No sound out of Jabra 410 except if switch to another source and then back
A couple of times per day, sound stops working, and the solution is to switch to a different output, and then back to the one I had selected.
The way I find that the audio is not working is because YouTube videos or conference calls won’t start at all, until I switch to another audio output, the video starts playing or I can join the meeting, and then I switch back to my Jabra and everything continues playing correctly.
Any idea what this could be? Here below the details on my setup:
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/vmlinuz-6.12-x86_64
    root=UUID=a819079e-0988-4dae-abf0-3142331eb62b rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Laptop System: LENOVO product: 83DN v: Yoga Pro 9 16IMH9
    serial: <superuser required> Chassis: type: 10 v: Yoga Pro 9 16IMH9
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
    serial: <superuser required> part-nu: LENOVO_MT_83DN_BU_idea_FM_Yoga Pro 9
    16IMH9 uuid: <superuser required> UEFI: LENOVO v: NKCN28WW
    date: 06/28/2024
  ID-1: BAT0 charge: 84.3 Wh (100.0%) condition: 84.3/84.0 Wh (100.4%)
    volts: 17.1 min: 15.6 model: BYD L23B4PF1 type: Li-poly serial: <filter>
    status: full cycles: 5
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
    status: discharging
  System RAM: total: 32 GiB available: 30.95 GiB used: 6.6 GiB (21.3%)
  Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
    size: 4 GiB speed: 7467 MT/s volts: curr: 0.5 width (bits): data: 16
    total: 16 manufacturer: SK Hynix part-no: H58G66BK7BX067 serial: N/A
  Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
  Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
  Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
  Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
  Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
  Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
  Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
  Info: model: Intel Core Ultra 9 185H bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x20
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
    st: 10 smt: enabled cache: 24 MiB note: check
  Speed (MHz): avg: 400 min/max: 400/4800:5100:3800:2500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
    15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
    bogomips: 135212
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdpid rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep
    smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
    tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Lenovo
    driver: i915 v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+)
    built: 2023+ ports: active: DP-1,DP-7 off: eDP-1 empty: DP-2, DP-3, DP-4,
    DP-5, DP-6, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:7d55 class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile] vendor: Lenovo
    driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:28e1 class-ID: 0300
  Device-3: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3 chip-ID: 174f:11ad
  Device-4: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.3.3:8
    chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1015x285mm (39.96x11.22")
    s-diag: 1054mm (41.51")
  Monitor-1: DP-1 pos: left model: VZ239 serial: <filter> built: 2018
    res: N/A dpi: 96 gamma: 1.2 chroma: red: x: 0.647 y: 0.341 green: x: 0.318
    y: 0.620 blue: x: 0.153 y: 0.059 white: x: 0.314 y: 0.329
    size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9
    modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x960,
    1360x768, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480, 720x400
  Monitor-2: DP-7 mapped: DP-2-2-1 pos: primary,right model: VZ239
    serial: <filter> built: 2018 res: N/A dpi: 96 gamma: 1.2 chroma: red:
    x: 0.647 y: 0.341 green: x: 0.318 y: 0.620 blue: x: 0.153 y: 0.059 white:
    x: 0.314 y: 0.329 size: 509x286mm (20.04x11.26") diag: 584mm (23")
    ratio: 16:9 modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1280x960, 1360x768, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480, 720x400
  Monitor-3: eDP-1 note: disabled model: Lenovo 0x8ba1 serial: <filter>
    built: 2022 res: N/A dpi: 236 gamma: 1.2 chroma: red: x: 0.675 y: 0.318
    green: x: 0.267 y: 0.682 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
    modes: 3200x2000
  EDID-Warnings: 1: parse_edid: unknown tag 112
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
    device-ID: 8086:7d55 memory: 15.11 GiB unified: yes
  API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4050 Laptop GPU driver: N/A device-ID: 10de:28e1
    surfaces: xcb,xlib
