No I don’t use any HUDs and I turned off the Steam Overlay which had no effect on the behavior.
Update after re-install:
I installed Manjaro v21.3.7 KDE (and yes I’ve verified that the install ISO is good). In an attempt to install Steam Runtime the GUI add/remove tool did a full system upgrade to 22.0.0 and installed the Steam Runtime (1.0.0.75-2). So now I’m at v22.0.0 KDE with the v5.15.85-1-MANJARO kernel.
I installed Civ 6 (Linux native client) and it failed. I next installed Shadow of Mordor (Linux native/vulkan client) it ran without any problems. I can get 550 to 630 FPS in the benchmark with my hardware. I then switched Civ 6 to use Proton Experimental and it worked without using any launcher strings. The 2K launcher came up without any errors. The game launched with DX12, I altered some game settings, restarted the game and encountered no issues. I next installed Grim Dawn x64 and again used Proton Experimental and it ran without any problems.
I switched Civ6 back to the Linux native client and ran Steam from the terminal. Below is the output from my attempted launch:
[james_game5800x@5800x-gamejaro ~]$ steam
steam.sh[34253]: Running Steam on manjarolinux 22.0.0 64-bit
steam.sh[34253]: STEAM_RUNTIME is enabled automatically
setup.sh[34327]: Steam runtime environment up-to-date!
steam.sh[34253]: Steam client's requirements are satisfied
[2022-12-31 16:19:19] Startup - updater built Dec 15 2022 21:26:49
[2022-12-31 16:19:19] Startup - Steam Client launched with: '/home/james_game5800x/.local/share/Steam/ubuntu12_32/steam'
Installing breakpad exception handler for appid(steam)/version(1671236931)
[2022-12-31 16:19:19] Loading cached metrics from disk (/home/james_game5800x/.local/share/Steam/package/steam_client_metrics.bin)
[2022-12-31 16:19:19] Using the following download hosts for Public, Realm steamglobal
[2022-12-31 16:19:19] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2022-12-31 16:19:19] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2022-12-31 16:19:19] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-12-31 16:19:19] Verifying installation...
[2022-12-31 16:19:19] Verification complete
Loaded SDL version 2.27.0-p7692409
/usr/share/themes/Breeze/gtk-2.0/widgets/entry:70: error: unexpected identifier 'direction', expected character '}'
(steam:34388): Gtk-WARNING **: 16:19:20.190: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Breeze/gtk-2.0/widgets/styles:36: error: invalid string constant "combobox_entry", expected valid string constant
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xea407db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xea406500
ComputeStartupMode: found registry default startup mode: 0steamwebhelper.sh[34404]: Runtime for steamwebhelper: defaulting to /home/james_game5800x/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[34404]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 34 milliseconds to initialize
(steam:34388): Gtk-WARNING **: 16:19:21.048: gtk_disable_setlocale() must be called before gtk_init()
local (potentially out of sync) copy of roaming config loaded - 403 bytes.
BRefreshApplicationsInLibrary 1: 1ms
roaming config store loaded successfully - 403 bytes.
