No sound (Dummy Output) on ASUS Zenbook S14 Lunar Lake under 6.12.0-rc2
Hi, I am running 6.12.0-rc2-2-MANJARO, the bluetooth works fine on my end but I could not fix the sound issue.
There is no output (output device is always Dummy Output) and no input device.
It has difficulty detecting the sound card:
> aplay -l
aplay: device_list:279: no soundcards found..
> pactl list sinks
Sink #34
	State: SUSPENDED
	Description: Dummy Output
	Driver: PipeWire
	Sample Specification: float32le 2ch 48000Hz
	Channel Map: front-left,front-right
	Owner Module: 4294967295
> lspci | grep audio
00:1f.3 Multimedia audio controller: Intel Corporation Lunar Lake-M HD Audio Controller (rev 10)
I installed sof-firmware but no luck.
Please let me know if there is a fix for this other than waiting for the kernel to pick up the driver.
Many thanks in advance.
Try this suggestions from the arch forum:
https://bbs.archlinux.org/viewtopic.php?pid=1923298#p1923298
Thanks @pheiduck. I tried the solution suggested by the post but it still shows Dummy Output and no input device.
I have the output for the three lines suggested to run below:
sudo fuser -v /dev/snd/*
aplay -lL
amixer -c0
                            PID ACCESS COMMAND
/dev/snd/controlC0:    1446 F.... wireplumber
/dev/snd/seq:    1445 F.... pipewire
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pipewire
    PipeWire Sound Server
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PipeWire Media Server)
hdmi:CARD=PCH,DEV=0
    HDA Intel PCH, HDMI 0
    HDMI Audio Output
hdmi:CARD=PCH,DEV=1
    HDA Intel PCH, HDMI 1
    HDMI Audio Output
hdmi:CARD=PCH,DEV=2
    HDA Intel PCH, HDMI 2
    HDMI Audio Output
hdmi:CARD=PCH,DEV=3
    HDA Intel PCH, HDMI 3
    HDMI Audio Output
usbstream:CARD=PCH
    HDA Intel PCH
    USB Stream Output
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Thanks again for your help!
If onboard audio was working normally, there should be an analog output for speaker/headphones
HW probe of ASUSTek VivoBook S14 X411UF #fb1c2503cf: aplay
card 0: PCH [HDA Intel PCH], device 0: Generic Analog [Generic Analog]
  Subdevices: 1/1
HW probe of ASUSTek VivoBook S14 X430UA #1ecd2b5284: aplay
card 0: PCH [HDA Intel PCH], device 0: ALC256 Analog [ALC256 Analog]
  Subdevices: 1/1
I suggest check detailed information for ALSA device
sudo alsa-info.sh --upload
Thanks @nikgnomic,
Here is what I get for ASUS Zenbook S 14 UX5406SA_UX5406SA
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
There is no analog output for speakers : (
Sorry I cannot post link, but please find the full results below:
!!ALSA Information Script v 0.5.3
!!Script ran on: Sun Nov 10 23:36:01 UTC 2024
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      ASUSTeK COMPUTER INC.
Product Name:      ASUS Zenbook S 14 UX5406SA_UX5406SA
Product Version:   1.0
Firmware Version:  UX5406SA.300
System SKU:
Board Vendor:      ASUSTeK COMPUTER INC.
