Hey there,
I installed manjaro plasma 21.2.6 on my imac. so far, everything seems to work except my wifi and audio device. This thread is about the audio device. it is not selectable within the system settings and isn’t working.
I followed the guide on the following page with no success. Hope, to get some help here.
wiki.archlinux .org/title/PulseAudio/Troubleshooting#No_cards
thanks in advance
b1nary
Attached my alsa-info.sh:
alsa-project .org/db/?f=d5a7439ee9e659ee2c87a56a9b32113747b0a7e2
Please let me know which else information is needed
Here is my inxi output:
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=34e4f9a9-2c85-450c-bec3-0e721a7fbde6 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Apple product: iMac19,1 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-AA95B1DDAB278B95
Mobo: Apple model: Mac-AA95B1DDAB278B95 v: iMac19,1
serial: <superuser required> UEFI: Apple v: 1731.100.125.0.0
date: 01/20/2022
Device-1: hid-94:f6:d6:b7:21:dc-battery model: Setup Users Maus serial: N/A
charge: N/A status: discharging
RAM: total: 7.64 GiB used: 3.42 GiB (44.8%)
RAM Report:
Info: model: Intel Core i5-9600K bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xEC
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
bogomips: 44412
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep
smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
STIBP: disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Apple driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300
Device-2: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
bus-ID: 1-13:4 chip-ID: 05ac:8511 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: eDP-1 mapped: eDP model: Apple iMac serial: <filter>
built: 2018 res: 3840x2160 hz: 60 dpi: 163 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
OpenGL: renderer: AMD POLARIS10 (LLVM 13.0.1 DRM 3.42 5.15.38-1-MANJARO)
v: 4.6 Mesa 22.0.3 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Broadcom BCM4364 802.11ac Wireless Network Adapter vendor: Apple
driver: N/A modules: brcmfmac pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:4464 class-ID: 0280
Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
chip-ID: 14e4:1686 class-ID: 0200
IF: enp4s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.86 TiB used: 13.77 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apple model: SSD SM0128L
size: 113 GiB block-size: physical: 4096 B logical: 4096 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: CXS7LA0Q temp: 25.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Apple model: HDD ST2000DM001
type: HDD rpm: 7200 serial: <filter> rev: AQ03 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD My Passport 25F3 size: 953.84 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1006 scheme: GPT
ID-1: / raw-size: 953.54 GiB size: 937.5 GiB (98.32%) used: 13.77 GiB (1.5%)
fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 34e4f9a9-2c85-450c-bec3-0e721a7fbde6
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: NO_LABEL
uuid: 4140-2272
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: EFI
uuid: 5F66-17ED
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 112.71 GiB fs: apfs label: N/A
uuid: cf1cced7-fc2f-4caf-a35d-dac9772e5e29
ID-3: /dev/sda1 maj-min: 8:1 size: 200 MiB fs: vfat label: EFI
uuid: 67E3-17ED
ID-4: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: apfs label: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-5:2 info: Apple Magic Keyboard with Numeric Keypad
type: HID,Keyboard driver: apple,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 05ac:026c class-ID: 0301
serial: <filter>
Device-2: 1-12:3 info: Western Digital My Passport SSD (WDBK3E)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s power: 500mA chip-ID: 1058:25f3 class-ID: 0806
serial: <filter>
Device-3: 1-13:4 info: Apple FaceTime HD Camera (Built-in) type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 49.0 C pch: 58.0 C mobo: N/A gpu: amdgpu
temp: 48.0 C
Processes: 247 Uptime: 2h 32m wakeups: 9 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1221
lib: 338 flatpak: 0 Shell: Bash v: 5.1.16 running-in: guake inxi: 3.3.16
sudo dmidecode | grep "Product Name" ✔
Product Name: iMac19,1
Product Name: Mac-AA95B1DDAB278B95
lspci | grep -i audio ✔
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
sudo dmesg | grep audio INT ✘
[ 7.508393] snd_hda_codec_cs8409 hdaudioC0D0: autoconfig for CS8409: line_outs=2 (0x24/0x25/0x0/0x0/0x0) type:speaker
[ 7.508396] snd_hda_codec_cs8409 hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 7.508397] snd_hda_codec_cs8409 hdaudioC0D0: hp_outs=1 (0x2c/0x0/0x0/0x0/0x0)
[ 7.508398] snd_hda_codec_cs8409 hdaudioC0D0: mono: mono_out=0x0
[ 7.508399] snd_hda_codec_cs8409 hdaudioC0D0: inputs:
[ 7.508400] snd_hda_codec_cs8409 hdaudioC0D0: Internal Mic=0x45
[ 7.508400] snd_hda_codec_cs8409 hdaudioC0D0: Mic=0x3c
[ 7.934360] snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
cat /sys/class/sound/hwC1D0/vendor_name
ATI
cat /sys/class/sound/hwC1D0/vendor_id
0x1002aa01
cat /sys/class/sound/hwC0D0/vendor_name
Cirrus Logic
cat /sys/class/sound/hwC0D0/vendor_id
0x10138409
pacmd list ✔
Memory blocks currently allocated: 1, size: 63.9 KiB.
