I can’t get manjaro to recognize my headphones that are plugged into a headphone jack, I’m running the 5.8 kernal
Please post the output of inxi -Fazy and pa-info.
inxi -Fazy
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=236f625f-27fc-4d97-a761-053d91806ac6 rw quiet apparmor=1
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FX505GT_FX505GT v: 1.0
serial: <filter>
Mobo: ASUSTeK model: FX505GT v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX505GT.307 date: 06/24/2020
ID-1: BAT0 charge: 46.7 Wh condition: 46.7/48.1 Wh (97%) volts: 12.8/11.7
model: Simplo SDI ICR18650 type: Li-ion serial: <filter> status: Full
cycles: 41
Topology: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: D6
L2 cache: 8192 KiB
bogomips: 38408
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:1f91
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-11:4 chip ID: 13d3:56a2 serial: <filter>
Display: wayland server: X.org 1.20.9 compositor: gnome-shell
driver: nouveau note: display driver n/a - try sudo/root display ID: 0
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10fa
Sound Server: ALSA v: k5.8.16-2-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
port: 5000 bus ID: 00:14.3 chip ID: 8086:a370
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus ID: 02:00.0
chip ID: 10ec:8168
Local Storage: total: 931.51 GiB used: 13.53 GiB (1.5%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM4 scheme: GPT
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus ID: 00:17.0 chip ID: 8086.282a rev: 10
ID-1: / raw size: 34.18 GiB size: 33.39 GiB (97.70%) used: 13.51 GiB (40.5%)
fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 51.0 C mobo: 27.8 C gpu: nouveau temp: 38 C
Fan Speeds (RPM): cpu: 2700
Processes: 250 Uptime: 22m Memory: 15.49 GiB used: 1.30 GiB (8.4%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1155 lib: 324
flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
pa-info
________________
> pulseaudio_ps_do
zakery 1515 0.0 0.0 1580636 12088 ? S<sl 08:40 0:00 /usr/bin/pulseaudio --daemonize=no
zakery 4735 0.0 0.0 3076 788 pts/0 S+ 09:02 0:00 grep pulseaudio
________________
> which pulseaudio
/usr/bin/pulseaudio
________________
> pidof pulseaudio
1515
________________
> pulseaudio --version
pulseaudio 13.0
________________
> pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 33
Server Protocol Version: 33
Is Local: yes
Client Index: 9
Tile Size: 65472
User Name: zakery
Host Name: ZaksLinuxInstall
Server Name: pulseaudio
Server Version: 13.0
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink
Default Source: alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__source
Cookie: 486a:4f05
________________
> pactl list
Module #0
Argument:
Usage counter: n/a
Properties:
module.author = “Lennart Poettering”
module.description = “Automatically restore the volume/mute state of devices”
module.version = “13.0”
Module #1
Argument:
Usage counter: n/a
Properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute/device state of streams"
module.version = "13.0"
Module #2
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore profile of cards"
Module #3
Argument:
Usage counter: n/a
Properties:
module.description = "Augment the property sets of streams with additional static information"
Module #4
Argument:
Usage counter: n/a
Properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
Module #5
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available audio hardware and load matching drivers"
Module #6
Argument: device_id="0" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 0
Properties:
module.description = "ALSA Card"
Module #7
Argument: device_id="1" name="pci-0000_00_1f.3-platform-skl_hda_dsp_generic" card_name="alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 0
Properties:
Module #8
Argument: channels=2
Usage counter: n/a
Properties:
module.description = "Adds JACK sink/source ports when JACK is started"
Module #9
Argument:
Usage counter: n/a
Properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
Module #10
Argument:
Usage counter: n/a
Properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Module #11
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Module #12
Argument:
Usage counter: n/a
Properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
Module #13
Argument:
Usage counter: n/a
Properties:
module.description = "Native protocol (UNIX sockets)"
Module #14
Argument:
Usage counter: n/a
Properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
Module #15
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the default sink and source"
Module #16
Argument:
Usage counter: n/a
Properties:
module.description = "When a sink/source is removed, try to move its streams to the default sink/source"
Module #17
Argument:
Usage counter: n/a
Properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #18
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically set device of streams based on intended roles of devices"
Module #19
Argument:
Usage counter: n/a
Properties:
module.description = "When a sink/source is idle for too long, suspend it"
Module #20
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each ConsoleKit session of this user"
Module #21
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each login session of this user"
Module #22
Argument:
Usage counter: n/a
Properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #23
Argument:
Usage counter: n/a
Properties:
module.description = "Mute & cork streams with certain roles while others exist"
Module #24
Argument:
Usage counter: n/a
Properties:
module.description = "Detect when various filters are desirable"
Module #25
Argument:
Usage counter: n/a
Properties:
module.description = "Load filter sinks automatically when needed"
Sink #0
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink
Description: Cannon Lake PCH cAVS HDMI3/DP3 Output
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 48000Hz
Owner Module: 7
Mute: no
Volume: front-left: 78640 / 120% / 4.75 dB, front-right: 78640 / 120% / 4.75 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = ""
alsa.id = "HDMI3 (*)"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "5"
alsa.card = "1"
alsa.card_name = "sof-hda-dsp"
alsa.long_card_name = "ASUSTeKCOMPUTERINC.-TUFGamingFX505GT_FX505GT-1.0-FX505GT"
alsa.driver_name = "snd_soc_skl_hda_dsp"
device.bus_path = "pci-0000:00:1f.3-platform-skl_hda_dsp_generic"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card1"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a348"
device.product.name = "Cannon Lake PCH cAVS"
device.string = "hw:sofhdadsp,5"
device.buffering.buffer_size = "65472"
device.buffering.fragment_size = "16320"
device.access_mode = "mmap+timer"
device.profile.name = "HiFi: hw:sofhdadsp,5: sink"
device.profile.description = "HDMI3/DP3 Output"
device.description = "Cannon Lake PCH cAVS HDMI3/DP3 Output"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Ports:
[Out] HDMI3: HDMI3/DP3 Output (priority: 700, not available)
Active Port: [Out] HDMI3
Formats:
pcm
Sink #1
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink
Description: Cannon Lake PCH cAVS HDMI2/DP2 Output
Owner Module: 7
Mute: no
Volume: front-left: 52422 / 80% / -5.82 dB, front-right: 52422 / 80% / -5.82 dB
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor
Properties:
device.api = "alsa"
alsa.name = ""
alsa.id = "HDMI2 (*)"
alsa.device = "4"
alsa.card = "1"
device.bus = "pci"
device.string = "hw:sofhdadsp,4"
device.profile.name = "HiFi: hw:sofhdadsp,4: sink"
device.profile.description = "HDMI2/DP2 Output"
device.description = "Cannon Lake PCH cAVS HDMI2/DP2 Output"
Ports:
[Out] HDMI2: HDMI2/DP2 Output (priority: 600, not available)
Active Port: [Out] HDMI2
Formats:
pcm
Sink #2
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink
Description: Cannon Lake PCH cAVS HDMI1/DP1 Output
Owner Module: 7
Mute: no
Volume: front-left: 58974 / 90% / -2.75 dB, front-right: 58974 / 90% / -2.75 dB
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor
Properties:
device.api = "alsa"
alsa.name = ""
alsa.id = "HDMI1 (*)"
alsa.device = "3"
alsa.card = "1"
device.bus = "pci"
device.string = "hw:sofhdadsp,3"
device.profile.name = "HiFi: hw:sofhdadsp,3: sink"
device.profile.description = "HDMI1/DP1 Output"
device.description = "Cannon Lake PCH cAVS HDMI1/DP1 Output"
Ports:
[Out] HDMI1: HDMI1/DP1 Output (priority: 500, not available)
Active Port: [Out] HDMI1
Formats:
pcm