Board Name:        UX5406SA
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI000C:00/status 	 15
/sys/bus/acpi/devices/ACPI000E:00/status 	 15
/sys/bus/acpi/devices/ASUF1208:00/status 	 15
/sys/bus/acpi/devices/ASUH2024:00/status 	 15
/sys/bus/acpi/devices/ASUS2018:00/status 	 15
/sys/bus/acpi/devices/ATK3001:00/status 	 15
/sys/bus/acpi/devices/INT33A1:00/status 	 15
/sys/bus/acpi/devices/INTC105D:00/status 	 15
/sys/bus/acpi/devices/INTC105D:01/status 	 15
/sys/bus/acpi/devices/INTC105D:02/status 	 15
/sys/bus/acpi/devices/INTC105D:03/status 	 15
/sys/bus/acpi/devices/INTC105D:04/status 	 15
/sys/bus/acpi/devices/INTC1068:00/status 	 15
/sys/bus/acpi/devices/INTC1069:00/status 	 15
/sys/bus/acpi/devices/INTC1069:01/status 	 15
/sys/bus/acpi/devices/INTC1069:02/status 	 15
/sys/bus/acpi/devices/INTC1069:03/status 	 15
/sys/bus/acpi/devices/INTC1069:05/status 	 15
/sys/bus/acpi/devices/INTC1069:06/status 	 15
/sys/bus/acpi/devices/INTC1069:07/status 	 15
/sys/bus/acpi/devices/INTC107B:00/status 	 15
/sys/bus/acpi/devices/INTC109D:00/status 	 15
/sys/bus/acpi/devices/LNXPOWER:01/status 	 1
/sys/bus/acpi/devices/LNXPOWER:04/status 	 1
/sys/bus/acpi/devices/LNXPOWER:05/status 	 1
/sys/bus/acpi/devices/LNXPOWER:07/status 	 1
/sys/bus/acpi/devices/LNXPOWER:09/status 	 1
/sys/bus/acpi/devices/MSFT0101:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0A05:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:01/status 	 8
/sys/bus/acpi/devices/PNP0C02:02/status 	 8
/sys/bus/acpi/devices/PNP0C02:04/status 	 8
/sys/bus/acpi/devices/PNP0C02:06/status 	 3
/sys/bus/acpi/devices/PNP0C02:07/status 	 3
/sys/bus/acpi/devices/PNP0C0A:03/status 	 31
/sys/bus/acpi/devices/PNP0C0B:00/status 	 15
/sys/bus/acpi/devices/PNP0C0C:00/status 	 15
/sys/bus/acpi/devices/PNP0C0F:00/status 	 9
/sys/bus/acpi/devices/PNP0C0F:01/status 	 9
/sys/bus/acpi/devices/PNP0C0F:02/status 	 9
/sys/bus/acpi/devices/PNP0C0F:03/status 	 9
/sys/bus/acpi/devices/PNP0C0F:04/status 	 9
/sys/bus/acpi/devices/PNP0C0F:05/status 	 9
/sys/bus/acpi/devices/PNP0C0F:06/status 	 9
/sys/bus/acpi/devices/PNP0C0F:07/status 	 9
/sys/bus/acpi/devices/PRP00001:00/status 	 15
/sys/bus/acpi/devices/PRP00001:01/status 	 11
/sys/bus/acpi/devices/USBC000:00/status 	 15
/sys/bus/acpi/devices/device:1f/status 	 15
/sys/bus/acpi/devices/device:3f/status 	 15
/sys/bus/acpi/devices/device:50/status 	 15
/sys/bus/acpi/devices/device:51/status 	 15
/sys/bus/acpi/devices/device:52/status 	 15
/sys/bus/acpi/devices/device:54/status 	 15
/sys/bus/acpi/devices/device:55/status 	 15
/sys/bus/acpi/devices/device:56/status 	 15
/sys/bus/acpi/devices/device:5c/status 	 15
/sys/bus/acpi/devices/device:63/status 	 15
/sys/bus/acpi/devices/device:65/status 	 15
/sys/bus/acpi/devices/device:67/status 	 15
!!ACPI SoundWire Device Status Information
Cirrus Logic 0x00023001fa355601
Cirrus Logic 0x00023101fa355601
Cirrus Logic 0x00033201fa355601
Cirrus Logic 0x00033301fa355601
Cirrus Logic 0x00003001fa424301
!!Kernel Information
Kernel release:    #1 SMP PREEMPT_DYNAMIC Sun Nov 10 23:51:59 AEDT 2024
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k6.12.0-rc6-MANJARO
Library version:    1.2.12
Utilities version:  1.2.12
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
      Installed - Yes (/usr/bin/pipewire)
      Running - Yes
No sound servers found.
