Hello,
I just installed Manjaro XFCE, but there is no sound from the speakers.
Could you please help me to fix it? Thanks a lot!
I’ve updated the kernel, but still no luck.
My output from inxi -Fazy:
Kernel: 6.0.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=c521deca-e92a-4069-b8f3-c73c56d83140 rw quiet apparmor=1
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop Mobo: N/A model: N/A serial: <superuser required>
UEFI: American Megatrends v: FW-BI-14.1-S8_G_116R300-E50A-020-A
date: 09/20/2022
ID-1: BAT0 charge: 15.2 Wh (51.9%) condition: 29.3/N/A Wh volts: 7.7 min: N/A
model: N/A type: Unknown serial: <filter> status: charging
Info: model: Intel Celeron J4105 bits: 64 type: MCP arch: Goldmont Plus
level: v2 built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122)
stepping: 1 microcode: 0x3C
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2049 high: 2503 min/max: 800/2500 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2396 2: 2503 3: 800
4: 2500 bogomips: 11984
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:3185
class-ID: 0300
Device-2: Generic HD camera type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 1902:8301 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0868 built: 2019 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: sof-audio-pci-intel-apl
alternate: snd_hda_intel,snd_soc_skl,snd_soc_avs,snd_sof_pci_intel_apl
bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0401
Sound API: ALSA v: k6.0.6-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-7:2 chip-ID: 0bda:c821 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 238.47 GiB used: 32 GiB (13.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Big Reservoir model: BR 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 6313 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%) used: 32 GiB (13.7%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 208 Uptime: 0m wakeups: 1 Memory: 5.63 GiB used: 1.12 GiB (19.9%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1298 libs: 392
tools: pamac,yay pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.23
output from pacmd dump:
pacmd dump
### Configuration dump generated at Sun Nov 13 13:50:39 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_00_0e.0-platform-sof-essx8336" card_name="alsa_card.pci-0000_00_0e.0-platform-sof-essx8336" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0.0 xauthority=/home/kunkun/.Xauthority
load-module module-x11-xsmp display=:0.0 xauthority=/home/kunkun/.Xauthority session_manager=local/cleverkunkun-laptop:@/tmp/.ICE-unix/901,unix/cleverkunkun-laptop:/tmp/.ICE-unix/901
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_0e.0-platform-sof-essx8336.stereo-fallback 0x10000
set-sink-mute alsa_output.pci-0000_00_0e.0-platform-sof-essx8336.stereo-fallback no
suspend-sink alsa_output.pci-0000_00_0e.0-platform-sof-essx8336.stereo-fallback yes
set-source-volume alsa_output.pci-0000_00_0e.0-platform-sof-essx8336.stereo-fallback.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_0e.0-platform-sof-essx8336.stereo-fallback.monitor no
suspend-source alsa_output.pci-0000_00_0e.0-platform-sof-essx8336.stereo-fallback.monitor yes
set-card-profile alsa_card.pci-0000_00_0e.0-platform-sof-essx8336 output:stereo-fallback
set-default-sink alsa_output.pci-0000_00_0e.0-platform-sof-essx8336.stereo-fallback
set-default-source alsa_output.pci-0000_00_0e.0-platform-sof-essx8336.stereo-fallback.monitor
### EOF
output from amixer --card=0:
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch pswitch-joined
Limits: Playback 0 - 3
Mono:
Front Left: Playback 0 [0%] [-48.00dB] [off]
Front Right: Playback 0 [0%] [-48.00dB] [off]
Simple mixer control 'Headphone Mixer',0
Capabilities: volume