migrating temporary roaming config store
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/james_game5800x/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 3.06 seconds
BuildCompleteAppOverviewChange: 182 apps
RegisterForAppOverview 1: 2ms
RegisterForAppOverview 2: 2ms
GameAction [AppID 289070, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 289070, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 289070, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 289070, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 289070, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/./Civ6'\0
Game process added : AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/./Civ6'", ProcID 34687, IP 0.0.0.0:0
chdir /my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier's Civilization VI
ERROR: ld.so: object '/home/james_game5800x/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/james_game5800x/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
./GameGuide/Civ6: symbol lookup error: /usr/lib/libfontconfig.so.1: undefined symbol: FT_Done_MM_Var
Game process removed: AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/./Civ6'", ProcID 34687
Uploaded AppInterfaceStats to Steam
GameAction [AppID 289070, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 289070, ActionID 1] : LaunchApp changed task to Completed with ""
GameAction [AppID 289070, ActionID 2] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 289070, ActionID 2] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 289070, ActionID 2] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 289070, ActionID 2] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 289070, ActionID 2] : LaunchApp continues with user response "CreatingProcess"
Game process added : AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/./Civ6'", ProcID 34690, IP 0.0.0.0:0
Game process removed: AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/./Civ6'", ProcID 34690
GameAction [AppID 289070, ActionID 2] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 289070, ActionID 2] : LaunchApp changed task to Completed with ""
(steam:34388): GLib-GObject-CRITICAL **: 16:19:52.179: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(steam:34388): GLib-GObject-WARNING **: 16:19:52.180: instance with invalid (NULL) class pointer
(steam:34388): GLib-GObject-CRITICAL **: 16:19:52.180: g_signal_handlers_disconnect_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(steam:34388): GLib-GObject-CRITICAL **: 16:19:52.180: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
[2022-12-31 16:19:52] Shutdown
While looking through the output above I found the following:
I googled it and found a potential fix:
Lib Font Fix in Steam forums
I changed “libfreetype.so.6” to “___libfreetype.so.6.old”. I restarted Steam and the Aspyr launcher came up with no errors. However, once I launch the game and get into the in-game menus the game freezes. I then renamed the above shared object file back to its original name. I restarted Steam and put the following string in the launch options box:
LD_PRELOAD=/usr/lib/libfreetype.so.6 %command%
The native Linux game now works without freezing and crashing.
Question: If I install both Steam-Runtime and Steam-Native would that cause trouble?
Installing the v6.0.15-1 kernel and continued testing with Steam-Runtime next.
Booted with the v6.0.15-1 kernel, the native game client fails to launch again. The output from the terminal is below. Testing the v6.1.1-1 kernel next with the native game client next.
steam.sh[2461]: Running Steam on manjarolinux 22.0.0 64-bit
steam.sh[2461]: STEAM_RUNTIME is enabled automatically
setup.sh[2535]: Steam runtime environment up-to-date!
steam.sh[2461]: Steam client's requirements are satisfied
[2022-12-31 22:44:38] Startup - updater built Dec 15 2022 21:26:49
[2022-12-31 22:44:38] Startup - Steam Client launched with: '/home/james_game5800x/.local/share/Steam/ubuntu12_32/steam'
[2022-12-31 22:44:38] Loading cached metrics from disk (/home/james_game5800x/.local/share/Steam/package/steam_client_metrics.bin)
[2022-12-31 22:44:38] Using the following download hosts for Public, Realm steamglobal
[2022-12-31 22:44:38] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2022-12-31 22:44:38] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2022-12-31 22:44:38] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-12-31 22:44:38] Verifying installation...
[2022-12-31 22:44:38] Verification complete
(steam:2596): Gtk-WARNING **: 22:44:38.281: Unable to locate theme engine in module_path: "adwaita",
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xead06db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xead05500
ComputeStartupMode: found registry default startup mode: 0Installing breakpad exception handler for appid(steam)/version(1671236931)
steamwebhelper.sh[2612]: Runtime for steamwebhelper: defaulting to /home/james_game5800x/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[2612]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
(steam:2596): Gtk-WARNING **: 22:44:39.034: gtk_disable_setlocale() must be called before gtk_init()
BRefreshApplicationsInLibrary 1: 0ms
System startup time: 2.52 seconds
RegisterForAppOverview 1: 1ms
RegisterForAppOverview 2: 1ms
/bin/sh\0-c\0LD_PRELOAD=/usr/lib/libfreetype.so.6 /home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/./Civ6'\0
Game process added : AppID 289070 "LD_PRELOAD=/usr/lib/libfreetype.so.6 /home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/./Civ6'", ProcID 2885, IP 0.0.0.0:0
ERROR: ld.so: object '/usr/lib/libfreetype.so.6' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Game process removed: AppID 289070 "LD_PRELOAD=/usr/lib/libfreetype.so.6 /home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/./Civ6'", ProcID 2885
(steam:2596): GLib-GObject-CRITICAL **: 22:45:05.227: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(steam:2596): GLib-GObject-WARNING **: 22:45:05.228: instance with invalid (NULL) class pointer
(steam:2596): GLib-GObject-CRITICAL **: 22:45:05.228: g_signal_handlers_disconnect_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(steam:2596): GLib-GObject-CRITICAL **: 22:45:05.228: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
[2022-12-31 22:45:05] Shutdown
The v6.0.15-1 and v6.1.1-1 kernels both cause the same native game client failure to launch. In the output I notice the old font library error returned. So, I renamed the library file, removed the “LD_PRELOAD” string and retried. I ended up with the same failure. The error output was the almost identical to earlier output where the only errors were the ignored overlay references. Switching to the Windows client with Proton-experimental and continued testing next.