Sink #3
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink
Description: Cannon Lake PCH cAVS Speaker + Headphones
Owner Module: 7
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor
Properties:
device.api = "alsa"
alsa.name = ""
alsa.id = "HDA Analog (*)"
alsa.device = "0"
alsa.card = "1"
device.bus = "pci"
device.string = "hw:sofhdadsp"
device.profile.name = "HiFi: hw:sofhdadsp: sink"
device.profile.description = "Speaker + Headphones"
device.description = "Cannon Lake PCH cAVS Speaker + Headphones"
Ports:
[Out] Speaker: Speaker (priority: 100)
[Out] Headphones: Headphones (priority: 200)
Active Port: [Out] Headphones
Formats:
pcm
Source #0
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor
Description: Monitor of Cannon Lake PCH cAVS HDMI3/DP3 Output
Owner Module: 7
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of Cannon Lake PCH cAVS HDMI3/DP3 Output"
device.class = "monitor"
alsa.card = "1"
device.bus = "pci"
device.string = "1"
Formats:
pcm
Source #1
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor
Description: Monitor of Cannon Lake PCH cAVS HDMI2/DP2 Output
Owner Module: 7
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink
Properties:
device.description = "Monitor of Cannon Lake PCH cAVS HDMI2/DP2 Output"
alsa.card = "1"
device.bus = "pci"
device.string = "1"
Formats:
pcm
Source #2
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor
Description: Monitor of Cannon Lake PCH cAVS HDMI1/DP1 Output
Owner Module: 7
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink
Properties:
device.description = "Monitor of Cannon Lake PCH cAVS HDMI1/DP1 Output"
alsa.card = "1"
device.bus = "pci"
device.string = "1"
Formats:
pcm
Source #3
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor
Description: Monitor of Cannon Lake PCH cAVS Speaker + Headphones
Owner Module: 7
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink
Properties:
device.description = "Monitor of Cannon Lake PCH cAVS Speaker + Headphones"
alsa.card = "1"
device.bus = "pci"
device.string = "1"
Formats:
pcm
Source #4
State: SUSPENDED
Name: alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__source
Description: Cannon Lake PCH cAVS Headphones Stereo Microphone
Owner Module: 7
Mute: no
balance 0.00
Monitor of Sink: n/a
Properties:
device.api = "alsa"
alsa.name = ""
alsa.device = "0"
alsa.card = "1"
device.bus = "pci"
device.profile.name = "HiFi: hw:sofhdadsp: source"
device.profile.description = "Headphones Stereo Microphone"
device.description = "Cannon Lake PCH cAVS Headphones Stereo Microphone"
Ports:
[In] Mic2: Headphones Stereo Microphone (priority: 200)
Active Port: [In] Mic2
Formats:
pcm
Source #5
State: SUSPENDED
Name: alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source
Description: Cannon Lake PCH cAVS Digital Microphone
Sample Specification: s16le 4ch 48000Hz
Channel Map: front-left,front-right,rear-left,rear-right
Owner Module: 7
Mute: no
Volume: front-left: 65531 / 100% / -0.00 dB, front-right: 65531 / 100% / -0.00 dB, rear-left: 65531 / 100% / -0.00 dB, rear-right: 65531 / 100% / -0.00 dB
balance 0.00
Properties:
device.api = "alsa"
alsa.name = ""
alsa.id = "DMIC (*)"
alsa.device = "6"
alsa.card = "1"
device.bus = "pci"
device.string = "hw:sofhdadsp,6"
device.profile.name = "HiFi: hw:sofhdadsp,6: source"
device.profile.description = "Digital Microphone"
device.description = "Cannon Lake PCH cAVS Digital Microphone"
Ports:
[In] Mic1: Digital Microphone (priority: 100)
Active Port: [In] Mic1
Formats:
pcm
Client #0
Driver: module-systemd-login.c
Owner Module: 21
Properties:
application.name = "Login Session 3"
systemd-login.session = "3"
Client #1
Driver: protocol-native.c
Owner Module: 13
Properties:
application.name = "GNOME Shell Volume Control"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "33"
application.id = "org.gnome.VolumeControl"
application.icon_name = "multimedia-volume-control"
application.version = "3.36.6"
application.process.id = "1531"
application.process.user = "zakery"
application.process.host = "ZaksLinuxInstall"
application.process.binary = "gnome-shell"
application.language = "en_CA.UTF-8"
window.x11.display = ":0"
application.process.machine_id = "880612d2d5294932a8155c93b63fcc64"
Client #2
Owner Module: 13
Properties:
application.name = "GNOME Volume Control Media Keys"
application.version = ""
application.process.id = "1726"
application.process.binary = "gsd-media-keys"
Client #3
Owner Module: 13
Properties:
application.name = "Firefox"
application.icon_name = "firefox"
application.version = "81.0.2"
application.process.id = "2307"
application.process.binary = "firefox"
Client #4
Owner Module: 13
Properties:
Client #10
Owner Module: 13
Properties:
application.name = "pactl"
application.process.id = "4740"
application.process.binary = "pactl"
application.language = "C"
Card #0
Owner Module: 6
Properties:
alsa.card = "0"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xa4080000 irq 17"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "10fa"
device.string = "0"
device.description = "HDA NVidia"
Profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: off
Ports:
hdmi-output-0: HDMI / DisplayPort (priority: 5900, latency offset: 0 usec, available)
Properties:
device.product.name = "S24C350"
Part of profile(s): output:hdmi-stereo
hdmi-output-1: HDMI / DisplayPort 2 (priority: 5800, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
hdmi-output-2: HDMI / DisplayPort 3 (priority: 5700, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (priority: 5600, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Card #1
Owner Module: 7
Properties:
alsa.card = "1"
device.bus = "pci"
device.string = "1"
device.description = "Cannon Lake PCH cAVS"
Profiles:
HiFi: Play HiFi quality Music (sinks: 4, sources: 2, priority: 8000, available: yes)
Active Profile: HiFi
Ports:
[Out] HDMI3: HDMI3/DP3 Output (priority: 700, latency offset: 0 usec, not available)
Part of profile(s): HiFi
[Out] HDMI2: HDMI2/DP2 Output (priority: 600, latency offset: 0 usec, not available)
[Out] HDMI1: HDMI1/DP1 Output (priority: 500, latency offset: 0 usec, not available)
[Out] Speaker: Speaker (priority: 100, latency offset: 0 usec)
[Out] Headphones: Headphones (priority: 200, latency offset: 0 usec)
[In] Mic2: Headphones Stereo Microphone (priority: 200, latency offset: 0 usec)
[In] Mic1: Digital Microphone (priority: 100, latency offset: 0 usec)
________________
> cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; enable-lfe-remixing = no
; lfe-crossover-freq = 0
flat-volumes = no
; flat-volumes = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
________________
> cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
________________
> cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Automatically move streams to the default sink if the sink they are
### connected to dies, similar for sources
load-module module-rescue-streams
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
________________
> cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
________________
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116, 11 Nov 3 08:40 /dev/snd/pcmC1D0c
crw-rw----+ 1 root audio 116, 8 Nov 3 08:40 /dev/snd/pcmC1D6c
crw-rw----+ 1 root audio 116, 10 Nov 3 08:40 /dev/snd/pcmC1D0p
crw-rw----+ 1 root audio 116, 14 Nov 3 08:40 /dev/snd/pcmC1D3p
crw-rw----+ 1 root audio 116, 15 Nov 3 08:40 /dev/snd/pcmC1D4p
crw-rw----+ 1 root audio 116, 16 Nov 3 08:40 /dev/snd/pcmC1D5p
crw-rw----+ 1 root audio 116, 2 Nov 3 08:40 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116, 1 Nov 3 08:40 /dev/snd/seq
crw-rw----+ 1 root audio 116, 5 Nov 3 08:40 /dev/snd/pcmC0D9p
crw-rw----+ 1 root audio 116, 4 Nov 3 08:40 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116, 3 Nov 3 08:40 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116, 18 Nov 3 08:38 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 17 Nov 3 08:38 /dev/snd/hwC1D2
crw-rw----+ 1 root audio 116, 13 Nov 3 08:38 /dev/snd/pcmC1D1c
crw-rw----+ 1 root audio 116, 12 Nov 3 08:38 /dev/snd/pcmC1D1p
crw-rw----+ 1 root audio 116, 19 Nov 3 08:38 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 9 Nov 3 08:38 /dev/snd/pcmC1D7c
crw-rw----+ 1 root audio 116, 7 Nov 3 08:38 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 6 Nov 3 08:38 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 33 Nov 3 08:38 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Nov 3 08:38 .