!!Soundcards recognised by ALSA
 0 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0x3014200000 irq 191
!!PCI Soundcards installed in the system
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Lunar Lake-M HD Audio Controller [8086:a828] (rev 10)
	Subsystem: ASUSTeK Computer Inc. Device [1043:1e13]
!!Modprobe options (Sound related)
snd_hda_intel: model=auto index=0
snd_intel_dspcfg: dsp_driver=1
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	ctl_dev_id : N
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : 0,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : auto,(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : -1
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 10
	power_save_controller : Y
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!Sysfs ctl-led info
!!CTL-LED: /sys/class/sound/ctl-led/mic/card0
List:
!!CTL-LED: /sys/class/sound/ctl-led/speaker/card0
List:
!!HDA-Intel Codec information
--startcollapse--
Codec: Intel Lunar Lake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x80862820
Subsystem Id: 0x80860101
Revision Id: 0x100000
No Modem Function Group found
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Converter: stream=0, channel=0
  Digital: Enabled
  Digital category: 0x0
  IEC Coding Type: 0x0
  PCM:
    rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
    bits [0x1a]: 16 24 32
    formats [0x5]: PCM AC3
  Power states:  D0 D3 EPSS
Node 0x04 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x00 0x00]
  Pincap 0x09000094: OUT Detect HBR HDMI DP
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x00:
  Unsolicited: tag=00, enabled=0
  Devices: 0
  Connection: 0
Node 0x05 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Digital: Enabled
  PCM:
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x07 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Digital: Enabled
  PCM:
Node 0x08 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x09 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Digital: Enabled
  PCM:
Node 0x0a [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x0b [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x0c [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x0d [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x0e [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x0f [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
--endcollapse--
!!ALSA Device nodes
crw-rw----  1 root audio 116,  7 Nov 11 10:35 /dev/snd/controlC0
crw-rw----  1 root audio 116,  6 Nov 11 10:35 /dev/snd/hwC0D2
crw-rw----  1 root audio 116,  2 Nov 11 10:35 /dev/snd/pcmC0D3p
crw-rw----  1 root audio 116,  3 Nov 11 10:35 /dev/snd/pcmC0D7p
crw-rw----  1 root audio 116,  4 Nov 11 10:35 /dev/snd/pcmC0D8p
crw-rw----  1 root audio 116,  5 Nov 11 10:35 /dev/snd/pcmC0D9p
crw-rw----  1 root audio 116,  1 Nov 11 10:35 /dev/snd/seq
crw-rw----  1 root audio 116, 33 Nov 11 10:35 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Nov 11 10:35 .
drwxr-xr-x 3 root root 220 Nov 11 10:35 ..
lrwxrwxrwx 1 root root  12 Nov 11 10:35 pci-0000:00:1f.3 -> ../controlC0
!!Aplay/Arecord output
APLAY
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0x3014200000 irq 191'
  Mixer name	: 'Intel Lunar Lake HDMI'
  Components	: 'HDA:80862820,80860101,00100000'
  Controls      : 28
  Simple ctrls  : 4
  Mono: Playback [on]
  Mono: Playback [on]
  Mono: Playback [on]
  Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
	control.1 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.2 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.3 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.4 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.5 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.6 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access 'read volatile'
			type BYTES
			count 0
	control.7 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.9 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.10 {
		iface MIXER
		index 1
		comment {
			access 'read write'
			type IEC958
			count 1
	control.11 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface PCM
		device 7
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.13 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.14 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.15 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.16 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.17 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.18 {
		iface PCM
		device 8
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.19 {
		iface CARD
		name 'HDMI/DP,pcm=9 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.21 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.22 {
		iface MIXER
		index 3
		comment {
			access 'read write'
			type IEC958
			count 1
	control.23 {
		iface MIXER
		index 3
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.24 {
		iface PCM
		device 9
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.25 {
		iface PCM
		device 3
		name 'Playback Channel Map'
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write volatile'
			type INTEGER
			count 8
			range '0 - 36'
	control.26 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			type INTEGER
			count 8
			range '0 - 36'
	control.27 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			type INTEGER
			count 8
			range '0 - 36'
	control.28 {
		iface PCM
		device 9
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			type INTEGER
			count 8
			range '0 - 36'
--endcollapse--
!!All Loaded Modules
8250_dw
ac97_bus
acpi_pad
acpi_tad
acpi_thermal_rel
aesni_intel
af_alg
algif_hash
algif_skcipher
asus_nb_wmi
asus_wmi
atkbd
bluetooth
bnep
btbcm
btintel
btmtk
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dm_mod
drm_buddy
drm_display_helper
drm_exec
drm_gpuvm
drm_suballoc_helper
drm_ttm_helper
ext4
fat
gf128mul
ghash_clmulni_intel
gpu_sched
hid_generic
hid_multitouch
hid_sensor_hub
hid_sensor_iio_common
hid_sensor_prox
hid_sensor_trigger
i2c_algo_bit
i2c_hid
i2c_hid_acpi
i8042
idma64
industrialio
industrialio_triggered_buffer
