Chromium without sound after recent update
Similar to No sound in chromium since last updates (2023-03-08/09) I don’t have sound on Chromium, but the system sound is working fine, and Firefox is also working with sound.
What can I do to fix this issue? The update also broke my webcam on Chromium, but I think this deserves a separate thread.
Any help is appreciated.
Please post more information about system and audio sub-system:
inxi -SMAaz
and check the audio stream from chromium:
  Kernel: 5.15.197-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=29be3570-21c7-4c44-8f3a-4926cb8bc6e5 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
  Type: Desktop Mobo: ASUSTeK model: TUF B360M-PLUS GAMING/BR v: Rev X.0x
    serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
    Firmware: UEFI vendor: American Megatrends v: 2811 date: 05/27/2020
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
    bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
  Device-3: Lenovo FHD Webcam driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 17ef:4831
    class-ID: 0102 serial: <filter>
  API: ALSA v: k5.15.197-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-98-gb096 status: active with: pulseaudio-alsa
The second command pactl list sink-inputs did not produce output.
I fixed the version of the kernel years ago to avoid recurring issues after Manjaro updates.
Nevermind! Somehow I must have pressed some KDE shortcut that muted the Chromium application. And this setting was permanent after multiple reboots.
I saw the “muted phone” icon in the top right corner of the Chromium icon opened in the bottom KDE bar. Clicked it and the sound is back again.
Sorry for the noise.