  Device-1: Intel Meteor Lake-P HD Audio vendor: Lenovo
    driver: sof-audio-pci-intel-mtl
    alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
    chip-ID: 8086:7e28 class-ID: 0401
  Device-2: Realtek USB Audio driver: hid-generic,usbhid type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.3.1:6 chip-ID: 0bda:48f0
    class-ID: 0300
  Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
  Device-4: GN Netcom Jabra SPEAK 410 USB driver: jabra,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1.4.2:9
    chip-ID: 0b0e:0412 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-1.3.4:6
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp9s0u1u3u4 state: down mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 1.03 TiB used: 633.16 GiB (60.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QJXD7 temp: 35.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Generic model: MassStorageClass
    size: 119.08 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 0001 scheme: MBR
  ID-1: / raw-size: 64 GiB size: 64 GiB (100.00%) used: 18.02 GiB (28.2%)
    fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: a819079e-0988-4dae-abf0-3142331eb62b
  ID-2: /boot raw-size: 512 MiB size: 487.2 MiB (95.16%)
    used: 237.1 MiB (48.7%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
    label: N/A uuid: 20ec8357-e565-4642-b64a-b47666c18912
  ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p10 maj-min: 259:10
    label: N/A uuid: 1BB3-4492
  ID-4: /home raw-size: 723.51 GiB size: 723.51 GiB (100.00%)
    used: 614.88 GiB (85.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: c41cbbec-eddb-477e-9ef3-3a52e8a20f66
  ID-5: /var/cache raw-size: 64 GiB size: 64 GiB (100.00%)
    used: 18.02 GiB (28.2%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: a819079e-0988-4dae-abf0-3142331eb62b
  ID-6: /var/log raw-size: 64 GiB size: 64 GiB (100.00%)
  ID-1: swap-1 type: partition size: 18 GiB used: 27.9 MiB (0.2%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 19d6a887-5054-4544-967a-b0bcff19cb9c
  ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 512 MiB fs: vfat label: N/A
    uuid: 6057-4C77
  ID-2: /dev/nvme0n1p5 maj-min: 259:5 size: 512 MiB fs: ext4 label: N/A
    uuid: bc247ec9-9dd0-4d71-b9cf-7c5aac052d25
  ID-3: /dev/nvme0n1p6 maj-min: 259:6 size: 34.22 GiB fs: btrfs
    label: fedora uuid: 5f9f0ce1-94d5-486c-8759-bcb098174733
  ID-4: /dev/nvme0n1p7 maj-min: 259:7 size: 489 MiB fs: ext4 label: N/A
    uuid: 9b0c707a-b2dc-44ed-b14e-e3bad0e9fc91
  ID-5: /dev/nvme0n1p8 maj-min: 259:8 size: 89.3 GiB fs: ext4 label: N/A
    uuid: 03c547de-d6a0-4a3c-ba28-abcea8c0d71b
  ID-6: /dev/sda1 maj-min: 8:1 size: 119.07 GiB fs: exfat label: N/A
    uuid: 3433-3331
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-5:2 info: Lenovo Idea5003 type: HID driver: hid-generic,usbhid
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 17ef:f006 class-ID: 0300 serial: <filter>
  Device-2: 3-8:3 info: Syntek Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 174f:11ad class-ID: fe01
    serial: <filter>
  Device-3: 3-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 5-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Device-1: 5-1.1:3 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
    type: keyboard,HID,smart card driver: hid-generic,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
    chip-ID: 1050:0407 class-ID: 0b00
  Hub-7: 5-1.3:4 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0612
  Device-1: 5-1.3.1:6 info: Realtek USB Audio type: HID
    chip-ID: 0bda:48f0 class-ID: 0300
  Device-2: 5-1.3.3:8 info: Logitech C920 HD Pro Webcam type: video,audio
  Hub-8: 5-1.4:5 info: Genesys Logic USB2.1 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0611
  Device-1: 5-1.4.1:7 info: Apple Aluminium Keyboard (ANSI)
    type: keyboard,mouse driver: apple,usbhid interfaces: 2 rev: 2.0
    chip-ID: 05ac:024f class-ID: 0301
  Device-2: 5-1.4.2:9 info: GN Netcom Jabra SPEAK 410 USB type: audio,HID
    driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  Device-3: 5-1.4.4:10 info: Logitech Nano Receiver type: mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c52f class-ID: 0300
  Hub-9: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-10: 6-1:2 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 05e3:0625
  Hub-11: 6-1.3:3 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0621
  Device-1: 6-1.3.2:5 info: Genesys Logic USB Storage type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 05e3:0754 class-ID: 0806
    serial: <filter>
  Device-2: 6-1.3.4:6 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