The v6.1.1-1 kernel breaks all steam games. The following games failed:
- Deus Ex Mankind Divided (native linux client)
- Shadow of Mordor (native linux client)
- Civ 6 (Windows client with Proton-Experimental, v7.0-5, v6.3-8)
- Grim Dawn (Windows client with Proton-Experimental, v7.0-5, v6.3-8)
The output below is from the Proton-Experimental run. Testing with the v6.0.15-1 kernel next.
steam.sh[6237]: Running Steam on manjarolinux 22.0.0 64-bit
steam.sh[6237]: STEAM_RUNTIME is enabled automatically
setup.sh[6311]: Steam runtime environment up-to-date!
steam.sh[6237]: Steam client's requirements are satisfied
[2022-12-31 23:17:45] Startup - updater built Dec 15 2022 21:26:49
[2022-12-31 23:17:45] Startup - Steam Client launched with: '/home/james_game5800x/.local/share/Steam/ubuntu12_32/steam'
[2022-12-31 23:17:45] Loading cached metrics from disk (/home/james_game5800x/.local/share/Steam/package/steam_client_metrics.bin)
[2022-12-31 23:17:45] Using the following download hosts for Public, Realm steamglobal
[2022-12-31 23:17:45] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2022-12-31 23:17:45] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2022-12-31 23:17:45] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-12-31 23:17:45] Verifying installation...
[2022-12-31 23:17:45] Verification complete
(steam:6372): Gtk-WARNING **: 23:17:45.770: Unable to locate theme engine in module_path: "adwaita",
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xead0adb0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xead09500
steamwebhelper.sh[6388]: Runtime for steamwebhelper: defaulting to /home/james_game5800x/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[6388]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 35 milliseconds to initialize
(steam:6372): Gtk-WARNING **: 23:17:46.521: gtk_disable_setlocale() must be called before gtk_init()
local (potentially out of sync) copy of roaming config loaded - 521 bytes.
roaming config store loaded successfully - 521 bytes.
System startup time: 2.38 seconds
GameAction [AppID 337000, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 337000, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 337000, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 337000, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 337000, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 337000, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=337000 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Deus Ex Mankind Divided/DeusExMD.sh'\0
Game process added : AppID 337000 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=337000 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Deus Ex Mankind Divided/DeusExMD.sh'", ProcID 6666, IP 0.0.0.0:0
chdir /my_data/local/LinuxGaming/steam/steamapps/common/Deus Ex Mankind Divided
Game process removed: AppID 337000 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=337000 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Deus Ex Mankind Divided/DeusExMD.sh'", ProcID 6666
GameAction [AppID 337000, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 337000, ActionID 1] : LaunchApp changed task to Completed with ""
GameAction [AppID 241930, ActionID 2] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 241930, ActionID 2] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 241930, ActionID 2] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 241930, ActionID 2] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 241930, ActionID 2] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 241930, ActionID 2] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=241930 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/ShadowOfMordor/ShadowOfMordor.sh'\0
Game process added : AppID 241930 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=241930 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/ShadowOfMordor/ShadowOfMordor.sh'", ProcID 6670, IP 0.0.0.0:0
chdir /my_data/local/LinuxGaming/steam/steamapps/common/ShadowOfMordor
Game process removed: AppID 241930 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=241930 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/ShadowOfMordor/ShadowOfMordor.sh'", ProcID 6670
GameAction [AppID 241930, ActionID 2] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 241930, ActionID 2] : LaunchApp changed task to Completed with ""
GameAction [AppID 289070, ActionID 3] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 289070, ActionID 3] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 289070, ActionID 3] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 289070, ActionID 3] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 289070, ActionID 3] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login\0
Game process added : AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 6684, IP 0.0.0.0:0
Game process removed: AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 6684
GameAction [AppID 289070, ActionID 3] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 289070, ActionID 3] : LaunchApp changed task to Completed with ""
GameAction [AppID 219990, ActionID 4] : LaunchApp changed task to ShowLaunchOption with ""
GameAction [AppID 219990, ActionID 4] : LaunchApp waiting for user response to ShowLaunchOption ""
GameAction [AppID 219990, ActionID 4] : LaunchApp continues with user response "1"
