Hi,
I turned on my computer today, and there was no network or Bluetooth connectivity. I didn’t move the tower, update the system, or change anything yesterday that would justify this sudden lack of network. I am not sure if it’s a hardware or software issue.
Here is the output of a few commands that might help. Please let me know if you have any ideas as to what might be the issue. Thank you in advance.
EDIT: from a previous post I created in the forum, I see that in my inxi output the network card was identified, but in this output it is not. I don’t know if I can do something software-wise, or it’s purely a hardware issue
[geo@desktop ~]$ sudo systemctl status NetworkManager.service
● NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: disabled)
Active: active (running) since Tue 2022-10-11 09:12:56 AWST; 4min 10s ago
Docs: man:NetworkManager(8)
Main PID: 561 (NetworkManager)
Tasks: 3 (limit: 38380)
Memory: 12.7M
CPU: 96ms
CGroup: /system.slice/NetworkManager.service
└─561 /usr/bin/NetworkManager --no-daemon
Oct 11 09:12:57 desktop NetworkManager[561]: <info> [1665450777.3547] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Oct 11 09:12:57 desktop NetworkManager[561]: <info> [1665450777.3552] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Oct 11 09:12:57 desktop NetworkManager[561]: <info> [1665450777.3576] ovsdb: disconnected from ovsdb
Oct 11 09:12:57 desktop NetworkManager[561]: <info> [1665450777.3577] device (eth0): interface index 2 renamed iface from 'eth0' to 'enp4s0'
Oct 11 09:12:57 desktop NetworkManager[561]: <info> [1665450777.3578] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 11 09:12:57 desktop NetworkManager[561]: <info> [1665450777.5916] settings: (enp4s0): created default wired connection 'Wired connection 1'
Oct 11 09:12:57 desktop NetworkManager[561]: <info> [1665450777.5918] modem-manager: ModemManager available
Oct 11 09:13:03 desktop NetworkManager[561]: <info> [1665450783.5931] manager: startup complete
Oct 11 09:13:11 desktop NetworkManager[561]: <info> [1665450791.1375] agent-manager: agent[f19f235cb387bcf5,:1.34/org.kde.plasma.networkmanagement/1000]: agent registered
Oct 11 09:13:11 desktop NetworkManager[561]: <info> [1665450791.3223] audit: op="statistics" interface="enp4s0" ifindex=2 args="500" pid=1148 uid=1000 result="success"
[geo@desktop ~]$ inxi -Fxxxz
Kernel: 5.19.13-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: B550M GAMING
serial: <superuser required> UEFI: American Megatrends LLC. v: F15c
date: 05/12/2022
Info: 12-core model: AMD Ryzen 9 5900X bits: 64 type: MT MCP smt: enabled
arch: Zen 3 rev: 2 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB
Speed (MHz): avg: 2475 high: 3700 min/max: 2200/4950 boost: enabled
cores: 1: 2800 2: 2200 3: 2200 4: 2200 5: 3700 6: 2200 7: 2200 8: 3700
9: 2200 10: 2200 11: 2200 12: 2200 13: 3700 14: 2200 15: 2200 16: 2200
17: 2200 18: 3700 19: 2200 20: 2200 21: 2200 22: 2200 23: 2200 24: 2200
bogomips: 177317
Device-1: AMD Navi 23 [Radeon RX 6650 XT] vendor: XFX driver: amdgpu
v: kernel arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-3,HDMI-A-1 empty: DP-2 bus-ID: 07:00.0 chip-ID: 1002:73ef
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 6440x1920 s-dpi: 96 s-size: 1703x508mm (67.05x20.00")
s-diag: 1777mm (69.97")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,middle-c
model: XQ340 PRO res: 3440x1440 dpi: 110 size: 797x334mm (31.38x13.15")
diag: 869mm (34.2") modes: max: 3440x1440 min: 720x400
Monitor-2: DP-3 mapped: DisplayPort-2 pos: bottom-l model: Lenovo D27-30
serial: <filter> res: 1920x1080 dpi: 82 size: 597x336mm (23.5x13.23")
diag: 685mm (27") modes: max: 1920x1080 min: 720x400
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: top-right model: Asus VP228
serial: <filter> res: 1080x1920 hz: 60 dpi: 102
size: 268x476mm (10.55x18.74") diag: 546mm (21.5") modes: max: 1920x1080
min: 720x400
OpenGL: renderer: AMD Radeon RX 6650 XT (dimgrey_cavefish LLVM 14.0.6 DRM
3.47 5.19.13-1-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: speed: 16 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k5.19.13-1-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.58 running: yes
vendor: Gigabyte driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 4.55 TiB used: 700.12 GiB (15.0%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P2SSD8 size: 931.51 GiB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P2CR048
temp: 37.9 C scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST4000DM004-2U9104 size: 3.64 TiB
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / size: 915.53 GiB used: 126.39 GiB (13.8%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 36.2 C mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 366 Uptime: 7m wakeups: 0 Memory: 31.25 GiB used: 2.51 GiB
(8.0%) Init: systemd v: 251 default: graphical Compilers: gcc: 12.2.0
