When I play sound it starts with a noise in the first second before becoming normal. It seems to be when the sound system is initialized after a pause, as it only happens after the system has been silent for a while. The noise comes when I run on kernel 5.18.12-3, but not on kernel 5.15.55-1. It did not happen on kernel 5.18.7-1 or earlier.
Gigabyte Radeon RX 590 Gaming 8GB rev. 1.0
export LANG=C && inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=bbaf3e0f-20db-40ad-b4ad-720e50db787a ro nosplash noresume
nohibernate udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME B450-PLUS v: Rev X.0x
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 2008
date: 12/06/2019
Device-1: hidpp_battery_0 model: Logitech M215 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
RAM: total: 15.56 GiB used: 1.94 GiB (12.5%)
RAM Report:
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113)
stepping: 0 microcode: 0x8701013
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2333 high: 3592 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2944 2: 2053
3: 2143 4: 2191 5: 2196 6: 2194 7: 3592 8: 2052 9: 2053 10: 2192 11: 2195
12: 2192 bogomips: 86273
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN 4 process: GF 14nm
built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2,DVI-D-1
bus-ID: 08:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x2160 s-dpi: 96 s-size: 1182x570mm (46.54x22.44")
s-diag: 1312mm (51.66")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,top-left
model: Philips FTV serial: <filter> built: 2017 res: 3840x2160 hz: 60
dpi: 68 gamma: 1.2 size: 1440x810mm (56.69x31.89") diag: 1652mm (65")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-r model: Denon DENON-AVR
serial: <filter> built: 2014 res: 640x480 hz: 60 dpi: 23 gamma: 1.2
size: 708x398mm (27.87x15.67") diag: 918mm (36.1") ratio: 16:9 modes:
OpenGL: renderer: AMD Radeon RX 590 Series (polaris10 LLVM 14.0.6 DRM 3.42
5.15.55-1-MANJARO)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 08:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.55 running: no
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Local Storage: total: 2.52 TiB used: 1.48 TiB (58.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EADS-00L5B1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EADS-00L5B1 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1A01
scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Micron model: MTFDDAK256MAY-1AH12ABHA
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: M5T4 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: A-Data model: SU800NS38
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 8B scheme: MBR
ID-1: / raw-size: 468.13 GiB size: 459.72 GiB (98.20%) used: 25.6 GiB (5.6%)
fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: e2root
uuid: bbaf3e0f-20db-40ad-b4ad-720e50db787a
ID-2: /home/adisk raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
used: 768.06 GiB (83.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: adisk
uuid: a0f67169-c4c3-48e9-bafe-a73dc0983560
ID-3: /home/bdisk raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
used: 692.07 GiB (75.6%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: bdisk
uuid: ed96f3d3-edea-43bc-8418-2223e4ec312d
ID-4: /home/cdisk raw-size: 238.47 GiB size: 233.67 GiB (97.99%)
used: 30.89 GiB (13.2%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: cdisk
uuid: f94e8a24-3ec4-4edb-b49f-0d26ab9fef52
ID-5: /home/<filter>/cryptomount.fredox.vol raw-size: 600 MiB
size: 573.7 MiB (95.62%) used: 455.3 MiB (79.4%) fs: ext4 dev: /dev/dm-1
maj-min: 254:1 mapped: loop0 label: N/A uuid: N/A
dev: /dev/dm-0 maj-min: 254:0 mapped: swap label: swap
uuid: 59bb8af1-1a61-48d6-9652-b9582aa07104
ID-1: /dev/sdd2 maj-min: 8:50 size: 8.8 GiB fs: ext2 label: cryptswap
uuid: a6fb126a-9bf7-40ed-84c2-2fbf22d608d3
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-4:3 info: Jing-Mold Enterprise 2.4G Dongle
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 05af:0906 class-ID: 0301
Device-2: 1-7:4 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-3: 1-9:5 info: NZXT Smart Device V2 type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1e71:2006 class-ID: 0300 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-2:2 info: Genesys Logic USB3.0 Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 05e3:0617 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 63.0 C mobo: 34.0 C gpu: amdgpu temp: 53.0 C
Fan Speeds (RPM): cpu: 1333 fan-2: 0 fan-3: 0 fan-4: 0 fan-6: 0
gpu: amdgpu fan: 781
Power: 12v: N/A 5v: N/A 3.3v: 3.29 vbat: 3.23 gpu: amdgpu watts: 28.12
Processes: 319 Uptime: 21m wakeups: 9 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: pacman: 1166 lib: 261 Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
