Hello togehter,
I got a new Asus TUF laptop, which comes with a Ryzen 7 3750h CPU and a GTX1650 GPU. I’m unable to get an external monitor to work. (e. g. a working monitor or a TV)
Xrndr recognize the external hdmi device:
~ >>> xrandr
Screen 0: minimum 320 x 200, current 5760 x 2160, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 382mm x 215mm
1920x1080 120.00*+ 48.00
1680x1050 120.00
1280x1024 120.00
1440x900 120.00
1280x800 120.00
1280x720 120.00
1024x768 120.00
800x600 120.00
640x480 120.00
HDMI-1-0 connected
3840x2160 30.00 + 59.94 50.00 29.97 25.00 23.98 23.98
4096x2160 29.97 25.00 24.00 23.98
1920x1080 60.00 59.94 50.00 29.97 25.00 23.98
1280x1024 60.02
1280x960 60.00
1280x720 60.00 59.94 50.00
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93
My installed drivers:
> 0000:01:00.0 (0300:10de:1f91) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-prime 2020.11.30 false PCI
video-nvidia 2020.11.30 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:05:00.0 (0300:1002:15d8) Display controller ATI Technologies Inc:
In the meantime i tried to fix is with de workaround from this thread:
But sadly it not work for me.
Do you have any idea what I can do to fix this?
The NVIDIA driver currently cannot be used as an output sink when the output source driver is xf86-video-amdgpu.
This is probably why you cannot get the external monitor to work. I’m not sure how the issue got resolved in the other, thread, since it technically shouldn’t be possible; maybe the README is out of date? Anyways, there are two things you can do:
I.
Install optimus-manager-git from AUR, and switch to the “nvidia” mode. I’m pretty sure this should reliably work no matter intel+nvidia or amd+nvidia configuration. Please refer to this guide on how to install optimus-manager. Please ignore the
So if you have AMD-Nvidia, stop reading futher as the guide below is only for Intel-Nvidia and you don’t need any of this.
part. And in the first step, run pamac build optimus-manager-git instead of what’s written in the guide, you can safely ignore the second step as well. If you want a tray applet to control which GPU is active, install optimus-manager-qt: pamac build optimus-manager-qt-git.
II.
Change the Xorg driver of your AMD GPU to “modesetting”. I’m not 100% sure, but it’s worth a try in my opinion.
hmm I don´t know if the repo from the other thread is outdated… the last change was for 10 months…?
Okay maybe I try your idea with the optimus-manager.
Do I have to switch my graphic driver from video-nvidia to video-hybrid-amd-nvidia-prime before I try your suggestion?
HI, Specter 456,
If sound is concerned …
only one idea … could be not question of driver but change swichting HDMI way-out instead speackers way …
'Left click at Sound volume of Taskbar - Change HDMI/display instead Digital/Output
Maybe ??
disable xorg graphic configurations (look at the link to the Guide)
install gdm prime (look at the link to the Guide)
enable gdm systemctl… (look at the link to the Guide)
set Wayland to false (look at the link to the Guide)
control if the systemctl service is running (look at the link to the Guide)
=> systemctl status optimus-manager.service
enable optimus-manager-qt as autostart app
=> So at startup there is the amd gpu choosen.
=> If I want to use a extern monitor or if I need the power of the nvidia gpu I switch via the optimus-manager-qt to the nvidia gpu (after the change to nvidia there is the hybrid icon active. But I checked with << nvidia-smi if the nvidia gpu is active, and thats the case.)
>>> nvidia-smi
Tue Jan 5 09:36:16 2021
| NVIDIA-SMI 455.45.01 Driver Version: 455.45.01 CUDA Version: 11.1 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 GeForce GTX 1650 Off | 00000000:01:00.0 Off | N/A |
| N/A 44C P8 1W / N/A | 221MiB / 3911MiB | 5% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 8902 G /usr/lib/Xorg 101MiB |
| 0 N/A N/A 8978 G /usr/bin/gnome-shell 24MiB |
| 0 N/A N/A 11353 G ...AAAAAAAA== --shared-files 92MiB |