  Hub-12: 6-1.4:4 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  Src: /sys System Temperatures: cpu: 39.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1438 pm: pacman pkgs: 1416 libs: 440 tools: pamac pm: flatpak
    pkgs: 22
    1: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    5: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    7: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    8: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 453
  1: cpu: 22.7% command: firefox pid: 2236 mem: 814.9 MiB (2.5%)
  2: cpu: 10.2% command: firefox pid: 15127 mem: 604.1 MiB (1.9%)
  3: cpu: 9.7% command: firefox pid: 15707 mem: 351.4 MiB (1.1%)
  4: cpu: 5.8% command: firefox pid: 19044 mem: 358.7 MiB (1.1%)
  5: cpu: 5.6% command: firefox pid: 2493 mem: 563.5 MiB (1.7%)
  Memory top: 5 of 453
  1: mem: 814.9 MiB (2.5%) command: firefox pid: 2236 cpu: 22.7%
  2: mem: 604.1 MiB (1.9%) command: firefox pid: 15127 cpu: 10.2%
  3: mem: 563.5 MiB (1.7%) command: firefox pid: 2493 cpu: 5.6%
  4: mem: 491.7 MiB (1.5%) command: firefox pid: 2609 cpu: 2.0%
  5: mem: 469.9 MiB (1.4%) command: firefox pid: 2744 cpu: 2.4%
  Processes: 453 Power: uptime: 30m states: freeze,mem,disk suspend: s2idle
    image: 12.35 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
Thanks Nik for the reply, here is the output for each command:
pactl list carts
Card #49
        Driver: alsa
        Owner Module: n/a
        Properties:
                api.acp.auto-port = "false"
                api.alsa.card = "2"
                api.alsa.card.longname = "HD Pro Webcam C920 at usb-0000:09:00.0-1.3.3, high speed"
                api.alsa.card.name = "HD Pro Webcam C920"
                api.alsa.path = "hw:2"
                api.alsa.use-acp = "true"
                api.dbus.ReserveDevice1 = "Audio2"
                api.dbus.ReserveDevice1.Priority = "-20"
                device.api = "alsa"
                device.bus = "usb"
                device.bus-id = "usb-046d_HD_Pro_Webcam_C920_92C801EF-02"
                device.bus_path = "pci-0000:09:00.0-usb-0:1.3.3:1.2"
                device.description = "C920 HD Pro Webcam"
                device.enum.api = "udev"
                device.form_factor = "webcam"
                device.icon_name = "camera-web-analog-usb"
                device.name = "alsa_card.usb-046d_HD_Pro_Webcam_C920_92C801EF-02"
                device.nick = "HD Pro Webcam C920"
                device.plugged.usec = "17755594"
                device.product.id = "0x0892"
                device.product.name = "C920 HD Pro Webcam"
                device.serial = "046d_HD_Pro_Webcam_C920_92C801EF"
                device.subsystem = "sound"
                sysfs.path = "/devices/pci0000:00/0000:00:07.0/0000:07:00.0/0000:08:02.0/0000:09:00.0/usb5/5-1/5-1.3/5-1.3.3/5-1.3.3:1.2/sound/card2"
                device.vendor.id = "0x046d"
                device.vendor.name = "Logitech, Inc."
                media.class = "Audio/Device"
                factory.id = "15"
                client.id = "47"
                object.id = "49"
                object.serial = "49"
                object.path = "alsa:acp:C920"
                alsa.card = "2"
                alsa.card_name = "HD Pro Webcam C920"
                alsa.long_card_name = "HD Pro Webcam C920 at usb-0000:09:00.0-1.3.3, high speed"
                alsa.driver_name = "snd_usb_audio"
                alsa.mixer_name = "USB Mixer"
                alsa.components = "USB046d:0892"
                alsa.id = "C920"
                device.string = "2"
        Profiles:
                off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
                input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
                input:iec958-stereo: Digital Stereo (IEC958) Input (sinks: 0, sources: 1, priority: 55, available: yes)
                pro-audio: Pro Audio (sinks: 0, sources: 1, priority: 1, available: yes)
        Active Profile: input:iec958-stereo
        Ports:
                analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "mic"
                                card.profile.port = "0"
                        Part of profile(s): input:analog-stereo
                iec958-stereo-input: Digital Input (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "spdif"
                                card.profile.port = "1"
                        Part of profile(s): input:iec958-stereo
Card #50
        Driver: alsa
        Owner Module: n/a
        Properties:
                api.alsa.card = "1"
                api.alsa.card.longname = "Jabra SPEAK 410 USB at usb-0000:09:00.0-1.4.2, full speed"
                api.alsa.card.name = "Jabra SPEAK 410 USB"
                api.alsa.path = "hw:1"
                api.dbus.ReserveDevice1 = "Audio1"
