No speaker sound, headphone sound ok
My speakers give no sound after Manjaro install. Headphones are ok, though. As in archwiki, I tried
amixer sset Speaker unmute
but get
amixer: Unable to find simple control 'Speaker',0
When I look at alsamixer, I see Pulseaudio in the top left, and when i look at
alsamixer -c 0
this brings up the GPU. But -c 1 gives ‘HD-Audio Generic’ which is the realtek chip which I assume I should want, since it has my headphones listed. Auto-mute is disabled too.
I’m new to Manjaro, can someone help me out getting my speakers enabled?
Thanks
I would install “pavucontrol” and use that, if on kde there is also a qt version.
PulseAudio Volume Control pavucontrol is installed by default on Xfce, and unlikely to help with speaker issue
Please post response to this command to show ALSA settings for onboard audio device
amixer -c1
and this to show more information about PulseAudio sinks
pactl list sinks
Here is the requested output:
amixer -c1
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 87
  Mono: Playback 45 [52%] [-31.50dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [off]
  Front Right: Playback 87 [100%] [0.00dB] [off]
Simple mixer control 'Front Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
  Mono:
  Front Left: Playback 0 [0%] [-65.25dB] [off]
  Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Center',0
  Mono: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'LFE',0
Simple mixer control 'Line',0
  Mono:
Simple mixer control 'Line Boost',0
  Limits: 0 - 3
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
  Mono: Playback [on]
Simple mixer control 'Beep',0
  Mono:
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 39 [62%] [12.00dB] [on]
  Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control 'Capture',1
  Front Left: Capture 0 [0%] [-17.25dB] [off]
  Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Input Source',0
  Capabilities: cenum
  Items: 'Front Mic' 'Rear Mic' 'Line'
  Item0: 'Front Mic'
Simple mixer control 'Input Source',1
  Capabilities: cenum
  Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
  Mono:
Simple mixer control 'Rear Mic Boost',0
  Limits: 0 - 3
and for pulseaudio sinks:
pactl list sinks
Sink #0
	State: SUSPENDED
	Description: GA102 High Definition Audio Controller Digital Stereo (HDMI 2)
	Driver: module-alsa-card.c
	Sample Specification: s16le 2ch 44100Hz
	Channel Map: front-left,front-right
	Owner Module: 6
	Mute: no
	Volume: front-left: 15728 /  24% / -37.19 dB,   front-right: 15728 /  24% / -37.19 dB
	        balance 0.00
	Base Volume: 65536 / 100% / 0.00 dB
	Monitor Source: alsa_output.pci-0000_08_00.1.hdmi-stereo-extra1.monitor
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
	Properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "PHL 243V5"
		alsa.id = "HDMI 1"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "7"
		alsa.card = "0"
		alsa.card_name = "HDA NVidia"
		alsa.long_card_name = "HDA NVidia at 0xfc080000 irq 104"
		device.bus_path = "pci-0000:08:00.1"
		sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:08:00.1/sound/card0"
		device.bus = "pci"
		device.vendor.id = "10de"
		device.vendor.name = "NVIDIA Corporation"
		device.product.id = "1aef"
		device.product.name = "GA102 High Definition Audio Controller"
		device.string = "hdmi:0,1"
		device.buffering.buffer_size = "352768"
		device.buffering.fragment_size = "176384"
		device.access_mode = "mmap+timer"
		device.profile.name = "hdmi-stereo-extra1"
		device.profile.description = "Digital Stereo (HDMI 2)"
		device.description = "GA102 High Definition Audio Controller Digital Stereo (HDMI 2)"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	Ports:
		hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, available)
	Active Port: hdmi-output-1
	Formats:
		dts-iec61937, format.rate = "[ 32000, 44100, 48000, 96000 ]"
		pcm
Sink #1
	State: SUSPENDED
	Description: Starship/Matisse HD Audio Controller Analog Stereo
	Owner Module: 7
	Mute: no
	Volume: front-left: 19660 /  30% / -31.37 dB,   front-right: 19660 /  30% / -31.37 dB
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_0a_00.4.analog-stereo.monitor
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		device.api = "alsa"
		alsa.name = "ALCS1200A Analog"
		alsa.id = "ALCS1200A Analog"
		alsa.device = "0"
		alsa.card = "1"
		alsa.card_name = "HD-Audio Generic"
		alsa.long_card_name = "HD-Audio Generic at 0xfca00000 irq 106"
		device.bus_path = "pci-0000:0a:00.4"
		sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:0a:00.4/sound/card1"
		device.bus = "pci"
		device.vendor.id = "1022"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
		device.product.id = "1487"
		device.product.name = "Starship/Matisse HD Audio Controller"
		device.string = "front:1"
		device.profile.name = "analog-stereo"
		device.profile.description = "Analog Stereo"
		device.description = "Starship/Matisse HD Audio Controller Analog Stereo"
	Ports:
		analog-output-lineout: Line Out (type: Line, priority: 9000, not available)
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, available)
	Active Port: analog-output-headphones
	Formats:
		pcm
and yes, if relevant, I am using XFCE
thanks all
edit: could someone let me know what I’m looking for here?
PulseAudio data shows Sink #1 for Starship/Matisse HD Audio Controller Analog Stereo has 2 sink Ports, but only Headphones Port is shown as available
    Ports:
PulseAudio will avoid using Line Out Port because it is detected as not available
ALSA control for speaker output to Front channels is shown as muted
Use this command to unmute Front mixer control
amixer -c1 sset Front 87 unmute
