No wifi on HP Victus
Hi,
black friday acquisition:
~]$ inxi -Fxxx
  Host: ordi1 Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc
  v: 11.1.0 Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel
  wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
  base: Arch Linux
  Type: Laptop System: HP product: Victus by HP Laptop 16-e0xxx v: N/A
  serial: <superuser required> Chassis: type: 10
  Mobo: HP model: 8934 v: 80.72 serial: <superuser required> UEFI: AMI
  v: F.11 date: 09/14/2021
  ID-1: BAT0 charge: 69.0 Wh (99.6%) condition: 69.3/69.3 Wh (100.0%)
  volts: 17.4 min: 15.4 model: HP Primary type: Li-ion serial: SerialNumber
  status: Unknown cycles: 1
  Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
  status: N/A
  Info: 6-Core model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64
  type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
  flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 79080
  Speed: 1323 MHz min/max: 1200/3300 MHz boost: enabled Core speeds (MHz):
  1: 1323 2: 1595 3: 1197 4: 1203 5: 3111 6: 1198 7: 1339 8: 1197 9: 1438
  10: 1198 11: 3274 12: 2342
  Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
  vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 03:00.0
  chip-ID: 1002:7340 class-ID: 0380
  Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel
  bus-ID: 08:00.0 chip-ID: 1002:1638 class-ID: 0300
  Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
  bus-ID: 1-3:2 chip-ID: 0408:5425 class-ID: fe01 serial: 0001
  Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
  loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
  resolution: 1920x1080~60Hz s-dpi: 96
  OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.19-2-MANJARO LLVM 13.0.0)
  v: 4.6 Mesa 21.2.5 direct render: Yes
  Device-1: AMD Navi 10 HDMI Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:ab38
  class-ID: 0403
  Device-2: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
  bus-ID: 08:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel bus-ID: 08:00.5
  chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 08:00.6 chip-ID: 1022:15e3
  class-ID: 0403
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: no
  vendor: Hewlett-Packard driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
  IF: eno1 state: down mac: e0:70:ea:b5:a2:4d
  Device-2: Realtek vendor: Hewlett-Packard driver: N/A port: e000
  bus-ID: 05:00.0 chip-ID: 10ec:8852 class-ID: 0280
  IF-ID-1: enp8s0f4u1c4i2 state: up speed: N/A duplex: N/A
  mac: 2e:f0:a2:d2:04:a2
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
  bus-ID: 1-4:3 chip-ID: 0bda:2852 class-ID: e001 serial: 00e04c000001
  Local Storage: total: 506.81 GiB used: 27.75 GiB (5.5%)
  ID-1: /dev/nvme0n1 vendor: Western Digital
  model: PC SN730 SDBPNTY-512G-1006 size: 476.94 GiB speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: 213928801626 rev: HPS2 temp: 35.9 C scheme: GPT
  ID-2: /dev/sda type: USB vendor: Lexar model: USB Flash Drive
  size: 29.88 GiB type: SSD serial: AA5E6YI68FNX5UXW rev: 1100 scheme: MBR
  ID-1: / size: 369.32 GiB used: 9.52 GiB (2.6%) fs: ext4
  dev: /dev/nvme0n1p5
  ID-2: /boot/efi size: 256 MiB used: 65 MiB (25.4%) fs: vfat
  dev: /dev/nvme0n1p1
  System Temperatures: cpu: 45.0 C mobo: N/A
  GPU: device: amdgpu temp: 44.0 C mem: 0.0 C fan: 65526 watts: 4.00
  device: amdgpu temp: 45.0 C
  Processes: 289 Uptime: 12m wakeups: 4 Memory: 14.98 GiB
  used: 1.87 GiB (12.5%) Init: systemd v: 249 Compilers: gcc: N/A Packages:
  pacman: 1073 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.09
but no wifi & no bluetooth @this stage !
~]$ rfkill list
0: hci0: Bluetooth
	Soft blocked: yes
	Hard blocked: no
What should I tell or do ?
That kernel is EOL. So the first thing you should probably do is upgrade/change it to an LTS kernel.
Look up the chipID:
https://linux-hardware.org/?id=pci:10ec-8852-103c-88e1
Search the Chipset:
AUR (en) - Packages
Build and install the package:
pamac build rtw89-dkms-git
and of course all headers of each installed kernel version for building the DKMS, example: linux510-headers
Wahhh, thank you both !
For the kernels I’m ashamed as I thought I did move to 515.
Now it’s fixed, I’ve 514 - 515 , theyr headers & rtw89 !
Wifi perfectly working
