Hello,
I have a rather recent laptop, a Dell Latitude 9520. I had no sound in the beginning but this was due to a bug in sof-firmware. With a 5.15 kernel I now have a working audio output. You can see the relevant thread here.
However a recent update made my mic not working anymore. As I don’t use it on a weekly basis, I cannot precisely pinpoint the date but I think it was in the past couple of weeks.
What can I do to try and solve this issue?
Here is the output of inxi --admin --verbosity=7 --filter --width
Kernel: 5.16.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=ca42843c-d00c-4f59-a56e-6d24cb43a854 rw quiet splash apparmor=1
security=apparmor resume=UUID=85c8f578-bf51-4e7d-848d-feea30522ef7
udev.log_priority=3
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Convertible System: Dell product: Latitude 9520 v: N/A
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: Dell model: 0GVMP9 v: A01 serial: <superuser required> UEFI: Dell
v: 1.5.2 date: 06/11/2021
ID-1: BAT0 charge: 44.1 Wh (93.2%) condition: 47.3/47.8 Wh (98.8%)
volts: 8.5 min: 7.6 model: BYD DELL F68NR14 type: Li-poly serial: <filter>
status: Discharging
RAM: total: 15.36 GiB used: 3.3 GiB (21.5%)
RAM Report:
Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x88
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1379 high: 1523 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1170 2: 1332 3: 1513
4: 1401 5: 1367 6: 1394 7: 1338 8: 1523 bogomips: 28888
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep smx split_lock_detect ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 0c45:672d class-ID: 0e02
Display: wayland server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.16.0-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 84.07 GiB (17.6%)
model: PC SN530 NVMe WDC 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 21113012 temp: 28.9 C scheme: GPT
ID-1: / raw-size: 459.73 GiB size: 451.45 GiB (98.20%)
used: 84.07 GiB (18.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: ca42843c-d00c-4f59-a56e-6d24cb43a854
used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 5665-DDF2
ID-1: swap-1 type: partition size: 16.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 85c8f578-bf51-4e7d-848d-feea30522ef7
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: Lenovo Traditional USB Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 98mA chip-ID: 17ef:6099 class-ID: 0301
Device-2: 3-6:3 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 3-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 26.0 C mobo: N/A
Processes: 277 Uptime: 1h 56m wakeups: 81 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1648 pacman: 1643 lib: 355
flatpak: 0 snap: 5 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.11
Up, the issue remains as of today. Currently using kernel 5.17.
