No sound after new installation
Hey there,
I tried fixing this problem many times before and never succeeded. When running Manjaro only on the Installation medium the sound worked fine. After I installed it, it stopped working. After I tried this: Manjaro Forum Entry it worked for a while. Until I connected an HDMI display or something I guess. I really love working with Linux, especially with Manjaro and i3, but this is a really big deal breaker. I hope anyone knows how to fix it.
I guess there should be everything you need:
Alsa System Information
  Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=a45025d4-2f21-4089-8096-014cca70c2d1 rw quiet apparmor=1
  Desktop: i3 v: 4.20.1 info: polybar vt: 7 dm: LightDM v: 1.30.0
  Type: Laptop System: HP product: HP Pavilion Laptop 15-cs3xxx
    v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
  Mobo: HP model: 86E2 v: 95.32 serial: <superuser required> UEFI: Insyde
    v: F.06 date: 04/08/2020
  ID-1: BAT0 charge: 29.7 Wh (85.6%) condition: 34.7/34.7 Wh (100.0%)
    volts: 13.0 min: 11.3 model: HP Primary type: Li-ion serial: N/A
    status: charging
  Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
    family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xA8
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 767 high: 986 min/max: 400/3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 986 2: 649 3: 832 4: 687
    5: 857 6: 579 7: 888 8: 664 bogomips: 19048
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
    v: kernel ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:8a56 class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce MX130] vendor: Hewlett-Packard
    driver: nouveau v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max:
    gen: 3 speed: 8 GT/s bus-ID: 06:00.0 chip-ID: 10de:174d class-ID: 0302
  Device-3: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
    bus-ID: 1-3:4 chip-ID: 04ca:707f class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 1.21.1.3 compositor: Compton driver: X:
    loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
    screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2018 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
    bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.49 running: no
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 10:00.0 chip-ID: 10ec:8168
    class-ID: 0200
    bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: 8060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
    class-ID: 0104
  Local Storage: total: 953.87 GiB used: 26.53 GiB (2.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8H
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: HPS0
    temp: 30.9 C scheme: GPT
  ID-1: / raw-size: 114.54 GiB size: 112.19 GiB (97.94%)
    used: 26.45 GiB (23.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 82.6 MiB (32.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 51.0 C mobo: N/A
  Processes: 225 Uptime: 17m wakeups: 1 Memory: 15.42 GiB
  used: 2.29 GiB (14.9%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: 1159 pacman: 1151 lib: 313 snap: 8
  Shell: Bash v: 5.1.16 running-in: urxvtd inxi: 3.3.15
Heya,
I’ve always found sound on Linux troublesome to get right. Lately I’ve switched to pipewire and that smoothed out my experience with Bluetooth headsets. It might work for you. To install :
pamac install manjaro-pipewire
Also after a new install, don’t forget the swap :slight_smile:
