No sound output before changing the sound card profile manually
I have a problem with my sound configuration.
For example, if I open the browser and then want to watch a video on Youtube, the video does not start playing. Neither picture nor sound start! The video only starts when I have changed the profile of the audio controller from “Digital-Stereo (HDMI)-Output” to something else in Pavucontrol under Configuration. I only hear the sound when I switch back to “Digital Stereo (HDMI) Output”.
If I then close and reopen the browser, I have to do the same thing all over again. Not always, but very often!
The same also happens e.g. with the Spotify Software. The system sounds work immediately.
What could that be?
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
the output of pactl info:
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 13
Tile Size: 65472
User Name: mb
Host Name: Waldorf
Server Name: pulseaudio
Server Version: 15.0
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_09_00.1.hdmi-stereo
Default Source: alsa_output.pci-0000_09_00.1.hdmi-stereo.monitor
Cookie: c0f2:ae27
here the output of inxi
  Kernel: 5.10.105-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=d130e17f-c255-471a-a439-401797d18320 rw quiet
    resume=UUID=7866d964-b131-402e-8520-3fd48534e796 udev.log_priority=3
  Desktop: Cinnamon v: 5.2.7 tk: GTK v: 3.24.33 vt: 7 dm: LightDM v: 1.30.0
  Type: Desktop System: Gigabyte product: B550M S2H v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: B550M S2H v: x.x serial: <superuser required>
    UEFI: American Megatrends v: F11d date: 10/29/2020
  Device-1: hidpp_battery_0 model: Logitech serial: <filter>
    charge: 70% (should be ignored) rechargeable: yes status: discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Mouse
    status: discharging
  RAM: total: 15.12 GiB used: 2.57 GiB (17.0%)
  RAM Report:
  Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
    microcode: 0xA50000B
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1631 high: 2994 min/max: 1400/4730:5001:4597:4867:4464
    boost: enabled scaling: driver: acpi-cpufreq governor: schedutil cores:
    1: 2992 2: 1346 3: 1356 4: 1330 5: 1348 6: 1385 7: 2994 8: 1331 9: 1340
    10: 1377 11: 1397 12: 1385 bogomips: 93466
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vaes
    vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves
    STIBP: always-on, RSB filling
  Device-1: AMD Cezanne vendor: Gigabyte driver: amdgpu v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: HDMI-A-1 empty: DP-1,HDMI-A-2 bus-ID: 09:00.0 chip-ID: 1002:1638
    class-ID: 0300
  Device-2: Sunplus Innovation FHD Camera Microphone type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 1-8.1:5 chip-ID: 1bcf:28c4
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu
    unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
    s-diag: 1165mm (45.88")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) HDR 4K
    serial: <filter> built: 2021 res: 3840x2160 hz: 60 dpi: 163 gamma: 1.2
    size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9 modes:
    max: 3840x2160 min: 640x480
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
    link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Device-3: Sunplus Innovation FHD Camera Microphone type: USB
  Sound Server-1: ALSA v: k5.10.105-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.48 running: yes
    lanes: 1 port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: XXX GiB used: XXX GiB (XX%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: XXXXX model: XXXXX
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: S5Z42105 temp: 33.9 C scheme: GPT
  Optical-1: /dev/sr0 vendor: ATAPI model: iHAS124 B rev: AL0F
    dev-links: cdrom
  ID-1: / raw-size: XXX GiB size: XXX GiB (XX%)
    used: XXX GiB (XX%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: d13xe17f-c255-471a-a439-401797d18320
    used: 312 KiB (X%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 2864-062E
  ID-1: swap-1 type: partition size: 17.21 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 7866d964-b131-402e-8520-3fd48534e796
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-7:2 info: Dynastream Innovations ANTUSB2 Stick
    type: <vendor specific> driver: suunto,usb_serial_simple interfaces: 1
    rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0fcf:1008 class-ID: 0000
    serial: <filter>
  Hub-2: 1-8:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-8.1:5 info: Sunplus Innovation FHD Camera Microphone
    type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
    speed: 480 Mb/s power: 500mA chip-ID: 1bcf:28c4 class-ID: 0102
    serial: <filter>
  Device-2: 1-8.2:6 info: Logitech Unifying Receiver
    type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-3: 1-10:4 info: Integrated Express ITE Device type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-7: 5-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Hub-8: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-9: 6-2:2 info: Genesys Logic hub ports: 4 rev: 3.0 speed: 5 Gb/s
    chip-ID: 05e3:0616 class-ID: 0900
  System Temperatures: cpu: 26.7 C mobo: 16.8 C gpu: amdgpu temp: 24.0 C
  Processes: 311 Uptime: 10m wakeups: 5 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1424 pacman: 1419 lib: 323
  flatpak: 5 Shell: Bash v: 5.1.16 running-in: zellij inxi: 3.3.14
i generally press the play button on the screen in a browser to get youtube videos playing. or just click on the video anywhere is usually enough?
This does not work for me! The video only starts when I have changed the setting back and forth in pavucontrol.
I noticed that pipewire is running as an audio server on my system. I usually use pulseaudio. After disabling pipewire I have no more problems. Crazy!
