Good morning!
I installed Manjaro KDE-Plasma (Kernel 6.1.29-1 on an LG All-In-One (2016/2017). Everything working fine except for sound/audio. The audio bar says it is recognizing sound, but the sound doesn’t come out of the computer speakers. When I use external speakers or headphones the sound works perfectly. I’ve tried PavuControl, Alsa, Pulse, PipeWire and I still can’t solve it.
I’ve read several posts about similar subjects here on the Forum and I’ve carried out the tests and unfortunately it’s still unresolved, so I’m opening this new post.
I ran the Alsa Script on my computer, let me know if that information might be usefull.
If anyone can help me. Thanks
As requested, I forward the audio specifications. Any additional information needed?
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio vendor: LG driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:2284 class-ID: 0403
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
If audio from headphone jack is working PulseAudio is probably working and issue with speakers is probably in ALSA
Please post more information about ALSA configuration
sudo alsa-info.sh --with-aplay --with-amixer --with-dmesg --upload
Do you have anything else checked besides “Built-In Audio” on the configuration tab in pavucontrol (I’m using pavucontrol-qt)? My laptop speakers quit working an update or two ago and I finally got them working again after unchecking the USB-C dock. Never had to do it before. Might be something similar.