                device.api = "alsa"
                device.bus = "usb"
                device.bus-id = "usb-0b0e_Jabra_SPEAK_410_USB_3050755D933Dx011200-00"
                device.bus_path = "pci-0000:09:00.0-usb-0:1.4.2:1.0"
                device.description = "Jabra SPEAK 410 USB"
                device.icon_name = "audio-card-analog-usb"
                device.name = "alsa_card.usb-0b0e_Jabra_SPEAK_410_USB_3050755D933Dx011200-00"
                device.nick = "Jabra SPEAK 410 USB"
                device.plugged.usec = "17497715"
                device.product.id = "0x0412"
                device.product.name = "Jabra SPEAK 410 USB"
                device.serial = "0b0e_Jabra_SPEAK_410_USB_3050755D933Dx011200"
                sysfs.path = "/devices/pci0000:00/0000:00:07.0/0000:07:00.0/0000:08:02.0/0000:09:00.0/usb5/5-1/5-1.4/5-1.4.2/5-1.4.2:1.0/sound/card1"
                device.vendor.id = "0x0b0e"
                device.vendor.name = "GN Netcom"
                factory.id = "15"
                client.id = "47"
                object.id = "50"
                object.serial = "50"
                object.path = "alsa:acp:USB"
                alsa.card = "1"
                alsa.card_name = "Jabra SPEAK 410 USB"
                alsa.long_card_name = "Jabra SPEAK 410 USB at usb-0000:09:00.0-1.4.2, full speed"
                alsa.components = "USB0b0e:0412"
                alsa.id = "USB"
                device.string = "1"
        Profiles:
                output:analog-stereo+input:mono-fallback: Analog Stereo Output + Mono Input (sinks: 1, sources: 1, priority: 6501, available: yes)
                output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
                output:iec958-stereo+input:mono-fallback: Digital Stereo (IEC958) Output + Mono Input (sinks: 1, sources: 1, priority: 5501, available: yes)
                output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
                output:iec958-ac3-surround-51+input:mono-fallback: Digital Surround 5.1 (IEC958/AC3) Output + Mono Input (sinks: 1, sources: 1, priority: 301, available: yes)
                output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
                pro-audio: Pro Audio (sinks: 1, sources: 1, priority: 1, available: yes)
                input:mono-fallback: Mono Input (sinks: 0, sources: 1, priority: 1, available: yes)
        Active Profile: output:iec958-stereo+input:mono-fallback
        Ports:
                        Properties:
                                port.type = "mic"
                        Part of profile(s): input:mono-fallback, output:analog-stereo+input:mono-fallback, output:iec958-stereo+input:mono-fallback, output:iec958-ac3-surround-51+input:mono-fallback
                analog-output: Analog Output (type: Analog, priority: 9900, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "analog"
                        Part of profile(s): output:analog-stereo, output:analog-stereo+input:mono-fallback
                iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "spdif"
                                card.profile.port = "2"
                        Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:mono-fallback
Card #51
        Driver: alsa
        Owner Module: n/a
        Properties:
                api.alsa.card = "0"
                api.alsa.card.longname = "LENOVO-83DN-YogaPro916IMH9-LNVNB161216"
                api.alsa.card.name = "sof-hda-dsp"
                api.alsa.path = "hw:0"
                device.api = "alsa"
                device.bus = "pci"
                device.bus_path = "pci-0000:00:1f.3-platform-skl_hda_dsp_generic"
                device.description = "Meteor Lake-P HD Audio Controller"
                device.icon_name = "audio-card-analog-pci"
                device.name = "alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic"
                device.nick = "sof-hda-dsp"
                device.plugged.usec = "7996152"
                device.product.id = "0x7e28"
                device.product.name = "Meteor Lake-P HD Audio Controller"
                sysfs.path = "/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0"
                device.vendor.id = "0x8086"
                factory.id = "15"
                client.id = "47"
                object.id = "51"
                object.serial = "51"
                object.path = "alsa:acp:sofhdadsp"
                alsa.card = "0"
                alsa.card_name = "sof-hda-dsp"
                alsa.long_card_name = "LENOVO-83DN-YogaPro916IMH9-LNVNB161216"
                alsa.driver_name = "snd_soc_skl_hda_dsp"
                alsa.mixer_name = "Realtek ALC287"
                alsa.components = "HDA:8086281d,80860101,00100000 HDA:10ec0287,17aa38d5,00100002 cfg-dmics:4 iec61937-pcm:5,4,3"
