Hello, there!
I need help, there are no Wi-Fi connections on my PC but wifi adapter is connected, I cheched lots of solutions but none of them helped. (Dell Optiplex 9030, Kde Plasma, dual boot with windows, linux 610, Tp-link adapter)
That’s not enough info, please post the output of
inxi -Fazy
(upload://sGfrKME4iD7oJd47GHBvBQFniKR.jpeg)(upload://adptI3F72wpi4U336ZFmmMeDstj.jpeg)
Please copy and paste the terminal output here, using the </> button in the toolbar of the post editor. Screenshots are useless to us.
it says i cant include links
I am not talking about links. I am talking of copy/pasting the terminal output with the mouse, and how you can paste it into your post.
I`m pasting it(output from the terminal) but it actually says I cant use links
Then… remove the link from the pasted output, maybe? ![]()
Use the </> button in the toolbar of the post editor and paste the output between the two lines of three backticks each.
Kernel: 6.1.30-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=90080a0c-6b44-4b4f-9496-374dd33b726f rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Dell product: OptiPlex 9020 v: 01
serial: <superuser required> Chassis: type: 15 serial: <superuser required>
Mobo: Dell model: 0XCR8D v: A03 serial: <superuser required> UEFI: Dell
v: A07 date: 04/25/2014
Info: model: Intel Core i5-4570 bits: 64 type: MCP arch: Haswell gen: core 4
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1562 high: 3193 min/max: 800/3600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3193 2: 800 3: 800
4: 1455 bogomips: 25549
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Dell driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm
built: 2013 ports: active: VGA-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:0412 class-ID: 0300
Device-2: Realtek FULL HD 1080P Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.1:3
chip-ID: 0bda:58b0 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: crocus gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: VGA-1 model: HP E232 serial: <filter> built: 2015 res: 1920x1080
dpi: 96 gamma: 1.2 size: 509x286mm (20.04x11.26") diag: 584mm (23")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) direct-render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-3: Realtek FULL HD 1080P Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.1.30-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: TP-Link 802.11ac WLAN Adapter driver: N/A type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.6:6 chip-ID: 2357:011f
class-ID: 0000 serial: <filter>
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 465.76 GiB used: 8.01 GiB (1.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000AAKX-75U6AA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1H20 scheme: GPT
ID-1: / raw-size: 232.57 GiB size: 227.87 GiB (97.98%) used: 7.98 GiB (3.5%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
used: 25.3 MiB (26.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 32.0 C mobo: N/A
Processes: 160 Uptime: 1h 40m wakeups: 0 Memory: available: 3.74 GiB
used: 1.24 GiB (33.3%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1159 libs: 350 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
Is this from the live USB? Because kernel 6.1.30 is outdated. Also — although this doesn’t have anything to do with your problem — it says that you don’t have any swap. On a machine with only 4 GiB, you definitely need swap. But you can create a swap file later, if you want.
You mean installed by using live usb? no
No, I meant whether that output comes from the live USB or from the installed system. Because if that is your installed system, then it hasn’t been updated in a very long time.
Also… ![]()
You must set your drive to AHCI in the UEFI/BIOS.
I was installing without wifi so I have an old kernel, it will be(probably) updated when I get internet connection
By the way, there are new ISOs out now. Maybe you’ll have better luck with those then. ![]()
But keep your WiFi plugged in when you install this time.
I will try but when I was installing it I had same problem, wifi just wasnt showing(I installed Manjaro on my old laptop ans I didnt have such problem)
According to the information here: Device 2357:011f: NIC doesnt come up; Whitelist ? · Issue #102 · RinCat/RTL88x2BU-Linux-Driver · GitHub you need to install rtl8812au-dkms-git from the AUR.
But that’s kind of difficult when…
- OP has no internet connection on that machine; and…
- OP’s system is not up to date.
OP probably also has no idea on how to install any package while offline. ![]()
Life without a LAN cable or phone tethering? ![]()
Apparently, because OP said… ![]()
OP does have a laptop with internet — as I understand it, this would then be WiFi, but on that machine it works.
I was already wondering why OP was trying to use WiFi on what appears be a desktop machine — at least, according to the inxi output. But apparently WiFi is OP’s only option, and it only works on the laptop, not on the desktop.