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_hid
intel_ish_ipc
intel_ishtp
intel_lpss
intel_lpss_pci
intel_pmc_core
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_uncore
intel_uncore_frequency
intel_uncore_frequency_common
intel_vpu
intel_vsec
ip6_tables
ip6table_filter
ip6table_nat
ip_tables
iptable_filter
iptable_nat
iwlmvm
iwlwifi
jbd2
joydev
kfifo_buf
kvm
kvm_intel
libarc4
libcrc32c
libps2
loop
mac80211
mac_hid
mbcache
mc
mei
mei_gsc_proxy
mei_me
mousedev
mtd
nf_conntrack
nf_defrag_ipv4
nf_defrag_ipv6
nf_nat
nf_tables
nfnetlink
nvme
nvme_auth
nvme_core
pcspkr
pinctrl_intel_platform
platform_profile
pmt_class
pmt_telemetry
polyval_clmulni
polyval_generic
pps_core
processor_thermal_device
processor_thermal_device_pci
processor_thermal_mbox
processor_thermal_power_floor
processor_thermal_rapl
processor_thermal_rfim
processor_thermal_wt_hint
processor_thermal_wt_req
ptp
qrtr
rapl
rfcomm
rfkill
roles
serio
serio_raw
sg
sha1_ssse3
sha256_ssse3
sha512_ssse3
snd
snd_compress
snd_ctl_led
snd_hda_codec
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_intel_hda_generic
snd_sof_intel_hda_mlink
snd_sof_pci
snd_sof_pci_intel_lnl
snd_sof_pci_intel_mtl
snd_sof_utils
snd_sof_xtensa_dsp
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_intel
spi_intel_pci
spi_nor
thunderbolt
ttm
tun
typec
typec_ucsi
ucsi_acpi
usbhid
uvc
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
vivaldi_fmap
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xe
xt_MASQUERADE
xt_mark
xt_tcpudp
!!Sysfs Files
/sys/class/sound/hwC0D2/init_pin_configs:
0x04 0x18560010
0x06 0x18560010
0x08 0x18560010
0x0a 0x18560010
0x0b 0x18560010
0x0c 0x18560010
0x0d 0x18560010
0x0e 0x18560010
0x0f 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[    0.135676] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[    0.135678] ACPI BIOS Error (bug): Could not resolve symbol [\_SB._SB.PC00.HDAS.IDA.SNDW], AE_NOT_FOUND (20240827/dswload2-162)
[    0.135679] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240827/psobject-220)
[    0.217012] ACPI: \_SB_.PC00.PAUD: New power resource
[    0.217466] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.217469] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.C024: can't evaluate "PMAP" as buffer
[    0.217506] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.217507] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.C024: can't evaluate "PMAP" as buffer
[    0.217575] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.217577] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.C024: can't evaluate "PMAP" as buffer
[    0.217684] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.217685] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.C024: can't evaluate "PMAP" as buffer
[    0.217955] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.217956] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.C024: can't evaluate "PMAP" as buffer
[    0.218109] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.218111] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.C024: can't evaluate "PMAP" as buffer
[    0.218281] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.218283] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.C024: can't evaluate "PMAP" as buffer
[    0.218473] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.218475] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.C024: can't evaluate "PMAP" as buffer
[    0.218660] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.218662] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.C024: can't evaluate "PMAP" as buffer
[    0.218929] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.218931] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD2.AF01.C024: can't evaluate "PMAP" as buffer
[    0.219562] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.219564] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.C024: can't evaluate "PMAP" as buffer
[    0.219599] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.219601] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.C024: can't evaluate "PMAP" as buffer
[    0.219662] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.219664] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.C024: can't evaluate "PMAP" as buffer
[    0.219765] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.219767] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.C024: can't evaluate "PMAP" as buffer
[    0.220030] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.220032] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.C024: can't evaluate "PMAP" as buffer
[    0.220183] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.220185] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.C024: can't evaluate "PMAP" as buffer
[    0.220346] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.220348] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.C024: can't evaluate "PMAP" as buffer
[    0.220538] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.220539] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.C024: can't evaluate "PMAP" as buffer
[    0.220725] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.220727] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.C024: can't evaluate "PMAP" as buffer
[    0.220997] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.220999] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD3.AF01.C024: can't evaluate "PMAP" as buffer
[    0.221621] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.221624] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.C024: can't evaluate "PMAP" as buffer
[    0.221662] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.221664] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.C024: can't evaluate "PMAP" as buffer
[    0.221733] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.221734] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.C024: can't evaluate "PMAP" as buffer
[    0.221835] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.221837] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.C024: can't evaluate "PMAP" as buffer