Memory blocks allocated during the whole lifetime: 5100, size: 22.7 MiB.
Memory blocks imported from other processes: 0, size: 0 B.
Memory blocks exported to other processes: 0, size: 0 B.
Total sample cache size: 0 B.
Default sample spec: s16le 2ch 44100Hz
Default channel map: front-left,front-right
Default sink name: auto_null
Default source name: auto_null.monitor
Memory blocks of type POOL: 1 allocated/4419 accumulated.
Memory blocks of type POOL_EXTERNAL: 0 allocated/0 accumulated.
Memory blocks of type APPENDED: 0 allocated/0 accumulated.
Memory blocks of type USER: 0 allocated/0 accumulated.
Memory blocks of type FIXED: 0 allocated/0 accumulated.
Memory blocks of type IMPORTED: 0 allocated/681 accumulated.
27 module(s) loaded.
index: 0
argument: <>
used: -1
load once: yes
properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "15.0"
index: 1
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the volume/mute/device state of streams"
index: 2
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore profile of cards"
index: 3
argument: <>
used: -1
load once: yes
properties:
module.description = "Augment the property sets of streams with additional static information"
index: 4
argument: <>
used: -1
load once: yes
properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
index: 5
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect available audio hardware and load matching drivers"
index: 6
argument: <device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
module.description = "ALSA Card"
index: 8
argument: <>
used: -1
load once: yes
properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
index: 9
argument: <>
used: -1
load once: yes
properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
index: 10
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
index: 11
argument: <>
used: -1
load once: yes
properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
index: 12
argument: <>
used: -1
load once: no
properties:
module.description = "Native protocol (UNIX sockets)"
index: 13
argument: <>
used: -1
load once: yes
properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
index: 14
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the default sink and source"
index: 15
argument: <>
used: -1
load once: yes
properties:
module.author = "Colin Guthrie"
module.description = "Hält stets ein Ziel geladen, selbst wenn dies ein Null-Ziel ist"
index: 16
argument: <sink_name=auto_null sink_properties='device.description="Dummy-Ausgabe"'>
used: 0
load once: no
properties:
module.description = "Getaktetes NULL-Ziel"
index: 17
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically set device of streams based on intended roles of devices"
index: 18
argument: <>
used: -1
load once: yes
properties:
module.description = "When a sink/source is idle for too long, suspend it"
index: 19
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each ConsoleKit session of this user"
index: 20
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each login session of this user"
index: 21
argument: <>
used: -1
load once: yes
properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
index: 22
argument: <>
used: -1
load once: yes
properties:
module.description = "Mute & cork streams with certain roles while others exist"
index: 23
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect when various filters are desirable"
index: 24
argument: <>
used: -1
load once: yes
properties:
module.description = "Load filter sinks automatically when needed"
index: 25
argument: <display=:0 xauthority=/home/binary/.Xauthority>
used: -1
load once: no
properties:
module.description = "X11 credential publisher"
index: 26
argument: <display=:0 xauthority=/home/binary/.Xauthority session_manager=local/manjaro:@/tmp/.ICE-unix/724,unix/manjaro:/tmp/.ICE-unix/724>
used: -1
load once: no
properties:
module.description = "X11 session management"
index: 27
argument: <>
used: -1
load once: no
properties:
module.description = "Command line interface protocol (UNIX sockets)"
1 sink(s) available.