                alsa.id = "sofhdadsp"
                device.string = "0"
        Profiles:
                HiFi (HDMI1, HDMI2, HDMI3, Headphones, Mic1, Mic2): Play HiFi quality Music (HDMI1, HDMI2, HDMI3, Headphones, Mic1, Mic2) (sinks: 4, sources: 2, priority: 10300, available: yes)
                HiFi (HDMI1, HDMI2, HDMI3, Mic1, Mic2, Speaker): Play HiFi quality Music (HDMI1, HDMI2, HDMI3, Mic1, Mic2, Speaker) (sinks: 4, sources: 2, priority: 10200, available: yes)
                pro-audio: Pro Audio (sinks: 5, sources: 2, priority: 1, available: yes)
        Active Profile: HiFi (HDMI1, HDMI2, HDMI3, Headphones, Mic1, Mic2)
        Ports:
                [Out] HDMI3: HDMI / DisplayPort 3 Output (type: HDMI, priority: 700, latency offset: 0 usec, availability group: HDMI/DP,pcm=5, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "HDMI/DP,pcm=5"
                        Part of profile(s): HiFi (HDMI1, HDMI2, HDMI3, Mic1, Mic2, Speaker), HiFi (HDMI1, HDMI2, HDMI3, Headphones, Mic1, Mic2)
                [Out] HDMI2: HDMI / DisplayPort 2 Output (type: HDMI, priority: 600, latency offset: 0 usec, availability group: HDMI/DP,pcm=4, available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "HDMI/DP,pcm=4"
                                device.product.name = "VZ239"
                [Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 500, latency offset: 0 usec, availability group: HDMI/DP,pcm=3, available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "HDMI/DP,pcm=3"
                [Out] Speaker: Speaker (type: Speaker, priority: 100, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "speaker"
                                card.profile.port = "3"
                [In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, latency offset: 0 usec, availability group: Mic, not available)
                        Properties:
                                port.type = "mic"
                                port.availability-group = "Mic"
                                card.profile.port = "4"
                [In] Mic1: Digital Microphone (type: Mic, priority: 100, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "mic"
                                card.profile.port = "5"
                [Out] Headphones: Headphones (type: Headphones, priority: 200, latency offset: 0 usec, availability group: Headphone, not available)
                        Properties:
                                port.type = "headphones"
                                port.availability-group = "Headphone"
                                card.profile.port = "6"
                        Part of profile(s): HiFi (HDMI1, HDMI2, HDMI3, Headphones, Mic1, Mic2)
pactl list sinks short
65      alsa_output.usb-0b0e_Jabra_SPEAK_410_USB_3050755D933Dx011200-00.iec958-stereo   PipeWire        s16le 2ch 48000Hz       RUNNING
235     alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__HDMI3__sink     PipeWire        s32le 2ch 48000Hz       SUSPENDED
236     alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__HDMI2__sink     PipeWire        s32le 2ch 48000Hz       SUSPENDED
237     alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__HDMI1__sink     PipeWire        s32le 2ch 48000Hz       SUSPENDED
238     alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__Headphones__sink        PipeWire        s32le 2ch 48000Hz       SUSPENDED
pactl get-default-sink
        Profiles:
Use higher priority profile Analog Stereo Output + Mono Input instead of Digital Stereo (IEC958) Output + Mono Input
pactl set-card-profile alsa_card.usb-0b0e_Jabra_SPEAK_410_USB_3050755D933Dx011200-00 output:analog-stereo+input:mono-fallback
pactl set-default-sink alsa_output.usb-0b0e_Jabra_SPEAK_410_USB_3050755D933Dx011200-00.output:analog-stereo
PipeWire Wiki - FAQ - What are those Analog Stereo and Digital Stereo (IEC958) profile?
TL;DR: You want to use the Analog Profile, it will sound best. Digital Profile is only used in specialized cases
Some hardware does not have a coaxial, optical or HDMI output but you still have the profile available. This is likely because hardware has the feature but is not made available. With the right model:vendor id (see with lsusb) it is possible to make a custom profile and remove the nonfunctional IEC958 profile.
Most hardware has the Digital output also connected to the DAC so that it will still produce output on the Analog outputs, usually with likely less optimal mixer settings (volume too low, less bass).
Hey @nikgnomic thanks for the advise. Sadly, I still need to switch between Jabra, Meteor Lake and then back to the Jabra output to get sound working.
Not sure what’s going on.
