: X.Org 1.20.9 driver: vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 271x203mm (10.7x8.0")
s-diag: 339mm (13.3")
Monitor-1: default res: 1024x768
OpenGL: renderer: llvmpipe (LLVM 11.0.0 128 bits) v: 4.5 Mesa 20.2.3
compat-v: 3.1 direct render: Yes
Device-1: Silicon Integrated Systems [SiS] Azalia Audio
vendor: Packard Bell B.V. driver: snd_hda_intel v: kernel bus ID: 00:0f.0
chip ID: 1039:7502
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Silicon Integrated Systems [SiS] 191 Gigabit Ethernet Adapter
vendor: Packard Bell B.V. driver: sis190 v: 1.4 port: cc00 bus ID: 00:04.0
chip ID: 1039:0191
IF: enp0s4 state: down mac: <filter>
Device-2: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter
vendor: AzureWave AW-GE780 802.11bg driver: ath5k v: kernel port: dc00
bus ID: 02:00.0 chip ID: 168c:001c
Local Storage: total: 232.89 GiB used: 7.99 GiB (3.4%)
ID-1: /dev/sda vendor: Seagate model: ST9250827AS size: 232.89 GiB
block size: physical: 512 B logical: 512 B speed: <unknown>
rotation: 5400 rpm serial: <filter> rev: A scheme: MBR
ID-1: / raw size: 229.88 GiB size: 225.28 GiB (97.99%) used: 7.99 GiB (3.5%)
fs: ext4 dev: /dev/sda2
Kernel: swappiness: 10 (default 60) cache pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 3.00 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1
System Temperatures: cpu: 59.0 C mobo: N/A
Processes: 152 Uptime: 3m Memory: 2.80 GiB used: 547.1 MiB (19.1%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1079 lib: 311
flatpak: 0 Shell: Zsh v: 5.8 running in: xfce4-terminal inxi: 3.1.08
~ >>> mhwd -l --pci
0000:01:00.0 (0300:1039:6351) Display controller Silicon Integrated Systems Corp.:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
When I tried to boot with video-modesetting manjaro didn’t even start.
cscs
30 November 2020 12:16
4
Huh.
Thats pretty old.
What is your GPU exactly? It doesnt seem to be recognized as an intel or radeon or …
(PS - given the age … I suggest going with a slightly older LTS driver like maybe 5.4 or 4.19)
jeancf
30 November 2020 12:21
5
This hardware is a bit dated and you probably need to install the driver manually. I saw an AUR package for it but there are reports of it being broken in 2018 and no update since. So I would not recommend it.
aur/xf86-video-sisimedia 0.9.1-13 (+3 0.00) (Out-of-date: 2018-07-15)
X.org SiS 671 video driver
I also found this page but it is ugly and you should try it only if you are desperate and if you have taken a snapshot of your system before (with e.g. Timeshift). if it works, it is not integrated in the package management system and may break (if it ever works in the first place).
Bill
30 November 2020 13:50
6
Using an other hard disk I’ve installed Ubuntu LTS 20.04 with a 5.4 kernel on the same computer. The driver used is xf86-video-fbdev, it works fine.
I downloaded it with pacman on manjaro and I configured it on Xorg.
sudo Xorg :2 -configure
sudo mv /root/xorg.conf.new /etc/X11/xorg.conf.d
but I’m still not able to use the new driver by using
mhwd -i pci video-fbdev
Error: config 'video-fbdev' does not exist!
did I forget something ?
I will try a 5.4 kernel soon.
Bill
30 November 2020 14:13
7
Hardware info :
Packard Bell MX37-U-044
Processeur Pentium Dual Core T2370 (1.73 GHz), 2 Go DDR2 667 MHz, un disque dur SATA de 250 Go à 5400 trs/min, un chipset graphique intégré SIS M672 256 Mo
jeancf
1 December 2020 09:21
8
Bill:
mhwd -i
What do mhwd -l and mhwd -li say?
Bill
2 December 2020 16:20
9
mhwd -l
mhwd -li
Warning: no installed PCI configs!
Warning: no installed USB configs!
Same troubles on kernel 5.4
jeancf
2 December 2020 17:03
10
I think you have to install extra/xf86-video-fbdev before trying mhwd -i pci video-fbdev.
mhwd -l shows that it is not available to install.
Bill
8 December 2020 09:28
11
I give up, Kali Linux and Ubuntu works fine. Thank you for your support !
I will try manjaro again with a new computer.