GameAction [AppID 219990, ActionID 4] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 219990, ActionID 4] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 219990, ActionID 4] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 219990, ActionID 4] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 219990, ActionID 4] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 219990, ActionID 4] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'\0
Game process added : AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 6688, IP 0.0.0.0:0
chdir /my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn
Game process removed: AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 6688
GameAction [AppID 219990, ActionID 4] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 219990, ActionID 4] : LaunchApp changed task to Completed with ""
(steam:6372): GLib-GObject-CRITICAL **: 23:18:22.207: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(steam:6372): GLib-GObject-WARNING **: 23:18:22.208: instance with invalid (NULL) class pointer
(steam:6372): GLib-GObject-CRITICAL **: 23:18:22.208: g_signal_handlers_disconnect_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(steam:6372): GLib-GObject-CRITICAL **: 23:18:22.208: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
[2022-12-31 23:18:22] Shutdown
The v6.0.15-1 kernel causes the same broken behavior as the the v6.1.1-1 kernel. Below is output from testing:
I will switch back to the 5.15 kernel and retest to see if the breakage remains or if the kernel switch allows steam to behave normally.
steam.sh[1373]: Running Steam on manjarolinux 22.0.0 64-bit
steam.sh[1373]: STEAM_RUNTIME is enabled automatically
setup.sh[1448]: Steam runtime environment up-to-date!
steam.sh[1373]: Steam client's requirements are satisfied
[2022-12-31 23:34:54] Startup - updater built Dec 15 2022 21:26:49
[2022-12-31 23:34:54] Startup - Steam Client launched with: '/home/james_game5800x/.local/share/Steam/ubuntu12_32/steam'
[2022-12-31 23:34:54] Loading cached metrics from disk (/home/james_game5800x/.local/share/Steam/package/steam_client_metrics.bin)
[2022-12-31 23:34:54] Using the following download hosts for Public, Realm steamglobal
[2022-12-31 23:34:54] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2022-12-31 23:34:54] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2022-12-31 23:34:54] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-12-31 23:34:54] Verifying installation...
[2022-12-31 23:34:54] Verification complete
(steam:1508): Gtk-WARNING **: 23:34:55.638: Unable to locate theme engine in module_path: "adwaita",
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xea227db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xea226500
ComputeStartupMode: found registry default startup mode: 0steamwebhelper.sh[1526]: Runtime for steamwebhelper: defaulting to /home/james_game5800x/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[1526]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 87 milliseconds to initialize
(steam:1508): Gtk-WARNING **: 23:34:58.124: gtk_disable_setlocale() must be called before gtk_init()
System startup time: 8.02 seconds
Game process added : AppID 337000 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=337000 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Deus Ex Mankind Divided/DeusExMD.sh'", ProcID 1848, IP 0.0.0.0:0
Game process removed: AppID 337000 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=337000 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Deus Ex Mankind Divided/DeusExMD.sh'", ProcID 1848
Game process added : AppID 241930 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=241930 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/ShadowOfMordor/ShadowOfMordor.sh'", ProcID 1851, IP 0.0.0.0:0
Game process removed: AppID 241930 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=241930 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/ShadowOfMordor/ShadowOfMordor.sh'", ProcID 1851
/bin/sh\0-c\0/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login\0
Game process added : AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 1858, IP 0.0.0.0:0
Game process removed: AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 1858
/bin/sh\0-c\0/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'\0
Game process added : AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 1862, IP 0.0.0.0:0
Game process removed: AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 1862
GameAction [AppID 219990, ActionID 5] : LaunchApp changed task to ShowLaunchOption with ""
GameAction [AppID 219990, ActionID 5] : LaunchApp waiting for user response to ShowLaunchOption ""
GameAction [AppID 219990, ActionID 5] : LaunchApp continues with user response "1"
GameAction [AppID 219990, ActionID 5] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 219990, ActionID 5] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 219990, ActionID 5] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 219990, ActionID 5] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 219990, ActionID 5] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 219990, ActionID 5] : LaunchApp continues with user response "CreatingProcess"
Game process added : AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 1869, IP 0.0.0.0:0
Game process removed: AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 1869
GameAction [AppID 219990, ActionID 5] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 219990, ActionID 5] : LaunchApp changed task to Completed with ""
