Hi everyone,
Trying to work through non-responsive sound issues with a new installation of Manjaro Gnome on a Gemini Lake Chuwi Hi10 X. Have been unable to resolve despite consulting the various similar posts here and elsewhere.
So here we go again… Sound Settings and Pulse Audio Volume Control show “Dummy Output” as the only available Output Device which yields no sound, but the meter in the Settings > Sound window can show sound activity. Also, no microphone or input device is available there.
A system update was done through the terminal, running the latest LTS Kernel 5.15, as well as installing the sof-firmware and manjaro-pipewire packages. Alsamixer in the terminal sees the card as sof-hda-dsp Intel Geminilake HDMI, and all channels are unmuted. Additionally, used nano to append snd_intel_dspcfg.dsp_driver=1 then alternatively snd_hda_intel.dmic_detect=0 to GRUB_CMDLINE_LINUX_DEFAULT and updated grub, but did nothing.
Please advise! If you solved this or a similar problem, what did you do? Or is it the case that this onboard audio is simply unsupported hardware right now?
Thanks!
Here is the system information–
inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=c964ede2-b58c-41ff-8262-a6471ce43481 rw quiet splash apparmor=1
security=apparmor resume=UUID=bd2505f5-0123-4cfa-8711-78c86e5729aa
udev.log_priority=3
Desktop: GNOME 41.4 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Detachable System: CHUWI Innovation And (ShenZhen) product: Hi10 X
v: N/A serial: <superuser required>
Mobo: N/A model: N/A serial: <superuser required>
UEFI: American Megatrends v: ZW-BI-101-S101GWR210-GH86B-068-E
date: 12/06/2021
ID-1: BAT0 charge: 27.4 Wh (100.0%) condition: 27.4/N/A Wh volts: 8.7
min: N/A model: GLK MRD Li-ion Battery type: Li-ion serial: <filter>
status: Charging
RAM: total: 5.61 GiB used: 2.45 GiB (43.6%)
RAM Report:
Info: model: Intel Celeron N4120 bits: 64 type: MCP arch: Goldmont Plus
family: 6 model-id: 0x7A (122) stepping: 8 microcode: 0x1C
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2132 high: 2423 min/max: 800/2600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2005 2: 1697 3: 2423
4: 2406 bogomips: 8756
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
flexpriority fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt
lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
nopl nx pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse
pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vme vmx vnmi vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel ports:
active: DSI-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3185
class-ID: 0300
Device-2: Realtek Front Camera type: USB driver: uvcvideo bus-ID: 1-5:5
chip-ID: 0bda:5842 class-ID: 0e02 serial: <filter>
Device-3: Realtek Back Camera type: USB driver: uvcvideo bus-ID: 1-6:6
chip-ID: 0bda:5876 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: gnome-shell driver: gpu: i915 display-ID: 0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-size: <missing: xdpyinfo>
Monitor-1: XWAYLAND0 mapped: DSI-1 res: 1920x1200 hz: 60 dpi: 225
size: 217x135mm (8.5x5.3") modes: 1200x1920
Message: Wayland GBM/EGL data currently not available.
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: sof-audio-pci-intel-apl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0401
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-7:7 chip-ID: 0bda:c821 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 115.31 GiB used: 12 GiB (10.4%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: BIWIN model: N/A
size: 115.31 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0x8 scheme: GPT
ID-1: / raw-size: 106.22 GiB size: 103.99 GiB (97.90%) used: 12 GiB (11.5%)
fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2 label: N/A
uuid: c964ede2-b58c-41ff-8262-a6471ce43481
used: 288 KiB (0.1%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
label: NO_LABEL uuid: D6C6-6280
dev: /dev/mmcblk0p3 maj-min: 179:3 label: swap
uuid: bd2505f5-0123-4cfa-8711-78c86e5729aa
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-3.1:4 info: SiGma Micro Touchpad (integrated in detachable
keyboard of Chuwi SurBook)
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 98mA chip-ID: 1c4f:0063 class-ID: 0300
Device-2: 1-4:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-3: 1-5:5 info: Realtek Front Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:5842
Device-4: 1-6:6 info: Realtek Back Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:5876
Device-5: 1-7:7 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-3: 2-0:1 info: Super-speed hub ports: 7 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 222 Uptime: 11m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 Packages: pacman: 1244 lib: 312 flatpak: 0 Shell: Zsh
v: 5.8.1 running-in: gnome-terminal inxi: 3.3.13
aplay --list-pcm
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
usbstream:CARD=sofhdadsp
sof-hda-dsp
USB Stream Output
alsactl init
Found hardware: "sof-hda-dsp" "Intel Geminilake HDMI" "HDA:8086280d,80860101,00100000" "" ""
Hardware is initialized using a generic method
alsa-info.sh
!!ALSA Information Script v 0.5.1
!!Script ran on: Thu Mar 3 15:12:30 UTC 2022
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: CHUWI Innovation And Technology(ShenZhen)co.,Ltd
Product Name: Hi10 X
Product Version: Default string
Firmware Version: ZW-BI-101-S101GWR210-GH86B-068-E
System SKU: Default string
Board Vendor: Default string
Board Name: Default string
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/ESSX8336:00/status 15
/sys/bus/acpi/devices/GXTP7386:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT33D5:00/status 15
/sys/bus/acpi/devices/INT3400:00/status 15
/sys/bus/acpi/devices/INT3403:04/status 15
/sys/bus/acpi/devices/INT3453:00/status 15
/sys/bus/acpi/devices/INT3453:01/status 15
/sys/bus/acpi/devices/INT3453:02/status 15
/sys/bus/acpi/devices/INT3453:03/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXPOWER:06/status 1
/sys/bus/acpi/devices/LNXPOWER:07/status 15
/sys/bus/acpi/devices/MSFT0001:00/status 15
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/MXC6655:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C09:00/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0D:00/status 15
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/device:01/status 15
/sys/bus/acpi/devices/device:09/status 15
/sys/bus/acpi/devices/device:0a/status 15
/sys/bus/acpi/devices/device:0d/status 15
!!Kernel Information
Kernel release: 5.15.25-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.15.25-1-MANJARO
Library version: 1.2.6.1
Utilities version: 1.2.6
!!Loaded ALSA modules
snd_soc_skl_hda_dsp (card 0)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [sofhdadsp ]: sof-hda-dsp - sof-hda-dsp
Defaultstring-Hi10X-Defaultstring-Defaultstring
!!PCI Soundcards installed in the system
00:0e.0 Multimedia audio controller [0401]: Intel Corporation Celeron/Pentium Silver Processor High Definition Audio [8086:3198] (rev 06)
DeviceName: Onboard - Sound
!!Loaded sound module options
!!Module: snd_soc_skl_hda_dsp
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/platform/drivers/skl_hda_dsp_generic
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Intel Geminilake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280d
Subsystem Id: 0x80860101
Revision Id: 0x100000
No Modem Function Group found
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Converter: stream=0, channel=0
Digital: Enabled KAE
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
formats [0x5]: PCM AC3
Power states: D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Devices: 0
Connection: 0
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 6 Mar 3 09:09 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 5 Mar 3 09:09 /dev/snd/hwC0D2
crw-rw---- 1 root audio 116, 2 Mar 3 09:09 /dev/snd/pcmC0D1p
crw-rw---- 1 root audio 116, 3 Mar 3 09:09 /dev/snd/pcmC0D2p
crw-rw---- 1 root audio 116, 4 Mar 3 09:09 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116, 1 Mar 3 09:09 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Mar 3 09:09 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Mar 3 09:09 .
drwxr-xr-x 3 root root 200 Mar 3 09:09 ..
lrwxrwxrwx 1 root root 12 Mar 3 09:09 pci-0000:00:0e.0-platform-skl_hda_dsp_generic -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: sofhdadsp [sof-hda-dsp], device 1: HDMI1 (*) []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: sofhdadsp [sof-hda-dsp], device 2: HDMI2 (*) []
Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 3: HDMI3 (*) []
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
!!Amixer output
!!-------Mixer controls for card sofhdadsp
Card sysdefault:0 'sofhdadsp'/'Defaultstring-Hi10X-Defaultstring-Defaultstring'
Mixer name : 'Intel Geminilake HDMI'
Components : 'HDA:8086280d,80860101,00100000'
Controls : 24
Simple ctrls : 6
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'PGA2.0 2 Master',0
Capabilities: pvolume
Limits: Playback 0 - 32
Mono:
Front Left: Playback 32 [100%] [0.00dB]
Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA3.0 3 Master',0
Mono:
Simple mixer control 'PGA4.0 4 Master',0
Mono:
!!Alsactl output
--startcollapse--
state.sofhdadsp {
control.1 {
iface CARD
name 'HDMI/DP,pcm=1 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 1
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=2 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 2