drwxr-xr-x 3 root root 460 Nov 3 08:38 ..
lrwxrwxrwx 1 root root 12 Nov 3 08:38 pci-0000:00:1f.3-platform-skl_hda_dsp_generic -> ../controlC1
lrwxrwxrwx 1 root root 12 Nov 3 08:38 pci-0000:01:00.1 -> ../controlC0
________________
> lsof /dev/snd/*
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
pulseaudi 1515 zakery 16u CHR 116,7 0t0 4009 /dev/snd/controlC0
pulseaudi 1515 zakery 17u CHR 116,19 0t0 16136 /dev/snd/controlC1
pulseaudi 1515 zakery 18u CHR 116,19 0t0 16136 /dev/snd/controlC1
pipewire 2101 zakery 28u CHR 116,1 0t0 15210 /dev/snd/seq
pipewire 2101 zakery 29u CHR 116,1 0t0 15210 /dev/snd/seq
pipewire- 2103 zakery 22u CHR 116,19 0t0 16136 /dev/snd/controlC1
pipewire- 2103 zakery 23u CHR 116,19 0t0 16136 /dev/snd/controlC1
pipewire- 2103 zakery 24u CHR 116,7 0t0 4009 /dev/snd/controlC0
________________
> jacks_do
card=0
numid=1,iface=CARD,name='HDMI/DP,pcm=3 Jack'
; type=BOOLEAN,access=r-------,values=1
: values=on
numid=7,iface=CARD,name='HDMI/DP,pcm=7 Jack'
: values=off
numid=13,iface=CARD,name='HDMI/DP,pcm=8 Jack'
: values=off
numid=19,iface=CARD,name='HDMI/DP,pcm=9 Jack'
: values=off
card=1
numid=13,iface=CARD,name='Front Headphone Jack'
: values=on
numid=15,iface=CARD,name='HDMI/DP,pcm=3 Jack'
: values=off
numid=21,iface=CARD,name='HDMI/DP,pcm=4 Jack'
: values=off
numid=27,iface=CARD,name='HDMI/DP,pcm=5 Jack'
: values=off
numid=12,iface=CARD,name='Mic Phantom Jack'
: values=on
numid=14,iface=CARD,name='Speaker Phantom Jack'
: values=on
________________
> aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 1
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
sysdefault:CARD=sofhdadsp
sof-hda-dsp,
Default Audio Device
usbstream:CARD=sofhdadsp
sof-hda-dsp
USB Stream Output
________________
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
HDA NVidia
USB Stream Output
sof-hda-dsp,
sof-hda-dsp
USB Stream Output
________________
> alsa_info_do
cat: '/sys/module/snd_soc_skl_hda_dsp/parameters/*': No such file or directory
dmesg: read kernel buffer failed: Operation not permitted
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Tue Nov 3 16:02:07 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: TUF Gaming FX505GT_FX505GT
Product Version: 1.0
Firmware Version: FX505GT.307
Board Vendor: ASUSTeK COMPUTER INC.
