alsa-info.sh --upload output is at http://alsa-project.org/db/?f=f5797475d15af54dab005ccdf2b9447739e1f81b
From inxi -Fazi:
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.10.136-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
And from pacmd dump:
Configuration dump generated at Wed Aug 24 19:54:42 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id=“1” name=“pci-0000_01_00.1” card_name=“alsa_card.pci-0000_01_00.1” namereg_fail=false tsched=yes fixed_latency_range=
no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties=“module-udev-detect.discovered=1”
load-module module-alsa-card device_id=“0” name=“pci-0000_00_1f.3” card_name=“alsa_card.pci-0000_00_1f.3” namereg_fail=false tsched=yes fixed_latency_range=
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0 xauthority=/home/sperlock/.Xauthority
load-module module-x11-xsmp display=:0 xauthority=/home/sperlock/.Xauthority session_manager=local/angel-iv:@/tmp/.ICE-unix/1161,unix/angel-iv:/tmp/.ICE-uni
x/1161
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_1f.3.iec958-stereo 0xc10b
set-sink-mute alsa_output.pci-0000_00_1f.3.iec958-stereo no
suspend-sink alsa_output.pci-0000_00_1f.3.iec958-stereo yes
set-source-volume alsa_output.pci-0000_00_1f.3.iec958-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1f.3.iec958-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1f.3.iec958-stereo.monitor yes
set-card-profile alsa_card.pci-0000_01_00.1 off
set-card-profile alsa_card.pci-0000_00_1f.3 output:iec958-stereo
set-default-sink alsa_output.pci-0000_00_1f.3.iec958-stereo
set-default-source alsa_output.pci-0000_00_1f.3.iec958-stereo.monitor
EOF
Suggestions? Thanks!
