Hi, I am running 6.12.0-MANJARO. The previous post
solves the sound issue but the microphone, although detected, does not have input or record any sound with the maximum input volumn.
The detailed information for ALSA device can be found here:
https://alsa-project.org/db/?f=4af5b11bab7bf5aed350ac3d2d97d39574639ecc
Some more details about the hardware can be found below.
Thanks so much in advance!
> aplay -l ✔
**** List of PLAYBACK Hardware Devices ****
card 0: sofsoundwire [sof-soundwire], device 0: Jack Out (*) []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: sofsoundwire [sof-soundwire], device 2: Speaker (*) []
Subdevices: 0/1
card 0: sofsoundwire [sof-soundwire], device 5: HDMI1 (*) []
Subdevices: 1/1
card 0: sofsoundwire [sof-soundwire], device 6: HDMI2 (*) []
Subdevices: 1/1
card 0: sofsoundwire [sof-soundwire], device 7: HDMI3 (*) []
Subdevices: 1/1
card 0: sofsoundwire [sof-soundwire], device 31: Deepbuffer Jack Out (*) []
Subdevices: 1/1
> pactl list sinks
Sink #48
State: SUSPENDED
Description: Lunar Lake-M HD Audio Controller HDMI / DisplayPort 3 Output
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-sof_sdw.HiFi__HDMI3__sink.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
alsa.card = "0"
alsa.card_name = "sof-soundwire"
alsa.class = "generic"
alsa.components = "HDA:80862820,80860101,00100000 cfg-amp:4 iec61937-pcm:7,6,5 hs:cs42l43 mic:cs42l43-dmic spk:cs35l56"
alsa.device = "7"
alsa.driver_name = "snd_soc_sof_sdw"
alsa.id = "HDMI3 (*)"
alsa.long_card_name = "ASUSTeKCOMPUTERINC.-ASUSZenbookS14UX5406SA_UX5406SA-1.0-UX5406SA"
alsa.mixer_device = "_ucm0001.hw:sofsoundwire"
alsa.mixer_name = "Intel Lunar Lake HDMI"
alsa.name = ""
alsa.resolution_bits = "16"
alsa.subclass = "generic-mix"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.sync.id = "00000000:00000000:00000000:00000000"
api.alsa.card.longname = "ASUSTeKCOMPUTERINC.-ASUSZenbookS14UX5406SA_UX5406SA-1.0-UX5406SA"
api.alsa.card.name = "sof-soundwire"
api.alsa.open.ucm = "true"
api.alsa.path = "hw:sofsoundwire,7"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
card.profile.device = "0"
device.api = "alsa"
device.class = "sound"
device.id = "47"
device.profile.description = "HDMI / DisplayPort 3 Output"
device.profile.name = "HiFi: HDMI3: sink"
device.routes = "1"
factory.name = "api.alsa.pcm.sink"
media.class = "Audio/Sink"
device.description = "Lunar Lake-M HD Audio Controller"
node.name = "alsa_output.pci-0000_00_1f.3-platform-sof_sdw.HiFi__HDMI3__sink"
node.nick = "HDMI / DisplayPort 3 Output"
node.pause-on-idle = "false"
object.path = "alsa:acp:sofsoundwire:0:playback"
port.group = "playback"
priority.driver = "632"
priority.session = "632"
factory.id = "19"
clock.quantum-limit = "8192"
client.id = "46"
node.driver = "true"
node.loop.name = "data-loop.0"
library.name = "audioconvert/libspa-audioconvert"
object.id = "48"
object.serial = "48"
api.acp.auto-port = "false"
api.alsa.card = "0"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1.Priority = "-20"
device.bus = "pci"
device.bus_path = "pci-0000:00:1f.3-platform-sof_sdw"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_00_1f.3-platform-sof_sdw"
device.nick = "sof-soundwire"
device.plugged.usec = "7237930"
device.product.id = "0xa828"
device.product.name = "Lunar Lake-M HD Audio Controller"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sof_sdw/sound/card0"
device.vendor.id = "0x8086"
device.string = "0"
Ports:
[Out] HDMI3: HDMI / DisplayPort 3 Output (type: HDMI, priority: 700, availability group: HDMI/DP,pcm=7, not available)
Active Port: [Out] HDMI3
Formats:
pcm
Sink #49
State: SUSPENDED
Description: Lunar Lake-M HD Audio Controller HDMI / DisplayPort 2 Output
Driver: PipeWire
Mute: no
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-sof_sdw.HiFi__HDMI2__sink.monitor
Properties:
alsa.card = "0"
alsa.device = "6"
