No sound on Event Notifications.
In Configure Notifications window “play” button does not produce any sound, while paplay could play those notification sounds.
$ paplay -v /usr/share/sounds/Oxygen-Sys-App-Error-Critical.ogg
Opening a playback stream with sample specification 'float32le 2ch 48000Hz' and channel map 'front-left,front-right'.
Connection established.
Stream successfully created.
Buffer metrics: maxlength=4194304, tlength=768000, prebuf=760328, minreq=7680
Using sample spec 'float32le 2ch 48000Hz', channel map 'front-left,front-right'.
Connected to device alsa_output.pci-0000_01_00.1.hdmi-stereo (index: 19, suspended: no).
Stream started.
Stream underrun.
Playback stream drained.
Draining connection to server.
PipeWire cannot support audio unless PulseAudio is removed and replaced, but it can impede PulseAudio functions.
Install metapackage manjaro-pipewire to remove and replace PulseAudio packages
To continue using PulseAudio without PipeWire use this command to stop, disable and mask PipeWire service and socket
Onboard audio device Intel Cannon Lake PCH cAVS is using legacy driver snd_hda_intel instead of the Sound Open Firmware driver to support internal digital microphone array
Check that package sof-firmware is installed for the Sound Open Firmware driver sof-audio-pci-intel-cnl
If you have resolved those 3 issues and audio is still not working as expected, please post full system information
I can only speak from experience of using PulseAudio and JACK. Both have been working well for me for a long time so I have not considered a replacement is necessary
The only knowledgable opinion I have seen so far is a recent video from Unfa Is PipeWire ready for audio production (in Q4 2021) ? - YouTube
He did not show benchmark data from recent PipeWire tests as expected, but advised he has reverted to using PulseAudio and JACK
But this was mostly focused on comparing JACK and pw-jack
IMO discussion of PulseAudio vs PipeWire is a false dilemma and Linux audio is more of a quandary if you consider that there is more to Linux audio than 2 conflicting sound servers
Tried clearly to “BIOS Flash update via USB > F12 > BIOS flash update”, but it failed on flashing with “Firmware update failed. Rebooting the system”. It seems to be a common fail in part of Dell community (considering version 1.18).