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 3
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface PCM
device 1
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.20 {
iface PCM
device 2
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.21 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.22 {
iface MIXER
name 'PGA2.0 2 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.23 {
iface MIXER
name 'PGA3.0 3 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.24 {
iface MIXER
name 'PGA4.0 4 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
8250_dw
ac97_bus
acpi_thermal_rel
aesni_intel
af_alg
algif_hash
algif_skcipher
atkbd
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cfg80211
cmac
coretemp
cqhci
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dw_dmac
ecdh_generic
ext4
fat
fuse
ghash_clmulni_intel
hid_multitouch
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_smbus
i8042
i915
idma64
industrialio
industrialio_triggered_buffer
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_hid
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_powerclamp
intel_punit_ipc
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_telemetry_core
intel_telemetry_pltdrv
ip_tables
ipmi_devintf
ipmi_msghandler
irqbypass
jbd2
joydev
kfifo_buf
kvm
kvm_intel
ledtrig_audio
libarc4
libps2
loop
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
memstick
mmc_block
mmc_core
mousedev
mxc4005
ns
pcspkr
processor_thermal_device
processor_thermal_device_pci_legacy
processor_thermal_mbox
processor_thermal_rapl
processor_thermal_rfim
qrtr
rapl
rfcomm
rfkill
rng_core
rtsx_usb
rtsx_usb_ms
rtsx_usb_sdmmc
rtw88_8821c
rtw88_8821ce
rtw88_core
rtw88_pci
sdhci
sdhci_pci
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_dmic
snd_soc_hdac_hda
snd_soc_hdac_hdmi
snd_soc_intel_hda_dsp_common
snd_soc_skl
snd_soc_skl_hda_dsp
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soc_button_array
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_pxa2xx_platform
squashfs
tpm
tpm_crb
tpm_tis
tpm_tis_core
ttm
usbhid
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wdat_wdt
x86_pkg_temp_thermal
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[ 0.268730] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.268733] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.268736] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 4.512211] Bluetooth: Core ver 2.22
[ 4.531282] snd_hda_intel 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 4.535767] NET: Registered PF_BLUETOOTH protocol family
[ 5.239023] rtw_8821ce 0000:01:00.0 wlp1s0: renamed from wlan0
[ 5.254090] snd_soc_skl 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 5.283132] kauditd_printk_skb: 43 callbacks suppressed
[ 5.388064] NET: Registered PF_ALG protocol family
[ 5.501867] sof-audio-pci-intel-apl 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 5.502178] sof-audio-pci-intel-apl 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if 0x040100
[ 5.502338] sof-audio-pci-intel-apl 0000:00:0e.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 5.533658] sof-audio-pci-intel-apl 0000:00:0e.0: use msi interrupt mode
[ 5.562721] sof-audio-pci-intel-apl 0000:00:0e.0: hda codecs found, mask 4
[ 5.562730] sof-audio-pci-intel-apl 0000:00:0e.0: using HDA machine driver skl_hda_dsp_generic now
[ 5.562739] sof-audio-pci-intel-apl 0000:00:0e.0: DMICs detected in NHLT tables: 0
[ 5.567560] sof-audio-pci-intel-apl 0000:00:0e.0: Firmware info: version 2:0:0-b678a
[ 5.567566] sof-audio-pci-intel-apl 0000:00:0e.0: Firmware: ABI 3:20:0 Kernel ABI 3:18:0
[ 5.567570] sof-audio-pci-intel-apl 0000:00:0e.0: warn: FW ABI is more recent than kernel
[ 5.567589] sof-audio-pci-intel-apl 0000:00:0e.0: unknown sof_ext_man header type 3 size 0x30
[ 5.620613] sof-audio-pci-intel-apl 0000:00:0e.0: Firmware info: version 2:0:0-b678a
[ 5.620638] sof-audio-pci-intel-apl 0000:00:0e.0: Firmware: ABI 3:20:0 Kernel ABI 3:18:0
[ 5.620642] sof-audio-pci-intel-apl 0000:00:0e.0: warn: FW ABI is more recent than kernel
[ 5.652197] sof-audio-pci-intel-apl 0000:00:0e.0: Topology: ABI 3:20:0 Kernel ABI 3:18:0
[ 5.652209] sof-audio-pci-intel-apl 0000:00:0e.0: warn: topology ABI is more recent than kernel
[ 5.655750] sof-audio-pci-intel-apl 0000:00:0e.0: ASoC: Parent card not yet available, widget card binding deferred
[ 5.764700] input: sof-hda-dsp HDMI/DP,pcm=1 as /devices/pci0000:00/0000:00:0e.0/skl_hda_dsp_generic/sound/card0/input22
[ 5.764935] input: sof-hda-dsp HDMI/DP,pcm=2 as /devices/pci0000:00/0000:00:0e.0/skl_hda_dsp_generic/sound/card0/input23
[ 5.765084] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:0e.0/skl_hda_dsp_generic/sound/card0/input24
[ 5.767436] rtw_8821ce 0000:01:00.0: start vif b8:4d:43:d7:d1:a2 on port 0