clang: 14.0.6 Packages: pm: pacman pkgs: 1374 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.22
[geo@desktop ~]$ cat /etc/resolv.conf
# Generated by NetworkManager
[geo@desktop ~]$ lspci -vv
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin ? routed to IRQ 25
Capabilities: <access denied>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 0
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Subsystem: Advanced Micro Devices, Inc. [AMD] Device 1453
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin ? routed to IRQ 27
IOMMU group: 1
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: [disabled] [32-bit]
Memory behind bridge: fcf00000-fcffffff [size=1M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Interrupt: pin ? routed to IRQ 28
IOMMU group: 2
Bus: primary=00, secondary=02, subordinate=04, sec-latency=0
I/O behind bridge: f000-ffff [size=4K] [16-bit]
Memory behind bridge: fcd00000-fcefffff [size=2M] [32-bit]
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 3
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 4
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort+ <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin ? routed to IRQ 29
IOMMU group: 5
Bus: primary=00, secondary=05, subordinate=07, sec-latency=0
I/O behind bridge: e000-efff [size=4K] [16-bit]
Memory behind bridge: fca00000-fccfffff [size=3M] [32-bit]
Prefetchable memory behind bridge: d0000000-e01fffff [size=258M] [32-bit]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort+ <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA+ VGA16+ MAbort- >Reset- FastB2B-
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 6
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 7
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 8
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
Interrupt: pin A routed to IRQ 31
IOMMU group: 9
Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
Memory behind bridge: [disabled] [32-bit]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 10
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 32
IOMMU group: 11
Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
Memory behind bridge: fc700000-fc9fffff [size=3M] [32-bit]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Subsystem: Gigabyte Technology Co., Ltd Device 5001
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
IOMMU group: 12
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
IOMMU group: 12
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 0
IOMMU group: 13
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 1
IOMMU group: 13
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 2
IOMMU group: 13
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 3
IOMMU group: 13
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 4
IOMMU group: 13
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 5
IOMMU group: 13
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 6
IOMMU group: 13
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 7
IOMMU group: 13
01:00.0 Non-Volatile memory controller: Micron/Crucial Technology P2 NVMe PCIe SSD (rev 01) (prog-if 02 [NVM Express])
Subsystem: Micron/Crucial Technology P2 NVMe PCIe SSD
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 42
NUMA node: 0
IOMMU group: 14
Region 0: Memory at fcf00000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
Kernel modules: nvme
02:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset USB 3.1 XHCI Controller (prog-if 30 [XHCI])
Subsystem: ASMedia Technology Inc. ASM1042A USB 3.0 Host Controller
Interrupt: pin A routed to IRQ 41
IOMMU group: 15
Region 0: Memory at fcea0000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
02:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset SATA Controller (prog-if 01 [AHCI 1.0])
Subsystem: ASMedia Technology Inc. ASM1062 Serial ATA Controller
Interrupt: pin B routed to IRQ 40
IOMMU group: 15
Region 5: Memory at fce80000 (32-bit, non-prefetchable) [size=128K]
Expansion ROM at fce00000 [disabled] [size=512K]
Kernel driver in use: ahci
02:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset Switch Upstream Port (prog-if 00 [Normal decode])
Subsystem: ASMedia Technology Inc. Device 0201
Interrupt: pin C routed to IRQ 34
IOMMU group: 15
Bus: primary=02, secondary=03, subordinate=04, sec-latency=0
Memory behind bridge: fcd00000-fcdfffff [size=1M] [32-bit]
03:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea (prog-if 00 [Normal decode])
Subsystem: ASMedia Technology Inc. Device 3308
Interrupt: pin A routed to IRQ 36
IOMMU group: 15
Bus: primary=03, secondary=04, subordinate=04, sec-latency=0
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 16)
Subsystem: Gigabyte Technology Co., Ltd Onboard Ethernet
Interrupt: pin A routed to IRQ 35
IOMMU group: 15
Region 0: I/O ports at f000 [size=256]
Region 2: Memory at fcd04000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at fcd00000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
05:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Upstream Port of PCI Express Switch (rev c1) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 38
IOMMU group: 16
Region 0: Memory at fcc00000 (32-bit, non-prefetchable) [size=16K]
Bus: primary=05, secondary=06, subordinate=07, sec-latency=0
Memory behind bridge: fca00000-fcbfffff [size=2M] [32-bit]
06:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Downstream Port of PCI Express Switch (prog-if 00 [Normal decode])
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Downstream Port of PCI Express Switch
Interrupt: pin A routed to IRQ 39
IOMMU group: 17
Bus: primary=06, secondary=07, subordinate=07, sec-latency=0
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 23 [Radeon RX 6650 XT] (rev c1) (prog-if 00 [VGA controller])
Subsystem: XFX Limited Device 6502
Interrupt: pin A routed to IRQ 77
IOMMU group: 18
Region 0: Memory at d0000000 (64-bit, prefetchable) [size=256M]
Region 2: Memory at e0000000 (64-bit, prefetchable) [size=2M]
Region 4: I/O ports at e000 [size=256]
Region 5: Memory at fca00000 (32-bit, non-prefetchable) [size=1M]
Expansion ROM at 000c0000 [disabled] [size=128K]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
07:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21/23 HDMI/DP Audio Controller
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21/23 HDMI/DP Audio Controller
Interrupt: pin B routed to IRQ 74
IOMMU group: 19
Region 0: Memory at fcb20000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
08:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
IOMMU group: 20
09:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
IOMMU group: 21
09:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Interrupt: pin A routed to IRQ 69
IOMMU group: 22
Region 2: Memory at fc800000 (32-bit, non-prefetchable) [size=1M]
Region 5: Memory at fc908000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: ccp
Kernel modules: ccp
09:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller (prog-if 30 [XHCI])
Subsystem: Gigabyte Technology Co., Ltd Device 5007
Interrupt: pin C routed to IRQ 52
IOMMU group: 23
Region 0: Memory at fc700000 (64-bit, non-prefetchable) [size=1M]
09:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
DeviceName: Realtek ALC1220
Subsystem: Gigabyte Technology Co., Ltd Device a184
Interrupt: pin D routed to IRQ 76
IOMMU group: 24
Region 0: Memory at fc900000 (32-bit, non-prefetchable) [size=32K]
[geo@desktop ~]$ lsmod
Module Size Used by
cfg80211 1089536 0
udp_diag 16384 0
tcp_diag 16384 0
inet_diag 24576 2 tcp_diag,udp_diag
snd_seq_dummy 16384 0
snd_hrtimer 16384 1
snd_seq 94208 7 snd_seq_dummy
snd_seq_device 16384 1 snd_seq
joydev 28672 0
mousedev 24576 0
hid_apple 24576 0
apple_mfi_fastcharge 20480 0
usbhid 73728 0
intel_rapl_msr 20480 0
intel_rapl_common 32768 1 intel_rapl_msr
snd_hda_codec_realtek 167936 1
edac_mce_amd 57344 0
snd_hda_codec_generic 98304 1 snd_hda_codec_realtek
ledtrig_audio 16384 1 snd_hda_codec_generic
snd_hda_codec_hdmi 86016 1
qrtr 57344 4
gigabyte_wmi 20480 0
wmi_bmof 16384 0
rfkill 32768 5 cfg80211
kvm_amd 172032 0
snd_hda_intel 61440 2
snd_intel_dspcfg 36864 1 snd_hda_intel
amdgpu 9379840 37
snd_intel_sdw_acpi 20480 1 snd_intel_dspcfg
kvm 1130496 1 kvm_amd
snd_hda_codec 188416 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_core 118784 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
gpu_sched 49152 1 amdgpu
irqbypass 16384 1 kvm
snd_hwdep 16384 1 snd_hda_codec
crct10dif_pclmul 16384 1
vfat 24576 1
r8169 102400 0
drm_ttm_helper 16384 1 amdgpu
crc32_pclmul 16384 0
snd_pcm 172032 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
fat 98304 1 vfat
ghash_clmulni_intel 16384 0
realtek 36864 1
ttm 94208 2 amdgpu,drm_ttm_helper
snd_timer 49152 3 snd_seq,snd_hrtimer,snd_pcm
aesni_intel 380928 0
drm_display_helper 180224 1 amdgpu
mdio_devres 16384 1 r8169
crypto_simd 16384 1 aesni_intel
snd 126976 16 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm
cec 81920 1 drm_display_helper
cryptd 28672 2 crypto_simd,ghash_clmulni_intel
libphy 172032 3 r8169,mdio_devres,realtek
tpm_crb 20480 0
sp5100_tco 20480 0
soundcore 16384 1 snd
rapl 16384 0
ccp 135168 1 kvm_amd
pcspkr 16384 0
k10temp 16384 0
i2c_piix4 36864 0
tpm_tis 16384 0
wmi 45056 2 gigabyte_wmi,wmi_bmof
tpm_tis_core 32768 1 tpm_tis
gpio_amdpt 20480 0
tpm 102400 3 tpm_tis,tpm_crb,tpm_tis_core
mac_hid 16384 0
acpi_cpufreq 32768 0
gpio_generic 20480 1 gpio_amdpt
rng_core 20480 2 ccp,tpm
uinput 20480 0
vboxnetflt 32768 0
vboxnetadp 28672 0
vboxdrv 544768 2 vboxnetadp,vboxnetflt
crypto_user 24576 0
fuse 176128 3
bpf_preload 24576 0
ip_tables 36864 0
x_tables 57344 1 ip_tables
ext4 1015808 2
crc32c_generic 16384 0
crc16 16384 1 ext4
mbcache 16384 1 ext4
jbd2 188416 1 ext4
nvme 61440 2
xhci_pci 20480 0
nvme_core 180224 3 nvme
crc32c_intel 24576 4
xhci_pci_renesas 24576 1 xhci_pci
