After an automatic update yesterday, my Manjaro Gnome no longer shows the GRUB menu and when it finishes loading it only has a black screen.
Accessing a terminal I was able to see the Xorg.0.log log.
Xorg LOGS
Can anyone give me a hint how to solve this?
Thanks
Is there in your logs
And you did not follow the instructions on the wiki announcement
Nvidia 495xx driver series drops Keppler support.
With the new 495xx driver series a lot of Wayland adjustments got added. Also Nvidia decided to remove Keppler support . Therefore you may want to switch drivers to 470xx series, which still supports those graphic cards:
sudo mhwd -r pci video-nvidia
sudo mhwd -i pci video-nvidia-470xx
hence you installed/updated video-nvidia aka 495 as per your logs
Since you can access logs, it means you can access TTY, so do the drivers thing from the quoted wiki.
anon89812132:
Sorry for my failure not to follow the wiki
Thank you very much for the guidance, it worked
system
Closed
6 December 2021 02:52
4