Limits: 0 - 11
Front Left: 11 [100%] [0.00dB]
Front Right: 11 [100%] [0.00dB]
Simple mixer control 'Speaker',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'Mic Boost',0
Mono: Playback [on]
Simple mixer control 'IEC958',0
Mono: Playback [off]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'Playback Polarity',0
Capabilities: enum
Items: 'Normal' 'R Invert' 'L Invert' 'L + R Invert'
Item0: 'Normal'
Simple mixer control 'Capture Polarity',0
Capabilities: enum
Items: 'Normal' 'Invert'
Item0: 'Normal'
Simple mixer control 'ADC',0
Capabilities: cvolume cvolume-joined
Capture channels: Mono
Limits: Capture 0 - 192
Mono: Capture 115 [60%] [-38.50dB]
Simple mixer control 'ADC Double Fs',0
Simple mixer control 'ADC PGA Gain',0
Capabilities: volume volume-joined
Limits: 0 - 10
Mono: 0 [0%] [-3.50dB]
Simple mixer control 'ADC Soft Ramp',0
Mono: Playback [on]
Simple mixer control 'ALC',0
Capabilities: cswitch cswitch-joined
Mono: Capture [off]
Simple mixer control 'ALC Capture Attack Time',0
Limits: 0 - 10
Mono: 2 [20%]
Simple mixer control 'ALC Capture Decay Time',0
Limits: 0 - 10
Mono: 3 [30%]
Simple mixer control 'ALC Capture Hold Time',0
Limits: 0 - 10
Mono: 0 [0%]
Simple mixer control 'ALC Capture Max',0
Limits: 0 - 28
Mono: 28 [100%] [35.50dB]
Simple mixer control 'ALC Capture Min',0
Limits: 0 - 28
Mono: 0 [0%] [-12.00dB]
Simple mixer control 'ALC Capture Noise Gate',0
Simple mixer control 'ALC Capture Noise Gate Threshold',0
Limits: 0 - 31
Mono: 0 [0%]
Simple mixer control 'ALC Capture Noise Gate Type',0
Capabilities: enum
Items: 'Constant PGA Gain' 'Mute ADC Output'
Item0: 'Constant PGA Gain'
Simple mixer control 'ALC Capture Target',0
Limits: 0 - 10
Mono: 11 [110%] [0.00dB]
Simple mixer control 'DAC',0
Limits: Playback 0 - 192
Mono:
Front Left: Playback 115 [60%] [-38.50dB]
Front Right: Playback 115 [60%] [-38.50dB]
Simple mixer control 'DAC Double Fs',0
Simple mixer control 'DAC Mono Mix',0
Simple mixer control 'DAC Notch Filter',0
Simple mixer control 'DAC Soft Ramp',0
Simple mixer control 'DAC Soft Ramp Rate',0
Limits: 0 - 4
Mono: 4 [100%]
Simple mixer control 'DAC Source Mux',0
Capabilities: enum
Items: 'LDATA TO LDAC, RDATA TO RDAC' 'LDATA TO LDAC, LDATA TO RDAC' 'RDATA TO LDAC, RDATA TO RDAC' 'RDATA TO LDAC, LDATA TO RDAC'
Item0: 'LDATA TO LDAC, RDATA TO RDAC'
Simple mixer control 'DAC Stereo Enhancement',0
Limits: 0 - 7
Mono: 0 [0%]
Simple mixer control 'Differential Mux',0
Capabilities: enum
Items: 'lin1-rin1' 'lin2-rin2' 'lin1-rin1 with 20db Boost' 'lin2-rin2 with 20db Boost'
Item0: 'lin1-rin1'
Simple mixer control 'Digital Mic Mux',0
Capabilities: enum
Items: 'dmic disable' 'dmic data at high level' 'dmic data at low level'
Item0: 'dmic disable'
Simple mixer control 'Headset Mic',0
Simple mixer control 'Internal Mic',0
Mono: Playback [on]
Simple mixer control 'Left Headphone Mixer LLIN',0
Simple mixer control 'Left Headphone Mixer Left DAC',0
Mono: Playback [on]
Simple mixer control 'Left Headphone Mux',0
Capabilities: enum
Items: 'lin1-rin1' 'lin2-rin2' 'lin-rin with Boost' 'lin-rin with Boost and PGA'
Item0: 'lin1-rin1'
Simple mixer control 'PGA1.0 1 Master',0
Limits: Playback 0 - 32
Mono:
Front Left: Playback 32 [100%] [0.00dB]
Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA2.0 2 PCM 0',0
Limits: Capture 0 - 40
Front Left: Capture 32 [80%] [0.00dB]
Front Right: Capture 32 [80%] [0.00dB]
Simple mixer control 'PGA5.0 5 Master',0
Mono:
Simple mixer control 'PGA6.0 6 Master',0
Mono:
Simple mixer control 'PGA7.0 7 Master',0
Mono:
Simple mixer control 'Right Headphone Mixer RLIN',0
Simple mixer control 'Right Headphone Mixer Right DAC',0
Mono: Playback [on]
Simple mixer control 'Right Headphone Mux',0
Capabilities: enum
Item0: 'lin1-rin1'
