Hi everyone. So, I’m new to the Linux world, we’re trying Manjaro but the sound isn’t working properly. I already looked in this forum and other places for a possible solution and tried some of the suggested solutions, but nothing seems to work.
The problem is only in the speakers, when I connect headphones they work normally. And the speakers work in Windows (dual-boot).
Thanks in advance.
pacmd dump &&
sudo alsa-info.sh --upload
Your ALSA information is located at http://alsa-project.org/db/?f=bf05ec69606c0c34643152bf4ae677e4b773a2f8
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC256 Analog [ALC256 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
inxi -Fxz
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: Xfce 4.16.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: LG product: 22V270-L.BJ31P1 v: 0.1 serial: <filter>
Mobo: LG model: 22V270 v: 2 serial: <filter> UEFI: Phoenix v: 22VB0230 X64
date: 02/16/2017
Info: Quad Core model: Intel Celeron N3450 bits: 64 type: MCP
arch: Goldmont rev: 9 cache: L2: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8756
Speed: 796 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 796 2: 2089
3: 1454 4: 2159
Device-1: Intel HD Graphics 500 vendor: LG driver: i915 v: kernel
bus-ID: 00:02.0
Device-2: Silicon Motion LG HD webcam type: USB driver: uvcvideo
bus-ID: 1-8:5
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 500 (APL 2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster vendor: LG driver: snd_hda_intel v: kernel bus-ID: 00:0e.0
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel bus-ID: 02:00.0
vendor: LG driver: r8169 v: kernel port: 1000 bus-ID: 03:00.0
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-7:4
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 465.76 GiB used: 12.92 GiB (2.8%)
ID-1: /dev/sda vendor: Western Digital model: WD5000LPCX-22VHAT0
ID-1: / size: 95.56 GiB used: 12.49 GiB (13.1%) fs: ext4 dev: /dev/sda7
ID-2: /boot/efi size: 508 MiB used: 437.3 MiB (86.1%) fs: vfat
dev: /dev/sda6
System Temperatures: cpu: 48.0 C mobo: 0.0 C
Processes: 209 Uptime: 19m Memory: 3.68 GiB used: 1.91 GiB (52.0%)
Init: systemd Compilers: gcc: N/A Packages: 1258 Shell: Bash v: 5.1.8
inxi: 3.3.08