GameAction [AppID 289070, ActionID 6] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 289070, ActionID 6] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 289070, ActionID 6] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 289070, ActionID 6] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 289070, ActionID 6] : LaunchApp continues with user response "CreatingProcess"
Game process added : AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 1873, IP 0.0.0.0:0
Game process removed: AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 1873
GameAction [AppID 289070, ActionID 6] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 289070, ActionID 6] : LaunchApp changed task to Completed with ""
GameAction [AppID 289070, ActionID 7] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 289070, ActionID 7] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 289070, ActionID 7] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 289070, ActionID 7] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 289070, ActionID 7] : LaunchApp continues with user response "CreatingProcess"
Game process added : AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 1877, IP 0.0.0.0:0
Game process removed: AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 1877
GameAction [AppID 289070, ActionID 7] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 289070, ActionID 7] : LaunchApp changed task to Completed with ""
GameAction [AppID 289070, ActionID 8] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 289070, ActionID 8] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 289070, ActionID 8] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 289070, ActionID 8] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 289070, ActionID 8] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 6.3'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login\0
Game process added : AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 6.3'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 1881, IP 0.0.0.0:0
Game process removed: AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 6.3'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 1881
GameAction [AppID 289070, ActionID 8] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 289070, ActionID 8] : LaunchApp changed task to Completed with ""
GameAction [AppID 219990, ActionID 9] : LaunchApp changed task to ShowLaunchOption with ""
GameAction [AppID 219990, ActionID 9] : LaunchApp waiting for user response to ShowLaunchOption ""
GameAction [AppID 219990, ActionID 9] : LaunchApp continues with user response "1"
GameAction [AppID 219990, ActionID 9] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 219990, ActionID 9] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 219990, ActionID 9] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 219990, ActionID 9] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 219990, ActionID 9] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 219990, ActionID 9] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 6.3'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'\0
Game process added : AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 6.3'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 1887, IP 0.0.0.0:0
Game process removed: AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 6.3'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 1887
GameAction [AppID 219990, ActionID 9] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 219990, ActionID 9] : LaunchApp changed task to Completed with ""
(steam:1508): GLib-GObject-CRITICAL **: 23:36:43.358: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(steam:1508): GLib-GObject-WARNING **: 23:36:43.359: instance with invalid (NULL) class pointer
(steam:1508): GLib-GObject-CRITICAL **: 23:36:43.359: g_signal_handlers_disconnect_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(steam:1508): GLib-GObject-CRITICAL **: 23:36:43.359: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
[2022-12-31 23:36:43] Shutdown
When booted into the 5.15 kenel Steam installs some update when launched. This is after going through the switch to the 6.x kernels and then booting into the 5.15 kernel. Steam remains broken with the 5.15 kernel.
The 6.x kernels must have caused a similar steam update install behavior that I missed when looking away from the screen. I am now back to square one of broken steam. Below is the output from testing the same games as above:
steam.sh[1360]: Running Steam on manjarolinux 22.0.0 64-bit
steam.sh[1360]: STEAM_RUNTIME is enabled automatically
setup.sh[1434]: Steam runtime environment up-to-date!
steam.sh[1360]: Steam client's requirements are satisfied
[2022-12-31 23:50:00] Startup - updater built Dec 15 2022 21:26:49
[2022-12-31 23:50:00] Startup - Steam Client launched with: '/home/james_game5800x/.local/share/Steam/ubuntu12_32/steam'
[2022-12-31 23:50:01] Loading cached metrics from disk (/home/james_game5800x/.local/share/Steam/package/steam_client_metrics.bin)
[2022-12-31 23:50:01] Using the following download hosts for Public, Realm steamglobal
[2022-12-31 23:50:01] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2022-12-31 23:50:01] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2022-12-31 23:50:01] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-12-31 23:50:01] Verifying installation...
