so it had to be those pulse packages …
install them back:
pamac install pavucontrol python-pulsectl
reboot
im on kde, so these are probably needed by gnome
ah.
Thanx.
I’ve rebooted. still no music
post output from:
ls /etc/modprobe.d
did it installed also the dependencies with it?
i dont know what the stager desktop is…
folder is empty.
I think it did all the dependacies.
ok, so run this: alsamixer
press f6, select your card, and check if the speakers are not muted
I checked, its not muted:
Moderator edit: Removed useless screenshot
and bt still works? can you test if jack works?
i can try that at home
Yes bluetooth still works!
I need to go now, im a teacher and one of my students won a prize, im going to hand it over
Thanks for everything and hopefully i will speak to you again!
allright, so then let me know, we will continue
I have flagged post #27 because of the background image and also because it is showing PulseAudio Volume Control (pavucontrol
) not alsamixer
Please post more information about ALSA settings in text-format
amixer --card=0
Hello friends! Sorry for the image, i was just watching the news…
amixer --card=0 ✔ base
Simple mixer control 'Headphone Jack',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [off]
Simple mixer control 'IEC958',0
Simple mixer control 'IEC958',1
Simple mixer control 'IEC958',2
Simple mixer control 'ADCDAT Mux',0
Capabilities: enum
Items: 'ADCDAT1' 'ADCDAT2'
Item0: 'ADCDAT1'
Simple mixer control 'CBJ Boost',0
Capabilities: volume volume-joined
Capture channels: Mono
Limits: 0 - 8
Mono: 0 [0%] [0.00dB]
Simple mixer control 'DAC L Mux',0
Capabilities: enum
Items: 'IF1' 'SOUND'
Item0: 'IF1'
Simple mixer control 'DAC L1 Source',0
Capabilities: enum
Items: 'Stereo1 DAC Mixer' 'DAC1'
Item0: 'DAC1'
Simple mixer control 'DAC R Mux',0
Capabilities: enum
Item0: 'IF1'
Simple mixer control 'DAC R1 Source',0
Capabilities: enum
Item0: 'DAC1'
Simple mixer control 'DAC1',0
Capabilities: pvolume
Limits: Playback 0 - 87
Mono:
Front Left: Playback 87 [100%] [0.00dB]
Front Right: Playback 87 [100%] [0.00dB]
Simple mixer control 'DAC1 MIXL DAC1',0
Mono: Playback [on]
Simple mixer control 'DAC1 MIXL Stereo ADC',0
Simple mixer control 'DAC1 MIXR DAC1',0
Mono: Playback [on]
Simple mixer control 'DAC1 MIXR Stereo ADC',0
Simple mixer control 'HPO Signal Demux',0
Capabilities: enum
Items: 'Legacy' 'OneBit'
Item0: 'OneBit'
Simple mixer control 'HPOL',0
Simple mixer control 'HPOR',0
Simple mixer control 'Headset Mic',0
Mono: Playback [on]
Simple mixer control 'IF1 01 ADC Swap Mux',0
Capabilities: enum
Items: 'L/R' 'R/L' 'L/L' 'R/R'
Item0: 'L/R'
Simple mixer control 'IF1 23 ADC Swap Mux',0
Capabilities: enum
Item0: 'L/R'
Simple mixer control 'IF1 45 ADC Swap Mux',0
Capabilities: enum
Item0: 'L/R'
Simple mixer control 'IF1 67 ADC Swap Mux',0
Capabilities: enum
Item0: 'L/R'
Simple mixer control 'IF1_ADC Mux',0
Capabilities: enum
Items: 'Slot 0' 'Slot 2' 'Slot 4' 'Slot 6'
Item0: 'Slot 0'
Simple mixer control 'IF2 ADC Swap Mux',0
Capabilities: enum
Item0: 'L/R'
Simple mixer control 'Left Spk',0
Mono: Playback [on]
Simple mixer control 'PGA1.0 1 Master',0
Limits: Playback 0 - 32
Mono:
Front Left: Playback 32 [100%] [0.00dB]
Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA2.0 2 Master',0
Capabilities: cvolume
Limits: Capture 0 - 80
Front Left: Capture 50 [62%] [0.00dB]
Front Right: Capture 50 [62%] [0.00dB]
Simple mixer control 'PGA4.0 4 Master',0
Mono:
Simple mixer control 'PGA5.0 5 Master',0
Mono:
Simple mixer control 'PGA6.0 6 Master',0
Mono:
Simple mixer control 'PGA7.0 7 Master',0
Mono:
Simple mixer control 'RECMIX1L CBJ',0
Simple mixer control 'Right Spk',0
Mono: Playback [on]
Simple mixer control 'STO1 ADC',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 23 [37%] [0.00dB] [off]
Front Right: Capture 23 [37%] [0.00dB] [off]
Simple mixer control 'STO1 ADC Boost Gain',0
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Spk',0
Mono: Playback [on]
Simple mixer control 'Stereo1 ADC L Mux',0
Capabilities: enum
Items: 'ADC1 L' 'ADC1 R'
Item0: 'ADC1 L'
Simple mixer control 'Stereo1 ADC L1 Mux',0
Capabilities: enum
Items: 'DAC MIX' 'ADC'
Item0: 'DAC MIX'
Simple mixer control 'Stereo1 ADC L2 Mux',0
Capabilities: enum
Items: 'DAC MIX' 'DMIC'
Item0: 'DAC MIX'
Simple mixer control 'Stereo1 ADC MIXL ADC1',0
Simple mixer control 'Stereo1 ADC MIXL ADC2',0
Simple mixer control 'Stereo1 ADC MIXR ADC1',0
Simple mixer control 'Stereo1 ADC MIXR ADC2',0
Simple mixer control 'Stereo1 ADC R Mux',0
Capabilities: enum
Item0: 'ADC1 R'
Simple mixer control 'Stereo1 ADC R1 Mux',0
Capabilities: enum
Item0: 'DAC MIX'
Simple mixer control 'Stereo1 ADC R2 Mux',0
Capabilities: enum
Item0: 'DAC MIX'
Simple mixer control 'Stereo1 DAC MIXL DAC L1',0
Simple mixer control 'Stereo1 DAC MIXL DAC R1',0
Simple mixer control 'Stereo1 DAC MIXR DAC L1',0
Simple mixer control 'Stereo1 DAC MIXR DAC R1',0
Hi there friendly people, are there maybe any other suggestions ?
Thank you!
did you tested, if the sound is working using jack?
I just tested, unfortunately no sound via jack
try running this:
sudo alsa force-reload
test audio, if it doesnt work, try this:
amixer -c0 set 'Master',0 100% unmute
amixer -c0 set 'Speaker',0 100% unmute
amixer -c0 set 'Headphone',0 100% unmute
test audio, if it doesnt work, install the 5.19 kernel(not the rt one), reboot and test audio again
Hi there,
Thanx for the reply again!
Unfortunately these comment’s doesn’t work.
alsa command is not found
for the amixer command i get the following output:
amixer: Unable to find simple control 'Master',0
I’m hoping this could be the source of the problem ?
I also fiddled around a bit with alsa, unfortunatly this did not help aswell.
I did the following according to https://wiki.manjaro.org/index.php/ALSA:
cat /proc/asound/cards ✔ 22s base
0 [sofrt5682 ]: sof-rt5682 - sof-rt5682
HP-Dragonair-rev4
sudo touch /etc/asound.conf
and add the following code:
defaults.pcm.card 0
defaults.ctl.card 0
and tried to run it in firefox:
apulse /usr/lib/firefox/firefox
[GFX1-]: glxtest: VA-API test failed: failed to initialise VAAPI connection.
ATTENTION: default value of option mesa_glthread overridden by environment.
Missing chrome or resource URL: resource://gre/modules/UpdateListener.sys.mjs
[2022-09-30T14:07:49Z ERROR mp4parse] Found 2 nul bytes in "\0\0"
[2022-09-30T14:08:03Z ERROR viaduct::backend::ffi] Missing HTTP status
and nothing
the alsa command will not work on manjaro/arch, didnt know that when i posted it…
the problem is, you having a chromebook, where the audio is a mess, you can check on internet, and there are others with audio issues, what is recommended is to buy some cheap usb audio adapter in the meantime… you can check this:
https://wiki.archlinux.org/title/Chrome_OS_devices#Fixing_audio
Hi there.
Yes I was worried i needed to settle with that. too bad. I did purchase a usbc creative aptx dongle.
I just have to choose, manjaro without propper sound, or chromeos. Ill think ill go with manjaro.
