Hey everyone!
I have a Lenovo ideapad 330, which from one day to the other decided not to output any HDMI signal. I’m using a normal HDMI connector, not USB-C. I’ve tested with a different monitor, different cable, and another laptop, the issue seems to be in my laptop. I’ve tried going back to previous kernel version, all drivers available in the hardware config section of settings, but nothing seems to work. The monitor also doesn’t show up in the settings. Google searches are getting flooded with optimus related things, I’m solely using the integrated UHD 620.
Any ideas on fixing this? Any help is appreciated.
Thanks a lot in advance!
System info:
Kernel: 5.16.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=0ef36afe-dcb4-4314-aac3-d8defcace511 ro quiet apparmor=1
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 81DE v: Lenovo ideapad 330-15IKB
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 330-15IKB
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: 8TCN58WW date: 06/18/2020
ID-1: BAT0 charge: 25.5 Wh (100.0%) condition: 25.5/35.0 Wh (72.9%)
volts: 8.5 min: 7.6 model: LGC L16L2PB3 type: Li-poly serial: <filter>
status: charging
ID-2: hidpp_battery_0 charge: 23% condition: N/A volts: 3.7 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: <filter> status: discharging
RAM: total: 7.67 GiB used: 3.83 GiB (49.9%)
RAM Report:
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 961 high: 1844 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 788 4: 800
5: 800 6: 800 7: 1060 8: 1844 bogomips: 28808
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: IMC Networks EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:6
chip-ID: 13d3:5a02 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 108 s-size: 451x254mm (17.76x10.00")
s-diag: 518mm (20.38")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15d5 built: 2015 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.8
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.16.18-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
vendor: Lenovo driver: r8168 v: 8.049.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:4
chip-ID: 0cf3:e500 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 238.47 GiB used: 213.57 GiB (89.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS256G3BTND-N210A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1P10 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 213.57 GiB (91.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 0ef36afe-dcb4-4314-aac3-d8defcace511
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 4726-5F2C
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Hub-2: 1-2:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-2.2:5 info: HUION 420 type: Mouse,HID driver: uclogic,usbhid
interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 256c:006e
class-ID: 0300
Device-2: 1-2.4:7 info: Razer USA BlackWidow Ultimate 2013
type: Keyboard,Mouse driver: razerkbd,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1532:011a class-ID: 0300
Device-3: 1-7:4 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e500
class-ID: e001
Device-4: 1-8:6 info: IMC Networks EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:5a02
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-4: 2-2:2 info: Genesys Logic hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0616 class-ID: 0900
System Temperatures: cpu: 39.0 C pch: 38.0 C mobo: N/A
Processes: 273 Uptime: 27m wakeups: 7 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1796 pacman: 1777 lib: 458
flatpak: 12 snap: 7 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.15
