No sound from new Manjaro install
I’ve just installed the latest Manjaro to a new Dell Inspiron laptop, and there is no sound. Scanned through similar problems in this forum but they seem unresolved (to the extend I can understand them!
Here’s my output from the recommended inxi command:
  Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=9c7ea2e0-9118-4a42-98d6-74ea85c32f7e rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Laptop System: Dell product: Inspiron 3505 v: 1.4.7 serial: <filter>
  Chassis: type: 10 v: 1.4.7 serial: <filter>
  Mobo: Dell model: 0NMTCX v: A00 serial: <filter> UEFI: Dell v: 1.4.7
  date: 05/31/2021
  ID-1: BAT1 charge: 41.8 Wh (100.0%) condition: 41.8/42.0 Wh (99.5%)
  volts: 13.0 min: 11.4 model: Simplo 0x32,0x38,0x33,0x35,0x0B,0x0A,0x000F
  type: Li-ion serial: <filter> status: Full
  RAM: total: 5.75 GiB used: 1.68 GiB (29.3%)
  Info: Quad Core model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24)
  stepping: 1 microcode: 8108109 cache: L2: 2 MiB bogomips: 36751
  Speed: 1222 MHz min/max: 1400/2300 MHz boost: enabled Core speeds (MHz):
  1: 1222 2: 1222 3: 1222 4: 1222 5: 1222 6: 1221 7: 1223 8: 1221
  bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
  mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
  npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
  perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
  rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
  smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
  topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
  disabled, RSB filling
  Device-1: AMD Picasso vendor: Dell driver: amdgpu v: kernel bus-ID: 04:00.0
  chip-ID: 1002:15d8 class-ID: 0300
  Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-4:3 chip-ID: 0c45:671e class-ID: 0e02
  Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
  loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.40.0
  5.10.53-1-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.1.5 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Dell
  driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de
  class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Dell
  driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 04:00.5
  chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Dell driver: snd_hda_intel
  v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.32 running: no
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
  driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8136
  class-ID: 0200
  Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
  driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 2000 bus-ID: 03:00.0
  chip-ID: 10ec:c821 class-ID: 0280
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
  bus-ID: 3-2.4:3 chip-ID: 0bda:c829 class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 55.51 GiB (11.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM991a NVMe 512GB
  lanes: 4 type: SSD serial: <filter> rev: 26300039 temp: 24.9 C scheme: GPT
  ID-1: / raw-size: 391.04 GiB size: 383.83 GiB (98.16%)
  used: 55.42 GiB (14.4%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
  label: N/A uuid: 9c7ea2e0-9118-4a42-98d6-74ea85c32f7e
  ID-2: /boot/efi raw-size: 250 MiB size: 246 MiB (98.40%)
  used: 87.3 MiB (35.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: ESP uuid: ACD5-41F4
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 69.11 GiB fs: ntfs label: OS
  uuid: E4B21F2EB21F04A8
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs label: WINRETOOLS
  uuid: 423C538C3C5379BD
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 14.13 GiB fs: ntfs label: Image
  uuid: E642541E4253F233
  ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.33 GiB fs: ntfs
  label: DELLSUPPORT uuid: 6AC4B923C4B8F305
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 1-3:2 info: Logitech M105 Optical Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
  power: 100mA chip-ID: 046d:c077 class-ID: 0301
  Device-2: 1-4:3 info: Microdia Integrated_Webcam_HD type: Video
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 3-2:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 3-2.4:3 info: Realtek Bluetooth Radio type: Bluetooth
  driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
  Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 57.8 C mobo: N/A gpu: amdgpu temp: 57.0 C
  Fan Speeds (RPM): fan-1: 2500
  Processes: 233 Uptime: 3h 17m wakeups: 2 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1241 lib: 338
  flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
I’m very non-technical. How should I go about getting the sound working?
Thanks
check the search function for pipewire. this is the new audio-standard but it’s not active at you’re system.
https://wiki.archlinux.org/title/PipeWire
Problem appears to be in ALSA and switching to Pipewire would not help
A kernel patch for the audio codecs on this laptop was added to kernel in March
[PATCH v3 2/4] ALSA: hda/cirrus: Add support for CS8409 HDA bridge and CS42L42 companion codec. - Vitaly Rodionov
Dell’s laptops Inspiron 3500, Inspiron 3501, Inspiron 3505 are using Cirrus Logic
CS8409 HDA bridge with CS42L42 companion codec
You can Install kernel v5.13 for this patch with Manjaro Settings Manager GUI - manjaro-settings-manager -m msm_kernel
or this command
sudo mhwd-kernel -i linux513
Many thanks nkgnomic … kernel v5.13 now installed and this has fixed the problem. Sound now working a treat.
