No sound manjaro
Hello,
I am just installing a new manjaro and no sound at all.
I already check on the forums and alsamixer give me 100 for master
thx for answers
Hello and welcome to Manjaro
For someone to be able to help you please provide more information.
Read through this post first.
Edit your post with the output of this command
inxi --admin --verbosity=7 --filter --width
Thanks.
Ok thx for the anwer and sorry for my question.
Here is the reult of inxi command.
  Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=1ed4b720-7d56-48ef-a85a-72112e8f00fe rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Laptop System: Micro-Star product: Katana GF66 11UC v: REV:1.0
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Micro-Star model: MS-1582 v: REV:1.0 serial: <filter>
  UEFI: American Megatrends LLC. v: E1582IMS.307 date: 06/11/2021
  ID-1: BAT1 charge: 49.4 Wh (93.7%) condition: 52.7/52.0 Wh (101.2%)
  volts: 12.7 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
  status: Unknown
  RAM: total: 7.47 GiB used: 1.88 GiB (25.1%)
  Info: 6-Core model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP
  arch: Tiger Lake family: 6 model-id: 8D (141) stepping: 1 microcode: 2C
  cache: L2: 12 MiB bogomips: 64536
  Speed: 801 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 801 2: 800 3: 800
  4: 801 5: 800 6: 800 7: 800 8: 800 9: 926 10: 801 11: 801 12: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
  avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
  avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
  clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
  dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
  fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
  hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
  lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
  nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
  pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
  sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
  ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
  tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
  xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Micro-Star MSI
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a68 class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Micro-Star MSI
  driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:25a5 class-ID: 0302
  Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 3-10:3
  chip-ID: 5986:211b class-ID: 0e02
  Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
  loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
  display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
  s-diag: 1055mm (41.5")
  Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  Monitor-2: HDMI-1 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2")
  diag: 686mm (27")
  OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 21.2.5
  direct render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
  driver: sof-audio-pci-intel-tgl
  alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
  chip-ID: 8086:43c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
  Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
  vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
  bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 9.93 GiB (2.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
  lanes: 4 type: SSD serial: <filter> rev: ECFK52.8 temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 9.9 GiB (10.4%)
  fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
  uuid: 1ed4b720-7d56-48ef-a85a-72112e8f00fe
  ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
  used: 27.8 MiB (9.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: SYSTEM uuid: 4678-FFF3
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 356.47 GiB fs: ntfs label: Windows
  uuid: FEB67A86B67A3F69
  ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 900 MiB fs: ntfs
  label: WinRE tools uuid: 4A4C7B2F4C7B14C3
  ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 21.51 GiB fs: ntfs label: BIOS_RVY
  uuid: 6A947D52947D21AD
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 3-1:2 info: Razer USA RZ01-0316 Gaming Mouse [Basilisk V2]
  type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 1532:0085 class-ID: 0301
  Device-2: 3-10:3 info: Acer HD Webcam type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:211b
  class-ID: 0e02
  Device-3: 3-14:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
  class-ID: e001
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 20 Gb/s
  System Temperatures: cpu: 42.0 C mobo: N/A
  Processes: 287 Uptime: 6m wakeups: 1 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1079 lib: 312 flatpak: 0
  Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.08
You have both “pipe wire” and “pulseaudio” running this does not work stop one and your sound should return
When I try to delete one of them, I’ve got dependencies problems.
here is for pipewire :
sudo pacman -Rs pipewire
checking dependencies...
:: removing pipewire breaks dependency 'pipewire' required by xdg-desktop-portal
and for pulseaudio
sudo pacman -Rs pulseaudio
:: removing pulseaudio breaks dependency 'pulseaudio' required by manjaro-pulse
:: removing pulseaudio breaks dependency 'pulseaudio' required by pulseaudio-alsa
:: removing pulseaudio breaks dependency 'pulseaudio=15.0-1' required by pulseaudio-bluetooth
:: removing pulseaudio breaks dependency 'pulseaudio' required by pulseaudio-ctl
:: removing pulseaudio breaks dependency 'pulseaudio=15.0-1' required by pulseaudio-jack
:: removing pulseaudio breaks dependency 'pulseaudio=15.0-1' required by pulseaudio-lirc
:: removing pulseaudio breaks dependency 'pulseaudio=15.0-1' required by pulseaudio-rtp
:: removing pulseaudio breaks dependency 'pulseaudio=15.0-1' required by pulseaudio-zeroconf
Hello sorry for late reply, been busy.
Before removing anything :slight_smile: Are You absolutely sure that you have left clicked on the sound icon in the panel → left clicked audio mixer → checked in Playback and Output Devices that nothing is muted ??
Hover on the sound icons there.
Also if you use Firefox when an YouTube video plays in the tab name you have sound icon as well check that also.
There must be some setting you are missing.
@robin0800
My audio also shows that
and I don’t have sound problems, at least for now :slight_smile:
Ok thanks for your answer, I finally install these 2 packages :
sof-firmware
and
alsa-ucm-conf
reboot and everythings fine !
Thanks for the time :slight_smile:
I’m glad you solved it
Please click the 3 dots below your answer to mark a solution like this below:
Solution
Cheers… :beers:
