Hello there!
I’ve decided to remove chromeOS (hp x360 c14) and replace it with manjaro. What a great difference! I love it!
I have however not been able to get my soundcard to work.
Lets start with the beginning, this is my system output:
inxi --admin --verbosity=7 245 ✘ base
Host: manjaro Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
root=UUID=132c0983-7600-47e3-b5a6-a1cb78ee220a rw quiet splash apparmor=1
security=apparmor resume=UUID=b125d531-c3f9-4f5e-bf7c-0644d0456280
udev.log_priority=3
Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Google product: Dragonair v: rev4
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: HP model: Dragonair v: rev4 serial: <superuser required>
UEFI: coreboot v: MrChromebox-4.17.2 date: 07/18/2022
ID-1: BAT0 charge: 51.9 Wh (100.0%) condition: 51.9/61.2 Wh (84.9%)
volts: 12.8 min: 11.6 model: 333-1C- BC03060 type: Li-ion serial: 122C
status: charging cycles: 216
Device-1: hid-0018:27C6:0E02.0004-battery model: GDIX0000:00 27C6:0E02
serial: N/A charge: N/A status: N/A
RAM: total: 7.64 GiB used: 2.21 GiB (28.9%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 built: 2018
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xC (12)
microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 4124 high: 4200 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 4182 2: 4200 3: 4101
4: 4101 5: 4101 6: 4017 7: 4191 8: 4100 bogomips: 33615
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-2,eDP-1
empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera
type: USB driver: uvcvideo bus-ID: 1-7:3 chip-ID: 05c8:03e1 class-ID: 0e02
serial: SunplusIT Inc
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: DP-2 model: Philips PHL 276B1 serial: UK02146030617
built: 2021 res: 2560x1440 dpi: 109 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Monitor-2: eDP-1 model: AU Optronics 0x818b built: 2019 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF: wlp0s20f3 state: up mac: d8:f8:83:25:6e:21
IP v4: 172.30.142.105/22 type: dynamic noprefixroute scope: global
broadcast: 172.30.143.255
IP v6: 2001:610:4c0:2140:f269:894d:83f9:7ca5/64
IP v6: fe80::a559:dcd7:381e:1e5d/64 type: noprefixroute scope: link
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 2-2.5:3 chip-ID: 0bda:8153 class-ID: 0000
serial: 001000001
IF: enp0s20f0u2u5 state: down mac: 00:d2:b1:a7:ea:26
WAN IP: 195.169.251.159
bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 116.48 GiB used: 34.18 GiB (29.3%)
ID-1: /dev/mmcblk1 maj-min: 179:0 vendor: SanDisk model: DA4128
size: 116.48 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: 0x8b748316 rev: 0x8 scheme: GPT
ID-1: / raw-size: 107.38 GiB size: 105.14 GiB (97.91%) used: 34.18 GiB
(32.5%) fs: ext4 dev: /dev/mmcblk1p2 maj-min: 179:2 label: N/A
uuid: 132c0983-7600-47e3-b5a6-a1cb78ee220a
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/mmcblk1p1 maj-min: 179:1 label: NO_LABEL
uuid: C899-878E
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/mmcblk1p3 maj-min: 179:3 label: swap
uuid: b125d531-c3f9-4f5e-bf7c-0644d0456280
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 6 rev: 2.1 speed: 480 Mb/s
Device-1: 1-2.3:4 info: HP Business Slim Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 03f0:2b4a class-ID: 0300
Device-2: 1-2.4:6 info: HP Optical Mouse [672662-001] type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 03f0:094a class-ID: 0301
Device-3: 1-7:3 info: Cheng Uei Precision Industry (Foxlink) HP Wide
Vision HD Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 05c8:03e1 class-ID: 0e02
Device-4: 1-10:5 info: Intel AX201 Bluetooth type: Bluetooth
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-2:2 info: Genesys Logic USB3.2 Hub ports: 5 rev: 3.2
speed: 5 Gb/s chip-ID: 05e3:0625 class-ID: 0900
Device-1: 2-2.5:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: 001000001
System Temperatures: cpu: 53.0 C pch: 43.0 C mobo: N/A
Processes: 286 Uptime: 9m wakeups: 1823 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1474 libs: 335 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.21
I’ve seen numerous topics discussing this but solutions vary.
Firstly I’ve found that pipewire and pulseaudio where running at the same time. I’ve managed to disable that, but unfortunately still no dice.
I’ve tried to do this but also no effect.
I’ve found some interesting info that might help:
systemctl --user status pipewire ✔ base
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
Active: active (running) since Thu 2022-09-22 14:58:25 CEST; 46min ago
TriggeredBy: ● pipewire.socket
Main PID: 1432 (pipewire)
Tasks: 2 (limit: 9354)
Memory: 4.1M
CPU: 27ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─1432 /usr/bin/pipewire
Sep 22 14:58:25 manjaro systemd[1196]: Started PipeWire Multimedia Service.
Sep 22 14:58:25 manjaro pipewire[1432]: mod.rt: Can't find xdg-portal: (null)
Sep 22 14:58:25 manjaro pipewire[1432]: mod.rt: found session bus but no portal
Sep 22 14:58:25 manjaro pipewire[1432]: mod.rt: RTKit error: org.freedesktop.DBus.Error.AccessDenied
Sep 22 14:58:25 manjaro pipewire[1432]: mod.rt: could not make thread 1440 realtime using RTKit: Permission denied
and
stat /usr/bin/pipewire-media-session ✔ base
File: /usr/bin/pipewire-media-session
Size: 412208 Blocks: 808 IO Block: 4096 regular file
Device: 179,2 Inode: 3684074 Links: 1
Access: (0755/-rwxr-xr-x) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2022-09-22 14:47:21.000000000 +0200
Modify: 2022-05-11 15:37:22.000000000 +0200
Change: 2022-09-22 14:47:21.343611699 +0200
Birth: 2022-09-22 14:47:21.343611699 +0200
but this one is the weirdest:
pipewire ✔ base
[E][00029.020341] mod.protocol-native | [module-protocol-: 728 lock_socket()] server 0x55d50a0b3d00: unable to lock lockfile '/run/user/1000/pipewire-0.lock': Resource temporarily unavailable (maybe another daemon is running)
[E][00029.020433] pw.conf | [ conf.c: 594 load_module()] 0x55d50a0761f0: could not load mandatory module "libpipewire-module-protocol-native": Resource temporarily unavailable
[E][00029.020503] default | [ pipewire.c: 125 main()] failed to create context: Resource temporarily unavailable
Can anyone help me please ? What should i do next ?
