No sound devices after installing 5.15
My laptop’s install of 5.14 Manjaro wouldn’t boot after I installed the latest updates for it throught the package manager, so I had to reinstall Manjaro. After doing so, I downloaded and installed 5.15. After doing this however, I had no audio, not from my laptop’s speakers nor my headphones. I checked the volume mixer, and Manjaro wasn’t recognizing any of my audio devices.
  Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=41a8aca7-d9b8-41b6-8dae-7ee8b8edd718 rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 16-a0xxx v: N/A
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 87AF v: 32.31 serial: <filter> UEFI: AMI v: F.21
  date: 03/17/2021
  ID-1: BAT0 charge: 45.7 Wh (100.0%) condition: 45.7/45.7 Wh (100.0%)
  volts: 12.8 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
  status: Full cycles: 19
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
  status: Discharging
  RAM: total: 7.54 GiB used: 2.02 GiB (26.8%)
  Info: Quad Core model: Intel Core i5-10300H bits: 64 type: MT MCP
  arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: EA
  cache: L2: 8 MiB bogomips: 40009
  Speed: 900 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
  4: 900 5: 900 6: 900 7: 900 8: 900
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
  pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
  smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
  tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
  xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Hewlett-Packard
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard
  driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:2191 class-ID: 0300
  Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
  bus-ID: 1-6:3 chip-ID: 0408:5365 class-ID: 0e02
  Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
  loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :0.0
  screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 137 size: 355x199mm (14.0x7.8")
  diag: 407mm (16")
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.5
  direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
  driver: sof-audio-pci-intel-cnl
  alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  chip-ID: 8086:06c8 class-ID: 0401
  Device-2: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
  class-ID: 0403
  Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 04:00.0
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
  vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
  port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:c822 class-ID: 0280
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
  bus-ID: 1-7:4 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
  Device-1: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
  Info: report: N/A blocks: 2944 chunk-size: N/A
  Components: Online: N/A Spare:
  0: nvme1n1 maj-min: 259:3 size: 27.25 GiB state: S
  Local Storage: total: 4.13 TiB used: 29.8 GiB (0.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202AH
  size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
  lanes: 2 type: SSD serial: <filter> rev: HPS2 temp: 35.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Intel model: HBRPEKNX0202AHO
  size: 27.25 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
  lanes: 2 type: SSD serial: <filter> rev: HPS3 temp: 48.9 C
  ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
  model: WD Elements 2620 size: 3.64 TiB block-size: physical: 4096 B
  logical: 512 B type: N/A serial: <filter> rev: 1018 scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 29.8 GiB (6.4%)
  fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  uuid: 41a8aca7-d9b8-41b6-8dae-7ee8b8edd718
  label: NO_LABEL uuid: DFD9-6E4E
  ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ntfs label: Windows Files
  uuid: 068621C08621B0DB
  ID-2: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ext4 label: Linux Files
  uuid: 71b9dd03-ed4e-4ed8-b2e3-51e1a1643063
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-6:3 info: Quanta HP TrueVision HD Camera type: Video
  Device-3: 1-7:4 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
  interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:b00c
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-2:2 info: Western Digital Elements 2620 type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
  chip-ID: 1058:2620 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 53.0 C mobo: N/A
  Processes: 267 Uptime: 14m wakeups: 4 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 1073 lib: 309 flatpak: 0 Shell: Bash
  v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.08
How do I get Manjaro to recognize my audio devices?
You should consider updating system BIOS
https://support.hp.com/us-en/drivers/selfservice/swdetails/hp-pavilion-gaming-16-a0000-laptop-pc-series/32885443/swItemId/ob-278055-1
System data shows 2 sound servers running