Board Name: FX505GT
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/ACPI000E:00/status 15
/sys/bus/acpi/devices/ASUS2018:00/status 15
/sys/bus/acpi/devices/ATK4002:00/status 15
/sys/bus/acpi/devices/ELAN1200:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT3400:00/status 15
/sys/bus/acpi/devices/INT3403:04/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT3450:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 15
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXPOWER:06/status 1
/sys/bus/acpi/devices/LNXPOWER:07/status 1
/sys/bus/acpi/devices/LNXPOWER:08/status 1
/sys/bus/acpi/devices/LNXPOWER:09/status 1
/sys/bus/acpi/devices/LNXPOWER:0b/status 1
/sys/bus/acpi/devices/MSFT0001:00/status 15
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C02:00/status 3
/sys/bus/acpi/devices/PNP0C02:03/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C04:00/status 31
/sys/bus/acpi/devices/PNP0C0A:03/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/PRP00001:00/status 11
/sys/bus/acpi/devices/XXXX0000:01/status 15
/sys/bus/acpi/devices/XXXX0000:03/status 15
/sys/bus/acpi/devices/XXXX0000:05/status 15
/sys/bus/acpi/devices/device:11/status 15
!!Kernel Information
Kernel release: 5.8.16-2-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.8.16-2-MANJARO
Library version: 1.2.3.2
Utilities version: 1.2.3
!!Loaded ALSA modules
snd_hda_intel
snd_soc_skl_hda_dsp
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [NVidia ]: HDA-Intel - HDA NVidia
1 [sofhdadsp ]: sof-hda-dsp - sof-hda-dsp
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10) (prog-if 80)
DeviceName: Onboard - Sound
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:10fa] (rev a1)
Subsystem: ASUSTeK Computer Inc. Device [1043:1ab1]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
!!Module: snd_soc_skl_hda_dsp
!!HDA-Intel Codec information
--startcollapse--
Codec: Nvidia GPU 94 HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10de0094
Subsystem Id: 0x10431ab1
Revision Id: 0x100100
No Modem Function Group found
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Devices: 4
Dev 00: PD = 1, ELDV = 1, IA = 0
Dev 01: PD = 0, ELDV = 0, IA = 0
Dev 02: PD = 0, ELDV = 0, IA = 0
*Dev 03: PD = 0, ELDV = 0, IA = 0
Connection: 4
0x08* 0x09 0x0a 0x0b
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 4
*Dev 00: PD = 0, ELDV = 0, IA = 0
Connection: 4
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Devices: 4
Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Devices: 4
Connection: 4
Node 0x08 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Converter: stream=0, channel=0
Digital: Enabled
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0xe]: 16 20 24
formats [0x5]: PCM AC3
Node 0x09 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Codec: Realtek ALC233
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0235
Revision Id: 0x100002
Default PCM:
rates [0x560]: 44100 48000 96000 192000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 D3cold CLKSTOP EPSS
GPIO: io=3, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Speaker Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x00 0x00]
PCM:
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
PCM:
formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x80 0x80]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In vals: [0x97 0x97]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 5
0x18 0x19 0x1a 0x1b 0x1d
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x03 0x0b
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Audio Mixer] wcaps 0x20010a: Mono Amp-In
Connection: 1
0x0d
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Control: name="Mic Boost Volume", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Pincap 0x00000020: IN
Pin Default 0x90a60130: [Fixed] Mic at Int N/A
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Speaker Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x80 0x80]
Pincap 0x00010014: OUT EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x90170110: [Fixed] Speaker at Int N/A
Conn = Analog, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x0c
Node 0x15 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x16 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x17 [Pin Complex] wcaps 0x40050c: Mono Amp-Out
Amp-Out vals: [0x80]
Pincap 0x00000010: OUT
Pin Default 0x40000000: [N/A] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x00:
Connection: 1
0x0f
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Pincap 0x00003724: IN Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN VREF_HIZ
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Misc = NO_PRESENCE
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Misc = NO_PRESENCE
Pin-ctls: 0x00: VREF_HIZ
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pincap 0x0001373c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Connection: 2
0x0c* 0x0d