[    0.222099] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.222101] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.C024: can't evaluate "PMAP" as buffer
[    0.222248] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.222250] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.C024: can't evaluate "PMAP" as buffer
[    0.222417] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.222418] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.C024: can't evaluate "PMAP" as buffer
[    0.222611] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.222612] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.C024: can't evaluate "PMAP" as buffer
[    0.222801] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.222802] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.C024: can't evaluate "PMAP" as buffer
[    0.223062] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.223064] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD4.AF01.C024: can't evaluate "PMAP" as buffer
[    0.223709] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.223711] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.C024: can't evaluate "PMAP" as buffer
[    0.223745] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.223746] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.C024: can't evaluate "PMAP" as buffer
[    0.223811] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.223813] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.C024: can't evaluate "PMAP" as buffer
[    0.223916] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.223917] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.C024: can't evaluate "PMAP" as buffer
[    0.224185] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.224186] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.C024: can't evaluate "PMAP" as buffer
[    0.224338] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.224339] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.C024: can't evaluate "PMAP" as buffer
[    0.224507] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.224510] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.C024: can't evaluate "PMAP" as buffer
[    0.224697] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.224699] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.C024: can't evaluate "PMAP" as buffer
[    0.224887] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.224889] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.C024: can't evaluate "PMAP" as buffer
[    0.225152] ACPI Error: Incorrect return type from \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.PMAP - received [Package], requested [Buffer] (20240827/nsxfeval-114)
[    0.225153] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD5.AF01.C024: can't evaluate "PMAP" as buffer
[    0.227767] sysfs: cannot create duplicate filename '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:32/device:33/PRP00001:00/device:3c/device:3d/mipi-sdca-entity-id-0x11-subproperties/mipi-sdca-control-0x2-subproperties'
[    0.227842] kobject: kobject_add_internal failed for mipi-sdca-control-0x2-subproperties with -EEXIST, don't try to register things with the same name in the same directory.
[    0.227843] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD6.AF03.CE31: Failed to expose (-17)
[    0.227845] sysfs: cannot create duplicate filename '/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:32/device:33/PRP00001:00/device:3c/device:3d/mipi-sdca-entity-id-0x11-subproperties/mipi-sdca-control-0x2-subproperties'
[    0.227890] kobject: kobject_add_internal failed for mipi-sdca-control-0x2-subproperties with -EEXIST, don't try to register things with the same name in the same directory.
[    0.227891] ACPI: \_SB_.PC00.HDAS.IDA_.SNDW.SWD6.AF03.CE32: Failed to expose (-17)
[    0.234230] ACPI: \_SB_.PC00.CNVW.WRST: New power resource
[    5.453779] usbcore: registered new interface driver uvcvideo
[    5.476679] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    5.476865] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [xe])
[    5.524271] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[    5.550175] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[    5.550207] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[    5.550229] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[    5.557698] input: ASUF1208:00 2808:0218 Mouse as /devices/pci0000:00/0000:00:19.1/i2c_designware.3/i2c-15/i2c-ASUF1208:00/0018:2808:0218.0002/input/input16
I did a kernel upgrade to rc_6 last night but still no luck.
New users cannot post active links, but they can post inactive links in preformatted text
But now you have been awarded Basic user badge, new user restrictions have been lifted
ALSA data shows 2 Modprobe options have been added to system
I suggest delete both modprobe options, reboot system and check unmodified ALSA data
I also suggest you consider updating system BIOS
ASUS Zenbook S 14 (UX5406) - BIOS & Firmware
Thanks so much @nikgnomic.
I did a BIOs update to UX5406SA.302, and removed the modprobe options. Please see the new output below:
https://alsa-project.org/db/?f=56dca2efa0d5e11974de7a9f78392563ce9b4927
It suggests me to install sof-firmware but it is already installed:
> pacman -Q | grep sof-firmware
sof-firmware 2024.06-1
Looking forward to hearing your suggestions!
Great news! I found a new version of sof-firmware released four days ago:
https://archlinux.org/packages/extra/x86_64/sof-firmware/
installing this gives me ability to hear.
I will mark your answer as solution as it helps pinning down this.
I have marked your post as the solution because I had not considered sof-firmware would help with this issue and I was not aware that a new version of package had been released
Previous generations of Zenbooks were patched in the kernel by ALSA developers so I was not expecting SOF drivers to provide full support for the onboard audio device and the smart amplifiers driving the speakers
Thanks @nikgnomic for your help! I learnt a lot!