[2022-12-31 23:50:01] Unable to read and verify install manifest /home/james_game5800x/.local/share/Steam/package/steam_client_ubuntu12.installed
[2022-12-31 23:50:01] Verification complete
[2022-12-31 23:50:01] Downloading update...
[2022-12-31 23:50:01] Checking for available updates...
[2022-12-31 23:50:01] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_ubuntu12
[2022-12-31 23:50:01] Manifest download: send request
[2022-12-31 23:50:01] Manifest download: waiting for download to finish
[2022-12-31 23:50:01] Manifest download: finished
[2022-12-31 23:50:01] Downloaded new manifest: /steam_client_ubuntu12 version 1671236931, installed version 1671236931, existing pending version 0
[2022-12-31 23:50:01] Download complete.
[2022-12-31 23:50:01] uninstalled manifest found in /home/james_game5800x/.local/share/Steam/package/steam_client_ubuntu12 (1).
[2022-12-31 23:50:02] Extracting package...
[2022-12-31 23:50:08] Installing update...
[2022-12-31 23:50:14] Cleaning up...
[2022-12-31 23:50:14] Update complete, launching Steam...
[2022-12-31 23:50:14] Shutdown
steam.sh[1360]: Restarting Steam by request...
steam.sh[1360]: STEAM_RUNTIME has been set by the user to: /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-runtime
setup.sh[1597]: Steam runtime environment up-to-date!
[2022-12-31 23:50:15] Startup - updater built Dec 15 2022 21:26:49
[2022-12-31 23:50:15] Startup - Steam Client launched with: '/home/james_game5800x/.local/share/Steam/ubuntu12_32/steam'
[2022-12-31 23:50:15] Loading cached metrics from disk (/home/james_game5800x/.local/share/Steam/package/steam_client_metrics.bin)
[2022-12-31 23:50:15] Using the following download hosts for Public, Realm steamglobal
[2022-12-31 23:50:15] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2022-12-31 23:50:15] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2022-12-31 23:50:15] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2022-12-31 23:50:15] Verifying installation...
[2022-12-31 23:50:15] Verification complete
(steam:1657): Gtk-WARNING **: 23:50:15.593: Unable to locate theme engine in module_path: "adwaita",
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xe8474db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xe8473500
ComputeStartupMode: found registry default startup mode: 0steamwebhelper.sh[1673]: Runtime for steamwebhelper: defaulting to /home/james_game5800x/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[1673]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 76 milliseconds to initialize
(steam:1657): Gtk-WARNING **: 23:50:16.792: gtk_disable_setlocale() must be called before gtk_init()
System startup time: 2.75 seconds
(steam:1657): LIBDBUSMENU-GLIB-WARNING **: 23:50:18.274: Trying to remove a child that doesn't believe we're it's parent.