alsa.id = "HDMI2 (*)"
alsa.name = ""
api.alsa.path = "hw:sofsoundwire,6"
card.profile.device = "1"
device.api = "alsa"
device.id = "47"
device.profile.description = "HDMI / DisplayPort 2 Output"
device.profile.name = "HiFi: HDMI2: sink"
device.routes = "1"
node.name = "alsa_output.pci-0000_00_1f.3-platform-sof_sdw.HiFi__HDMI2__sink"
node.nick = "HDMI / DisplayPort 2 Output"
object.path = "alsa:acp:sofsoundwire:1:playback"
priority.driver = "648"
priority.session = "648"
factory.id = "19"
client.id = "46"
object.id = "49"
object.serial = "49"
api.alsa.card = "0"
device.bus = "pci"
device.string = "0"
Ports:
[Out] HDMI2: HDMI / DisplayPort 2 Output (type: HDMI, priority: 600, availability group: HDMI/DP,pcm=6, not available)
Active Port: [Out] HDMI2
Formats:
pcm
Sink #50
State: SUSPENDED
Description: Lunar Lake-M HD Audio Controller HDMI / DisplayPort 1 Output
Driver: PipeWire
Mute: no
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-sof_sdw.HiFi__HDMI1__sink.monitor
Properties:
alsa.card = "0"
alsa.device = "5"
alsa.id = "HDMI1 (*)"
alsa.name = ""
api.alsa.path = "hw:sofsoundwire,5"
card.profile.device = "2"
device.api = "alsa"
device.id = "47"
device.profile.description = "HDMI / DisplayPort 1 Output"
device.profile.name = "HiFi: HDMI1: sink"
device.routes = "1"
node.name = "alsa_output.pci-0000_00_1f.3-platform-sof_sdw.HiFi__HDMI1__sink"
node.nick = "HDMI / DisplayPort 1 Output"
object.path = "alsa:acp:sofsoundwire:2:playback"
priority.driver = "664"
priority.session = "664"
factory.id = "19"
client.id = "46"
object.id = "50"
object.serial = "50"
api.alsa.card = "0"
device.bus = "pci"
device.string = "0"
Ports:
[Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 500, availability group: HDMI/DP,pcm=5, not available)
Active Port: [Out] HDMI1
Formats:
pcm
Sink #51
State: SUSPENDED
Description: Lunar Lake-M HD Audio Controller Headphones
Driver: PipeWire
Mute: no
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-sof_sdw.HiFi__Headphones__sink.monitor
Properties:
alsa.card = "0"
alsa.device = "0"
alsa.id = "Jack Out (*)"
alsa.name = ""
api.alsa.path = "hw:sofsoundwire,0"
card.profile.device = "3"
device.api = "alsa"
device.id = "47"
device.profile.description = "Headphones"
device.profile.name = "HiFi: Headphones: sink"
device.routes = "1"
node.name = "alsa_output.pci-0000_00_1f.3-platform-sof_sdw.HiFi__Headphones__sink"
node.nick = "Headphones"
object.path = "alsa:acp:sofsoundwire:3:playback"
priority.driver = "1000"
priority.session = "1000"
factory.id = "19"
client.id = "46"
object.id = "51"
object.serial = "51"
api.alsa.card = "0"
device.bus = "pci"
device.string = "0"
Ports:
[Out] Headphones: Headphones (type: Headphones, priority: 200, availability group: Headphone, not available)
Active Port: [Out] Headphones
Formats:
pcm
Sink #52
State: IDLE
Description: Lunar Lake-M HD Audio Controller Speaker
Driver: PipeWire
Mute: no
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-sof_sdw.HiFi__Speaker__sink.monitor
Properties:
alsa.card = "0"
alsa.device = "2"
alsa.id = "Speaker (*)"
alsa.name = ""
api.alsa.path = "hw:sofsoundwire,2"
card.profile.device = "4"
device.api = "alsa"
device.id = "47"
device.profile.description = "Speaker"
device.profile.name = "HiFi: Speaker: sink"
device.routes = "1"
node.name = "alsa_output.pci-0000_00_1f.3-platform-sof_sdw.HiFi__Speaker__sink"
node.nick = "Speaker"
object.path = "alsa:acp:sofsoundwire:4:playback"
priority.driver = "712"
priority.session = "712"
factory.id = "19"
client.id = "46"
object.id = "52"
object.serial = "52"
node.max-latency = "16384/48000"
api.alsa.period-size = "1024"
api.alsa.period-num = "32"
api.alsa.headroom = "0"
api.alsa.card = "0"
device.bus = "pci"
device.string = "0"
Ports:
[Out] Speaker: Speaker (type: Speaker, priority: 100, availability unknown)
Active Port: [Out] Speaker
Formats:
pcm
