Hi,
since last update today, i have no longer sound when using chromium (111.0.5563.64 (Offizieller Build) Arch Linux (64-Bit)).
VLC, Firefox, Opera and Vivaldi don’t have this problem - KDE sounds are also working.
Steps:
- Open chromium, play vid on YouTube - no sound
- pavucontrol shows chromium playing on the correct sound device
- restarting pulseaudio with
pulseaudio -korsystemctl --user restart pulseaudio.servicebrings back the sound immediately - close chromium, open again, play YT vid → sound gone again
- goto 4 - sound works again.
What i have tried so far:
sudo pacman-mirrors -f && sudo pacman -Syyu
already actual - so no change
rm -rf ~/.config/pulse and restart → no change
inxi -A (ASUSTek Xonar U7 MKII is main output)
Device-1: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
Device-2: AMD Family 17h/19h HD Audio driver: snd_hda_intel
Device-3: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: cmedia_hs100b,snd-usb-audio,usbhid
Device-4: Razer USA Kraken Tournament Edition type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-5: ASUSTek Xonar U7 MKII type: USB
Sound API: ALSA v: k6.2.2-1-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: yes
Sound Server-2: PipeWire v: 0.3.66 running: yes
pulseaudio --version:
pulseaudio 16.1
systemctl --user status pulseaudio.service pulseaudio.socket
● pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; preset: enabled)
Active: active (running) since Thu 2023-03-09 08:10:09 CET; 1min 50s ago
TriggeredBy: ● pulseaudio.socket
Main PID: 5136 (pulseaudio)
Tasks: 10 (limit: 67379)
Memory: 21.3M
CPU: 4.524s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulseaudio.service
├─5136 /usr/bin/pulseaudio --daemonize=no --log-target=journal
└─5169 /usr/lib/pulse/gsettings-helper
Mär 09 08:10:07 sal9000 systemd[1430]: Starting Sound Service...
Mär 09 08:10:09 sal9000 pulseaudio[5136]: Failed to find a working profile.
Mär 09 08:10:09 sal9000 pulseaudio[5136]: Failed to load module "module-alsa-card" (argument: "device_id="0" name="pci-0000_04_00.6" card_name="alsa_card.pci-0000_04_00.6" namereg_fail=false tsched=yes fixed_latency_ra>
Mär 09 08:10:09 sal9000 pulseaudio[5136]: stat('/etc/pulse/default.pa.d'): Datei oder Verzeichnis nicht gefunden
Mär 09 08:10:09 sal9000 systemd[1430]: Started Sound Service.
Mär 09 08:10:09 sal9000 pulseaudio[5136]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
● pulseaudio.socket - Sound System
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.socket; enabled; preset: enabled)
Active: active (running) since Thu 2023-03-09 07:53:23 CET; 18min ago
Triggers: ● pulseaudio.service
Listen: /run/user/1000/pulse/native (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pulseaudio.socket
Mär 09 07:53:23 sal9000 systemd[1430]: Listening on Sound System.
uname -a
Linux sal9000 6.2.2-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri Mar 3 14:53:59 UTC 2023 x86_64 GNU/Linux
I’m on testing branch since 2020 and never had any problems - i configured this somewhen during the pandemic - it worked right out of the box so i never touched the sound stuff again.
any clue?
thanks in advance!