Game process added : AppID 337000 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=337000 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Deus Ex Mankind Divided/DeusExMD.sh'", ProcID 1992, IP 0.0.0.0:0
Game process removed: AppID 337000 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=337000 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/Deus Ex Mankind Divided/DeusExMD.sh'", ProcID 1992
Game process added : AppID 241930 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=241930 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/ShadowOfMordor/ShadowOfMordor.sh'", ProcID 1995, IP 0.0.0.0:0
Game process removed: AppID 241930 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=241930 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/ShadowOfMordor/ShadowOfMordor.sh'", ProcID 1995
Game process added : AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 6.3'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 2009, IP 0.0.0.0:0
Game process removed: AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 6.3'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 2009
GameAction [AppID 289070, ActionID 4] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 289070, ActionID 4] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 289070, ActionID 4] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 289070, ActionID 4] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 289070, ActionID 4] : LaunchApp continues with user response "CreatingProcess"
Game process added : AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 2013, IP 0.0.0.0:0
Game process removed: AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 2013
GameAction [AppID 289070, ActionID 4] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 289070, ActionID 4] : LaunchApp changed task to Completed with ""
GameAction [AppID 289070, ActionID 5] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 289070, ActionID 5] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 289070, ActionID 5] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 289070, ActionID 5] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 289070, ActionID 5] : LaunchApp continues with user response "CreatingProcess"
Game process added : AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 2017, IP 0.0.0.0:0
Game process removed: AppID 289070 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=289070 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Sid Meier'\''s Civilization VI/2KLauncher/LauncherPatcher.exe' -steam_auto_login", ProcID 2017
GameAction [AppID 289070, ActionID 5] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 289070, ActionID 5] : LaunchApp changed task to Completed with ""
GameAction [AppID 219990, ActionID 6] : LaunchApp changed task to ShowLaunchOption with ""
GameAction [AppID 219990, ActionID 6] : LaunchApp waiting for user response to ShowLaunchOption ""
GameAction [AppID 219990, ActionID 6] : LaunchApp continues with user response "1"
GameAction [AppID 219990, ActionID 6] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 219990, ActionID 6] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 219990, ActionID 6] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 219990, ActionID 6] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 219990, ActionID 6] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 219990, ActionID 6] : LaunchApp continues with user response "CreatingProcess"
Game process added : AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 6.3'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 2026, IP 0.0.0.0:0
Game process removed: AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 6.3'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 2026
GameAction [AppID 219990, ActionID 6] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 219990, ActionID 6] : LaunchApp changed task to Completed with ""
GameAction [AppID 219990, ActionID 7] : LaunchApp changed task to ShowLaunchOption with ""
GameAction [AppID 219990, ActionID 7] : LaunchApp waiting for user response to ShowLaunchOption ""
GameAction [AppID 219990, ActionID 7] : LaunchApp continues with user response "1"
GameAction [AppID 219990, ActionID 7] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 219990, ActionID 7] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 219990, ActionID 7] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 219990, ActionID 7] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 219990, ActionID 7] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 219990, ActionID 7] : LaunchApp continues with user response "CreatingProcess"
Game process added : AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 2039, IP 0.0.0.0:0
Game process removed: AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 2039
GameAction [AppID 219990, ActionID 7] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 219990, ActionID 7] : LaunchApp changed task to Completed with ""
GameAction [AppID 219990, ActionID 8] : LaunchApp changed task to ShowLaunchOption with ""
GameAction [AppID 219990, ActionID 8] : LaunchApp waiting for user response to ShowLaunchOption ""
GameAction [AppID 219990, ActionID 8] : LaunchApp continues with user response "1"
GameAction [AppID 219990, ActionID 8] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 219990, ActionID 8] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 219990, ActionID 8] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 219990, ActionID 8] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 219990, ActionID 8] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 219990, ActionID 8] : LaunchApp continues with user response "CreatingProcess"
Game process added : AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 2043, IP 0.0.0.0:0
Game process removed: AppID 219990 "/home/james_game5800x/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=219990 -- /home/james_game5800x/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/my_data/local/LinuxGaming/steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/my_data/local/LinuxGaming/steam/steamapps/common/Proton - Experimental'/proton waitforexitandrun '/my_data/local/LinuxGaming/steam/steamapps/common/Grim Dawn/x64/Grim Dawn.exe'", ProcID 2043
GameAction [AppID 219990, ActionID 8] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 219990, ActionID 8] : LaunchApp changed task to Completed with ""
(steam:1657): GLib-GObject-CRITICAL **: 23:51:37.745: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(steam:1657): GLib-GObject-WARNING **: 23:51:37.746: instance with invalid (NULL) class pointer
(steam:1657): GLib-GObject-CRITICAL **: 23:51:37.746: g_signal_handlers_disconnect_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(steam:1657): GLib-GObject-CRITICAL **: 23:51:37.746: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
[2022-12-31 23:51:37] Shutdown
