No sound after dual boot with windows 11
i recently dual booted manjaro kde with windows 11 but there is no sound
pactl list sources
        State: RUNNING
        Description: Monitor of Dummy Output
        Driver: module-null-sink.c
        Sample Specification: s16le 2ch 44100Hz
        Channel Map: front-left,front-right
        Owner Module: 15
        Mute: no
        Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
                balance 0.00
        Base Volume: 65536 / 100% / 0.00 dB
        Monitor of Sink: auto_null
        Latency: 0 usec, configured 40000 usec
        Flags: DECIBEL_VOLUME LATENCY
        Properties:
                device.description = "Monitor of Dummy Output"
                device.class = "monitor"
        Formats:
                pcm
and
inxi -Fxxxx
  Host: tanishk-box Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64
    compiler: gcc v: 12.1.1 Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5
    wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Flipkart India Pvt. product: NKi510TL85S v: N/A
    serial: <superuser required>
  Mobo: N/A model: N/A serial: <superuser required>
    UEFI: American Megatrends v: CML_CM618_V1.0.1 date: 09/15/2021
  ID-1: BAT0 charge: 11.7 Wh (26.0%) condition: 45.0/45.0 Wh (100.0%)
    volts: 11.6 min: N/A model: Comet Lake Li-ion Battery type: Li-ion
    serial: 123456789 status: discharging
  Info: quad core model: Intel Core i5-10210U bits: 64 type: MT MCP
    smt: enabled arch: Comet/Whiskey Lake note: check rev: C cache: L1: 256 KiB
    L2: 1024 KiB L3: 6 MiB
  Speed (MHz): avg: 899 high: 900 min/max: 400/4200 cores: 1: 900 2: 900
    3: 900 4: 900 5: 900 6: 894 7: 900 8: 900 bogomips: 33615
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: nCipher Security
    driver: i915 v: kernel arch: Gen-9.5 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:9b41
    class-ID: 0300
  Device-2: Sunplus Innovation Hy HD Camera type: USB driver: uvcvideo
    bus-ID: 1-4:2 chip-ID: 1bcf:2ced class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 model: BOE Display 0x0827 res: 1366x768 hz: 60 dpi: 112
    size: 309x174mm (12.17x6.85") diag: 355mm (14") modes: 1366x768
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.6
    direct render: Yes
  Device-1: Intel Comet Lake PCH-LP cAVS driver: snd_hda_intel v: kernel
    bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
  Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel pcie:
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
  IF: wlp2s0 state: up mac: ec:63:d7:7e:14:ae
    bus-ID: 1-10:3 chip-ID: 8087:0a2a class-ID: e001
  Local Storage: total: 476.94 GiB used: 79.86 GiB (16.7%)
  ID-1: /dev/sda vendor: Netac model: SSD 512GB size: 476.94 GiB
    speed: 6.0 Gb/s type: SSD serial: NSN218DKL09995 rev: 0A0 scheme: GPT
  ID-1: / size: 114.31 GiB used: 8.85 GiB (7.7%) fs: ext4 dev: /dev/sda8
  ID-2: /boot/efi size: 499 MiB used: 312 KiB (0.1%) fs: vfat
    dev: /dev/sda6
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda7
  System Temperatures: cpu: 44.0 C pch: 36.0 C mobo: N/A
  Processes: 248 Uptime: 4m wakeups: 1 Memory: 7.6 GiB used: 1.85 GiB (24.4%)
  Init: systemd v: 251 default: graphical Compilers: gcc: 12.1.1
  clang: 14.0.6 Packages: pacman: 1187 Shell: Zsh v: 5.9 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.20
please help
i am a noob at this
i have pavucontrol installed is it of any use here ?
Can you update the system with pacman -Syyu on console ?
ill do it now
alright its updating
what should i do after its done?
What is the output of alsamixer on console ?
You are running both pipewire and pulseaudio.
This does not work. You must uninstall one of both.
Yeah
Both pipewire and pulseaudio are running
Which one should I remove??
And how
Should i run this command??
You can disable or uninstall one:
  1. disable: command above
  2. uninstall. with software center
Can’t uninstall pipewire(says the software center)
Some other programs are depending on it
Should I remove those too?
i disabled pipewire and also i updated my system and kernel to 6.0
Still no sound
  Host: tanishk-box Kernel: 6.0.2-2-MANJARO arch: x86_64 bits: 64
    compiler: gcc v: 12.2.0 Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6
  ID-1: BAT0 charge: 18.0 Wh (40.0%) condition: 45.0/45.0 Wh (100.0%)
  Speed (MHz): avg: 1275 high: 2100 min/max: 400/4200 cores: 1: 1000
    2: 1000 3: 1000 4: 2100 5: 1000 6: 2100 7: 1000 8: 1000 bogomips: 33615
    class-ID: 0300
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :0 screens: 1
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
    direct render: Yes
  Device-1: Intel Comet Lake PCH-LP cAVS driver: sof-audio-pci-intel-cnl
  Sound API: ALSA v: k6.0.2-2-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.58 running: no
  Local Storage: total: 476.94 GiB used: 10.76 GiB (2.3%)
  ID-1: / size: 114.31 GiB used: 10.76 GiB (9.4%) fs: ext4 dev: /dev/sda8
  ID-2: /boot/efi size: 499 MiB used: 316 KiB (0.1%) fs: vfat
    dev: /dev/sda6
    dev: /dev/sda7
  System Temperatures: cpu: 40.0 C pch: 32.0 C mobo: N/A
  Processes: 221 Uptime: 9m wakeups: 1 Memory: 7.6 GiB used: 1.85 GiB (24.3%)
  Init: systemd v: 251 default: graphical Compilers: gcc: 12.2.0
  clang: 14.0.6 Packages: pm: pacman pkgs: 1231 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
and looks like alsa can’t detect any soundcards
please help with this
http://alsa-project.org/db/?f=7fc20d0db7eae0422f22f8e4fc2eceb816201016
Perhaps some firmware must be loaded.
hey
i installed manjaro-pipewire
and it now detects some soundcards
The sound cards are detected but getting no sound - Support / Sound - Manjaro Linux Forum
please look at this