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x40e59a05: [N/A] Reserved at Ext N/A
Conn = Optical, Color = Pink
DefAssociation = 0x0, Sequence = 0x5
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
Pincap 0x00000014: OUT Detect
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=76
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x02211020: [Jack] HP Out at Ext Front
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 2
0x0c 0x0d*
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 6
0x18 0x19 0x1a 0x1b 0x1d 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x00 0x00]
Connection: 7
0x18 0x19 0x1a 0x1b 0x1d 0x0b 0x12
Codec: Intel Kabylake HDMI
Address: 2
Vendor Id: 0x8086280b
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled KAE
PCM:
bits [0x1a]: 16 24 32
Power states: D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-path:
total 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: sofhdadsp [sof-hda-dsp], device 0: HDA Analog (*) []
Subdevices: 1/1
card 1: sofhdadsp [sof-hda-dsp], device 1: HDA Digital (*) []
Subdevices: 1/1
card 1: sofhdadsp [sof-hda-dsp], device 3: HDMI1 (*) []
Subdevices: 1/1
card 1: sofhdadsp [sof-hda-dsp], device 4: HDMI2 (*) []
Subdevices: 1/1
card 1: sofhdadsp [sof-hda-dsp], device 5: HDMI3 (*) []
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
Subdevices: 1/1
card 1: sofhdadsp [sof-hda-dsp], device 6: DMIC (*) []
Subdevices: 1/1
card 1: sofhdadsp [sof-hda-dsp], device 7: DMIC16kHz (*) []
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card NVidia
Card hw:0 'NVidia'/'HDA NVidia at 0xa4080000 irq 17'
Mixer name : 'Nvidia GPU 94 HDMI/DP'
Components : 'HDA:10de0094,10431ab1,00100100'
Controls : 28
Simple ctrls : 4
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
!!-------Mixer controls for card sofhdadsp
Card hw:1 'sofhdadsp'/'ASUSTeKCOMPUTERINC.-TUFGamingFX505GT_FX505GT-1.0-FX505GT'
Mixer name : 'Realtek ALC233'
Components : 'HDA:8086280b,80860101,00100000 HDA:10ec0235,10431ab1,00100002 cfg-dmics:4'
Controls : 49
Simple ctrls : 19
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Limits: Playback 0 - 87
Mono: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
Mono:
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Dmic0',0
Limits: Capture 0 - 70
Front Left: Capture 50 [71%] [0.00dB] [on]
Front Right: Capture 50 [71%] [0.00dB] [on]
Simple mixer control 'Dmic1 2nd',0
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'PGA1.0 1 Master',0
Limits: Playback 0 - 32
Mono:
Front Left: Playback 32 [100%] [0.00dB]
Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA2.0 2 Master',0
Limits: Capture 0 - 80
Front Left: Capture 50 [62%] [0.00dB]
Front Right: Capture 50 [62%] [0.00dB]
Simple mixer control 'PGA3.0 3 Master',0
Mono:
Simple mixer control 'PGA4.0 4 Master',0
Simple mixer control 'PGA7.0 7 Master',0
Mono:
Simple mixer control 'PGA8.0 8 Master',0
Mono:
Simple mixer control 'PGA9.0 9 Master',0
Mono:
!!Alsactl output
--startcollapse--
state.NVidia {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value '100007006712000100000000000000004c2d3c0a533234433335300907070000'
comment {
access 'read volatile'
type BYTES
count 32
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface PCM
device 3
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.26 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.27 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.28 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
state.sofhdadsp {
control.1 {
iface MIXER
name 'Headphone Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Auto-Mute Mode'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.7 {
iface MIXER
name 'Capture Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 -1725
dbvalue.1 -1725
control.8 {
iface MIXER
name 'Capture Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.9 {
iface MIXER
name 'Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
name 'Master Playback Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
control.11 {
iface MIXER
name 'Master Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface CARD
name 'Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.13 {
iface CARD
name 'Front Headphone Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.14 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.15 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.16 {
iface MIXER
comment {
access read
type IEC958
count 1
control.17 {
iface MIXER
comment {
access read
type IEC958
count 1
control.18 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.19 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.20 {
iface PCM
device 3
name ELD
value ''
comment {
type BYTES
count 0
control.21 {
iface CARD
name 'HDMI/DP,pcm=4 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.22 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.23 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.24 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.25 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.26 {
iface PCM
device 4
name ELD
value ''
comment {
type BYTES
count 0
control.27 {
iface CARD
name 'HDMI/DP,pcm=5 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.28 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.29 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.30 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.31 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.32 {
iface PCM
device 5
name ELD
value ''
comment {
type BYTES
count 0
control.33 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.34 {
iface PCM
device 4
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.35 {
iface PCM
device 5
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.36 {
iface MIXER
name 'PGA1.0 1 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.37 {
iface MIXER
name 'PGA2.0 2 Master Capture Volume'
value.0 50
value.1 50
comment {
access 'read write'
type INTEGER
count 2
range '0 - 80'
dbmin -9999999
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.39 {
iface MIXER
name 'PGA3.0 3 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.40 {
iface MIXER
name 'PGA4.0 4 Master Capture Volume'
value.0 50
value.1 50
comment {
access 'read write'
type INTEGER
count 2
range '0 - 80'
dbmin -9999999
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.42 {
iface MIXER
name 'PGA7.0 7 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.43 {
iface MIXER
name 'PGA8.0 8 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.44 {
iface MIXER
name 'PGA9.0 9 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.45 {
iface MIXER
name 'Dmic0 Capture Volume'
value.0 50
value.1 50
comment {
access 'read write'
type INTEGER
count 2
range '0 - 70'
dbmin -9999999
dbmax 2000
dbvalue.0 0
dbvalue.1 0
control.46 {
iface MIXER
name 'Dmic0 Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.48 {
iface MIXER
name 'Dmic1 2nd Capture Volume'
value.0 50
value.1 50
comment {
access 'read write'
type INTEGER
count 2
range '0 - 70'
dbmin -9999999
dbmax 2000
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
8250_dw
ac
ac97_bus
acpi_tad
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
asus_nb_wmi
asus_wireless
asus_wmi
atkbd
battery
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cec
cfg80211
cmac
cmdlinepart
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
ee1004
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
i2c_algo_bit
i2c_hid
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
input_leds
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_spi
intel_spi_pci
intel_uncore
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libphy
libps2
loop
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mousedev
mtd
mxm_wmi
nls_cp437
nls_iso8859_1
nouveau
ofpart
pcspkr
processor_thermal_device
r8169
rapl
rc_core
realtek
rfcomm
rfkill
rng_core
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_dmic
snd_soc_hdac_hda
snd_soc_hdac_hdmi
snd_soc_skl
snd_soc_skl_hda_dsp
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_byt
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_intel_ipc
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soundcore
sparse_keymap
spi_nor
squashfs
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
ttm
uinput
usbhid
uvcvideo
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x04 0x185600f0
0x05 0x585600f0
0x06 0x585600f0
0x07 0x585600f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x12 0x90a60130
0x14 0x90170110
0x17 0x40000000
0x18 0x411111f0
0x19 0x411111f0
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40e59a05
0x1e 0x411111f0
0x21 0x02211020
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
/sys/class/sound/hwC1D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC1D2/driver_pin_configs:
/sys/class/sound/hwC1D2/user_pin_configs:
/sys/class/sound/hwC1D2/init_verbs:
/sys/class/sound/hwC1D2/hints:
!!ALSA/HDA dmesg
I have had the same problem with pulseaudio 13.99.3-1 on the 5.4.74-1 kernel. My external speaker connected to the audio jack was not properly detected. I ended up downgrading pulseaudio and every pulse package that depended on that pulseaudio version to version 13.0-3 from the Arch Linux Archive using the downgrade utility. (Downgrading is described here. Unfortunately, I may not add links, so the space needs to be removed: wiki.manjaro. org/index.php?title=Downgrading_packages)
Obviously, this is not a permanent fix but it might help until an upstream fix is available.
This leads me to believe that it is recognized. Why do you think it is not?
Your system has PulseAudio v13.0
Suggest you update your system to get PulseAudio v13.99
(new version was included in latest update release 2020-11-04)
Onboard audio device Cannon Lake PCH has a digital microphone array (dmic)
System appears to have package sof-firmware installed to support the dmic
PulseAudio v13.99 has been patched to support new Sound Open Firmware drivers