index: 0
driver: <module-null-sink.c>
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1000
volume: front-left: 64224 / 98% / -0.53 dB, front-right: 64224 / 98% / -0.53 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 344 KiB
max rewind: 344 KiB
monitor source: 0
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
module: 16
properties:
device.description = "Dummy-Ausgabe"
device.class = "abstract"
device.icon_name = "audio-card"
1 source(s) available.
index: 0
state: SUSPENDED
suspend cause: IDLE
priority: 1000
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
volume steps: 65537
muted: no
max rewind: 344 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 0
module: 16
properties:
device.description = "Monitor of Dummy-Ausgabe"
device.class = "monitor"
7 client(s) logged in.
index: 0
driver: <module-systemd-login.c>
owner module: 20
properties:
application.name = "Login Session 2"
systemd-login.session = "2"
index: 3
driver: <protocol-native.c>
owner module: 12
properties:
application.name = "Plasma-PulseAudio"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "35"
application.id = "org.kde.plasma-pa"
application.icon_name = "audio-card"
application.process.id = "736"
application.process.user = "binary"
application.process.host = "manjaro"
application.process.binary = "plasmashell"
application.language = "de_DE.UTF-8"
window.x11.display = ":0"
application.process.machine_id = "5d854ddaa48d4cb088a4e2a589ff04be"
application.process.session_id = "2"
index: 5
driver: <module-x11-xsmp.c>
owner module: 26
properties:
application.name = "XSMP Session on KDE as 10ced3dd6a000165311620600000007240009"
xsmp.vendor = "KDE"
xsmp.client.id = "10ced3dd6a000165311620600000007240009"
index: 6
owner module: 12
properties:
application.name = "Firefox"
window.x11.screen = "0"
application.process.id = "1062"
application.process.binary = "firefox"
application.icon_name = "firefox"
index: 7
owner module: 12
properties:
application.version = "100.0"
index: 14
owner module: 12
properties:
index: 18
driver: <cli.c>
owner module: 27
properties:
application.name = "UNIX socket client"
1 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "1"
alsa.card_name = "HDA ATI HDMI"
alsa.long_card_name = "HDA ATI HDMI at 0x81760000 irq 60"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "aaf0"
device.product.name = "Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]"
device.string = "1"
device.description = "Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI)-Ausgabe (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI)-Ausgabe (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI)-Ausgabe (priority 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2)-Ausgabe (priority 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2)-Ausgabe (priority 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2)-Ausgabe (priority 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3)-Ausgabe (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3)-Ausgabe (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3)-Ausgabe (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4)-Ausgabe (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4)-Ausgabe (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4)-Ausgabe (priority 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5)-Ausgabe (priority 5700, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5)-Ausgabe (priority 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5)-Ausgabe (priority 600, available: no)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6)-Ausgabe (priority 5700, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6)-Ausgabe (priority 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6)-Ausgabe (priority 600, available: no)
output:hdmi-stereo-extra6: Digital Stereo (HDMI 7)-Ausgabe (priority 5700, available: no)
output:hdmi-surround-extra6: Digital Surround 5.1 (HDMI 7)-Ausgabe (priority 600, available: no)
output:hdmi-surround71-extra6: Digital Surround 7.1 (HDMI 7)-Ausgabe (priority 600, available: no)
off: Aus (priority 0, available: unknown)
active profile: <off>
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
hdmi-output-5: HDMI / DisplayPort 6 (priority 5400, latency offset 0 usec, available: no)
properties:
hdmi-output-6: HDMI / DisplayPort 7 (priority 5300, latency offset 0 usec, available: no)
properties:
0 sink input(s) available.
0 source output(s) available.
0 cache entrie(s) available.```
