Hi, installed Manjaro recently and I can’t get any sound out of my headphones. I use a Behringer USB audio interface which is plugged into one of my motherboard USB2.0 ports.
inxi -Fazy
Kernel: 6.1.23-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=b3e6c24e-3675-469d-9d86-a6a65978e515 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: ROG CROSSHAIR VII HERO (WI-FI) v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 5003
date: 02/03/2023
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2315 high: 3662 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3551 2: 2200
3: 2200 4: 2200 5: 2195 6: 2196 7: 2200 8: 2200 9: 2200 10: 2199 11: 2200
12: 2196 13: 2200 14: 2200 15: 2200 16: 2196 17: 2200 18: 2196 19: 2200
20: 3662 21: 2200 22: 2196 23: 2195 24: 2200 bogomips: 182133
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Tul /
PowerColor Red Devil driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,DP-2 empty: DP-3,HDMI-A-1 bus-ID: 0c:00.0
chip-ID: 1002:73bf class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-12:5 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 6560x2560 s-dpi: 96 s-size: 1735x677mm (68.31x26.65")
s-diag: 1862mm (73.32")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,bottom-l
model: Samsung LC49G95T serial: <filter> built: 2020 res: 5120x1440 hz: 120
dpi: 109 gamma: 1.2 size: 1190x340mm (46.85x13.39") diag: 1239mm (48.8")
modes: max: 5120x1440 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: top-right
model: Gigabyte AORUS AD27QD serial: <filter> built: 2019 res: 1440x2560
dpi: 103 gamma: 1.2 size: 355x609mm (13.98x23.98") diag: 705mm (27.8")
ratio: 15:9 modes: max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon RX 6900 XT (navi21
LLVM 15.0.7 DRM 3.49 6.1.23-1-MANJARO) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 1-12:5 pcie: gen: 4 chip-ID: 046d:085c class-ID: 0102 speed: 16 GT/s
serial: <filter> lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam type: USB
Device-4: BEHRINGER GmbH UMC204HD 192k type: USB driver: snd-usb-audio
bus-ID: 7-4:2 chip-ID: 1397:0508 class-ID: fe01
API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: off with: wireplumber status: off
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active
tools: pacat,pactl,pavucontrol,pulsemixer
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: c000 bus-ID: 07:00.0 chip-ID: 10ec:b822 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-1: ASUSTek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-2:2 chip-ID: 0b05:185c class-ID: e001 serial: <filter>
Local Storage: total: 3.86 TiB used: 9.83 GiB (0.2%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD2003FZEX-00SRLA0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000524AS
type: HDD rpm: 7200 serial: <filter> rev: JC4B scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SHFS37A240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: BBF0 scheme: MBR
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 9.83 GiB (1.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 34.0 C mobo: 24.0 C gpu: amdgpu temp: 58.0 C
mem: 56.0 C
Fan Speeds (RPM): cpu: 2136 case-1: 744 case-2: 0 case-3: 726 gpu: amdgpu
fan: 0
Power: 12v: 11.99 5v: N/A 3.3v: N/A vbat: 3.21 gpu: amdgpu watts: 35.00
Processes: 391 Uptime: 36m wakeups: 1 Memory: 15.51 GiB
used: 2.77 GiB (17.9%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1098 libs: 335 tools: pamac Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.26[/code]
pacmd dump
### Configuration dump generated at Mon Apr 17 09:04:57 2023
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="3" name="usb-046d_C922_Pro_Stream_Webcam_AA79661F-02" card_name="alsa_card.usb-046d_C92
2_Pro_Stream_Webcam_AA79661F-02" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=
yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="1" name="pci-0000_0c_00.1" card_name="alsa_card.pci-0000_0c_00.1" namereg_fail=false ts
ched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-d
etect.discovered=1"
load-module module-alsa-card device_id="0" name="usb-BEHRINGER_UMC204HD_192k-00" card_name="alsa_card.usb-BEHRINGER_UMC204HD_19
2k-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no ca
load-module module-alsa-card device_id="2" name="pci-0000_0e_00.4" card_name="alsa_card.pci-0000_0e_00.4" namereg_fail=false ts
etect.discovered=1"
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-cli-protocol-unix
set-sink-volume alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_2_3__sink 0x10000
set-sink-mute alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_2_3__sink no
suspend-sink alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_2_3__sink yes
set-sink-volume alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_0_1__sink 0x10000
set-sink-mute alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_0_1__sink no
suspend-sink alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_0_1__sink yes
set-source-volume alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_2_3__sink.monitor 0x10000
set-source-mute alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_2_3__sink.monitor yes
suspend-source alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_2_3__sink.monitor yes
set-source-volume alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_0_1__sink.monitor 0x1051f
set-source-mute alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_0_1__sink.monitor yes
suspend-source alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_0_1__sink.monitor yes
set-source-volume alsa_input.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_mono_in_U192k_0_1__source 0x10000
set-source-mute alsa_input.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_mono_in_U192k_0_1__source yes
suspend-source alsa_input.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_mono_in_U192k_0_1__source yes
set-source-volume alsa_input.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_mono_in_U192k_0_0__source 0x10000
set-source-mute alsa_input.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_mono_in_U192k_0_0__source no
suspend-source alsa_input.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_mono_in_U192k_0_0__source yes
set-card-profile alsa_card.usb-046d_C922_Pro_Stream_Webcam_AA79661F-02 off
set-card-profile alsa_card.pci-0000_0c_00.1 off
set-card-profile alsa_card.usb-BEHRINGER_UMC204HD_192k-00 HiFi
set-card-profile alsa_card.pci-0000_0e_00.4 off
set-default-sink alsa_output.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_stereo_out_U192k_0_0_1__sink
set-default-source alsa_input.usb-BEHRINGER_UMC204HD_192k-00.HiFi__umc204hd_mono_in_U192k_0_0__source
### EOF
amixer --card=0
Simple mixer control 'Line A',0
Capabilities: pvolume pswitch
Limits: Playback 0 - 127
Mono:
Front Left: Playback 127 [100%] [0.00dB] [on]
Front Right: Playback 127 [100%] [0.00dB] [on]
Simple mixer control 'Line B',0
Mono:
Simple mixer control 'Mic',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 127
Front Left: Capture 127 [100%] [0.00dB] [on]
Front Right: Capture 127 [100%] [0.00dB] [off]
Simple mixer control 'Mic',1
Capabilities: cvolume cvolume-joined cswitch cswitch-joined
Capture channels: Mono
Mono: Capture 127 [100%] [0.00dB] [on]
Simple mixer control 'Input 1',0
Simple mixer control 'Input 2',0
Mono: Capture 127 [100%] [0.00dB] [off]
Simple mixer control 'UMC204HD 192k Output',0
Playback channels: Front Left - Front Right - Rear Left - Rear Right
Mono:
Rear Left: Playback 127 [100%] [0.00dB] [on]
Rear Right: Playback 127 [100%] [0.00dB] [on]
Simple mixer control 'UMC204HD 192k Output',1
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Mono: Playback 127 [100%] [0.00dB] [off]
